RTEMS 6.1-rc1
The application configuration defines system parameters according to configuration options (defines) provided by the application. More...
Files | |
file | bdbuf.h |
This header file evaluates configuration options related to the block device cache configuration. | |
file | bsp.h |
This header file evaluates configuration options related to the BSP configuration. | |
file | clock.h |
This header file evaluates configuration options related to the clock driver configuration. | |
file | console.h |
This header file evaluates configuration options related to the console driver configuration. | |
file | extensions.h |
This header file evaluates configuration options related to the user extensions configuration. | |
file | face.h |
This header file evaluates configuration options related to the FACE Technical Standard. | |
file | inittask.h |
This header file evaluates configuration options related to the Classic API initialization task configuration. | |
file | initthread.h |
This header file evaluates configuration options related to the POSIX initialization thread configuration. | |
file | iodrivers.h |
This header file evaluates configuration options related to the I/O driver configuration. | |
file | libio.h |
This header file evaluates configuration options related to the I/O library configuration. | |
file | libpci.h |
This header file evaluates configuration options related to the PCI library configuration. | |
file | malloc.h |
This header file evaluates configuration options related to the C Program Heap configuration. | |
file | mpci.h |
This header file evaluates configuration options related to the MPCI configuration. | |
file | newlib.h |
This header file evaluates configuration options related to the Newlib C Library configuration. | |
file | objectsclassic.h |
This header file evaluates configuration options related to the Classic API objects configuration. | |
file | objectsposix.h |
This header file evaluates configuration options related to the POSIX API objects configuration. | |
file | obsolete.h |
This header file evaluates configuration options related to obsolete configuration options. | |
file | percpu.h |
This header file evaluates configuration options related to the per-CPU configuration. | |
file | scheduler.h |
This header file evaluates configuration options related to the scheduler configuration. | |
file | threads.h |
This header file evaluates configuration options related to the thread configuration. | |
file | unlimited.h |
This header file evaluates configuration options related to the unlimited objects configuration. | |
file | wkspace.h |
This header file evaluates configuration options related to the RTEMS Workspace configuration. | |
file | wkspacesupport.h |
This header file provides support macros to evaluate configuration options related to the RTEMS Workspace configuration. | |
