#define | LCDIF_CTRL_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RUN_SHIFT)) & LCDIF_CTRL_RUN_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RSRVD0_SHIFT)) & LCDIF_CTRL_RSRVD0_MASK) |
#define | LCDIF_CTRL_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_MASTER_SHIFT)) & LCDIF_CTRL_MASTER_MASK) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLKGATE_SHIFT)) & LCDIF_CTRL_CLKGATE_MASK) |
#define | LCDIF_CTRL_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SFTRST_SHIFT)) & LCDIF_CTRL_SFTRST_MASK) |
#define | LCDIF_CTRL_SET_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_SET_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_SET_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RUN_SHIFT)) & LCDIF_CTRL_SET_RUN_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_SET_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_SET_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RSRVD0_SHIFT)) & LCDIF_CTRL_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL_SET_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_SET_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_SET_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_MASTER_SHIFT)) & LCDIF_CTRL_SET_MASTER_MASK) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_SET_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_SET_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_SET_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_SET_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_SET_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_SET_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CLKGATE_SHIFT)) & LCDIF_CTRL_SET_CLKGATE_MASK) |
#define | LCDIF_CTRL_SET_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SET_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SET_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SFTRST_SHIFT)) & LCDIF_CTRL_SET_SFTRST_MASK) |
#define | LCDIF_CTRL_CLR_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_CLR_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_CLR_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RUN_SHIFT)) & LCDIF_CTRL_CLR_RUN_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_CLR_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_CLR_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL_CLR_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_CLR_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_CLR_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_MASTER_SHIFT)) & LCDIF_CTRL_CLR_MASTER_MASK) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_CLR_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_CLR_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_CLR_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLR_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLR_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLR_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CLKGATE_SHIFT)) & LCDIF_CTRL_CLR_CLKGATE_MASK) |
#define | LCDIF_CTRL_CLR_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_CLR_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_CLR_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SFTRST_SHIFT)) & LCDIF_CTRL_CLR_SFTRST_MASK) |
#define | LCDIF_CTRL_TOG_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_TOG_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_TOG_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RUN_SHIFT)) & LCDIF_CTRL_TOG_RUN_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_TOG_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_TOG_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL_TOG_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_TOG_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_TOG_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_MASTER_SHIFT)) & LCDIF_CTRL_TOG_MASTER_MASK) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_TOG_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_TOG_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_TOG_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_TOG_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_TOG_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_TOG_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CLKGATE_SHIFT)) & LCDIF_CTRL_TOG_CLKGATE_MASK) |
#define | LCDIF_CTRL_TOG_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_TOG_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_TOG_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SFTRST_SHIFT)) & LCDIF_CTRL_TOG_SFTRST_MASK) |
#define | LCDIF_CTRL1_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RSRVD0_SHIFT)) & LCDIF_CTRL1_RSRVD0_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_SET_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RSRVD0_SHIFT)) & LCDIF_CTRL1_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_SET_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_CLR_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL1_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_TOG_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL1_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL2_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD0_SHIFT)) & LCDIF_CTRL2_RSRVD0_MASK) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD3_SHIFT)) & LCDIF_CTRL2_RSRVD3_MASK) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD4_SHIFT)) & LCDIF_CTRL2_RSRVD4_MASK) |
#define | LCDIF_CTRL2_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD5_SHIFT)) & LCDIF_CTRL2_RSRVD5_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_SET_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD0_SHIFT)) & LCDIF_CTRL2_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_SET_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_SET_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD3_SHIFT)) & LCDIF_CTRL2_SET_RSRVD3_MASK) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_SET_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_SET_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD4_SHIFT)) & LCDIF_CTRL2_SET_RSRVD4_MASK) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_SET_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_SET_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_SET_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD5_SHIFT)) & LCDIF_CTRL2_SET_RSRVD5_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_CLR_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_CLR_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_CLR_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD3_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD3_MASK) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_CLR_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_CLR_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD4_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD4_MASK) