RTEMS 6.1-rc1
Files | Functions
Trivial File Transfer Protocol (TFTP) file system
The TFTP file system provides the ability to read files from and to write files to remote servers using the Trivial File Transfer Protocol (TFTP). More...
file  tftp.h
 This header file provides interfaces and functions used to implement the TFTP file system.
file  tftp_driver.h
 This header file provides private interfaces of the TFTP client library.
file  tftpDriver.c
 This source file contains the implementation of a Trivial File Transfer Protocol (TFTP) client library.
file  tftpfs.c
 This source file contains the implementation of the Trivial File Transfer Protocol (TFTP) file system.
int rtems_tftpfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
 Do not call directly, use mount(). More...
void _Tftp_Destroy (void *tftp_handle)
 Free the resources associated with a TFTP client connection. More...
ssize_t _Tftpfs_Parse_options (const char *option_str, tftp_net_config *tftp_config, uint32_t *flags)
The file spec/build/cpukit/libtftpfs.yml specifies how the RTEMS WAF build system has to compile, link and install libtftpfs.
There also exists a TFTP file system test suite.
◆ _Tftp_Destroy()
void _Tftp_Destroy ( void *  tftp_handle)
This directive releases any resources allocated at the client side. The connection is not closed which implies that the server will not be informed and data is likely lost. According to RFC 1350 the server will recognize the defect connection by timeouts. This directive is internally used when the TFTP file system is unmounted.
Parameters
tftp_handleis the reference returned by a call to tftp_open(). If this parameter is NULL, the directive call is a no-op.
◆ rtems_tftpfs_initialize()
int rtems_tftpfs_initialize ( rtems_filesystem_mount_table_entry_t mt_entry,
const void *  data
Filesystem Mount table entry.
