#define | USB_ANALOG_VBUS_DETECT_COUNT (2U) |
#define | USB_ANALOG_VBUS_DETECT_SET_COUNT (2U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_COUNT (2U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_COUNT (2U) |
#define | USB_ANALOG_CHRG_DETECT_COUNT (2U) |
#define | USB_ANALOG_CHRG_DETECT_SET_COUNT (2U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_COUNT (2U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_COUNT (2U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_COUNT (2U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_COUNT (2U) |
#define | USB_ANALOG_LOOPBACK_COUNT (2U) |
#define | USB_ANALOG_LOOPBACK_SET_COUNT (2U) |
#define | USB_ANALOG_LOOPBACK_CLR_COUNT (2U) |
#define | USB_ANALOG_LOOPBACK_TOG_COUNT (2U) |
#define | USB_ANALOG_MISC_COUNT (2U) |
#define | USB_ANALOG_MISC_SET_COUNT (2U) |
#define | USB_ANALOG_MISC_CLR_COUNT (2U) |
#define | USB_ANALOG_MISC_TOG_COUNT (2U) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_THRESH_MASK (0x7U) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_THRESH_SHIFT (0U) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_THRESH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_VBUSVALID_THRESH_SHIFT)) & USB_ANALOG_VBUS_DETECT_VBUSVALID_THRESH_MASK) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_PWRUP_CMPS_MASK (0x100000U) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_PWRUP_CMPS_SHIFT (20U) |
#define | USB_ANALOG_VBUS_DETECT_VBUSVALID_PWRUP_CMPS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_VBUSVALID_PWRUP_CMPS_SHIFT)) & USB_ANALOG_VBUS_DETECT_VBUSVALID_PWRUP_CMPS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_DISCHARGE_VBUS_MASK (0x4000000U) |
#define | USB_ANALOG_VBUS_DETECT_DISCHARGE_VBUS_SHIFT (26U) |
#define | USB_ANALOG_VBUS_DETECT_DISCHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_DISCHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_DISCHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_CHARGE_VBUS_MASK (0x8000000U) |
#define | USB_ANALOG_VBUS_DETECT_CHARGE_VBUS_SHIFT (27U) |
#define | USB_ANALOG_VBUS_DETECT_CHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_CHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_CHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK (0x7U) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT (0U) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_THRESH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_THRESH_SHIFT)) & USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_THRESH_MASK) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_PWRUP_CMPS_MASK (0x100000U) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_PWRUP_CMPS_SHIFT (20U) |
#define | USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_PWRUP_CMPS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_PWRUP_CMPS_SHIFT)) & USB_ANALOG_VBUS_DETECT_SET_VBUSVALID_PWRUP_CMPS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK (0x4000000U) |
#define | USB_ANALOG_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT (26U) |
#define | USB_ANALOG_VBUS_DETECT_SET_DISCHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_SET_DISCHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_SET_DISCHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_SET_CHARGE_VBUS_MASK (0x8000000U) |
#define | USB_ANALOG_VBUS_DETECT_SET_CHARGE_VBUS_SHIFT (27U) |
#define | USB_ANALOG_VBUS_DETECT_SET_CHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_SET_CHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_SET_CHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK (0x7U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT (0U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_THRESH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_THRESH_SHIFT)) & USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_THRESH_MASK) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_PWRUP_CMPS_MASK (0x100000U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_PWRUP_CMPS_SHIFT (20U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_PWRUP_CMPS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_PWRUP_CMPS_SHIFT)) & USB_ANALOG_VBUS_DETECT_CLR_VBUSVALID_PWRUP_CMPS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK (0x4000000U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT (26U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_DISCHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_CLR_DISCHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_CLR_DISCHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_CLR_CHARGE_VBUS_MASK (0x8000000U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_CHARGE_VBUS_SHIFT (27U) |
#define | USB_ANALOG_VBUS_DETECT_CLR_CHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_CLR_CHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_CLR_CHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK (0x7U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT (0U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_THRESH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_THRESH_SHIFT)) & USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_THRESH_MASK) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_PWRUP_CMPS_MASK (0x100000U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_PWRUP_CMPS_SHIFT (20U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_PWRUP_CMPS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_PWRUP_CMPS_SHIFT)) & USB_ANALOG_VBUS_DETECT_TOG_VBUSVALID_PWRUP_CMPS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK (0x4000000U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT (26U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_DISCHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_TOG_DISCHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_TOG_DISCHARGE_VBUS_MASK) |
#define | USB_ANALOG_VBUS_DETECT_TOG_CHARGE_VBUS_MASK (0x8000000U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_CHARGE_VBUS_SHIFT (27U) |
#define | USB_ANALOG_VBUS_DETECT_TOG_CHARGE_VBUS(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_TOG_CHARGE_VBUS_SHIFT)) & USB_ANALOG_VBUS_DETECT_TOG_CHARGE_VBUS_MASK) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CONTACT_MASK (0x40000U) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CONTACT_SHIFT (18U) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CONTACT(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_CHK_CONTACT_SHIFT)) & USB_ANALOG_CHRG_DETECT_CHK_CONTACT_MASK) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CHRG_B_MASK (0x80000U) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CHRG_B_SHIFT (19U) |
#define | USB_ANALOG_CHRG_DETECT_CHK_CHRG_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_CHK_CHRG_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_CHK_CHRG_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_EN_B_MASK (0x100000U) |
#define | USB_ANALOG_CHRG_DETECT_EN_B_SHIFT (20U) |
#define | USB_ANALOG_CHRG_DETECT_EN_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_EN_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_EN_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CONTACT_MASK (0x40000U) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CONTACT_SHIFT (18U) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CONTACT(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_SET_CHK_CONTACT_SHIFT)) & USB_ANALOG_CHRG_DETECT_SET_CHK_CONTACT_MASK) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CHRG_B_MASK (0x80000U) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CHRG_B_SHIFT (19U) |
#define | USB_ANALOG_CHRG_DETECT_SET_CHK_CHRG_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_SET_CHK_CHRG_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_SET_CHK_CHRG_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_SET_EN_B_MASK (0x100000U) |
#define | USB_ANALOG_CHRG_DETECT_SET_EN_B_SHIFT (20U) |
