RTEMS 6.1-rc1
Enumerations | Functions
init_system.c File Reference
#include <stdint.h>
#include <stdbool.h>
#include <bsp/tms570.h>
#include <bsp/tms570-pinmux.h>
#include <bsp/tms570_selftest.h>
#include <bsp/tms570_hwinit.h>
enum  tms570_flash_power_modes { TMS570_FLASH_SYS_SLEEP = 0U , TMS570_FLASH_SYS_STANDBY = 1U , TMS570_FLASH_SYS_ACTIVE = 3U }
enum  tms570_system_clock_source {
  TMS570_SYS_CLK_SRC_OSC = 0U , TMS570_SYS_CLK_SRC_PLL1 = 1U , TMS570_SYS_CLK_SRC_EXTERNAL1 = 3U , TMS570_SYS_CLK_SRC_LPO_LOW = 4U ,
  TMS570_SYS_CLK_SRC_LPO_HIGH = 5U , TMS570_SYS_CLK_SRC_PLL2 = 6U , TMS570_SYS_CLK_SRC_EXTERNAL2 = 7U , TMS570_SYS_CLK_SRC_VCLK = 9U
void tms570_pll_init (void)
 Setup all system PLLs (HCG:setupPLL) More...
void tms570_trim_lpo_init (void)
 Adjust Low-Frequency (LPO) oscilator (HCG:trimLPO) More...
void tms570_flash_init (void)
 Setup Flash memory parameters and timing (HCG:setupFlash) More...
void tms570_periph_init (void)
 Power-up all peripherals and enable their clocks (HCG:periphInit) More...
void tms570_map_clock_init (void)
 Setup chip clocks including to wait for PLLs locks (HCG:mapClocks) More...
void tms570_system_hw_init (void)
 TMS570 system hardware initialization (HCG:systemInit) More...
based on Ti HalCoGen generated file
◆ tms570_flash_power_modes
Alias for flash bank power mode sleep
Alias for flash bank power mode standby
Alias for flash bank power mode active
◆ tms570_system_clock_source
Alias for oscillator clock Source
Alias for Pll1 clock Source
Alias for external clock Source
Alias for low power oscillator low clock Source
Alias for low power oscillator high clock Source
Alias for Pll2 clock Source
Alias for external 2 clock Source
Alias for synchronous VCLK1 clock Source
◆ tms570_flash_init()
void tms570_flash_init ( void  )
  • Setup flash read mode, address wait states and data wait states
  • Setup flash access wait states for bank 7
  • Disable write access to flash state machine registers
  • Setup flash bank power modes
◆ tms570_map_clock_init()
void tms570_map_clock_init ( void  )
Initialize Clock Tree:
  • Disable / Enable clock domain
  • Wait for until clocks are locked
  • Map device clock domains to desired sources and configure top-level dividers
  • All clock domains are working off the default clock sources until now
  • The below assignments can be easily modified using the HALCoGen GUI
  • Setup GCLK, HCLK and VCLK clock source for normal operation, power down mode and after wakeup
  • Setup synchronous peripheral clock dividers for VCLK1, VCLK2, VCLK3
  • Setup RTICLK1 and RTICLK2 clocks
  • Setup asynchronous peripheral clock sources for AVCLK1 and AVCLK2
◆ tms570_periph_init()
void tms570_periph_init ( void  )
  • Disable Peripherals before peripheral powerup
  • Release peripherals from reset and enable clocks to all peripherals
  • Power-up all peripherals
  • Enable Peripherals
◆ tms570_pll_init()
void tms570_pll_init ( void  )
  • Configure PLL control registers
Initialize Pll1:
Initialize Pll2:
  • Enable PLL(s) to start up or Lock
◆ tms570_system_hw_init()
void tms570_system_hw_init ( void  )
  • Set up flash address and data wait states based on the target CPU clock frequency The number of address and data wait states for the target CPU clock frequency are specified in the specific part's datasheet.
  • Configure the LPO such that HF LPO is as close to 10MHz as possible
  • Wait for PLLs to start up and map clock domains to desired clock sources
  • set ECLK pins functional mode
  • set ECLK pins default output value
  • set ECLK pins output direction
  • set ECLK pins open drain enable
  • set ECLK pins pullup/pulldown enable
  • set ECLK pins pullup/pulldown select
  • Setup ECLK
◆ tms570_trim_lpo_init()
void tms570_trim_lpo_init ( void  )
Initialize Lpo:
Load TRIM values from OTP if present else load user defined values
