void | Xil_DCacheEnable (void) |
| Enable the Data cache. More...
void | Xil_DCacheDisable (void) |
| Disable the Data cache. More...
void | Xil_DCacheInvalidate (void) |
| Invalidate the Data cache. The contents present in the cache are cleaned and invalidated. More...
void | Xil_DCacheInvalidateRange (INTPTR adr, INTPTR len) |
| Invalidate the Data cache for the given address range. The cachelines present in the adderss range are cleaned and invalidated. More...
void | Xil_DCacheInvalidateLine (INTPTR adr) |
| Invalidate a Data cache line. The cacheline is cleaned and invalidated. More...
void | Xil_DCacheFlush (void) |
| Flush the Data cache. More...
void | Xil_DCacheFlushLine (INTPTR adr) |
| Flush a Data cache line. If the byte specified by the address (adr) is cached by the Data cache, the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the entire contents of the cacheline are written to system memory before the line is invalidated. More...
void | Xil_ICacheEnable (void) |
| Enable the instruction cache. More...
void | Xil_ICacheDisable (void) |
| Disable the instruction cache. More...
void | Xil_ICacheInvalidate (void) |
| Invalidate the entire instruction cache. More...
void | Xil_ICacheInvalidateRange (INTPTR adr, INTPTR len) |
| Invalidate the instruction cache for the given address range. If the instructions specified by the address range are cached by the instrunction cache, the cachelines containing those instructions are invalidated. More...
void | Xil_ICacheInvalidateLine (INTPTR adr) |
| Invalidate an instruction cache line. If the instruction specified by the parameter adr is cached by the instruction cache, the cacheline containing that instruction is invalidated. More...
void | Xil_ConfigureL1Prefetch (u8 num) |
| Configure the maximum number of outstanding data prefetches allowed in L1 cache. More...
Cache functions provide access to cache related operations such as flush and invalidate for instruction and data caches. It gives option to perform the cache operations on a single cacheline, a range of memory and an entire cache.
MODIFICATION HISTORY:
Ver Who Date Changes
5.00 pkp 05/29/14 First release
◆ Xil_ConfigureL1Prefetch()
void Xil_ConfigureL1Prefetch |
u8 |
num | ) |
- Parameters
num | maximum number of outstanding data prefetches allowed, valid values are 0-7. |
- Returns
- None.
- Note
- This function is implemented only for EL3 privilege level.
◆ Xil_DCacheDisable()
void Xil_DCacheDisable |
void |
- Returns
- None.
◆ Xil_DCacheEnable()
void Xil_DCacheEnable |
void |
- Returns
- None.
◆ Xil_DCacheFlush()
void Xil_DCacheFlush |
void |
- Returns
- None.
- Returns
- None.
◆ Xil_DCacheFlushLine()
void Xil_DCacheFlushLine |
INTPTR |
adr | ) |
- Parameters
adr | 64bit address of the data to be flushed. |
- Returns
- None.
- Note
- The bottom 6 bits are set to 0, forced by architecture.
- Parameters
adr | 32bit address of the data to be flushed. |
- Returns
- None.
- Note
- The bottom 5 bits are set to 0, forced by architecture.
◆ Xil_DCacheInvalidate()
void Xil_DCacheInvalidate |
void |
- Returns
- None.
- Note
- In Cortex-A53, functionality to simply invalid the cachelines is not present. Such operations are a problem for an environment that supports virtualisation. It would allow one OS to invalidate a line belonging to another OS. This could lead to the other OS crashing because of the loss of essential data. Hence, such operations are promoted to clean and invalidate which avoids such corruption.
- Returns
- None.
◆ Xil_DCacheInvalidateLine()
void Xil_DCacheInvalidateLine |
INTPTR |
adr | ) |
- Parameters
- Returns
- None.
- Note
- Parameters
- Returns
- None.
- Note
◆ Xil_DCacheInvalidateRange()
void Xil_DCacheInvalidateRange |
INTPTR |
adr, |
INTPTR |
len |
- Parameters
adr | 64bit start address of the range to be invalidated. |
len | Length of the range to be invalidated in bytes. |
- Returns
- None.
- Note
◆ Xil_ICacheDisable()
void Xil_ICacheDisable |
void |
- Returns
- None.
◆ Xil_ICacheEnable()
void Xil_ICacheEnable |
void |
- Returns
- None.
◆ Xil_ICacheInvalidate()
void Xil_ICacheInvalidate |
void |
- Returns
- None.
◆ Xil_ICacheInvalidateLine()
void Xil_ICacheInvalidateLine |
INTPTR |
adr | ) |
- Parameters
adr | 64bit address of the instruction to be invalidated. |
- Returns
- None.
- Note
- Parameters
adr | 32bit address of the instruction to be invalidated. |
- Returns
- None.
- Note
◆ Xil_ICacheInvalidateRange()
void Xil_ICacheInvalidateRange |
INTPTR |
adr, |
INTPTR |
len |
- Parameters
- Returns
- None.
