RTEMS 6.1-rc1
Moxie Architecture Support. More...
Modules | |
Moxie Assembler Support | |
Moxie Assembler Support. | |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 10 |
RTEMS_NO_RETURN void | _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error) |
RTEMS_NO_RETURN void _CPU_Fatal_halt | ( | uint32_t | source, |
CPU_Uint32ptr | error | ||
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
