RTEMS 6.1-rc1
SRAM0 - Description Address Register | |
#define | SSARC_HP_SRAM0_ADDR_MASK (0xFFFFFFFFU) |
#define | SSARC_HP_SRAM0_ADDR_SHIFT (0U) |
#define | SSARC_HP_SRAM0_ADDR(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM0_ADDR_SHIFT)) & SSARC_HP_SRAM0_ADDR_MASK) |
SRAM1 - Description Data Register | |
#define | SSARC_HP_SRAM1_DATA_MASK (0xFFFFFFFFU) |
#define | SSARC_HP_SRAM1_DATA_SHIFT (0U) |
#define | SSARC_HP_SRAM1_DATA(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM1_DATA_SHIFT)) & SSARC_HP_SRAM1_DATA_MASK) |
SRAM2 - Description Control Register | |
#define | SSARC_HP_SRAM2_TYPE_MASK (0x7U) |
#define | SSARC_HP_SRAM2_TYPE_SHIFT (0U) |
#define | SSARC_HP_SRAM2_TYPE(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_TYPE_SHIFT)) & SSARC_HP_SRAM2_TYPE_MASK) |
#define | SSARC_HP_SRAM2_SV_EN_MASK (0x10U) |
#define | SSARC_HP_SRAM2_SV_EN_SHIFT (4U) |
#define | SSARC_HP_SRAM2_SV_EN(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SV_EN_SHIFT)) & SSARC_HP_SRAM2_SV_EN_MASK) |
#define | SSARC_HP_SRAM2_RT_EN_MASK (0x20U) |
#define | SSARC_HP_SRAM2_RT_EN_SHIFT (5U) |
#define | SSARC_HP_SRAM2_RT_EN(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_RT_EN_SHIFT)) & SSARC_HP_SRAM2_RT_EN_MASK) |
#define | SSARC_HP_SRAM2_SIZE_MASK (0xC0U) |
#define | SSARC_HP_SRAM2_SIZE_SHIFT (6U) |
#define | SSARC_HP_SRAM2_SIZE(x) (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SIZE_SHIFT)) & SSARC_HP_SRAM2_SIZE_MASK) |
#define SSARC_HP_SRAM0_ADDR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM0_ADDR_SHIFT)) & SSARC_HP_SRAM0_ADDR_MASK) |
ADDR - Address field
#define SSARC_HP_SRAM1_DATA | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM1_DATA_SHIFT)) & SSARC_HP_SRAM1_DATA_MASK) |
DATA - Data field
DATA - Data field
#define SSARC_HP_SRAM2_RT_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_RT_EN_SHIFT)) & SSARC_HP_SRAM2_RT_EN_MASK) |
RT_EN - Restore Enable 0b0..Do not use this descriptor for the restore operation 0b1..Use this descriptor for the restore operation
#define SSARC_HP_SRAM2_SIZE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SIZE_SHIFT)) & SSARC_HP_SRAM2_SIZE_MASK) |
SIZE - Size field 0b00..8-bit 0b01..16-bit 0b10..32-bit 0b11..Reserved
#define SSARC_HP_SRAM2_SV_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_SV_EN_SHIFT)) & SSARC_HP_SRAM2_SV_EN_MASK) |
SV_EN - Save Enable 0b0..Do not use this descriptor in the save operation 0b1..Use this descriptor in the save operation
#define SSARC_HP_SRAM2_TYPE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SSARC_HP_SRAM2_TYPE_SHIFT)) & SSARC_HP_SRAM2_TYPE_MASK) |
TYPE - Type field 0b000..SR 0b001..WO 0b010..RMW_OR 0b011..RMW_AND 0b100..DELAY 0b101..POLLING_0 0b110..POLLING_1 0b111..Reserved
