RTEMS 6.1-rc1
Modules | Files | Data Structures | Typedefs
SpaceWire Router
This group contains the SpaceWire Router interfaces. More...
 APB address area (APBAREA)
 This group contains register bit definitions.
 Capability (CAP)
 Configuration port write enable (CFGWE)
 Credit counter, SpaceWire ports (CREDCNT)
 General purpose in, bits 0-31, 32-63, 64-95, and 96-127 (GPI)
 General purpose out, bits 0-31, 32-63, 64-95, and 96-127 (GPO)
 Initialization divisor (IDIV)
 Interrupt code distribution ACK-to-INT timer reload (AITIMER)
 Interrupt code distribution ISR change timer reload (ISRCTIMER)
 Interrupt code distribution ISR register, interrupt 0-31 (ISR0)
 Interrupt code distribution ISR register, interrupt 32-63 (ISR1)
 Interrupt code distribution ISR timer reload (ISRTIMER)
 Interrupt code generation (ICODEGEN)
 Interrupt mask (IMASK)
 Interrupt port mask (IPMASK)
 Link running status (LRUNSTAT)
 Maximum packet length, ports > 0 (MAXPLEN)
 Port control 2, port 0 (configuration port) (PCTRL2CFG)
 Port control 2, ports > 0 (PCTRL2)
 Port control, port 0 (configuration port) (PCTRLCFG)
 Port control, ports > 0 (PCTRL)
 Port interrupt pending (PIP)
 Port status, port 0 (configuration port) (PSTSCFG)
 Port status, ports > 0 (PSTS)
 Port timer reload (PTIMER)
 Router configuration / status (RTRCFG)
 Routing table address control, addresses 1-31 and 32-255 (RTACTRL)
 Routing table port mapping, addresses 1-31 and 32-255 (RTPMAP)
 Routing table, combined port mapping and address control, addresses 1-255 (RTCOMB)
 SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND)
 SpaceWire Plug-and-Play - Port network discovery enable (PNPNETDISC)
 SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN)
 SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND)
 SpaceWire Router Port Statistics
 This group contains the SpaceWire Router Port Statistics interfaces.
 Time-code (TC)
 Timer prescaler reload (PRESCALER)
 Version / instance ID (VER)
file  grspwrouter-regs.h
 This header file defines the GRSPWROUTER register block interface.
struct  grspwrouter
 This structure defines the SpaceWire Router register block memory map. More...
typedef struct grspwrouter grspwrouter
