RTEMS 6.1-rc1
This header file provides interfaces of the Chain Handler which are only used by the implementation. More...
struct | Chain_Iterator |
A chain iterator which is updated during node extraction if it is properly registered. More... | |
struct | Chain_Iterator_registry |
A registry for chain iterators. More... | |
#define | CHAIN_INITIALIZER_EMPTY(name) { { { &(name).Tail.Node, NULL }, &(name).Head.Node } } |
Chain initializer for an empty chain with designator name. | |
#define | CHAIN_INITIALIZER_ONE_NODE(node) { { { (node), NULL }, (node) } } |
Chain initializer for a chain with one node. More... | |
#define | CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain) { &(chain)->Tail.Node, &(chain)->Head.Node } |
Chain node initializer for a chain containing exactly this node. More... | |
#define | CHAIN_DEFINE_EMPTY(name) Chain_Control name = CHAIN_INITIALIZER_EMPTY(name) |
Chain definition for an empty chain with designator name. | |
#define | CHAIN_ITERATOR_REGISTRY_INITIALIZER(name) { CHAIN_INITIALIZER_EMPTY( name.Iterators ) } |
Chain iterator registry initializer for static initialization. More... | |
Typedefs | |
typedef bool(* | Chain_Node_order) (const void *key, const Chain_Node *left, const Chain_Node *right) |
Chain node order. More... | |
Enumerations | |
enum | Chain_Iterator_direction { CHAIN_ITERATOR_FORWARD , CHAIN_ITERATOR_BACKWARD } |
The chain iterator direction. More... | |
void | _Chain_Initialize (Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size) |
Initializes a chain header. More... | |
size_t | _Chain_Node_count_unprotected (const Chain_Control *chain) |
Returns the node count of the chain. More... | |
