RTEMS 6.1-rc1
Credit counter, SpaceWire ports (CREDCNT)
This group contains register bit definitions. More...
#define GRSPWROUTER_CREDCNT_OC_SHIFT   6
#define GRSPWROUTER_CREDCNT_OC_MASK   0xfc0U
#define GRSPWROUTER_CREDCNT_OC_GET(_reg)
#define GRSPWROUTER_CREDCNT_OC_SET(_reg, _val)
#define GRSPWROUTER_CREDCNT_OC(_val)
#define GRSPWROUTER_CREDCNT_IC_SHIFT   0
#define GRSPWROUTER_CREDCNT_IC_MASK   0x3fU
#define GRSPWROUTER_CREDCNT_IC_GET(_reg)
#define GRSPWROUTER_CREDCNT_IC_SET(_reg, _val)
#define GRSPWROUTER_CREDCNT_IC(_val)
◆ GRSPWROUTER_CREDCNT_IC
#define GRSPWROUTER_CREDCNT_IC (   _val)
Value:
( ( ( _val ) << GRSPWROUTER_CREDCNT_IC_SHIFT ) & \
GRSPWROUTER_CREDCNT_IC_MASK )
◆ GRSPWROUTER_CREDCNT_IC_GET
#define GRSPWROUTER_CREDCNT_IC_GET (   _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_CREDCNT_IC_MASK ) >> \
◆ GRSPWROUTER_CREDCNT_IC_SET
#define GRSPWROUTER_CREDCNT_IC_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRSPWROUTER_CREDCNT_IC_MASK ) | \
GRSPWROUTER_CREDCNT_IC_MASK ) )
◆ GRSPWROUTER_CREDCNT_OC
#define GRSPWROUTER_CREDCNT_OC (   _val)
Value:
( ( ( _val ) << GRSPWROUTER_CREDCNT_OC_SHIFT ) & \
GRSPWROUTER_CREDCNT_OC_MASK )
◆ GRSPWROUTER_CREDCNT_OC_GET
#define GRSPWROUTER_CREDCNT_OC_GET (   _reg)
Value:
( ( ( _reg ) & GRSPWROUTER_CREDCNT_OC_MASK ) >> \
◆ GRSPWROUTER_CREDCNT_OC_SET
#define GRSPWROUTER_CREDCNT_OC_SET (   _reg,
  _val
Value:
( ( ( _reg ) & ~GRSPWROUTER_CREDCNT_OC_MASK ) | \
GRSPWROUTER_CREDCNT_OC_MASK ) )
