RTEMS 6.1-rc1
microblaze-fdt-support.h
2
11/*
12 * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
37#define LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H
38
39#ifdef __cplusplus
40extern "C" {
41#endif
42
43#include <stdint.h>
44
56 const char *compatible,
57 const char *prop_name,
58 uint32_t default_value
59);
60
61#ifdef __cplusplus
62}
63#endif
64
65#endif /* LIBBSP_MICROBLAZE_MICROBLAZE_FDT_SUPPORT_H */
uint32_t try_get_prop_from_device_tree(const char *compatible, const char *prop_name, uint32_t default_value)
Get the value of a property from a compatible node in the device tree.
Definition: microblaze-fdt-support.c:82
