RTEMS 6.1-rc1
This source file contains the implementation of network interaction functions related to the UDP network fake for tftpfs testing. More...
#include <inttypes.h>
#include <arpa/inet.h>
#include <rtems/test.h>
#include "tftpfs_interactions.h"
#include "tftpfs_udp_network_fake.h"
struct | interaction_data_socket |
struct | interaction_data_close |
struct | interaction_data_bind |
struct | interaction_data_sendto |
struct | interaction_data_recvfrom |
#define | TFTP_MAX_FILENAME_STRLEN 12 |
Typedefs | |
typedef struct interaction_data_socket | interaction_data_socket |
typedef struct interaction_data_close | interaction_data_close |
typedef struct interaction_data_bind | interaction_data_bind |
typedef struct interaction_data_sendto | interaction_data_sendto |
typedef struct interaction_data_recvfrom | interaction_data_recvfrom |
The UDP Network Fake requires interactions between TFTP client and test (which emulates a TFTP server). The idea is that each test defines a sequence of interactions. In a successful test run all interactions must be carried out one-by-one till the last interaction is reached.
Interactions appear when the TFTP client calls functions like sendto(), recvfrom(), or socket(). Here functions are defined which
