RTEMS 6.1-rc1
This group contains the EDF Scheduler implementation. More...
Files | |
file | scheduleredf.h |
This header file provides interfaces of the EDF Scheduler which are used by the implementation and the Application Configuration. | |
file | scheduleredfimpl.h |
This header file provides interfaces of the EDF Scheduler which are only used by the implementation. | |
file | scheduleredf.c |
This source file contains the implementation of _Scheduler_EDF_Initialize(). | |
file | scheduleredfblock.c |
This source file contains the implementation of _Scheduler_EDF_Block(). | |
file | scheduleredfchangepriority.c |
This source file contains the implementation of _Scheduler_EDF_Update_priority(). | |
file | scheduleredfnodeinit.c |
This source file contains the implementation of _Scheduler_EDF_Node_initialize(). | |
file | scheduleredfreleasejob.c |
This source file contains the implementation of _Scheduler_EDF_Map_priority(), _Scheduler_EDF_Unmap_priority(), _Scheduler_EDF_Release_job(), and _Scheduler_EDF_Cancel_job(). | |
file | scheduleredfschedule.c |
This source file contains the implementation of _Scheduler_EDF_Schedule(). | |
file | scheduleredfunblock.c |
This source file contains the implementation of _Scheduler_EDF_Unblock(). | |
file | scheduleredfyield.c |
This source file contains the implementation of _Scheduler_EDF_Yield(). | |
struct | Scheduler_EDF_Context |
struct | Scheduler_EDF_Node |
Scheduler node specialization for EDF schedulers. More... | |
#define | SCHEDULER_EDF_MAXIMUM_PRIORITY INT_MAX |
#define | SCHEDULER_EDF_ENTRY_POINTS |
#define | SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
void | _Scheduler_EDF_Initialize (const Scheduler_Control *scheduler) |
Initializes EDF scheduler. More... | |
void | _Scheduler_EDF_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Removes the blocking thread from the ready queue and schedules is only again if the thread is executing or the heir thread. More... | |
void | _Scheduler_EDF_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
Sets the heir thread to be the next ready thread in the rbtree ready queue. More... | |
void | _Scheduler_EDF_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
Initializes an EDF specific scheduler node of the_thread. More... | |
void | _Scheduler_EDF_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Performs an unblocking of the thread. More... | |
void | _Scheduler_EDF_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Updates the priority of the scheduler node. More... | |
Priority_Control | _Scheduler_EDF_Map_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
Gets the mapped priority map of the priority control. More... | |
Priority_Control | _Scheduler_EDF_Unmap_priority (const Scheduler_Control *scheduler, Priority_Control priority) |
Gets the unmapped priority map of the priority control. More... | |
void | _Scheduler_EDF_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
Executes a thread yield for the thread. More... | |
void | _Scheduler_EDF_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context) |
Releases a EDF job. More... | |
void | _Scheduler_EDF_Cancel_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context) |
Cancels a job and removes the thread from the queue context. More... | |
#define SCHEDULER_EDF_ENTRY_POINTS |
Entry points for the Earliest Deadline First Scheduler.
#define SCHEDULER_EDF_PRIO_MSB 0x8000000000000000 |
This is just a most significant bit of Priority_Control type. It distinguishes threads which are deadline driven (priority represented by a lower number than SCHEDULER_EDF_PRIO_MSB) from those ones who do not have any deadlines and thus are considered background tasks.
void _Scheduler_EDF_Block | ( | const Scheduler_Control * | scheduler, |
Thread_Control * | the_thread, | ||
Scheduler_Node * | node | ||
[in,out] | scheduler | The scheduler for the operation. |
the_thread | The thread to operate upon. | |
[in,out] | node | The scheduler node for this thread. |
void _Scheduler_EDF_Cancel_job | ( | const Scheduler_Control * | scheduler, |
Priority_Node * | priority_node, | ||
Thread_queue_Context * | queue_context | ||
scheduler | The scheduler instance. | |
the_thread | The thread for the operation. | |
[in,out] | priority_node | The corresponding priority node. |
[in,out] | queue_context | The thread queue context. |
void _Scheduler_EDF_Initialize | ( | const Scheduler_Control * | scheduler | ) |
This routine initializes the EDF scheduler.
[in,out] | scheduler | The scheduler instance. |
Priority_Control _Scheduler_EDF_Map_priority | ( | const Scheduler_Control * | scheduler, |
Priority_Control | priority | ||
scheduler | Not used in this operation. |
priority | The priority control to get the priority map of. |
void _Scheduler_EDF_Node_initialize | ( | const Scheduler_Control * | scheduler, |
Scheduler_Node * | node, | ||
node | The node being initialized. |
the_thread | The thread of the node. |
priority | The thread priority. |
void _Scheduler_EDF_Release_job | ( | const Scheduler_Control * | scheduler, |
uint64_t | deadline, | ||
Releases a EDF job.
scheduler | The scheduler instance | |
the_thread | The thread | |
[in,out] | priority_node | The priority node for the operation. |
deadline | The deadline for the job. | |
void _Scheduler_EDF_Schedule | ( | const Scheduler_Control * | scheduler, |
Thread_Control * | the_thread | ||
This kernel routine sets the heir thread to be the next ready thread in the rbtree ready queue.
the_thread | The thread being scheduled. |
void _Scheduler_EDF_Unblock | ( | const Scheduler_Control * | scheduler, |
the_thread | The unblocking thread. May be set as new heir. | |
[in,out] | node | The scheduler node for the thread. |
Priority_Control _Scheduler_EDF_Unmap_priority | ( | const Scheduler_Control * | scheduler, |
void _Scheduler_EDF_Update_priority | ( | const Scheduler_Control * | scheduler, |
[in,out] | node | The priority node to update the priority of. |
void _Scheduler_EDF_Yield | ( | const Scheduler_Control * | scheduler, |
the_thread | The thread that performs the yield. | |