#define | USB_ANALOG_CHRG_DETECT_SET_EN_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_SET_EN_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_SET_EN_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CONTACT_MASK (0x40000U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CONTACT_SHIFT (18U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CONTACT(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_CLR_CHK_CONTACT_SHIFT)) & USB_ANALOG_CHRG_DETECT_CLR_CHK_CONTACT_MASK) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CHRG_B_MASK (0x80000U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CHRG_B_SHIFT (19U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_CHK_CHRG_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_CLR_CHK_CHRG_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_CLR_CHK_CHRG_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_CLR_EN_B_MASK (0x100000U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_EN_B_SHIFT (20U) |
#define | USB_ANALOG_CHRG_DETECT_CLR_EN_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_CLR_EN_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_CLR_EN_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CONTACT_MASK (0x40000U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CONTACT_SHIFT (18U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CONTACT(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_TOG_CHK_CONTACT_SHIFT)) & USB_ANALOG_CHRG_DETECT_TOG_CHK_CONTACT_MASK) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CHRG_B_MASK (0x80000U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CHRG_B_SHIFT (19U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_CHK_CHRG_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_TOG_CHK_CHRG_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_TOG_CHK_CHRG_B_MASK) |
#define | USB_ANALOG_CHRG_DETECT_TOG_EN_B_MASK (0x100000U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_EN_B_SHIFT (20U) |
#define | USB_ANALOG_CHRG_DETECT_TOG_EN_B(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_TOG_EN_B_SHIFT)) & USB_ANALOG_CHRG_DETECT_TOG_EN_B_MASK) |
#define | USB_ANALOG_VBUS_DETECT_STAT_SESSEND_MASK (0x1U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_SESSEND_SHIFT (0U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_SESSEND(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_STAT_SESSEND_SHIFT)) & USB_ANALOG_VBUS_DETECT_STAT_SESSEND_MASK) |
#define | USB_ANALOG_VBUS_DETECT_STAT_BVALID_MASK (0x2U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_BVALID_SHIFT (1U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_BVALID(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_STAT_BVALID_SHIFT)) & USB_ANALOG_VBUS_DETECT_STAT_BVALID_MASK) |
#define | USB_ANALOG_VBUS_DETECT_STAT_AVALID_MASK (0x4U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_AVALID_SHIFT (2U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_AVALID(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_STAT_AVALID_SHIFT)) & USB_ANALOG_VBUS_DETECT_STAT_AVALID_MASK) |
#define | USB_ANALOG_VBUS_DETECT_STAT_VBUS_VALID_MASK (0x8U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_VBUS_VALID_SHIFT (3U) |
#define | USB_ANALOG_VBUS_DETECT_STAT_VBUS_VALID(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_VBUS_DETECT_STAT_VBUS_VALID_SHIFT)) & USB_ANALOG_VBUS_DETECT_STAT_VBUS_VALID_MASK) |
#define | USB_ANALOG_CHRG_DETECT_STAT_PLUG_CONTACT_MASK (0x1U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_PLUG_CONTACT_SHIFT (0U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_PLUG_CONTACT(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_STAT_PLUG_CONTACT_SHIFT)) & USB_ANALOG_CHRG_DETECT_STAT_PLUG_CONTACT_MASK) |
