38#ifndef _RTEMS_SCORE_OBJECTMP_H
39#define _RTEMS_SCORE_OBJECTMP_H
41#ifndef _RTEMS_SCORE_OBJECTIMPL_H
42# error "Never use <rtems/rtems/objectmp.h> directly; include <rtems/rtems/objectimpl.h> instead."
102 Objects_MP_Control *the_global_object,
173 uint32_t nodes_to_search,
This header file provides interfaces of the Chain Handler which are only used by the implementation.
Status_Control _Objects_MP_Global_name_search(const Objects_Information *information, Objects_Name the_name, uint32_t nodes_to_search, Objects_Id *the_id)
Looks for the object with the_name in the global object tables indicated by information.
Definition: objectmp.c:315
void _Objects_MP_Handler_initialization(void)
Intializes the inactive global object chain based on the maximum number of global objects configured.
Definition: objectmp.c:201
uint32_t _Objects_MP_Maximum_global_objects
Definition: objectmp.c:69
void _Objects_MP_Free_global_object(Objects_MP_Control *the_object)
This routine deallocates a Global Object control block.
Definition: objectmp.c:405
void _Objects_MP_Handler_early_initialization(void)
Intializes the global object node number used in the ID field of all objects.
Definition: objectmp.c:186
Objects_MP_Control * _Objects_MP_Allocate_global_object(void)
This function allocates a Global Object control block.
Definition: objectmp.c:391
void _Objects_MP_Open(Objects_Information *information, Objects_MP_Control *the_global_object, uint32_t the_name, Objects_Id the_id)
Place the specified global object in the specified information table.
Definition: objectmp.c:221
void _Objects_MP_Close(Objects_Information *information, Objects_Id the_id)
Removes a global object from the specified information table.
Definition: objectmp.c:279
bool _Objects_MP_Is_remote(Objects_Id id, const Objects_Information *information)
Checks if the object identifier is in the global object identifier cache of the specified object info...
Definition: objectmp.c:368
bool _Objects_MP_Allocate_and_open(Objects_Information *information, uint32_t the_name, Objects_Id the_id, bool is_fatal_error)
Allocates a global object control block and places it in the specified information table.
Definition: objectmp.c:255
uint32_t Objects_Id
Definition: object.h:101
Status_Control
Status codes.
Definition: status.h:111
