RTEMS 6.1-rc1
This header file provides the main interfaces of the ISR Handler. More...
#include <rtems/score/isrlevel.h>
#define | _ISR_Install_vector(_vector, _new_handler, _old_handler) _CPU_ISR_install_vector( _vector, _new_handler, _old_handler ) |
Install interrupt handler vector. More... | |
Typedefs | |
typedef uint32_t | ISR_Vector_number |
typedef void | ISR_Handler |
typedef void * | ISR_Handler_entry |
RTEMS_DECLARE_GLOBAL_SYMBOL (_ISR_Stack_size) | |
Provides the configured interrupt stack size through an address. More... | |
void | _ISR_Handler_initialization (void) |
Initializes the ISR handler. More... | |
void | _ISR_Handler (void) |
ISR interrupt dispatcher. More... | |
const char *const volatile | _ISR_Stack_size_object |
Provides the configured interrupt stack size through an object. More... | |
char | _ISR_Stack_area_begin [] |
The interrupt stack area begin. More... | |
const char | _ISR_Stack_area_end [] |
The interrupt stack area end. More... | |
