RTEMS 6.1-rc1
CFG_NUM_LANES - Lane Configuration Register | |
#define | MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK (0x3U) |
#define | MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT)) & MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK) |
CFG_DISABLE_DATA_LANES - Disable Data Lane Register | |
#define | MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK (0xFU) |
#define | MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK) |
BIT_ERR - ECC and CRC Error Status Register | |
#define | MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK (0x3FFU) |
#define | MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT (0U) |
#define | MIPI_CSI2RX_BIT_ERR_BIT_ERR(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT)) & MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK) |
IRQ_STATUS - IRQ Status Register | |
#define | MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK (0x1FFU) |
#define | MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT)) & MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK) |
IRQ_MASK - IRQ Mask Setting Register | |
#define | MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK (0x1FFU) |
#define | MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT (0U) |
#define | MIPI_CSI2RX_IRQ_MASK_IRQ_MASK(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT)) & MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK) |
ULPS_STATUS - Ultra Low Power State (ULPS) Status Register | |
#define | MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK (0x3FFU) |
#define | MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_ULPS_STATUS_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT)) & MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK) |
PPI_ERRSOT_HS - ERRSot HS Status Register | |
#define | MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK (0xFU) |
#define | MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK) |
PPI_ERRSOTSYNC_HS - ErrSotSync HS Status Register | |
#define | MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK (0xFU) |
#define | MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK) |
PPI_ERRESC - ErrEsc Status Register | |
#define | MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK (0xFU) |
#define | MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_PPI_ERRESC_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK) |
PPI_ERRSYNCESC - ErrSyncEsc Status Register | |
#define | MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK (0xFU) |
#define | MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK) |
PPI_ERRCONTROL - ErrControl Status Register | |
#define | MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK (0xFU) |
#define | MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT (0U) |
#define | MIPI_CSI2RX_PPI_ERRCONTROL_STATUS(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK) |
CFG_DISABLE_PAYLOAD_0 - Disable Payload 0 Register | |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK (0x1U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK (0x2U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT (1U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK (0x4U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT (2U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK (0x400U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT (10U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK (0x4000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT (14U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK (0x10000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT (16U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK (0x20000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT (17U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK (0x40000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT (18U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK (0x80000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT (19U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK (0x100000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT (20U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK) |
CFG_DISABLE_PAYLOAD_1 - Disable Payload 1 Register | |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK (0x1U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK (0x2U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT (1U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK (0x4U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT (2U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK (0x8U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT (3U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK (0x10U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT (4U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK (0x20U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT (5U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK (0x40U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT (6U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK (0x80U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT (7U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK (0x10000U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT (16U) |
#define | MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK) |
CFG_VID_P_FIFO_SEND_LEVEL - FIFO Send Level Configuration Register | |
#define | MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK (0xFFFFU) |
#define | MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT)) & MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK) |
CFG_VID_VSYNC - VSYNC Configuration Register | |
#define | MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK (0xFFU) |
#define | MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK) |
CFG_VID_HSYNC_FP - Start of HSYNC Delay control Register | |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK (0xFFU) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK) |
CFG_VID_HSYNC - HSYNC Configuration Register | |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK (0xFFU) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK) |
CFG_VID_HSYNC_BP - End of HSYNC Delay Control Register | |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK (0xFFU) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT (0U) |
#define | MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL(x) (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK) |
#define MIPI_CSI2RX_BIT_ERR_BIT_ERR | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_BIT_ERR_BIT_ERR_SHIFT)) & MIPI_CSI2RX_BIT_ERR_BIT_ERR_MASK) |
BIT_ERR - This field shows the error status of ECC and CRC
#define MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_DATA_LANES_CFG_DISABLE_DATA_LANES_MASK) |
CFG_DISABLE_DATA_LANES - This field is used to disable data lanes.
