RTEMS 6.1-rc1
SMSC - LAN9218i. More...
#include <bsp.h>
struct | smsc9218i_registers |
#define | SMSC9218I_BIT_POS(pos) |
#define | SMSC9218I_FLAG(pos) (1U << SMSC9218I_BIT_POS(pos)) |
#define | SMSC9218I_FIELD_8(val, pos) (((val) & 0xff) << SMSC9218I_BIT_POS(pos)) |
#define | SMSC9218I_GET_FIELD_8(reg, pos) (((reg) >> SMSC9218I_BIT_POS(pos)) & 0xff) |
#define | SMSC9218I_FIELD_16(val, pos) |
#define | SMSC9218I_GET_FIELD_16(reg, pos) |
#define | SMSC9218I_SWAP(val) |
Receive Status | |
#define | SMSC9218I_RX_STS_FILTER_FAIL SMSC9218I_FLAG(30) |
#define | SMSC9218I_RX_STS_GET_LENGTH(reg) (SMSC9218I_GET_FIELD_16(reg, 16) & 0x3fff) |
#define | SMSC9218I_RX_STS_ERROR SMSC9218I_FLAG(15) |
#define | SMSC9218I_RX_STS_BROADCAST SMSC9218I_FLAG(13) |
#define | SMSC9218I_RX_STS_ERROR_LENGTH SMSC9218I_FLAG(12) |
#define | SMSC9218I_RX_STS_ERROR_RUNT_FRAME SMSC9218I_FLAG(11) |
#define | SMSC9218I_RX_STS_MULTICAST SMSC9218I_FLAG(10) |
#define | SMSC9218I_RX_STS_ERROR_TOO_LONG SMSC9218I_FLAG(7) |
#define | SMSC9218I_RX_STS_ERROR_COLLISION SMSC9218I_FLAG(6) |
#define | SMSC9218I_RX_STS_TYPE SMSC9218I_FLAG(5) |
#define | SMSC9218I_RX_STS_WATCHDOG SMSC9218I_FLAG(4) |
#define | SMSC9218I_RX_STS_ERROR_MII SMSC9218I_FLAG(3) |
#define | SMSC9218I_RX_STS_DRIBBLING_BIT SMSC9218I_FLAG(2) |
#define | SMSC9218I_RX_STS_ERROR_CRC SMSC9218I_FLAG(1) |
Transmit Status | |
#define | SMSC9218I_TX_STS_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16) |
#define | SMSC9218I_TX_STS_ERROR SMSC9218I_FLAG(15) |
#define | SMSC9218I_TX_STS_ERROR_LOSS_OF_CARRIER SMSC9218I_FLAG(11) |
#define | SMSC9218I_TX_STS_ERROR_NO_CARRIER SMSC9218I_FLAG(10) |
#define | SMSC9218I_TX_STS_ERROR_LATE_COLLISION SMSC9218I_FLAG(9) |
#define | SMSC9218I_TX_STS_ERROR_EXCESSIVE_COLLISIONS SMSC9218I_FLAG(8) |
#define | SMSC9218I_TX_STS_ERROR_EXCESSIVE_DEFERRAL SMSC9218I_FLAG(2) |
#define | SMSC9218I_TX_STS_ERROR_DEFERRED SMSC9218I_FLAG(0) |
Transmit Command A | |
#define | SMSC9218I_TX_A_IOC SMSC9218I_FLAG(31) |
#define | SMSC9218I_TX_A_END_ALIGN_4 0 |
#define | SMSC9218I_TX_A_END_ALIGN_16 SMSC9218I_FLAG(24) |
#define | SMSC9218I_TX_A_END_ALIGN_32 SMSC9218I_FLAG(25) |
#define | SMSC9218I_TX_A_DOFF(val) SMSC9218I_FIELD_8(val, 16) |
#define | SMSC9218I_TX_A_FIRST SMSC9218I_FLAG(13) |
#define | SMSC9218I_TX_A_LAST SMSC9218I_FLAG(12) |
#define | SMSC9218I_TX_A_FRAGMENT_LENGTH(val) SMSC9218I_FIELD_16(val, 0) |
Transmit Command B | |
#define | SMSC9218I_TX_B_TAG(val) SMSC9218I_FIELD_16(val, 16) |