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_CLR_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_CLR_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_CLR_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD5_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD5_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_TOG_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_TOG_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_TOG_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD3_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD3_MASK) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_TOG_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_TOG_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD4_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD4_MASK) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_TOG_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_TOG_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_TOG_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD5_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD5_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_RSRVD2_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL0_RSRVD2_SHIFT (29U) |
#define | LCDIF_VDCTRL0_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_SHIFT (29U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT (29U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT (29U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD2_MASK) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK (0xFFFFU) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK (0xFFF0000U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT (16U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_MASK (0x10000000U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT (28U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT)) & LCDIF_VDCTRL3_VSYNC_ONLY_MASK) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK (0x20000000U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT (29U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT)) & LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK) |
#define | LCDIF_VDCTRL3_RSRVD0_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL3_RSRVD0_SHIFT (30U) |
#define | LCDIF_VDCTRL3_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_RSRVD0_SHIFT)) & LCDIF_VDCTRL3_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK (0x40000U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT (18U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT)) & LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK) |
#define | LCDIF_VDCTRL4_RSRVD0_MASK (0x1FF80000U) |
#define | LCDIF_VDCTRL4_RSRVD0_SHIFT (19U) |
#define | LCDIF_VDCTRL4_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_RSRVD0_SHIFT)) & LCDIF_VDCTRL4_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT (29U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK) |
#define | LCDIF_STAT_LFIFO_COUNT_MASK (0x1FFU) |
#define | LCDIF_STAT_LFIFO_COUNT_SHIFT (0U) |
#define | LCDIF_STAT_LFIFO_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_COUNT_SHIFT)) & LCDIF_STAT_LFIFO_COUNT_MASK) |
#define | LCDIF_STAT_RSRVD0_MASK (0x1FFFE00U) |
#define | LCDIF_STAT_RSRVD0_SHIFT (9U) |
#define | LCDIF_STAT_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_RSRVD0_SHIFT)) & LCDIF_STAT_RSRVD0_MASK) |
#define | LCDIF_STAT_TXFIFO_EMPTY_MASK (0x4000000U) |
#define | LCDIF_STAT_TXFIFO_EMPTY_SHIFT (26U) |
#define | LCDIF_STAT_TXFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_EMPTY_SHIFT)) & LCDIF_STAT_TXFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_TXFIFO_FULL_MASK (0x8000000U) |
#define | LCDIF_STAT_TXFIFO_FULL_SHIFT (27U) |
#define | LCDIF_STAT_TXFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_FULL_SHIFT)) & LCDIF_STAT_TXFIFO_FULL_MASK) |
#define | LCDIF_STAT_LFIFO_EMPTY_MASK (0x10000000U) |
#define | LCDIF_STAT_LFIFO_EMPTY_SHIFT (28U) |
#define | LCDIF_STAT_LFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_EMPTY_SHIFT)) & LCDIF_STAT_LFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_LFIFO_FULL_MASK (0x20000000U) |
#define | LCDIF_STAT_LFIFO_FULL_SHIFT (29U) |
#define | LCDIF_STAT_LFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_FULL_SHIFT)) & LCDIF_STAT_LFIFO_FULL_MASK) |
#define | LCDIF_STAT_PRESENT_MASK (0x80000000U) |
#define | LCDIF_STAT_PRESENT_SHIFT (31U) |
#define | LCDIF_STAT_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_PRESENT_SHIFT)) & LCDIF_STAT_PRESENT_MASK) |
#define | LCDIF_PIGEON_0_EN_MASK (0x1U) |
#define | LCDIF_PIGEON_0_EN_SHIFT (0U) |
#define | LCDIF_PIGEON_0_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_EN_SHIFT)) & LCDIF_PIGEON_0_EN_MASK) |
#define | LCDIF_PIGEON_0_POL_MASK (0x2U) |
#define | LCDIF_PIGEON_0_POL_SHIFT (1U) |
#define | LCDIF_PIGEON_0_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_POL_SHIFT)) & LCDIF_PIGEON_0_POL_MASK) |
#define | LCDIF_PIGEON_0_INC_SEL_MASK (0xCU) |
#define | LCDIF_PIGEON_0_INC_SEL_SHIFT (2U) |
#define | LCDIF_PIGEON_0_INC_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_INC_SEL_SHIFT)) & LCDIF_PIGEON_0_INC_SEL_MASK) |
#define | LCDIF_PIGEON_0_OFFSET_MASK (0xF0U) |
#define | LCDIF_PIGEON_0_OFFSET_SHIFT (4U) |
#define | LCDIF_PIGEON_0_OFFSET(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_OFFSET_SHIFT)) & LCDIF_PIGEON_0_OFFSET_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_MASK (0xF00U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT (8U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_SEL_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_MASK (0xFFF000U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SHIFT (12U) |
#define | LCDIF_PIGEON_0_MASK_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_MASK) |
#define | LCDIF_PIGEON_0_STATE_MASK_MASK (0xFF000000U) |
#define | LCDIF_PIGEON_0_STATE_MASK_SHIFT (24U) |
#define | LCDIF_PIGEON_0_STATE_MASK(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_STATE_MASK_SHIFT)) & LCDIF_PIGEON_0_STATE_MASK_MASK) |
#define | LCDIF_CTRL_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RUN_SHIFT)) & LCDIF_CTRL_RUN_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RSRVD0_SHIFT)) & LCDIF_CTRL_RSRVD0_MASK) |
#define | LCDIF_CTRL_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_MASTER_SHIFT)) & LCDIF_CTRL_MASTER_MASK) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLKGATE_SHIFT)) & LCDIF_CTRL_CLKGATE_MASK) |
#define | LCDIF_CTRL_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SFTRST_SHIFT)) & LCDIF_CTRL_SFTRST_MASK) |
