RTEMS 6.1-rc1
#define | OPAMP_PGA_CONNECT_INVERTINGINPUT_NO 0x00000000U |
#define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0 OPAMP_CSR_PGGAIN_2 |
#define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS OPAMP_CSR_PGGAIN_3 |
#define | OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3) |
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0 OPAMP_CSR_PGGAIN_2 |
In PGA mode, the inverting input is connected to VINM0
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_BIAS OPAMP_CSR_PGGAIN_3 |
In PGA mode, the inverting input is connected to VINM0 or bias
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_IO0_IO1_BIAS (OPAMP_CSR_PGGAIN_2 | OPAMP_CSR_PGGAIN_3) |
In PGA mode, the inverting input is connected to VINM0 or bias , VINM1 connected for filtering
#define OPAMP_PGA_CONNECT_INVERTINGINPUT_NO 0x00000000U |
In PGA mode, the inverting input is not connected
