RTEMS 6.1-rc1
CFG_NUM_LANES - CFG_NUM_LANES | |
#define | DSI_HOST_CFG_NUM_LANES_NUM_LANES_MASK (0x3U) |
#define | DSI_HOST_CFG_NUM_LANES_NUM_LANES_SHIFT (0U) |
#define | DSI_HOST_CFG_NUM_LANES_NUM_LANES(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_NUM_LANES_NUM_LANES_SHIFT)) & DSI_HOST_CFG_NUM_LANES_NUM_LANES_MASK) |
CFG_NONCONTINUOUS_CLK - CFG_NONCONTINUOUS_CLK | |
#define | DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_MASK (0x1U) |
#define | DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_SHIFT (0U) |
#define | DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_SHIFT)) & DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_MASK) |
CFG_T_PRE - CFG_T_PRE | |
#define | DSI_HOST_CFG_T_PRE_NUM_PERIODS_MASK (0xFFU) |
#define | DSI_HOST_CFG_T_PRE_NUM_PERIODS_SHIFT (0U) |
#define | DSI_HOST_CFG_T_PRE_NUM_PERIODS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_T_PRE_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_T_PRE_NUM_PERIODS_MASK) |
CFG_T_POST - CFG_T_POST | |
#define | DSI_HOST_CFG_T_POST_NUM_PERIODS_MASK (0xFFU) |
#define | DSI_HOST_CFG_T_POST_NUM_PERIODS_SHIFT (0U) |
#define | DSI_HOST_CFG_T_POST_NUM_PERIODS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_T_POST_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_T_POST_NUM_PERIODS_MASK) |
CFG_TX_GAP - CFG_TX_GAP | |
#define | DSI_HOST_CFG_TX_GAP_NUM_PERIODS_MASK (0xFFU) |
#define | DSI_HOST_CFG_TX_GAP_NUM_PERIODS_SHIFT (0U) |
#define | DSI_HOST_CFG_TX_GAP_NUM_PERIODS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_TX_GAP_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_TX_GAP_NUM_PERIODS_MASK) |
CFG_AUTOINSERT_EOTP - CFG_AUTOINSERT_ETOP | |
#define | DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_MASK (0x1U) |
#define | DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_SHIFT (0U) |
#define | DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_SHIFT)) & DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_MASK) |
CFG_EXTRA_CMDS_AFTER_EOTP - CFG_EXTRA_CMDS_AFTER_ETOP | |
#define | DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_MASK (0xFFU) |
#define | DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_SHIFT (0U) |
#define | DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_SHIFT)) & DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_MASK) |
CFG_HTX_TO_COUNT - CFG_HTX_TO_COUNT | |
#define | DSI_HOST_CFG_HTX_TO_COUNT_COUNT_MASK (0xFFFFFFU) |
#define | DSI_HOST_CFG_HTX_TO_COUNT_COUNT_SHIFT (0U) |
#define | DSI_HOST_CFG_HTX_TO_COUNT_COUNT(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_HTX_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_HTX_TO_COUNT_COUNT_MASK) |
CFG_LRX_H_TO_COUNT - CFG_LRX_H_TO_COUNT | |
#define | DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_MASK (0xFFFFFFU) |
#define | DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_SHIFT (0U) |
#define | DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_MASK) |
CFG_BTA_H_TO_COUNT - CFG_BTA_H_TO_COUNT | |
#define | DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_MASK (0xFFFFFFU) |
#define | DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_SHIFT (0U) |
#define | DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_MASK) |
CFG_TWAKEUP - CFG_TWAKEUP | |
#define | DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_MASK (0x7FFFFU) |
#define | DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_SHIFT (0U) |
#define | DSI_HOST_CFG_TWAKEUP_NUM_PERIODS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_MASK) |
CFG_STATUS_OUT - CFG_STATUS_OUT | |
#define | DSI_HOST_CFG_STATUS_OUT_STATUS_MASK (0xFFFFFFFFU) |
#define | DSI_HOST_CFG_STATUS_OUT_STATUS_SHIFT (0U) |
#define | DSI_HOST_CFG_STATUS_OUT_STATUS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_STATUS_OUT_STATUS_SHIFT)) & DSI_HOST_CFG_STATUS_OUT_STATUS_MASK) |
RX_ERROR_STATUS - RX_ERROR_STATUS | |
#define | DSI_HOST_RX_ERROR_STATUS_STATUS_MASK (0x7FFU) |
#define | DSI_HOST_RX_ERROR_STATUS_STATUS_SHIFT (0U) |
#define | DSI_HOST_RX_ERROR_STATUS_STATUS(x) (((uint32_t)(((uint32_t)(x)) << DSI_HOST_RX_ERROR_STATUS_STATUS_SHIFT)) & DSI_HOST_RX_ERROR_STATUS_STATUS_MASK) |
#define DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_SHIFT)) & DSI_HOST_CFG_AUTOINSERT_EOTP_AUTOINSERT_MASK) |
AUTOINSERT - Enables the Host Controller to automatically insert an EoTp short packet when switching from HS to LP mode. 0b0..EoTp is not automatically inserted 0b1..EoTp is automatically inserted
#define DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_BTA_H_TO_COUNT_COUNT_MASK) |
COUNT - Sets the value of the DSI Host Bus Turn Around (BTA) timeout in clk_byte clock periods that once reached will initiate a timeout error.