#define | LCDIF_CTRL_SET_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_SET_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_SET_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RUN_SHIFT)) & LCDIF_CTRL_SET_RUN_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_SET_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_SET_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RSRVD0_SHIFT)) & LCDIF_CTRL_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL_SET_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_SET_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_SET_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_MASTER_SHIFT)) & LCDIF_CTRL_SET_MASTER_MASK) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_SET_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_SET_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_SET_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_SET_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_SET_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_SET_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CLKGATE_SHIFT)) & LCDIF_CTRL_SET_CLKGATE_MASK) |
#define | LCDIF_CTRL_SET_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SET_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SET_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SFTRST_SHIFT)) & LCDIF_CTRL_SET_SFTRST_MASK) |
#define | LCDIF_CTRL_CLR_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_CLR_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_CLR_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RUN_SHIFT)) & LCDIF_CTRL_CLR_RUN_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_CLR_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_CLR_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL_CLR_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_CLR_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_CLR_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_MASTER_SHIFT)) & LCDIF_CTRL_CLR_MASTER_MASK) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_CLR_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_CLR_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_CLR_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLR_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLR_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLR_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CLKGATE_SHIFT)) & LCDIF_CTRL_CLR_CLKGATE_MASK) |
#define | LCDIF_CTRL_CLR_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_CLR_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_CLR_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SFTRST_SHIFT)) & LCDIF_CTRL_CLR_SFTRST_MASK) |
#define | LCDIF_CTRL_TOG_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_TOG_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_TOG_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RUN_SHIFT)) & LCDIF_CTRL_TOG_RUN_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_TOG_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_TOG_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL_TOG_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_TOG_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_TOG_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_MASTER_SHIFT)) & LCDIF_CTRL_TOG_MASTER_MASK) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_TOG_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_TOG_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_TOG_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_TOG_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_TOG_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_TOG_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CLKGATE_SHIFT)) & LCDIF_CTRL_TOG_CLKGATE_MASK) |
#define | LCDIF_CTRL_TOG_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_TOG_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_TOG_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SFTRST_SHIFT)) & LCDIF_CTRL_TOG_SFTRST_MASK) |
#define | LCDIF_CTRL1_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RSRVD0_SHIFT)) & LCDIF_CTRL1_RSRVD0_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_SET_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RSRVD0_SHIFT)) & LCDIF_CTRL1_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_SET_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_CLR_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL1_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_TOG_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL1_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL2_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD0_SHIFT)) & LCDIF_CTRL2_RSRVD0_MASK) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD3_SHIFT)) & LCDIF_CTRL2_RSRVD3_MASK) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD4_SHIFT)) & LCDIF_CTRL2_RSRVD4_MASK) |
#define | LCDIF_CTRL2_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD5_SHIFT)) & LCDIF_CTRL2_RSRVD5_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_SET_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD0_SHIFT)) & LCDIF_CTRL2_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_SET_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_SET_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD3_SHIFT)) & LCDIF_CTRL2_SET_RSRVD3_MASK) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_SET_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_SET_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD4_SHIFT)) & LCDIF_CTRL2_SET_RSRVD4_MASK) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_SET_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_SET_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_SET_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD5_SHIFT)) & LCDIF_CTRL2_SET_RSRVD5_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_CLR_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_CLR_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_CLR_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD3_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD3_MASK) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_CLR_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_CLR_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD4_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD4_MASK) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_CLR_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_CLR_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_CLR_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD5_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD5_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_TOG_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_TOG_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_TOG_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD3_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD3_MASK) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_TOG_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_TOG_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD4_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD4_MASK) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_TOG_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_TOG_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_TOG_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD5_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD5_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD2_MASK) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK (0xFFFFU) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK (0xFFF0000U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT (16U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_MASK (0x10000000U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT (28U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT)) & LCDIF_VDCTRL3_VSYNC_ONLY_MASK) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK (0x20000000U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT (29U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT)) & LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK) |
