RTEMS 6.1-rc1
This group contains the implementation to support Time of Day Handler action hooks. More...
Files | |
file | todimpl.h |
This header file provides the interfaces of the Time of Day Handler and the Time of Day Handler Action Hooks. | |
file | coretodhookdata.c |
This source file contains the definition of _TOD_Hooks. | |
file | coretodhookregister.c |
This source file contains the implementation of _TOD_Hook_Register(). | |
file | coretodhookrun.c |
This source file contains the implementation of _TOD_Hook_Run(). | |
file | coretodhookunregister.c |
This source file contains the implementation of _TOD_Hook_Unregister(). | |
struct | TOD_Hook |
Structure to manage each TOD action hook. More... | |
Typedefs | |
typedef struct TOD_Hook | TOD_Hook |
Structure to manage each TOD action hook. | |
Enumerations | |
enum | TOD_Action { TOD_ACTION_SET_CLOCK } |
Possible actions where a registered hook could be invoked. More... | |
void | _TOD_Hook_Register (TOD_Hook *hook) |
Add a TOD Action Hook. More... | |
void | _TOD_Hook_Unregister (TOD_Hook *hook) |
Remove a TOD Action Hook. More... | |
Status_Control | _TOD_Hook_Run (TOD_Action action, const struct timespec *tod) |
Run the TOD Action Hooks. More... | |
Chain_Control | _TOD_Hooks |
Set of registered methods for TOD Actions. | |
The following support registering a hook which is invoked when the TOD is set. These can be used by a paravirtualized BSP to mirror time changes to the hosting environment or a regular BSP to program a real-time clock when the RTEMS TOD is set.
enum TOD_Action |
void _TOD_Hook_Register | ( | TOD_Hook * | hook | ) |
This method is used to add a hook to the TOD action set.
hook is the action hook to register.
Status_Control _TOD_Hook_Run | ( | TOD_Action | action, |
const struct timespec * | tod | ||
This method is used to invoke the set of TOD action hooks.
action The action which triggered this run.
tod The current time of day.
STATUS_SUCCESSFUL | Successful operation. |
other | Some error occurred. |
void _TOD_Hook_Unregister | ( | TOD_Hook * | hook | ) |
This method is used to remove a hook from the TOD action set.
hook is the action hook to unregister.