#define | SMSC9218I_TX_B_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16) |
#define | SMSC9218I_TX_B_DISABLE_CRC SMSC9218I_FLAG(13) |
#define | SMSC9218I_TX_B_DISABLE_PAD SMSC9218I_FLAG(12) |
#define | SMSC9218I_TX_B_FRAME_LENGTH(val) SMSC9218I_FIELD_16(val, 0) |
Chip ID and Revision | |
#define | SMSC9218I_ID_REV_GET_ID(reg) SMSC9218I_GET_FIELD_16(reg, 16) |
#define | SMSC9218I_ID_REV_GET_REV(reg) SMSC9218I_GET_FIELD_16(reg, 0) |
#define | SMSC9218I_ID_REV_ID_CHIP_118 0x0118U |
#define | SMSC9218I_ID_REV_ID_CHIP_218 0x118aU |
Interrupt Configuration | |
#define | SMSC9218I_IRQ_CFG_INT_DEAS(val) SMSC9218I_FIELD_8(val, 24) |
#define | SMSC9218I_IRQ_CFG_GET_INT_DEAS(reg) SMSC9218I_GET_FIELD_8(reg, 24) |
#define | SMSC9218I_IRQ_CFG_INT_DEAS_CLR SMSC9218I_FLAG(14) |
#define | SMSC9218I_IRQ_CFG_INT_DEAS_STS SMSC9218I_FLAG(13) |
#define | SMSC9218I_IRQ_CFG_IRQ_INT SMSC9218I_FLAG(12) |
#define | SMSC9218I_IRQ_CFG_IRQ_EN SMSC9218I_FLAG(8) |
#define | SMSC9218I_IRQ_CFG_IRQ_POL SMSC9218I_FLAG(4) |
#define | SMSC9218I_IRQ_CFG_IRQ_TYPE SMSC9218I_FLAG(0) |
Interrupt Enable and Status | |
#define | SMSC9218I_INT_SW SMSC9218I_FLAG(31) |
#define | SMSC9218I_INT_TXSTOP SMSC9218I_FLAG(25) |
#define | SMSC9218I_INT_RXSTOP SMSC9218I_FLAG(24) |
#define | SMSC9218I_INT_RXDFH SMSC9218I_FLAG(23) |
#define | SMSC9218I_INT_TIOC SMSC9218I_FLAG(21) |
#define | SMSC9218I_INT_RXD SMSC9218I_FLAG(20) |
#define | SMSC9218I_INT_GPT SMSC9218I_FLAG(19) |
#define | SMSC9218I_INT_PHY SMSC9218I_FLAG(18) |
#define | SMSC9218I_INT_PME SMSC9218I_FLAG(17) |
#define | SMSC9218I_INT_TXSO SMSC9218I_FLAG(16) |
#define | SMSC9218I_INT_RWT SMSC9218I_FLAG(15) |
#define | SMSC9218I_INT_RXE SMSC9218I_FLAG(14) |
#define | SMSC9218I_INT_TXE SMSC9218I_FLAG(13) |
#define | SMSC9218I_INT_TDFO SMSC9218I_FLAG(10) |
#define | SMSC9218I_INT_TDFA SMSC9218I_FLAG(9) |
#define | SMSC9218I_INT_TSFF SMSC9218I_FLAG(8) |
#define | SMSC9218I_INT_TSFL SMSC9218I_FLAG(7) |
#define | SMSC9218I_INT_RSFF SMSC9218I_FLAG(4) |
#define | SMSC9218I_INT_RSFL SMSC9218I_FLAG(3) |
#define | SMSC9218I_INT_GPIO2 SMSC9218I_FLAG(2) |
#define | SMSC9218I_INT_GPIO1 SMSC9218I_FLAG(1) |
#define | SMSC9218I_INT_GPIO0 SMSC9218I_FLAG(0) |
Byte Order Testing | |
#define | SMSC9218I_BYTE_TEST SMSC9218I_SWAP(0x87654321U) |
FIFO Level Interrupts | |
#define | SMSC9218I_FIFO_INT_TDAL(val) SMSC9218I_FIELD_8(val, 24) |
#define | SMSC9218I_FIFO_INT_GET_TDAL(reg) SMSC9218I_GET_FIELD_8(reg, 24) |
#define | SMSC9218I_FIFO_INT_TSL(val) SMSC9218I_FIELD_8(val, 16) |
