RTEMS 6.1-rc1
CTRL0 - Analog Control Register CTRL0
#define PHY_LDO_CTRL0_LINREG_EN_MASK   (0x1U)
#define PHY_LDO_CTRL0_LINREG_EN_SHIFT   (0U)
#define PHY_LDO_CTRL0_LINREG_EN(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & PHY_LDO_CTRL0_LINREG_EN_MASK)
#define PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_MASK   (0x2U)
#define PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_SHIFT   (1U)
#define PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_SHIFT)) & PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_MASK)
#define PHY_LDO_CTRL0_LINREG_ILIMIT_EN_MASK   (0x4U)
#define PHY_LDO_CTRL0_LINREG_ILIMIT_EN_SHIFT   (2U)
#define PHY_LDO_CTRL0_LINREG_ILIMIT_EN(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_ILIMIT_EN_SHIFT)) & PHY_LDO_CTRL0_LINREG_ILIMIT_EN_MASK)
#define PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_MASK   (0x1F0U)
#define PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_SHIFT   (4U)
#define PHY_LDO_CTRL0_LINREG_OUTPUT_TRG(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_SHIFT)) & PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_MASK)
#define PHY_LDO_CTRL0_LINREG_PHY_ISO_B_MASK   (0x8000U)
#define PHY_LDO_CTRL0_LINREG_PHY_ISO_B_SHIFT   (15U)
#define PHY_LDO_CTRL0_LINREG_PHY_ISO_B(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_PHY_ISO_B_SHIFT)) & PHY_LDO_CTRL0_LINREG_PHY_ISO_B_MASK)
#define VMBANDGAP_CTRL0_REFTOP_PWD_MASK   (0x1U)
#define VMBANDGAP_CTRL0_REFTOP_PWD_SHIFT   (0U)
#define VMBANDGAP_CTRL0_REFTOP_PWD(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_PWD_MASK)
#define VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK   (0x2U)
#define VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT   (1U)
#define VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK)
#define VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK   (0x4U)
#define VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT   (2U)
#define VMBANDGAP_CTRL0_REFTOP_PWDVBGUP(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK)
#define VMBANDGAP_CTRL0_REFTOP_LOWPOWER_MASK   (0x8U)
#define VMBANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT   (3U)
#define VMBANDGAP_CTRL0_REFTOP_LOWPOWER(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_LOWPOWER_MASK)
#define VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK   (0x10U)
#define VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT   (4U)
#define VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK)
STAT0 - Analog Status Register STAT0
#define PHY_LDO_STAT0_LINREG_STAT_MASK   (0xFU)
#define PHY_LDO_STAT0_LINREG_STAT_SHIFT   (0U)
#define PHY_LDO_STAT0_LINREG_STAT(x)   (((uint32_t)(((uint32_t)(x)) << PHY_LDO_STAT0_LINREG_STAT_SHIFT)) & PHY_LDO_STAT0_LINREG_STAT_MASK)
#define VMBANDGAP_STAT0_REFTOP_VBGUP_MASK   (0x1U)
#define VMBANDGAP_STAT0_REFTOP_VBGUP_SHIFT   (0U)
#define VMBANDGAP_STAT0_REFTOP_VBGUP(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_REFTOP_VBGUP_SHIFT)) & VMBANDGAP_STAT0_REFTOP_VBGUP_MASK)
#define VMBANDGAP_STAT0_VDD1_PORB_MASK   (0x2U)
#define VMBANDGAP_STAT0_VDD1_PORB_SHIFT   (1U)
#define VMBANDGAP_STAT0_VDD1_PORB(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD1_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD1_PORB_MASK)
#define VMBANDGAP_STAT0_VDD2_PORB_MASK   (0x4U)
#define VMBANDGAP_STAT0_VDD2_PORB_SHIFT   (2U)
#define VMBANDGAP_STAT0_VDD2_PORB(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD2_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD2_PORB_MASK)
#define VMBANDGAP_STAT0_VDD3_PORB_MASK   (0x8U)
#define VMBANDGAP_STAT0_VDD3_PORB_SHIFT   (3U)
#define VMBANDGAP_STAT0_VDD3_PORB(x)   (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD3_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD3_PORB_MASK)
◆ PHY_LDO_CTRL0_LINREG_EN [1/2]
#define PHY_LDO_CTRL0_LINREG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_EN_SHIFT)) & PHY_LDO_CTRL0_LINREG_EN_MASK)
LINREG_EN - LinrReg master enable
◆ PHY_LDO_CTRL0_LINREG_EN [2/2]
