RTEMS 6.1-rc1
linkersets.h File Reference
This header file provides the linker sets API. More...
#define RTEMS_LINKER_SET_BEGIN(set)    _Linker_set_##set##_begin
#define RTEMS_LINKER_SET_END(set)    _Linker_set_##set##_end
#define RTEMS_LINKER_SET_ALIGN(type)    RTEMS_ALIGNED( RTEMS_ALIGNOF( type ) )
#define RTEMS_LINKER_ROSET_DECLARE(set, type)
#define RTEMS_LINKER_ROSET(set, type)
#define RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE(set, type, item, order)
#define RTEMS_LINKER_ROSET_ITEM_DECLARE(set, type, item)
#define RTEMS_LINKER_ROSET_ITEM_REFERENCE(set, type, item)
#define RTEMS_LINKER_ROSET_ITEM_ORDERED(set, type, item, order)
#define RTEMS_LINKER_ROSET_ITEM(set, type, item)
#define RTEMS_LINKER_ROSET_CONTENT(set, decl)
#define RTEMS_LINKER_RWSET_DECLARE(set, type)
#define RTEMS_LINKER_RWSET(set, type)
#define RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE(set, type, item, order)
#define RTEMS_LINKER_RWSET_ITEM_DECLARE(set, type, item)
#define RTEMS_LINKER_RWSET_ITEM_REFERENCE(set, type, item)
#define RTEMS_LINKER_RWSET_ITEM_ORDERED(set, type, item, order)
#define RTEMS_LINKER_RWSET_ITEM(set, type, item)
#define RTEMS_LINKER_RWSET_CONTENT(set, decl)
#define RTEMS_LINKER_SET_SIZE(set)
#define RTEMS_LINKER_SET_ITEM_COUNT(set)
#define RTEMS_LINKER_SET_IS_EMPTY(set)    ( RTEMS_LINKER_SET_SIZE( set ) == 0 )
#define RTEMS_LINKER_SET_FOREACH(set, item)