#define | SMSC9218I_FIFO_INT_GET_TSL(reg) SMSC9218I_GET_FIELD_8(reg, 16) |
#define | SMSC9218I_FIFO_INT_RSL(val) SMSC9218I_FIELD_8(val, 0) |
#define | SMSC9218I_FIFO_INT_GET_RSL(reg) SMSC9218I_GET_FIELD_8(reg, 0) |
Receive Configuration | |
#define | SMSC9218I_RX_CFG_END_ALIGN_4 0 |
#define | SMSC9218I_RX_CFG_END_ALIGN_16 SMSC9218I_FLAG(30) |
#define | SMSC9218I_RX_CFG_END_ALIGN_32 SMSC9218I_FLAG(31) |
#define | SMSC9218I_RX_CFG_DMA_CNT(val) SMSC9218I_FIELD_8(val, 24) |
#define | SMSC9218I_RX_CFG_GET_DMA_CNT(reg) SMSC9218I_GET_FIELD_8(reg, 24) |
#define | SMSC9218I_RX_CFG_DUMP SMSC9218I_FLAG(15) |
#define | SMSC9218I_RX_CFG_DOFF(val) SMSC9218I_FIELD_8(val, 8) |
#define | SMSC9218I_RX_CFG_GET_DOFF(reg) SMSC9218I_GET_FIELD_8(reg, 8) |
Transmit Configuration | |
#define | SMSC9218I_TX_CFG_SDUMP SMSC9218I_FLAG(15) |
#define | SMSC9218I_TX_CFG_DDUMP SMSC9218I_FLAG(14) |
#define | SMSC9218I_TX_CFG_SAO SMSC9218I_FLAG(2) |
#define | SMSC9218I_TX_CFG_ON SMSC9218I_FLAG(1) |
#define | SMSC9218I_TX_CFG_STOP SMSC9218I_FLAG(0) |
Hardware Configuration | |
#define | SMSC9218I_HW_CFG_LED_3 SMSC9218I_FLAG(30) |
#define | SMSC9218I_HW_CFG_LED_2 SMSC9218I_FLAG(29) |
#define | SMSC9218I_HW_CFG_LED_1 SMSC9218I_FLAG(28) |
#define | SMSC9218I_HW_CFG_AMDIX SMSC9218I_FLAG(24) |
#define | SMSC9218I_HW_CFG_MBO SMSC9218I_FLAG(20) |
#define | SMSC9218I_HW_CFG_TX_FIF_SZ(val) SMSC9218I_FIELD_8(val, 16) |
#define | SMSC9218I_HW_CFG_GET_TX_FIF_SZ(reg) SMSC9218I_GET_FIELD_8(reg, 16) |
#define | SMSC9218I_HW_CFG_BITMD_32 SMSC9218I_FLAG(2) |
#define | SMSC9218I_HW_CFG_SRST_TO SMSC9218I_FLAG(1) |
#define | SMSC9218I_HW_CFG_SRST SMSC9218I_FLAG(0) |
Receive Datapath Control | |
#define | SMSC9218I_RX_DP_CTRL_FFWD SMSC9218I_FLAG(31) |
Receive FIFO Information | |
#define | SMSC9218I_RX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16) |
#define | SMSC9218I_RX_FIFO_INF_GET_DUSED(reg) SMSC9218I_GET_FIELD_16(reg, 0) |
Transmit FIFO Information | |
#define | SMSC9218I_TX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16) |
#define | SMSC9218I_TX_FIFO_INF_GET_FREE(reg) SMSC9218I_GET_FIELD_16(reg, 0) |
Power Management Control | |
#define | SMSC9218I_PMT_CTRL_PM_MODE_D0 0 |
#define | SMSC9218I_PMT_CTRL_PM_MODE_D1 SMSC9218I_FLAG(12) |
#define | SMSC9218I_PMT_CTRL_PM_MODE_D2 SMSC9218I_FLAG(13) |
#define | SMSC9218I_PMT_CTRL_PHY_RST SMSC9218I_FLAG(10) |
#define | SMSC9218I_PMT_CTRL_WOL_EN SMSC9218I_FLAG(9) |
#define | SMSC9218I_PMT_CTRL_ED_EN SMSC9218I_FLAG(8) |