#define | LCDIF_VDCTRL3_RSRVD0_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL3_RSRVD0_SHIFT (30U) |
#define | LCDIF_VDCTRL3_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_RSRVD0_SHIFT)) & LCDIF_VDCTRL3_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK (0x40000U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT (18U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT)) & LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK) |
#define | LCDIF_VDCTRL4_RSRVD0_MASK (0x1FF80000U) |
#define | LCDIF_VDCTRL4_RSRVD0_SHIFT (19U) |
#define | LCDIF_VDCTRL4_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_RSRVD0_SHIFT)) & LCDIF_VDCTRL4_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT (29U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK) |
#define | LCDIF_STAT_LFIFO_COUNT_MASK (0x1FFU) |
#define | LCDIF_STAT_LFIFO_COUNT_SHIFT (0U) |
#define | LCDIF_STAT_LFIFO_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_COUNT_SHIFT)) & LCDIF_STAT_LFIFO_COUNT_MASK) |
#define | LCDIF_STAT_RSRVD0_MASK (0x1FFFE00U) |
#define | LCDIF_STAT_RSRVD0_SHIFT (9U) |
#define | LCDIF_STAT_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_RSRVD0_SHIFT)) & LCDIF_STAT_RSRVD0_MASK) |
#define | LCDIF_STAT_TXFIFO_EMPTY_MASK (0x4000000U) |
#define | LCDIF_STAT_TXFIFO_EMPTY_SHIFT (26U) |
#define | LCDIF_STAT_TXFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_EMPTY_SHIFT)) & LCDIF_STAT_TXFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_TXFIFO_FULL_MASK (0x8000000U) |
#define | LCDIF_STAT_TXFIFO_FULL_SHIFT (27U) |
#define | LCDIF_STAT_TXFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_FULL_SHIFT)) & LCDIF_STAT_TXFIFO_FULL_MASK) |
#define | LCDIF_STAT_LFIFO_EMPTY_MASK (0x10000000U) |
#define | LCDIF_STAT_LFIFO_EMPTY_SHIFT (28U) |
#define | LCDIF_STAT_LFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_EMPTY_SHIFT)) & LCDIF_STAT_LFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_LFIFO_FULL_MASK (0x20000000U) |
#define | LCDIF_STAT_LFIFO_FULL_SHIFT (29U) |
#define | LCDIF_STAT_LFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_FULL_SHIFT)) & LCDIF_STAT_LFIFO_FULL_MASK) |
#define | LCDIF_STAT_DMA_REQ_MASK (0x40000000U) |
#define | LCDIF_STAT_DMA_REQ_SHIFT (30U) |
#define | LCDIF_STAT_DMA_REQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_DMA_REQ_SHIFT)) & LCDIF_STAT_DMA_REQ_MASK) |
#define | LCDIF_STAT_PRESENT_MASK (0x80000000U) |
#define | LCDIF_STAT_PRESENT_SHIFT (31U) |
#define | LCDIF_STAT_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_PRESENT_SHIFT)) & LCDIF_STAT_PRESENT_MASK) |
#define | LCDIF_PIGEON_0_EN_MASK (0x1U) |
#define | LCDIF_PIGEON_0_EN_SHIFT (0U) |
#define | LCDIF_PIGEON_0_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_EN_SHIFT)) & LCDIF_PIGEON_0_EN_MASK) |
#define | LCDIF_PIGEON_0_POL_MASK (0x2U) |
#define | LCDIF_PIGEON_0_POL_SHIFT (1U) |
#define | LCDIF_PIGEON_0_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_POL_SHIFT)) & LCDIF_PIGEON_0_POL_MASK) |
#define | LCDIF_PIGEON_0_INC_SEL_MASK (0xCU) |
#define | LCDIF_PIGEON_0_INC_SEL_SHIFT (2U) |
#define | LCDIF_PIGEON_0_INC_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_INC_SEL_SHIFT)) & LCDIF_PIGEON_0_INC_SEL_MASK) |
#define | LCDIF_PIGEON_0_OFFSET_MASK (0xF0U) |
#define | LCDIF_PIGEON_0_OFFSET_SHIFT (4U) |
#define | LCDIF_PIGEON_0_OFFSET(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_OFFSET_SHIFT)) & LCDIF_PIGEON_0_OFFSET_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_MASK (0xF00U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT (8U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_SEL_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_MASK (0xFFF000U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SHIFT (12U) |
#define | LCDIF_PIGEON_0_MASK_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_MASK) |
#define | LCDIF_PIGEON_0_STATE_MASK_MASK (0xFF000000U) |
#define | LCDIF_PIGEON_0_STATE_MASK_SHIFT (24U) |
#define | LCDIF_PIGEON_0_STATE_MASK(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_STATE_MASK_SHIFT)) & LCDIF_PIGEON_0_STATE_MASK_MASK) |
#define | LCDIF_CTRL_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RUN_SHIFT)) & LCDIF_CTRL_RUN_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_RSRVD0_SHIFT)) & LCDIF_CTRL_RSRVD0_MASK) |
#define | LCDIF_CTRL_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_MASTER_SHIFT)) & LCDIF_CTRL_MASTER_MASK) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLKGATE_SHIFT)) & LCDIF_CTRL_CLKGATE_MASK) |
#define | LCDIF_CTRL_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SFTRST_SHIFT)) & LCDIF_CTRL_SFTRST_MASK) |
#define | LCDIF_CTRL_SET_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_SET_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_SET_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RUN_SHIFT)) & LCDIF_CTRL_SET_RUN_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_SET_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_SET_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_SET_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_SET_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_RSRVD0_SHIFT)) & LCDIF_CTRL_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL_SET_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_SET_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_SET_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_MASTER_SHIFT)) & LCDIF_CTRL_SET_MASTER_MASK) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_SET_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_SET_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_SET_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_SET_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_SET_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_SET_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_SET_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_SET_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_SET_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_SET_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_SET_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_SET_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_SET_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_SET_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_SET_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_SET_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_SET_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_SET_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_CLKGATE_SHIFT)) & LCDIF_CTRL_SET_CLKGATE_MASK) |