◆ PHY_LDO_CTRL0_LINREG_ILIMIT_EN [1/2]
#define PHY_LDO_CTRL0_LINREG_ILIMIT_EN (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_ILIMIT_EN_SHIFT)) & PHY_LDO_CTRL0_LINREG_ILIMIT_EN_MASK)
LINREG_ILIMIT_EN - LinReg current-limit enable
◆ PHY_LDO_CTRL0_LINREG_ILIMIT_EN [2/2]
◆ PHY_LDO_CTRL0_LINREG_OUTPUT_TRG [1/2]
#define PHY_LDO_CTRL0_LINREG_OUTPUT_TRG (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_SHIFT)) & PHY_LDO_CTRL0_LINREG_OUTPUT_TRG_MASK)
LINREG_OUTPUT_TRG - LinReg output voltage target setting 0b00000..Set output voltage to x.xV 0b10000..Sets output voltage to 1.0V 0b11111..Set output voltage to x.xV
◆ PHY_LDO_CTRL0_LINREG_OUTPUT_TRG [2/2]
◆ PHY_LDO_CTRL0_LINREG_PHY_ISO_B [1/2]
#define PHY_LDO_CTRL0_LINREG_PHY_ISO_B (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_PHY_ISO_B_SHIFT)) & PHY_LDO_CTRL0_LINREG_PHY_ISO_B_MASK)
LINREG_PHY_ISO_B - Isolation control for attached PHY load
◆ PHY_LDO_CTRL0_LINREG_PHY_ISO_B [2/2]
◆ PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS [1/2]
#define PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_SHIFT)) & PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS_MASK)
LINREG_PWRUPLOAD_DIS - LinReg power-up load disable 0b0..Internal pull-down enabled 0b1..Internal pull-down disabled
◆ PHY_LDO_CTRL0_LINREG_PWRUPLOAD_DIS [2/2]
◆ PHY_LDO_STAT0_LINREG_STAT [1/2]
#define PHY_LDO_STAT0_LINREG_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << PHY_LDO_STAT0_LINREG_STAT_SHIFT)) & PHY_LDO_STAT0_LINREG_STAT_MASK)
LINREG_STAT - LinReg Status Bits
◆ PHY_LDO_STAT0_LINREG_STAT [2/2]
◆ VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD [1/2]
#define VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD_MASK)
REFTOP_LINREGREF_PWD - Power-down for bandgap voltage-reference buffer
◆ VMBANDGAP_CTRL0_REFTOP_LINREGREF_PWD [2/2]
◆ VMBANDGAP_CTRL0_REFTOP_LOWPOWER [1/2]
#define VMBANDGAP_CTRL0_REFTOP_LOWPOWER (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_LOWPOWER_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_LOWPOWER_MASK)
REFTOP_LOWPOWER - Low-power control bit
◆ VMBANDGAP_CTRL0_REFTOP_LOWPOWER [2/2]
◆ VMBANDGAP_CTRL0_REFTOP_PWD [1/2]
#define VMBANDGAP_CTRL0_REFTOP_PWD (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_PWD_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_PWD_MASK)
REFTOP_PWD - Master power-down for bandgap module
◆ VMBANDGAP_CTRL0_REFTOP_PWD [2/2]
◆ VMBANDGAP_CTRL0_REFTOP_PWDVBGUP [1/2]
#define VMBANDGAP_CTRL0_REFTOP_PWDVBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_PWDVBGUP_MASK)
REFTOP_PWDVBGUP - Power-down VBGUP detector in bandgap
◆ VMBANDGAP_CTRL0_REFTOP_PWDVBGUP [2/2]
◆ VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF [1/2]
#define VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_SHIFT)) & VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF_MASK)
REFTOP_SELFBIASOFF - bandgap self-bias control bit
◆ VMBANDGAP_CTRL0_REFTOP_SELFBIASOFF [2/2]
◆ VMBANDGAP_STAT0_REFTOP_VBGUP [1/2]
#define VMBANDGAP_STAT0_REFTOP_VBGUP (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_REFTOP_VBGUP_SHIFT)) & VMBANDGAP_STAT0_REFTOP_VBGUP_MASK)
REFTOP_VBGUP - Brief description here
◆ VMBANDGAP_STAT0_REFTOP_VBGUP [2/2]
◆ VMBANDGAP_STAT0_VDD1_PORB [1/2]
#define VMBANDGAP_STAT0_VDD1_PORB (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD1_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD1_PORB_MASK)
VDD1_PORB - Brief description here
◆ VMBANDGAP_STAT0_VDD1_PORB [2/2]
◆ VMBANDGAP_STAT0_VDD2_PORB [1/2]
#define VMBANDGAP_STAT0_VDD2_PORB (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD2_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD2_PORB_MASK)
VDD2_PORB - Brief description here
◆ VMBANDGAP_STAT0_VDD2_PORB [2/2]
◆ VMBANDGAP_STAT0_VDD3_PORB [1/2]
#define VMBANDGAP_STAT0_VDD3_PORB (   x)    (((uint32_t)(((uint32_t)(x)) << VMBANDGAP_STAT0_VDD3_PORB_SHIFT)) & VMBANDGAP_STAT0_VDD3_PORB_MASK)
VDD3_PORB - Brief description here
◆ VMBANDGAP_STAT0_VDD3_PORB [2/2]