#define | SMSC9218I_PMT_CTRL_PME_TYPE_PUPU SMSC9218I_FLAG(6) |
#define | SMSC9218I_PMT_CTRL_WUPS_NO 0 |
#define | SMSC9218I_PMT_CTRL_WUPS_ENERGY SMSC9218I_FLAG(4) |
#define | SMSC9218I_PMT_CTRL_WUPS_MAGIC SMSC9218I_FLAG(5) |
#define | SMSC9218I_PMT_CTRL_PME_IND SMSC9218I_FLAG(3) |
#define | SMSC9218I_PMT_CTRL_PME_POL SMSC9218I_FLAG(2) |
#define | SMSC9218I_PMT_CTRL_PME_EN SMSC9218I_FLAG(1) |
#define | SMSC9218I_PMT_CTRL_READY SMSC9218I_FLAG(0) |
General Purpose IO Configuration | |
#define | SMSC9218I_GPIO_CFG_LED3 SMSC9218I_FLAG(30) |
#define | SMSC9218I_GPIO_CFG_LED2 SMSC9218I_FLAG(29) |
#define | SMSC9218I_GPIO_CFG_LED1 SMSC9218I_FLAG(28) |
#define | SMSC9218I_GPIO_CFG_GPIO2_INT_POL SMSC9218I_FLAG(26) |
#define | SMSC9218I_GPIO_CFG_GPIO1_INT_POL SMSC9218I_FLAG(25) |
#define | SMSC9218I_GPIO_CFG_GPIO0_INT_POL SMSC9218I_FLAG(24) |
#define | SMSC9218I_GPIO_CFG_GPIOBUF2 SMSC9218I_FLAG(18) |
#define | SMSC9218I_GPIO_CFG_GPIOBUF1 SMSC9218I_FLAG(17) |
#define | SMSC9218I_GPIO_CFG_GPIOBUF0 SMSC9218I_FLAG(16) |
#define | SMSC9218I_GPIO_CFG_GPIODIR2 SMSC9218I_FLAG(10) |
#define | SMSC9218I_GPIO_CFG_GPIODIR1 SMSC9218I_FLAG(9) |
#define | SMSC9218I_GPIO_CFG_GPIODIR0 SMSC9218I_FLAG(8) |
#define | SMSC9218I_GPIO_CFG_GPO4 SMSC9218I_FLAG(4) |
#define | SMSC9218I_GPIO_CFG_GPO3 SMSC9218I_FLAG(3) |
#define | SMSC9218I_GPIO_CFG_GPIO0 SMSC9218I_FLAG(0) |
#define | SMSC9218I_GPIO_CFG_GPIO2 SMSC9218I_FLAG(2) |
#define | SMSC9218I_GPIO_CFG_GPIO1 SMSC9218I_FLAG(1) |
General Purpose Timer Configuration | |
#define | SMSC9218I_GPT_CFG_TIMER_EN SMSC9218I_FLAG(29) |
#define | SMSC9218I_GPT_CFG_LOAD(val) SMSC9218I_FIELD_16(val, 0) |
#define | SMSC9218I_GPT_CFG_GET_LOAD(reg) SMSC9218I_GET_FIELD_16(reg, 0) |
General Purpose Timer Count | |
#define | SMSC9218I_GPT_CNT_GET_CNT SMSC9218I_GET_FIELD_16(reg, 0) |
Word Swap | |
#define | SMSC9218I_ENDIAN_BIG 0xffffffffU |
Free Run Counter | |
#define | SMSC9218I_FREE_RUN_GET(reg) SMSC9218I_SWAP(reg) |
Receiver Dropped Frames Counter | |
#define | SMSC9218I_RX_DROP_GET(reg) SMSC9218I_SWAP(reg) |
EEPROM Command Register | |
#define | SMSC9218I_E2P_CMD_EPC_BUSY SMSC9218I_FLAG(31) |
MAC Control and Status Synchronizer Command | |
#define | SMSC9218I_MAC_CSR_CMD_BUSY SMSC9218I_FLAG(31) |
#define | SMSC9218I_MAC_CSR_CMD_READ SMSC9218I_FLAG(30) |
#define | SMSC9218I_MAC_CSR_CMD_ADDR(val) SMSC9218I_FIELD_8(val, 0) |
#define | SMSC9218I_MAC_CSR_CMD_GET_ADDR(reg) SMSC9218I_GET_FIELD_8(reg, 0) |
MAC Control Register | |
#define | SMSC9218I_MAC_CR 0x00000001U |