#define | LCDIF_CTRL_SET_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_SET_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_SET_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_SET_SFTRST_SHIFT)) & LCDIF_CTRL_SET_SFTRST_MASK) |
#define | LCDIF_CTRL_CLR_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_CLR_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_CLR_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RUN_SHIFT)) & LCDIF_CTRL_CLR_RUN_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_CLR_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_CLR_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_CLR_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL_CLR_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_CLR_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_CLR_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_MASTER_SHIFT)) & LCDIF_CTRL_CLR_MASTER_MASK) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_CLR_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_CLR_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_CLR_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_CLR_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_CLR_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_CLR_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_CLR_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_CLR_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_CLR_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_CLR_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_CLR_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_CLR_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_CLR_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_CLR_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_CLR_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_CLR_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_CLKGATE_SHIFT)) & LCDIF_CTRL_CLR_CLKGATE_MASK) |
#define | LCDIF_CTRL_CLR_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_CLR_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_CLR_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_CLR_SFTRST_SHIFT)) & LCDIF_CTRL_CLR_SFTRST_MASK) |
#define | LCDIF_CTRL_TOG_RUN_MASK (0x1U) |
#define | LCDIF_CTRL_TOG_RUN_SHIFT (0U) |
#define | LCDIF_CTRL_TOG_RUN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RUN_SHIFT)) & LCDIF_CTRL_TOG_RUN_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK (0x2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT (1U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_24_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK (0x4U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT (2U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_18_BIT_MASK) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK (0x8U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT (3U) |
#define | LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_SHIFT)) & LCDIF_CTRL_TOG_DATA_FORMAT_16_BIT_MASK) |
#define | LCDIF_CTRL_TOG_RSRVD0_MASK (0x10U) |
#define | LCDIF_CTRL_TOG_RSRVD0_SHIFT (4U) |
#define | LCDIF_CTRL_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL_TOG_MASTER_MASK (0x20U) |
#define | LCDIF_CTRL_TOG_MASTER_SHIFT (5U) |
#define | LCDIF_CTRL_TOG_MASTER(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_MASTER_SHIFT)) & LCDIF_CTRL_TOG_MASTER_MASK) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK (0x40U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT (6U) |
#define | LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_SHIFT)) & LCDIF_CTRL_TOG_ENABLE_PXP_HANDSHAKE_MASK) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_MASK (0x300U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT (8U) |
#define | LCDIF_CTRL_TOG_WORD_LENGTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_WORD_LENGTH_SHIFT)) & LCDIF_CTRL_TOG_WORD_LENGTH_MASK) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK (0xC00U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT (10U) |
#define | LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_SHIFT)) & LCDIF_CTRL_TOG_LCD_DATABUS_WIDTH_MASK) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK (0x3000U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT (12U) |
#define | LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_CSC_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK (0xC000U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT (14U) |
#define | LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_SHIFT)) & LCDIF_CTRL_TOG_INPUT_DATA_SWIZZLE_MASK) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_MASK (0x20000U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT (17U) |
#define | LCDIF_CTRL_TOG_DOTCLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DOTCLK_MODE_SHIFT)) & LCDIF_CTRL_TOG_DOTCLK_MODE_MASK) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_MASK (0x80000U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT (19U) |
#define | LCDIF_CTRL_TOG_BYPASS_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_BYPASS_COUNT_SHIFT)) & LCDIF_CTRL_TOG_BYPASS_COUNT_MASK) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK (0x3E00000U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT (21U) |
#define | LCDIF_CTRL_TOG_SHIFT_NUM_BITS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SHIFT_NUM_BITS_SHIFT)) & LCDIF_CTRL_TOG_SHIFT_NUM_BITS_MASK) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK (0x4000000U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT (26U) |
#define | LCDIF_CTRL_TOG_DATA_SHIFT_DIR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_DATA_SHIFT_DIR_SHIFT)) & LCDIF_CTRL_TOG_DATA_SHIFT_DIR_MASK) |
#define | LCDIF_CTRL_TOG_CLKGATE_MASK (0x40000000U) |
#define | LCDIF_CTRL_TOG_CLKGATE_SHIFT (30U) |
#define | LCDIF_CTRL_TOG_CLKGATE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_CLKGATE_SHIFT)) & LCDIF_CTRL_TOG_CLKGATE_MASK) |
#define | LCDIF_CTRL_TOG_SFTRST_MASK (0x80000000U) |
#define | LCDIF_CTRL_TOG_SFTRST_SHIFT (31U) |
#define | LCDIF_CTRL_TOG_SFTRST(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL_TOG_SFTRST_SHIFT)) & LCDIF_CTRL_TOG_SFTRST_MASK) |
