RTEMS 6.1-rc1
microblaze-fdt-support.h File Reference
This header file provides support for the device tree. More...
#include <stdint.h>
uint32_t try_get_prop_from_device_tree (const char *compatible, const char *prop_name, uint32_t default_value)
 Get the value of a property from a compatible node in the device tree. More...
◆ try_get_prop_from_device_tree()
uint32_t try_get_prop_from_device_tree ( const char *  compatible,
const char *  prop_name,
Parameters
[in]compatibleThe 'compatible' string to match against.
[in]prop_nameThe property name.
[in]default_valueThe default value to return if no compatible node was found or the property was not found.
Returns
The value of the property or the default value.
