RTEMS 6.1-rc1
percpudata.h
2
12/*
13 * Copyright (c) 2018 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_PERCPUDATA_H
38#define _RTEMS_SCORE_PERCPUDATA_H
39
40#include <rtems/score/percpu.h>
41#include <rtems/linkersets.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
64RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char );
65
70#ifdef RTEMS_SMP
71#define PER_CPU_DATA_NEED_INITIALIZATION() \
72 static const char * const _Per_CPU_Data_reference \
73 RTEMS_SECTION( ".rtemsroset.reference" ) RTEMS_USED = \
74 RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data )
75#else
76#define PER_CPU_DATA_NEED_INITIALIZATION() \
77 RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char )
78#endif
79
88#define PER_CPU_DATA_ITEM_DECLARE( type, item ) \
89 RTEMS_LINKER_RWSET_ITEM_DECLARE( _Per_CPU_Data, type, item )
90
97#define PER_CPU_DATA_ITEM( type, item ) \
98 RTEMS_LINKER_RWSET_ITEM( _Per_CPU_Data, type, item )
99
106#define PER_CPU_DATA_OFFSET( item ) \
107 ( (uintptr_t) &_Linker_set__Per_CPU_Data_##item \
108 - (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) )
109
118#ifdef RTEMS_SMP
119#define PER_CPU_DATA_GET_BY_OFFSET( cpu, type, offset ) \
120 (type *) ( cpu->data + offset )
121#else
122#define PER_CPU_DATA_GET_BY_OFFSET( cpu, type, offset ) \
123 (type *) ( (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) + offset ), \
124 (void) cpu
125#endif
126
135#ifdef RTEMS_SMP
136#define PER_CPU_DATA_GET( cpu, type, item ) \
137 PER_CPU_DATA_GET_BY_OFFSET( cpu, type, PER_CPU_DATA_OFFSET( item ) )
138#else
139#define PER_CPU_DATA_GET( cpu, type, item ) \
140 &_Linker_set__Per_CPU_Data_##item, (void) cpu
141#endif
142
145#ifdef __cplusplus
146}
147#endif /* __cplusplus */
148
149#endif /* _RTEMS_SCORE_PERCPUDATA_H */
This header file provides the linker sets API.
This header file provides the interfaces of the Per-CPU Information.