#define | LCDIF_CTRL1_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RSRVD0_SHIFT)) & LCDIF_CTRL1_RSRVD0_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_SET_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RSRVD0_SHIFT)) & LCDIF_CTRL1_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_SET_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_SET_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_SET_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_SET_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_SET_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_SET_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_SET_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_SET_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_SET_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_SET_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_SET_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_SET_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_CLR_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL1_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_CLR_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_CLR_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_CLR_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_CLR_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_CLR_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_CLR_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_CLR_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_CLR_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_CLR_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_CLR_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_RSRVD0_MASK (0xF8U) |
#define | LCDIF_CTRL1_TOG_RSRVD0_SHIFT (3U) |
#define | LCDIF_CTRL1_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL1_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK (0x100U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT (8U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK (0x200U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT (9U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK (0x400U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT (10U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK (0x800U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT (11U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK (0x1000U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT (12U) |
#define | LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_VSYNC_EDGE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK (0x2000U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT (13U) |
#define | LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_CUR_FRAME_DONE_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK (0x4000U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT (14U) |
#define | LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_UNDERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK (0x8000U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT (15U) |
#define | LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_OVERFLOW_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK (0xF0000U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT (16U) |
#define | LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_SHIFT)) & LCDIF_CTRL1_TOG_BYTE_PACKING_FORMAT_MASK) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK (0x100000U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT (20U) |
#define | LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_IRQ_ON_ALTERNATE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK (0x200000U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT (21U) |
#define | LCDIF_CTRL1_TOG_FIFO_CLEAR(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_FIFO_CLEAR_SHIFT)) & LCDIF_CTRL1_TOG_FIFO_CLEAR_MASK) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK (0x400000U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT (22U) |
#define | LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_SHIFT)) & LCDIF_CTRL1_TOG_START_INTERLACE_FROM_SECOND_FIELD_MASK) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK (0x800000U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT (23U) |
#define | LCDIF_CTRL1_TOG_INTERLACE_FIELDS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_INTERLACE_FIELDS_SHIFT)) & LCDIF_CTRL1_TOG_INTERLACE_FIELDS_MASK) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK (0x1000000U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT (24U) |
#define | LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_SHIFT)) & LCDIF_CTRL1_TOG_RECOVER_ON_UNDERFLOW_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK (0x2000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT (25U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_MASK) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK (0x4000000U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT (26U) |
#define | LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_SHIFT)) & LCDIF_CTRL1_TOG_BM_ERROR_IRQ_EN_MASK) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK (0x40000000U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT (30U) |
#define | LCDIF_CTRL1_TOG_CS_OUT_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_CS_OUT_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_CS_OUT_SELECT_MASK) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK (0x80000000U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT (31U) |
#define | LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_SHIFT)) & LCDIF_CTRL1_TOG_IMAGE_DATA_SELECT_MASK) |
#define | LCDIF_CTRL2_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD0_SHIFT)) & LCDIF_CTRL2_RSRVD0_MASK) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD3_SHIFT)) & LCDIF_CTRL2_RSRVD3_MASK) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD4_SHIFT)) & LCDIF_CTRL2_RSRVD4_MASK) |
