RTEMS 6.1-rc1
Header file of SRAM HAL module. More...
#include "stm32h7xx_ll_fmc.h"
struct | SRAM_HandleTypeDef |
SRAM handle Structure definition. More... | |
#define | __HAL_SRAM_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SRAM_STATE_RESET) |
Reset SRAM handle state. More... | |
Enumerations | |
enum | HAL_SRAM_StateTypeDef { HAL_SRAM_STATE_RESET = 0x00U , HAL_SRAM_STATE_READY = 0x01U , HAL_SRAM_STATE_BUSY = 0x02U , HAL_SRAM_STATE_ERROR = 0x03U , HAL_SRAM_STATE_PROTECTED = 0x04U } |
HAL SRAM State structures definition. More... | |
HAL_StatusTypeDef | HAL_SRAM_Init (SRAM_HandleTypeDef *hsram, FMC_NORSRAM_TimingTypeDef *Timing, FMC_NORSRAM_TimingTypeDef *ExtTiming) |
HAL_StatusTypeDef | HAL_SRAM_DeInit (SRAM_HandleTypeDef *hsram) |
void | HAL_SRAM_MspInit (SRAM_HandleTypeDef *hsram) |
void | HAL_SRAM_MspDeInit (SRAM_HandleTypeDef *hsram) |
HAL_StatusTypeDef | HAL_SRAM_Read_8b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint8_t *pDstBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Write_8b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint8_t *pSrcBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Read_16b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint16_t *pDstBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Write_16b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint16_t *pSrcBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Read_32b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Write_32b (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Read_DMA (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize) |
HAL_StatusTypeDef | HAL_SRAM_Write_DMA (SRAM_HandleTypeDef *hsram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize) |
void | HAL_SRAM_DMA_XferCpltCallback (MDMA_HandleTypeDef *hmdma) |
void | HAL_SRAM_DMA_XferErrorCallback (MDMA_HandleTypeDef *hmdma) |
HAL_StatusTypeDef | HAL_SRAM_WriteOperation_Enable (SRAM_HandleTypeDef *hsram) |
HAL_StatusTypeDef | HAL_SRAM_WriteOperation_Disable (SRAM_HandleTypeDef *hsram) |
HAL_SRAM_StateTypeDef | HAL_SRAM_GetState (SRAM_HandleTypeDef *hsram) |
