RTEMS 6.1-rc1
Cortex A9 Processor Cache Functions
void Xil_DCacheEnable (void)
 Enable the Data cache. More...
void Xil_DCacheDisable (void)
 Disable the Data cache. More...
void Xil_DCacheInvalidate (void)
 Invalidate the Data cache. The contents present in the cache are cleaned and invalidated. More...
void Xil_DCacheInvalidateRange (INTPTR adr, u32 len)
 Invalidate the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache,the cacheline containing that byte is invalidated. If the cacheline is modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. More...
void Xil_DCacheFlush (void)
 Flush the Data cache. More...
void Xil_DCacheFlushRange (INTPTR adr, u32 len)
 Flush the Data cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing those bytes is invalidated.If the cacheline is modified (dirty), the written to system memory before the lines are invalidated. More...
void Xil_ICacheEnable (void)
 Enable the instruction cache. More...
void Xil_ICacheDisable (void)
 Disable the instruction cache. More...
void Xil_ICacheInvalidate (void)
 Invalidate the entire instruction cache. More...
void Xil_ICacheInvalidateRange (INTPTR adr, u32 len)
 Invalidate the instruction cache for the given address range. If the bytes specified by the address (adr) are cached by the Data cache, the cacheline containing that byte is invalidated. If the cachelineis modified (dirty), the modified contents are lost and are NOT written to system memory before the line is invalidated. More...
Cache functions provide access to cache related operations such as flush and invalidate for instruction and data caches. It gives option to perform the cache operations on a single cacheline, a range of memory and an entire cache.
MODIFICATION HISTORY:
Ver   Who  Date     Changes
1.00a ecm  01/29/10 First release
3.04a sdm  01/02/12 Remove redundant dsb/dmb instructions in cache maintenance
          APIs.
6.8   aru  09/06/18 Removed compilation warnings for ARMCC toolchain.
◆ Xil_DCacheDisable()
void Xil_DCacheDisable ( void  )
Returns
None.
◆ Xil_DCacheEnable()
void Xil_DCacheEnable ( void  )
Returns
None.
◆ Xil_DCacheFlush()
void Xil_DCacheFlush ( void  )
Returns
None.
Returns
None.
◆ Xil_DCacheFlushRange()
void Xil_DCacheFlushRange ( INTPTR  adr,
u32  len
Parameters
adr32bit start address of the range to be flushed.
lenLength of the range to be flushed in bytes
Returns
None.
◆ Xil_DCacheInvalidate()
void Xil_DCacheInvalidate ( void  )
Returns
None.
Note
In Cortex-A53, functionality to simply invalid the cachelines is not present. Such operations are a problem for an environment that supports virtualisation. It would allow one OS to invalidate a line belonging to another OS. This could lead to the other OS crashing because of the loss of essential data. Hence, such operations are promoted to clean and invalidate which avoids such corruption.
Returns
None.
◆ Xil_DCacheInvalidateRange()
void Xil_DCacheInvalidateRange ( INTPTR  adr,
u32  len
Parameters
adr32bit start address of the range to be invalidated.
lenLength of range to be invalidated in bytes.
Returns
None.
◆ Xil_ICacheDisable()
void Xil_ICacheDisable ( void  )
Returns
None.
◆ Xil_ICacheEnable()
void Xil_ICacheEnable ( void  )
Returns
None.
◆ Xil_ICacheInvalidate()
void Xil_ICacheInvalidate ( void  )
Returns
None.
◆ Xil_ICacheInvalidateRange()
void Xil_ICacheInvalidateRange ( INTPTR  adr,
u32  len
Parameters
lenLength of the range to be invalidated in bytes.
Returns
None.