#define | LCDIF_CTRL2_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_RSRVD5_SHIFT)) & LCDIF_CTRL2_RSRVD5_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_SET_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_SET_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD0_SHIFT)) & LCDIF_CTRL2_SET_RSRVD0_MASK) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_SET_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_SET_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_SET_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD3_SHIFT)) & LCDIF_CTRL2_SET_RSRVD3_MASK) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_SET_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_SET_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_SET_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_SET_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD4_SHIFT)) & LCDIF_CTRL2_SET_RSRVD4_MASK) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_SET_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_SET_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_SET_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_SET_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_SET_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_SET_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_SET_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_SET_RSRVD5_SHIFT)) & LCDIF_CTRL2_SET_RSRVD5_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_CLR_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_CLR_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD0_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD0_MASK) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_CLR_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_CLR_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD3_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD3_MASK) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_CLR_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_CLR_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_CLR_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_CLR_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD4_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD4_MASK) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_CLR_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_CLR_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_CLR_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_CLR_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_CLR_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_CLR_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_CLR_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_CLR_RSRVD5_SHIFT)) & LCDIF_CTRL2_CLR_RSRVD5_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD0_MASK (0xFFFU) |
#define | LCDIF_CTRL2_TOG_RSRVD0_SHIFT (0U) |
#define | LCDIF_CTRL2_TOG_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD0_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD0_MASK) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK (0x7000U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT (12U) |
#define | LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_EVEN_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD3_MASK (0x8000U) |
#define | LCDIF_CTRL2_TOG_RSRVD3_SHIFT (15U) |
#define | LCDIF_CTRL2_TOG_RSRVD3(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD3_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD3_MASK) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK (0x70000U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT (16U) |
#define | LCDIF_CTRL2_TOG_ODD_LINE_PATTERN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_SHIFT)) & LCDIF_CTRL2_TOG_ODD_LINE_PATTERN_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD4_MASK (0x80000U) |
#define | LCDIF_CTRL2_TOG_RSRVD4_SHIFT (19U) |
#define | LCDIF_CTRL2_TOG_RSRVD4(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD4_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD4_MASK) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_MASK (0x100000U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT (20U) |
#define | LCDIF_CTRL2_TOG_BURST_LEN_8(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_BURST_LEN_8_SHIFT)) & LCDIF_CTRL2_TOG_BURST_LEN_8_MASK) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK (0xE00000U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT (21U) |
#define | LCDIF_CTRL2_TOG_OUTSTANDING_REQS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_OUTSTANDING_REQS_SHIFT)) & LCDIF_CTRL2_TOG_OUTSTANDING_REQS_MASK) |
#define | LCDIF_CTRL2_TOG_RSRVD5_MASK (0xFF000000U) |
#define | LCDIF_CTRL2_TOG_RSRVD5_SHIFT (24U) |
#define | LCDIF_CTRL2_TOG_RSRVD5(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_CTRL2_TOG_RSRVD5_SHIFT)) & LCDIF_CTRL2_TOG_RSRVD5_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_SET_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_SET_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_SET_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_SET_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_SET_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_SET_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_SET_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_SET_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_SET_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_SET_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_SET_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_SET_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_SET_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_CLR_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_CLR_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_CLR_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_CLR_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_CLR_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_CLR_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_CLR_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_CLR_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_CLR_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_CLR_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_CLR_RSRVD2_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT (0U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK (0x40000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT (18U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MODE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MODE_MASK) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_MASK (0x80000U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT (19U) |
#define | LCDIF_VDCTRL0_TOG_HALF_LINE(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HALF_LINE_SHIFT)) & LCDIF_VDCTRL0_TOG_HALF_LINE_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK (0x100000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT (20U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PULSE_WIDTH_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK (0x200000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT (21U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_PERIOD_UNIT_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_MASK (0xC00000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT (22U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD1(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD1_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD1_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK (0x1000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT (24U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK (0x2000000U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT (25U) |