#define DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_SHIFT)) & DSI_HOST_CFG_EXTRA_CMDS_AFTER_EOTP_EXTRA_EOTP_MASK) |
EXTRA_EOTP - Configures the DSI Host Controller to send extra End Of Transmission Packets after the end of a packet. The value is the number of extra EOTP packets sent.
#define DSI_HOST_CFG_HTX_TO_COUNT_COUNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_HTX_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_HTX_TO_COUNT_COUNT_MASK) |
COUNT - Sets the value of the DSI Host High Speed TX timeout count in clk_byte clock periods that once reached will initiate a timeout error and follow the recovery procedure documented in the DSI specification.
#define DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_SHIFT)) & DSI_HOST_CFG_LRX_H_TO_COUNT_COUNT_MASK) |
COUNT - Sets the value of the DSI Host low power RX timeout count in clk_byte clock periods that once reached will initiate a timeout error and follow the recovery procedure documented in the DSI specification.
#define DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_SHIFT)) & DSI_HOST_CFG_NONCONTINUOUS_CLK_CLK_MODE_MASK) |
CLK_MODE - Sets the Host Controller into non-continuous MIPI clock mode. When in non-continuous clock mode, the high speed clock will transition into low power mode between transmissions. 0b0..Continuous high speed clock 0b1..Non-Continuous high speed clock
#define DSI_HOST_CFG_NUM_LANES_NUM_LANES | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_NUM_LANES_NUM_LANES_SHIFT)) & DSI_HOST_CFG_NUM_LANES_NUM_LANES_MASK) |
NUM_LANES - Sets the number of active lanes that are to be used for transmitting data. 0b00..1 lane 0b01..2 lanes
#define DSI_HOST_CFG_STATUS_OUT_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_STATUS_OUT_STATUS_SHIFT)) & DSI_HOST_CFG_STATUS_OUT_STATUS_MASK) |
STATUS - Status Register
#define DSI_HOST_CFG_T_POST_NUM_PERIODS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_T_POST_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_T_POST_NUM_PERIODS_MASK) |
NUM_PERIODS - Sets the number of byte clock periods ('clk_byte' input) to wait before putting the clock lane into LP mode after the data lanes have been detected to be in Stop State. This setting represents the DPHY timing parameters TLPX + TCLK-PREPARE + TCLK-ZERO + TCLK-PRE requirement for the clock lane before the data lane is allowed to change from LP11 to start a high speed transmission. The minimum value for this port is 1.
#define DSI_HOST_CFG_T_PRE_NUM_PERIODS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_T_PRE_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_T_PRE_NUM_PERIODS_MASK) |
NUM_PERIODS - Sets the number of byte clock periods ('clk_byte' input) that the controller will wait after enabling the clock lane for HS operation before enabling the data lanes for HS operation. This setting represents the TCLK-PRE DPHY timing parameter. The minimum value for this port is 1.
#define DSI_HOST_CFG_TWAKEUP_NUM_PERIODS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_TWAKEUP_NUM_PERIODS_MASK) |
NUM_PERIODS - DPHY Twakeup timing parameter. Sets the number of clk_esc clock periods to keep a clock or data lane in Mark-1 state after exiting ULPS. The MIPI DPHY spec requires a minimum of 1ms in Mark-1 state after leaving ULPS.
#define DSI_HOST_CFG_TX_GAP_NUM_PERIODS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_CFG_TX_GAP_NUM_PERIODS_SHIFT)) & DSI_HOST_CFG_TX_GAP_NUM_PERIODS_MASK) |
NUM_PERIODS - Sets the number of byte clock periods ('clk_byte' input) that the controller will wait after the clock lane has been put into LP mode before enabling the clock lane for HS mode again. This setting represents the THS-EXIT DPHY timing parameter. The minimum value for this port is 1.
#define DSI_HOST_RX_ERROR_STATUS_STATUS | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << DSI_HOST_RX_ERROR_STATUS_STATUS_SHIFT)) & DSI_HOST_RX_ERROR_STATUS_STATUS_MASK) |
STATUS - Status Register for Host receive error detection, ECC errors, CRC errors and for timeout indicators