#define | SMSC9218I_MAC_CR_RXALL 0x80000000U |
#define | SMSC9218I_MAC_CR_HBDIS 0x10000000U |
#define | SMSC9218I_MAC_CR_RCVOWN 0x00800000U |
#define | SMSC9218I_MAC_CR_LOOPBK 0x00200000U |
#define | SMSC9218I_MAC_CR_FDPX 0x00100000U |
#define | SMSC9218I_MAC_CR_MCPAS 0x00080000U |
#define | SMSC9218I_MAC_CR_PRMS 0x00040000U |
#define | SMSC9218I_MAC_CR_INVFILT 0x00020000U |
#define | SMSC9218I_MAC_CR_PASSBAD 0x00010000U |
#define | SMSC9218I_MAC_CR_HFILT 0x00008000U |
#define | SMSC9218I_MAC_CR_HPFILT 0x00002000U |
#define | SMSC9218I_MAC_CR_LCOLL 0x00001000U |
#define | SMSC9218I_MAC_CR_BCAST 0x00000800U |
#define | SMSC9218I_MAC_CR_DISRTY 0x00000400U |
#define | SMSC9218I_MAC_CR_PADSTR 0x00000100U |
#define | SMSC9218I_MAC_CR_BOLMT_MASK 0x000000c0U |
#define | SMSC9218I_MAC_CR_BOLMT_10 0x00000000U |
#define | SMSC9218I_MAC_CR_BOLMT_8 0x00000040U |
#define | SMSC9218I_MAC_CR_BOLMT_4 0x00000080U |
#define | SMSC9218I_MAC_CR_BOLMT_1 0x000000c0U |
#define | SMSC9218I_MAC_CR_DFCHK 0x00000020U |
#define | SMSC9218I_MAC_CR_TXEN 0x00000008U |
#define | SMSC9218I_MAC_CR_RXEN 0x00000004U |
MAC Address High | |
#define | SMSC9218I_MAC_ADDRH 0x00000002U |
#define | SMSC9218I_MAC_ADDRH_MASK 0x0000ffffU |
MAC Address Low | |
#define | SMSC9218I_MAC_ADDRL 0x00000003U |
#define | SMSC9218I_MAC_ADDRL_MASK 0xffffffffU |
Multicast Hash Table High | |
#define | SMSC9218I_MAC_HASHH 0x00000004U |
#define | SMSC9218I_MAC_HASHH_MASK 0xffffffffU |
Multicast Hash Table Low | |
#define | SMSC9218I_MAC_HASHL 0x00000005U |
#define | SMSC9218I_MAC_HASHL_MASK 0xffffffffU |
MII Access | |
#define | SMSC9218I_MAC_MII_ACC 0x00000006U |
#define | SMSC9218I_MAC_MII_ACC_PHY_DEFAULT (1U << 11) |
#define | SMSC9218I_MAC_MII_ACC_WRITE (1U << 1) |
#define | SMSC9218I_MAC_MII_ACC_BUSY (1U << 0) |
#define | SMSC9218I_MAC_MII_ACC_ADDR(addr) ((addr) << 6) |
MII Data | |
#define | SMSC9218I_MAC_MII_DATA 0x00000007U |
Flow Control | |
#define | SMSC9218I_MAC_FLOW 0x00000008U |
#define | SMSC9218I_MAC_FLOW_FCPT_MASK 0xffff0000U |
#define | SMSC9218I_MAC_FLOW_FCPASS 0x00000004U |
#define | SMSC9218I_MAC_FLOW_FCEN 0x00000002U |
#define | SMSC9218I_MAC_FLOW_FCBSY 0x00000001U |
VLAN1 Tag | |
#define | SMSC9218I_MAC_VLAN1 0x00000009U |
VLAN2 Tag | |
#define | SMSC9218I_MAC_VLAN2 0x0000000aU |
Wake-up Frame Filter | |
#define | SMSC9218I_MAC_WUFF 0x0000000bU |
Wake-up Control and Status | |
#define | SMSC9218I_MAC_WUCSR 0x0000000cU |
#define | SMSC9218I_MAC_WUCSR_GUE 0x00000200U |
