RTEMS 6.1-rc1
Modules | Files | Data Structures | Macros | Enumerations | Functions | Variables
Message Manager
This group contains the Message Manager implementation. More...
 Message Manager Multiprocessing (MP) Support
 This group contains the implementation to support the Message Manager in multiprocessing (MP) configurations.
file  message.h
 This header file defines the Message Manager API.
file  messagedata.h
 This header file provides data structures used by the implementation and the Application Configuration to define _Message_queue_Information.
file  messageimpl.h
 This header file provides the implementation interfaces of the Message Manager.
file  msg.c
 This source file contains a definition of the _Message_queue_Information with zero objects.
file  msgqbroadcast.c
 This source file contains the implementation of rtems_message_queue_broadcast().
file  msgqconstruct.c
 This source file contains the implementation of rtems_message_queue_construct().
file  msgqcreate.c
 This source file contains the implementation of rtems_message_queue_create().
file  msgqdelete.c
 This source file contains the implementation of rtems_message_queue_delete().
file  msgqflush.c
 This source file contains the implementation of rtems_message_queue_flush().
file  msgqgetnumberpending.c
 This source file contains the implementation of rtems_message_queue_get_number_pending().
file  msgqident.c
 This source file contains the implementation of rtems_message_queue_ident().
file  msgqreceive.c
 This source file contains the implementation of rtems_message_queue_receive().
file  msgqsend.c
 This source file contains the implementation of rtems_message_queue_send().
file  msgqurgent.c
 This source file contains the implementation of rtems_message_queue_urgent().
struct  Message_queue_Control
#define MESSAGE_QUEUE_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Message Queue objects. More...
enum  Message_queue_Submit_types { MESSAGE_QUEUE_SEND_REQUEST = 0 , MESSAGE_QUEUE_URGENT_REQUEST = 1 }
rtems_status_code _Message_queue_Submit (rtems_id id, const void *buffer, size_t size, Message_queue_Submit_types submit_type)
 Message_queue_Submit. More...
rtems_status_code _Message_queue_Create (const rtems_message_queue_config *config, rtems_id *id, CORE_message_queue_Allocate_buffers allocate_buffers)
 Creates a message queue. More...
Objects_Information _Message_queue_Information
 The Classic Message Queue objects information.
◆ MESSAGE_QUEUE_INFORMATION_DEFINE
#define MESSAGE_QUEUE_INFORMATION_DEFINE (   max)
Value:
_Message_queue, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_MESSAGE_QUEUES, \
max, \
_Message_queue_MP_Send_extract_proxy \
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:123
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:449
Definition: messagedata.h:58
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ Message_queue_Submit_types
The following enumerated type details the modes in which a message may be submitted to a message queue. The message may be posted in a send or urgent fashion.
This value indicates the user wants to send the message using the normal message insertion protocol (FIFO or priority).
This value indicates the user considers the message to be urgent and wants it inserted at the head of the pending message queue.
◆ _Message_queue_Create()
rtems_status_code _Message_queue_Create ( const rtems_message_queue_config config,
rtems_id id,
Parameters
configis the message queue configuration.
[out]idcontains the object identifier if the operation was successful.
allocate_buffersis the message buffer storage area allocation handler.
◆ _Message_queue_Submit()
rtems_status_code _Message_queue_Submit ( rtems_id  id,
const void *  buffer,
size_t  size,
This routine implements the directives rtems_message_queue_send and rtems_message_queue_urgent. It processes a message that is to be submitted to the designated message queue. The message will either be processed as a send send message which it will be inserted at the rear of the queue or it will be processed as an urgent message which will be inserted at the front of the queue.
