RTEMS 6.1-rc1
Files | Macros | Functions
Flexible Per-CPU Data
This group contains the implementation to support flexible per-CPU data. More...
file  percpudata.h
 This header file provides the interfaces of the Flexible Per-CPU Data.
file  percpudata.c
 This source file contains the per-CPU data linker set and its system initialization handler.
#define PER_CPU_DATA_NEED_INITIALIZATION()    RTEMS_LINKER_RWSET_DECLARE( _Per_CPU_Data, char )
 Translation units which define per-CPU items shall call this macro exactly once at file scope.
#define PER_CPU_DATA_ITEM_DECLARE(type, item)    RTEMS_LINKER_RWSET_ITEM_DECLARE( _Per_CPU_Data, type, item )
 Declares a per-CPU item of the specified type. More...
#define PER_CPU_DATA_ITEM(type, item)    RTEMS_LINKER_RWSET_ITEM( _Per_CPU_Data, type, item )
 Defines a per-CPU item of the specified type. More...
#define PER_CPU_DATA_OFFSET(item)
 Returns the offset of the per-CPU item to the begin of the per-CPU data area. More...
#define PER_CPU_DATA_GET_BY_OFFSET(cpu, type, offset)
 Returns a pointer of the specified type to the per-CPU item at the specified offset for the specified processor. More...
#define PER_CPU_DATA_GET(cpu, type, item)    &_Linker_set__Per_CPU_Data_##item, (void) cpu
 Returns a pointer of the specified type to the specified per-CPU item for the specified processor. More...
 RTEMS_LINKER_RWSET_DECLARE (_Per_CPU_Data, char)
Macros to define custom per-CPU items are provided. The items are collected in a special linker set. During system initialization the content of the linker set is duplicated for all secondary processors using memory allocated from the workspace. The begin and end of the per-CPU data area is cache line aligned (CPU_CACHE_LINE_BYTES).
◆ PER_CPU_DATA_GET
#define PER_CPU_DATA_GET (   cpu,
  type,
  item
Parameters
cpuThe processor of the item.
typeThe type of the item.
itemThe designator of the item.
◆ PER_CPU_DATA_GET_BY_OFFSET
#define PER_CPU_DATA_GET_BY_OFFSET (   cpu,
  type,
  offset
Value:
(type *) ( (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) + offset ), \
(void) cpu
Parameters
offsetThe offset of the item.
◆ PER_CPU_DATA_ITEM
#define PER_CPU_DATA_ITEM (   type,
  item
Parameters
◆ PER_CPU_DATA_ITEM_DECLARE
#define PER_CPU_DATA_ITEM_DECLARE (   type,
  item
Items declared with this macro have external linkage.
Parameters
◆ PER_CPU_DATA_OFFSET
#define PER_CPU_DATA_OFFSET (   item)
Value:
( (uintptr_t) &_Linker_set__Per_CPU_Data_##item \
- (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) )
Parameters
