RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions
stm32h7xx_hal_opamp.h File Reference
Header file of OPAMP HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_opamp_ex.h"
struct  OPAMP_InitTypeDef
 OPAMP Init structure definition
More...
struct  OPAMP_HandleTypeDef
 OPAMP Handle Structure definition. More...
#define OPAMP_STANDALONE_MODE   0x00000000U
#define OPAMP_PGA_MODE   OPAMP_CSR_VMSEL_1
#define OPAMP_FOLLOWER_MODE   (OPAMP_CSR_VMSEL_1 | OPAMP_CSR_VMSEL_0)
#define OPAMP_NONINVERTINGINPUT_IO0   0x00000000U
#define OPAMP_NONINVERTINGINPUT_DAC_CH   OPAMP_CSR_VPSEL_0
#define OPAMP_INVERTINGINPUT_IO0   0x00000000U
#define OPAMP_INVERTINGINPUT_IO1   OPAMP_CSR_VMSEL_0
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_NO   0x00000000U
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0   OPAMP_CSR_PGGAIN_2
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS   OPAMP_CSR_PGGAIN_3
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS   (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3)
#define OPAMP_PGA_GAIN_2_OR_MINUS_1   0x00000000U
#define OPAMP_PGA_GAIN_4_OR_MINUS_3   OPAMP_CSR_PGGAIN_0
#define OPAMP_PGA_GAIN_8_OR_MINUS_7   OPAMP_CSR_PGGAIN_1
#define OPAMP_PGA_GAIN_16_OR_MINUS_15   (OPAMP_CSR_PGGAIN_0 | OPAMP_CSR_PGGAIN_1)
#define OPAMP_POWERMODE_NORMAL   0x00000000U
#define OPAMP_POWERMODE_HIGHSPEED   OPAMP_CSR_OPAHSM
#define OPAMP_VREF_3VDDA   0x00000000U
#define OPAMP_VREF_10VDDA   OPAMP_CSR_CALSEL_0
#define OPAMP_VREF_50VDDA   OPAMP_CSR_CALSEL_1
#define OPAMP_VREF_90VDDA   OPAMP_CSR_CALSEL
#define OPAMP_TRIMMING_FACTORY   0x00000000U
#define OPAMP_TRIMMING_USER   OPAMP_CSR_USERTRIM
#define OPAMP_FACTORYTRIMMING_DUMMY   0xFFFFFFFFU
#define OPAMP_FACTORYTRIMMING_N   0x00000000U
#define OPAMP_FACTORYTRIMMING_P   0x00000001U
#define OPAMP_INPUT_NONINVERTING   (8U)
#define OPAMP_TRIMMING_DELAY   (2U)
#define __HAL_OPAMP_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_OPAMP_STATE_RESET)
 Reset OPAMP handle state. More...
#define IS_OPAMP_FUNCTIONAL_NORMALMODE(INPUT)
#define IS_OPAMP_INVERTING_INPUT_STANDALONE(INPUT)
#define IS_OPAMP_NONINVERTING_INPUT(INPUT)
#define IS_OPAMP_PGACONNECT(CONNECT)
#define IS_OPAMP_PGA_GAIN(GAIN)
#define IS_OPAMP_VREF(VREF)
#define IS_OPAMP_POWERMODE(TRIMMING)
#define IS_OPAMP_TRIMMING(TRIMMING)
#define IS_OPAMP_TRIMMINGVALUE(TRIMMINGVALUE)   ((TRIMMINGVALUE) <= 0x1FU)
#define IS_OPAMP_FACTORYTRIMMING(TRIMMING)
typedef uint32_t HAL_OPAMP_TrimmingValueTypeDef
 HAl_OPAMP_TrimmingValueTypeDef definition.
enum  HAL_OPAMP_StateTypeDef {
  HAL_OPAMP_STATE_RESET = 0x00000000U , HAL_OPAMP_STATE_READY = 0x00000001U , HAL_OPAMP_STATE_CALIBBUSY = 0x00000002U , HAL_OPAMP_STATE_BUSY = 0x00000004U ,
  HAL_OPAMP_STATE_BUSYLOCKED = 0x00000005U
 HAL State structures definition
More...
HAL_StatusTypeDef HAL_OPAMP_Init (OPAMP_HandleTypeDef *hopamp)
HAL_StatusTypeDef HAL_OPAMP_DeInit (OPAMP_HandleTypeDef *hopamp)
void HAL_OPAMP_MspInit (OPAMP_HandleTypeDef *hopamp)
void HAL_OPAMP_MspDeInit (OPAMP_HandleTypeDef *hopamp)
HAL_StatusTypeDef HAL_OPAMP_Start (OPAMP_HandleTypeDef *hopamp)
HAL_StatusTypeDef HAL_OPAMP_Stop (OPAMP_HandleTypeDef *hopamp)
HAL_StatusTypeDef HAL_OPAMP_SelfCalibrate (OPAMP_HandleTypeDef *hopamp)
HAL_StatusTypeDef HAL_OPAMP_Lock (OPAMP_HandleTypeDef *hopamp)
HAL_OPAMP_TrimmingValueTypeDef HAL_OPAMP_GetTrimOffset (OPAMP_HandleTypeDef *hopamp, uint32_t trimmingoffset)
HAL_OPAMP_StateTypeDef HAL_OPAMP_GetState (OPAMP_HandleTypeDef *hopamp)
Author
MCD Application Team
Attention