#define | USB_ANALOG_CHRG_DETECT_STAT_CHRG_DETECTED_MASK (0x2U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_CHRG_DETECTED_SHIFT (1U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_CHRG_DETECTED(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_STAT_CHRG_DETECTED_SHIFT)) & USB_ANALOG_CHRG_DETECT_STAT_CHRG_DETECTED_MASK) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DM_STATE_MASK (0x4U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DM_STATE_SHIFT (2U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DM_STATE(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_STAT_DM_STATE_SHIFT)) & USB_ANALOG_CHRG_DETECT_STAT_DM_STATE_MASK) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DP_STATE_MASK (0x8U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DP_STATE_SHIFT (3U) |
#define | USB_ANALOG_CHRG_DETECT_STAT_DP_STATE(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_CHRG_DETECT_STAT_DP_STATE_SHIFT)) & USB_ANALOG_CHRG_DETECT_STAT_DP_STATE_MASK) |
#define | USB_ANALOG_MISC_HS_USE_EXTERNAL_R_MASK (0x1U) |
#define | USB_ANALOG_MISC_HS_USE_EXTERNAL_R_SHIFT (0U) |
#define | USB_ANALOG_MISC_HS_USE_EXTERNAL_R(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_HS_USE_EXTERNAL_R_SHIFT)) & USB_ANALOG_MISC_HS_USE_EXTERNAL_R_MASK) |
#define | USB_ANALOG_MISC_EN_DEGLITCH_MASK (0x2U) |
#define | USB_ANALOG_MISC_EN_DEGLITCH_SHIFT (1U) |
#define | USB_ANALOG_MISC_EN_DEGLITCH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_EN_DEGLITCH_SHIFT)) & USB_ANALOG_MISC_EN_DEGLITCH_MASK) |
#define | USB_ANALOG_MISC_EN_CLK_UTMI_MASK (0x40000000U) |
#define | USB_ANALOG_MISC_EN_CLK_UTMI_SHIFT (30U) |
#define | USB_ANALOG_MISC_EN_CLK_UTMI(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_EN_CLK_UTMI_SHIFT)) & USB_ANALOG_MISC_EN_CLK_UTMI_MASK) |
#define | USB_ANALOG_MISC_SET_HS_USE_EXTERNAL_R_MASK (0x1U) |
#define | USB_ANALOG_MISC_SET_HS_USE_EXTERNAL_R_SHIFT (0U) |
#define | USB_ANALOG_MISC_SET_HS_USE_EXTERNAL_R(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_SET_HS_USE_EXTERNAL_R_SHIFT)) & USB_ANALOG_MISC_SET_HS_USE_EXTERNAL_R_MASK) |
#define | USB_ANALOG_MISC_SET_EN_DEGLITCH_MASK (0x2U) |
#define | USB_ANALOG_MISC_SET_EN_DEGLITCH_SHIFT (1U) |
#define | USB_ANALOG_MISC_SET_EN_DEGLITCH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_SET_EN_DEGLITCH_SHIFT)) & USB_ANALOG_MISC_SET_EN_DEGLITCH_MASK) |
#define | USB_ANALOG_MISC_SET_EN_CLK_UTMI_MASK (0x40000000U) |
#define | USB_ANALOG_MISC_SET_EN_CLK_UTMI_SHIFT (30U) |
#define | USB_ANALOG_MISC_SET_EN_CLK_UTMI(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_SET_EN_CLK_UTMI_SHIFT)) & USB_ANALOG_MISC_SET_EN_CLK_UTMI_MASK) |
#define | USB_ANALOG_MISC_CLR_HS_USE_EXTERNAL_R_MASK (0x1U) |
#define | USB_ANALOG_MISC_CLR_HS_USE_EXTERNAL_R_SHIFT (0U) |
#define | USB_ANALOG_MISC_CLR_HS_USE_EXTERNAL_R(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_CLR_HS_USE_EXTERNAL_R_SHIFT)) & USB_ANALOG_MISC_CLR_HS_USE_EXTERNAL_R_MASK) |
#define | USB_ANALOG_MISC_CLR_EN_DEGLITCH_MASK (0x2U) |
#define | USB_ANALOG_MISC_CLR_EN_DEGLITCH_SHIFT (1U) |
#define | USB_ANALOG_MISC_CLR_EN_DEGLITCH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_CLR_EN_DEGLITCH_SHIFT)) & USB_ANALOG_MISC_CLR_EN_DEGLITCH_MASK) |
#define | USB_ANALOG_MISC_CLR_EN_CLK_UTMI_MASK (0x40000000U) |
#define | USB_ANALOG_MISC_CLR_EN_CLK_UTMI_SHIFT (30U) |
#define | USB_ANALOG_MISC_CLR_EN_CLK_UTMI(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_CLR_EN_CLK_UTMI_SHIFT)) & USB_ANALOG_MISC_CLR_EN_CLK_UTMI_MASK) |
#define | USB_ANALOG_MISC_TOG_HS_USE_EXTERNAL_R_MASK (0x1U) |
#define | USB_ANALOG_MISC_TOG_HS_USE_EXTERNAL_R_SHIFT (0U) |
#define | USB_ANALOG_MISC_TOG_HS_USE_EXTERNAL_R(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_TOG_HS_USE_EXTERNAL_R_SHIFT)) & USB_ANALOG_MISC_TOG_HS_USE_EXTERNAL_R_MASK) |
#define | USB_ANALOG_MISC_TOG_EN_DEGLITCH_MASK (0x2U) |
#define | USB_ANALOG_MISC_TOG_EN_DEGLITCH_SHIFT (1U) |
#define | USB_ANALOG_MISC_TOG_EN_DEGLITCH(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_TOG_EN_DEGLITCH_SHIFT)) & USB_ANALOG_MISC_TOG_EN_DEGLITCH_MASK) |
#define | USB_ANALOG_MISC_TOG_EN_CLK_UTMI_MASK (0x40000000U) |
#define | USB_ANALOG_MISC_TOG_EN_CLK_UTMI_SHIFT (30U) |
#define | USB_ANALOG_MISC_TOG_EN_CLK_UTMI(x) (((uint32_t)(((uint32_t)(x)) << USB_ANALOG_MISC_TOG_EN_CLK_UTMI_SHIFT)) & USB_ANALOG_MISC_TOG_EN_CLK_UTMI_MASK) |