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_BLANK_MASK) |
DIS_PAYLOAD_BLANK - Blank
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_EMBEDDED_MASK) |
DIS_PAYLOAD_EMBEDDED - Embedded
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_NULL_MASK) |
DIS_PAYLOAD_NULL - Null
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB444_MASK) |
DIS_PAYLOAD_RGB444 - RGB444
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB555_MASK) |
DIS_PAYLOAD_RGB555 - RGB555
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB565_MASK) |
DIS_PAYLOAD_RGB565 - RGB565
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB666_MASK) |
DIS_PAYLOAD_RGB666 - RGB666
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_RGB888_MASK) |
DIS_PAYLOAD_RGB888 - RGB888
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV420_MASK) |
DIS_PAYLOAD_YUV420 - Legacy YUV 420 8 bit
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_0_DIS_PAYLOAD_YUV422_8BIT_MASK) |
DIS_PAYLOAD_YUV422_8BIT - YUV422 8 bit
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_30_MASK) |
DIS_PAYLOAD_UDEF_30 - User defined type 0x31
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_31_MASK) |
DIS_PAYLOAD_UDEF_31 - User defined type 0x32
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_32_MASK) |
DIS_PAYLOAD_UDEF_32 - User defined type 0x33
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_33_MASK) |
DIS_PAYLOAD_UDEF_33 - User defined type 0x34
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_34_MASK) |
DIS_PAYLOAD_UDEF_34 - User defined type 0x35
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_35_MASK) |
DIS_PAYLOAD_UDEF_35 - User defined type 0x35
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_36_MASK) |
DIS_PAYLOAD_UDEF_36 - User defined type 0x36
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37 | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UDEF_37_MASK) |
DIS_PAYLOAD_UDEF_37 - User defined type 0x37
#define MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_SHIFT)) & MIPI_CSI2RX_CFG_DISABLE_PAYLOAD_1_DIS_PAYLOAD_UNSUPPORTED_MASK) |
DIS_PAYLOAD_UNSUPPORTED - Unsupported Data Types
#define MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_SHIFT)) & MIPI_CSI2RX_CFG_NUM_LANES_CFG_NUM_LANES_MASK) |
CFG_NUM_LANES - This field is used to set the number of active lanes for receiving data. 0b00..1 Lane 0b01..2 Lane 0b10-0b11..Reserved
#define MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_BP_DELAY_CTL_MASK) |
DELAY_CTL - Delay Control for end of HSYNC pulse
#define MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_FP_DELAY_CTL_MASK) |
DELAY_CTL - Delay control for beginning of HSYNC pulse
#define MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_HSYNC_WIDTH_MASK) |
WIDTH - Width of HSYNC
#define MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_SHIFT)) & MIPI_CSI2RX_CFG_VID_P_FIFO_SEND_LEVEL_SEND_LEVEL_MASK) |
SEND_LEVEL - FIFO Send Level field
#define MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_SHIFT)) & MIPI_CSI2RX_CFG_VID_VSYNC_WIDTH_MASK) |
WIDTH - Width of VSYNC
#define MIPI_CSI2RX_IRQ_MASK_IRQ_MASK | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_SHIFT)) & MIPI_CSI2RX_IRQ_MASK_IRQ_MASK_MASK) |
IRQ_MASK - This field shows the IRQ Mask setting
#define MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_SHIFT)) & MIPI_CSI2RX_IRQ_STATUS_IRQ_STATUS_MASK) |
IRQ_STATUS - This field shows the IRQ status
#define MIPI_CSI2RX_PPI_ERRCONTROL_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRCONTROL_STATUS_MASK) |
STATUS - This field indicates PPI ErrControl captured status from D-PHY
#define MIPI_CSI2RX_PPI_ERRESC_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRESC_STATUS_MASK) |
STATUS - This field indicates PPI ErrEsc captured status from D-PHY
#define MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOT_HS_STATUS_MASK) |
STATUS - This field indicates PPI ErrSotHS captured status from D-PHY
#define MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSOTSYNC_HS_STATUS_MASK) |
STATUS - This field indicates PPI ErrSotSync_HS captured status from D-PHY
#define MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_SHIFT)) & MIPI_CSI2RX_PPI_ERRSYNCESC_STATUS_MASK) |
STATUS - This field indicates PPI ErrSyncEsc captured status from D-PHY
#define MIPI_CSI2RX_ULPS_STATUS_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << MIPI_CSI2RX_ULPS_STATUS_STATUS_SHIFT)) & MIPI_CSI2RX_ULPS_STATUS_STATUS_MASK) |
STATUS - This field shows the status of Rx D-PHY ULPS state