#define | SMSC9218I_MAC_WUCSR_WUFR 0x00000040U |
#define | SMSC9218I_MAC_WUCSR_MPR 0x00000020U |
#define | SMSC9218I_MAC_WUCSR_WUEN 0x00000004U |
#define | SMSC9218I_MAC_WUCSR_MPEN 0x00000002U |
PHY Identifier 1 | |
#define | SMSC9218I_PHY_ID1_LAN9118 0x7 |
PHY Identifier 2 | |
#define | SMSC9218I_PHY_ID2_LAN9218 0xc0c3 |
Mode Control and Status | |
#define | SMSC9218I_PHY_MCSR 0x00000011U |
#define | SMSC9218I_PHY_MCSR_EDPWRDOWN 0x00002000U |
#define | SMSC9218I_PHY_MCSR_ENERGYON 0x00000002U |
Special Modes | |
#define | SMSC9218I_PHY_SPMODES 0x00000012U |
Special Control and Status Indications | |
#define | SMSC9218I_PHY_CSIR 0x0000001bU |
#define | SMSC9218I_PHY_CSIR_SQEOFF 0x00000800U |
#define | SMSC9218I_PHY_CSIR_FEFIEN 0x00000020U |
#define | SMSC9218I_PHY_CSIR_XPOL 0x00000010U |
Interrupt Source Flag | |
#define | SMSC9218I_PHY_ISR 0x0000001dU |
#define | SMSC9218I_PHY_ISR_INT7 0x00000080U |
#define | SMSC9218I_PHY_ISR_INT6 0x00000040U |
#define | SMSC9218I_PHY_ISR_INT5 0x00000020U |
#define | SMSC9218I_PHY_ISR_INT4 0x00000010U |
#define | SMSC9218I_PHY_ISR_INT3 0x00000008U |
#define | SMSC9218I_PHY_ISR_INT2 0x00000004U |
#define | SMSC9218I_PHY_ISR_INT1 0x00000002U |
Interrupt Mask | |
#define | SMSC9218I_PHY_IMR 0x0000001eU |
#define | SMSC9218I_PHY_IMR_INT7 0x00000080U |
#define | SMSC9218I_PHY_IMR_INT6 0x00000040U |
#define | SMSC9218I_PHY_IMR_INT5 0x00000020U |
#define | SMSC9218I_PHY_IMR_INT4 0x00000010U |
#define | SMSC9218I_PHY_IMR_INT3 0x00000008U |
#define | SMSC9218I_PHY_IMR_INT2 0x00000004U |
#define | SMSC9218I_PHY_IMR_INT1 0x00000002U |
PHY Special Control and Status | |
#define | SMSC9218I_PHY_PHYSCSR 0x0000001fU |
#define | SMSC9218I_PHY_PHYSCSR_ANDONE 0x00001000U |
#define | SMSC9218I_PHY_PHYSCSR_4B5B_EN 0x00000040U |
#define | SMSC9218I_PHY_PHYSCSR_SPEED_MASK 0x0000001cU |
#define | SMSC9218I_PHY_PHYSCSR_SPEED_10HD 0x00000004U |
#define | SMSC9218I_PHY_PHYSCSR_SPEED_10FD 0x00000014U |
#define | SMSC9218I_PHY_PHYSCSR_SPEED_100HD 0x00000008U |
#define | SMSC9218I_PHY_PHYSCSR_SPEED_100FD 0x00000018U |
Memory Map | |
volatile smsc9218i_registers *const | smsc9218i |
volatile smsc9218i_registers *const | smsc9218i_dma |
SMSC - LAN9218i.
#define SMSC9218I_BIT_POS | ( | pos | ) |
#define SMSC9218I_FIELD_16 | ( | val, | |
pos | |||
#define SMSC9218I_GET_FIELD_16 | ( | reg, | |
pos | |||
#define SMSC9218I_SWAP | ( | val | ) |
volatile smsc9218i_registers* const smsc9218i |
volatile smsc9218i_registers* const smsc9218i_dma |