#define | LCDIF_VDCTRL0_TOG_DOTCLK_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_DOTCLK_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_DOTCLK_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK (0x4000000U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT (26U) |
#define | LCDIF_VDCTRL0_TOG_HSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_HSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_HSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK (0x8000000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT (27U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_POL_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_POL_MASK) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK (0x10000000U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT (28U) |
#define | LCDIF_VDCTRL0_TOG_ENABLE_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_SHIFT)) & LCDIF_VDCTRL0_TOG_ENABLE_PRESENT_MASK) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB_MASK (0x20000000U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB_SHIFT (29U) |
#define | LCDIF_VDCTRL0_TOG_VSYNC_OEB(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_VSYNC_OEB_SHIFT)) & LCDIF_VDCTRL0_TOG_VSYNC_OEB_MASK) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT (30U) |
#define | LCDIF_VDCTRL0_TOG_RSRVD2(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL0_TOG_RSRVD2_SHIFT)) & LCDIF_VDCTRL0_TOG_RSRVD2_MASK) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK (0xFFFFU) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL3_VERTICAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK (0xFFF0000U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT (16U) |
#define | LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_SHIFT)) & LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_MASK (0x10000000U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT (28U) |
#define | LCDIF_VDCTRL3_VSYNC_ONLY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_VSYNC_ONLY_SHIFT)) & LCDIF_VDCTRL3_VSYNC_ONLY_MASK) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK (0x20000000U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT (29U) |
#define | LCDIF_VDCTRL3_MUX_SYNC_SIGNALS(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_SHIFT)) & LCDIF_VDCTRL3_MUX_SYNC_SIGNALS_MASK) |
#define | LCDIF_VDCTRL3_RSRVD0_MASK (0xC0000000U) |
#define | LCDIF_VDCTRL3_RSRVD0_SHIFT (30U) |
#define | LCDIF_VDCTRL3_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL3_RSRVD0_SHIFT)) & LCDIF_VDCTRL3_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK (0x3FFFFU) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT (0U) |
#define | LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK (0x40000U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT (18U) |
#define | LCDIF_VDCTRL4_SYNC_SIGNALS_ON(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_SYNC_SIGNALS_ON_SHIFT)) & LCDIF_VDCTRL4_SYNC_SIGNALS_ON_MASK) |
#define | LCDIF_VDCTRL4_RSRVD0_MASK (0x1FF80000U) |
#define | LCDIF_VDCTRL4_RSRVD0_SHIFT (19U) |
#define | LCDIF_VDCTRL4_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_RSRVD0_SHIFT)) & LCDIF_VDCTRL4_RSRVD0_MASK) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK (0xE0000000U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT (29U) |
#define | LCDIF_VDCTRL4_DOTCLK_DLY_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_SHIFT)) & LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK) |
#define | LCDIF_STAT_LFIFO_COUNT_MASK (0x1FFU) |
#define | LCDIF_STAT_LFIFO_COUNT_SHIFT (0U) |
#define | LCDIF_STAT_LFIFO_COUNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_COUNT_SHIFT)) & LCDIF_STAT_LFIFO_COUNT_MASK) |
#define | LCDIF_STAT_RSRVD0_MASK (0x1FFFE00U) |
#define | LCDIF_STAT_RSRVD0_SHIFT (9U) |
#define | LCDIF_STAT_RSRVD0(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_RSRVD0_SHIFT)) & LCDIF_STAT_RSRVD0_MASK) |
#define | LCDIF_STAT_TXFIFO_EMPTY_MASK (0x4000000U) |
#define | LCDIF_STAT_TXFIFO_EMPTY_SHIFT (26U) |
#define | LCDIF_STAT_TXFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_EMPTY_SHIFT)) & LCDIF_STAT_TXFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_TXFIFO_FULL_MASK (0x8000000U) |
#define | LCDIF_STAT_TXFIFO_FULL_SHIFT (27U) |
#define | LCDIF_STAT_TXFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_TXFIFO_FULL_SHIFT)) & LCDIF_STAT_TXFIFO_FULL_MASK) |
#define | LCDIF_STAT_LFIFO_EMPTY_MASK (0x10000000U) |
#define | LCDIF_STAT_LFIFO_EMPTY_SHIFT (28U) |
#define | LCDIF_STAT_LFIFO_EMPTY(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_EMPTY_SHIFT)) & LCDIF_STAT_LFIFO_EMPTY_MASK) |
#define | LCDIF_STAT_LFIFO_FULL_MASK (0x20000000U) |
#define | LCDIF_STAT_LFIFO_FULL_SHIFT (29U) |
#define | LCDIF_STAT_LFIFO_FULL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_LFIFO_FULL_SHIFT)) & LCDIF_STAT_LFIFO_FULL_MASK) |
#define | LCDIF_STAT_DMA_REQ_MASK (0x40000000U) |
#define | LCDIF_STAT_DMA_REQ_SHIFT (30U) |
#define | LCDIF_STAT_DMA_REQ(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_DMA_REQ_SHIFT)) & LCDIF_STAT_DMA_REQ_MASK) |
#define | LCDIF_STAT_PRESENT_MASK (0x80000000U) |
#define | LCDIF_STAT_PRESENT_SHIFT (31U) |
#define | LCDIF_STAT_PRESENT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_STAT_PRESENT_SHIFT)) & LCDIF_STAT_PRESENT_MASK) |
#define | LCDIF_PIGEON_0_EN_MASK (0x1U) |
#define | LCDIF_PIGEON_0_EN_SHIFT (0U) |
#define | LCDIF_PIGEON_0_EN(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_EN_SHIFT)) & LCDIF_PIGEON_0_EN_MASK) |
#define | LCDIF_PIGEON_0_POL_MASK (0x2U) |
#define | LCDIF_PIGEON_0_POL_SHIFT (1U) |
#define | LCDIF_PIGEON_0_POL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_POL_SHIFT)) & LCDIF_PIGEON_0_POL_MASK) |
#define | LCDIF_PIGEON_0_INC_SEL_MASK (0xCU) |
#define | LCDIF_PIGEON_0_INC_SEL_SHIFT (2U) |
#define | LCDIF_PIGEON_0_INC_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_INC_SEL_SHIFT)) & LCDIF_PIGEON_0_INC_SEL_MASK) |
#define | LCDIF_PIGEON_0_OFFSET_MASK (0xF0U) |
#define | LCDIF_PIGEON_0_OFFSET_SHIFT (4U) |
#define | LCDIF_PIGEON_0_OFFSET(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_OFFSET_SHIFT)) & LCDIF_PIGEON_0_OFFSET_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_MASK (0xF00U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT (8U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SEL(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SEL_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_SEL_MASK) |
#define | LCDIF_PIGEON_0_MASK_CNT_MASK (0xFFF000U) |
#define | LCDIF_PIGEON_0_MASK_CNT_SHIFT (12U) |
#define | LCDIF_PIGEON_0_MASK_CNT(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_MASK_CNT_SHIFT)) & LCDIF_PIGEON_0_MASK_CNT_MASK) |
#define | LCDIF_PIGEON_0_STATE_MASK_MASK (0xFF000000U) |
#define | LCDIF_PIGEON_0_STATE_MASK_SHIFT (24U) |
#define | LCDIF_PIGEON_0_STATE_MASK(x) (((uint32_t)(((uint32_t)(x)) << LCDIF_PIGEON_0_STATE_MASK_SHIFT)) & LCDIF_PIGEON_0_STATE_MASK_MASK) |
