RTEMS 6.1-rc1
This test suite provides a tests for libtftpfs. More...
Files | |
file | init.c |
This source file contains the implementation of tests for libtftpfs. | |
file | tftpfs_interactions.c |
This source file contains the implementation of network interaction functions related to the UDP network fake for tftpfs testing. | |
file | tftpfs_interactions.h |
This header file provides functions used to implement network interactions of the UDP network fake for tftpfs tests. | |
file | tftpfs_udp_network_fake.c |
This source file contains the implementation of UDP network fake functions related to tftpfs testing. | |
file | tftpfs_udp_network_fake.h |
This header file provides interfaces and functions used to implement the UDP network fake for tftpfs tests. | |
struct | Tftp_Action |
struct | Tftp_Interaction |
struct | Tftp_Packet |
Typedefs | |
typedef enum Tftp_Action_kind | Tftp_Action_kind |
typedef struct Tftp_Action | Tftp_Action |
typedef bool(* | Tftp_Interaction_fn) (Tftp_Action *act, void *data) |
Carry out interactions with TFTP client. More... | |
typedef struct Tftp_Interaction | Tftp_Interaction |
typedef enum Tftp_Opcode | Tftp_Opcode |
typedef enum Tftp_Error_code | Tftp_Error_code |
typedef struct Tftp_Packet | Tftp_Packet |
void | _Tftp_Add_interaction_socket (int domain, int type, int protocol, int result) |
void | _Tftp_Add_interaction_close (int fd, int result) |
void | _Tftp_Add_interaction_bind (int fd, int family, int result) |
void | _Tftp_Add_interaction_send_rrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result) |
void | _Tftp_Add_interaction_send_wrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result) |
void | _Tftp_Add_interaction_send_ack (int fd, uint16_t block_num, uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_send_data (int fd, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_send_error (int fd, uint16_t error_code, uint16_t dest_port, const char *dest_addr_str, bool result) |
void | _Tftp_Add_interaction_recv_data (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), bool result) |
void | _Tftp_Add_interaction_recv_ack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, bool result) |
void | _Tftp_Add_interaction_recv_oack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, const char *options, size_t options_size, bool result) |
void | _Tftp_Add_interaction_recv_error (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t error_code, const char *err_msg, bool result) |
void | _Tftp_Add_interaction_recv_raw (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, size_t len, const uint8_t *bytes, bool result) |
void | _Tftp_Add_interaction_recv_nothing (int fd, uint32_t timeout_ms) |
void | _Tftp_Reset (void) |
Initialize and free the singleton control object. More... | |
void * | _Tftp_Append_interaction (Tftp_Action_kind kind, Tftp_Interaction_fn fn, size_t size) |
Create an interaction and append it to the sequence of expected interactions. More... | |
bool | _Tftp_Has_no_more_interactions (void) |
Have all queued interactions been processed? More... | |
const char * | _Tftp_Get_error_str (uint16_t error_code) |
Provides a human readable description for an error code from an TFTP error packet. More... | |
There are some additional files relevant for the TFTP test suite:
spec/build/testsuites/fstests/grp.yml
spec/build/testsuites/fstests/tftpfs.yml
Doxygen
INPUT
the test suite is included to be processed by the Doxygen documentation generator.See also the RTEMS Filesystem Design Guide Chapter Trivial FTP Client Filesystem.
typedef bool(* Tftp_Interaction_fn) (Tftp_Action *act, void *data) |
Tftp_Interaction_fn()
is called to
act
)act
)The function should not call T_assert_*
() but use T_*
(). Otherwise, it is unlikely that the test can terminate the client in teardown()
[in,out] | act | The actual arguments provided by the TFTP client to the network function. Moreover, storage to store the results to be returned to the TFTP client. |
data | Arbitrary data area allocated when the interaction is created by _Tftp_Append_interaction() |
true | if the client behaved as expected. |
false | if the test shall fail. |
void * _Tftp_Append_interaction | ( | Tftp_Action_kind | kind, |
Tftp_Interaction_fn | fn, | ||
size_t | size | ||
This allocates memory for an interaction and additional specific data for the function fn()
parameter data
. The interaction is initialized and appended at the end of the sequence of expected interactions. If an error occurs a T_assert_*
() macro is called. Hence, this function never returns NULL
kind | Defines which interaction is expected. Note that it cannot happen that fn is called for a different network function. |
fn | A function which is called to handle the interaction. See Tftp_Interaction_fn() |
size | The size of a memory area which is given to fn() as data argument when it is invoked. This can be used to provide private data to the function. |
size
. The same pointer will be provided to fn
as argument data
when invoked. const char * _Tftp_Get_error_str | ( | uint16_t | error_code | ) |
error_code | The error code from the TFTP error packet in host byte order. |
bool _Tftp_Has_no_more_interactions | ( | void | ) |
At the end of a test, it should be checked whether all queued interactions have been consumed by the TFTP client.
true | All queued interactions have been processed. |
false | At least one queued interactions has not yet been processed. |
void _Tftp_Reset | ( | void | ) |
Invoke _Tftp_Reset()
in setup()
and teardown()
of the test.
