RTEMS 6.1-rc1
CTRL - DCP control register 0
#define DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_MASK   (0xFFU)
#define DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_SHIFT   (0U)
#define DCP_CTRL_CHANNEL_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_RSVD_CSC_INTERRUPT_ENABLE_MASK   (0x100U)
#define DCP_CTRL_RSVD_CSC_INTERRUPT_ENABLE_SHIFT   (8U)
#define DCP_CTRL_RSVD_CSC_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_RSVD_CSC_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_RSVD_CSC_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_ENABLE_CONTEXT_SWITCHING_MASK   (0x200000U)
#define DCP_CTRL_ENABLE_CONTEXT_SWITCHING_SHIFT   (21U)
#define DCP_CTRL_ENABLE_CONTEXT_SWITCHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_ENABLE_CONTEXT_SWITCHING_SHIFT)) & DCP_CTRL_ENABLE_CONTEXT_SWITCHING_MASK)
#define DCP_CTRL_ENABLE_CONTEXT_CACHING_MASK   (0x400000U)
#define DCP_CTRL_ENABLE_CONTEXT_CACHING_SHIFT   (22U)
#define DCP_CTRL_ENABLE_CONTEXT_CACHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_ENABLE_CONTEXT_CACHING_SHIFT)) & DCP_CTRL_ENABLE_CONTEXT_CACHING_MASK)
#define DCP_CTRL_GATHER_RESIDUAL_WRITES_MASK   (0x800000U)
#define DCP_CTRL_GATHER_RESIDUAL_WRITES_SHIFT   (23U)
#define DCP_CTRL_GATHER_RESIDUAL_WRITES(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_GATHER_RESIDUAL_WRITES_SHIFT)) & DCP_CTRL_GATHER_RESIDUAL_WRITES_MASK)
#define DCP_CTRL_PRESENT_SHA_MASK   (0x10000000U)
#define DCP_CTRL_PRESENT_SHA_SHIFT   (28U)
#define DCP_CTRL_PRESENT_SHA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_PRESENT_SHA_SHIFT)) & DCP_CTRL_PRESENT_SHA_MASK)
#define DCP_CTRL_PRESENT_CRYPTO_MASK   (0x20000000U)
#define DCP_CTRL_PRESENT_CRYPTO_SHIFT   (29U)
#define DCP_CTRL_PRESENT_CRYPTO(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_PRESENT_CRYPTO_MASK)
#define DCP_CTRL_CLKGATE_MASK   (0x40000000U)
#define DCP_CTRL_CLKGATE_SHIFT   (30U)
#define DCP_CTRL_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLKGATE_SHIFT)) & DCP_CTRL_CLKGATE_MASK)
#define DCP_CTRL_SFTRST_MASK   (0x80000000U)
#define DCP_CTRL_SFTRST_SHIFT   (31U)
#define DCP_CTRL_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SFTRST_SHIFT)) & DCP_CTRL_SFTRST_MASK)
CTRL_SET - DCP control register 0
#define DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_MASK   (0xFFU)
#define DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_SHIFT   (0U)
#define DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_SET_RSVD_CSC_INTERRUPT_ENABLE_MASK   (0x100U)
#define DCP_CTRL_SET_RSVD_CSC_INTERRUPT_ENABLE_SHIFT   (8U)
#define DCP_CTRL_SET_RSVD_CSC_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_RSVD_CSC_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_SET_RSVD_CSC_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_SET_ENABLE_CONTEXT_SWITCHING_MASK   (0x200000U)
#define DCP_CTRL_SET_ENABLE_CONTEXT_SWITCHING_SHIFT   (21U)
#define DCP_CTRL_SET_ENABLE_CONTEXT_SWITCHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_ENABLE_CONTEXT_SWITCHING_SHIFT)) & DCP_CTRL_SET_ENABLE_CONTEXT_SWITCHING_MASK)
#define DCP_CTRL_SET_ENABLE_CONTEXT_CACHING_MASK   (0x400000U)
#define DCP_CTRL_SET_ENABLE_CONTEXT_CACHING_SHIFT   (22U)
#define DCP_CTRL_SET_ENABLE_CONTEXT_CACHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_ENABLE_CONTEXT_CACHING_SHIFT)) & DCP_CTRL_SET_ENABLE_CONTEXT_CACHING_MASK)
#define DCP_CTRL_SET_GATHER_RESIDUAL_WRITES_MASK   (0x800000U)
#define DCP_CTRL_SET_GATHER_RESIDUAL_WRITES_SHIFT   (23U)
#define DCP_CTRL_SET_GATHER_RESIDUAL_WRITES(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_GATHER_RESIDUAL_WRITES_SHIFT)) & DCP_CTRL_SET_GATHER_RESIDUAL_WRITES_MASK)
#define DCP_CTRL_SET_PRESENT_SHA_MASK   (0x10000000U)
#define DCP_CTRL_SET_PRESENT_SHA_SHIFT   (28U)
#define DCP_CTRL_SET_PRESENT_SHA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_PRESENT_SHA_SHIFT)) & DCP_CTRL_SET_PRESENT_SHA_MASK)
#define DCP_CTRL_SET_PRESENT_CRYPTO_MASK   (0x20000000U)
#define DCP_CTRL_SET_PRESENT_CRYPTO_SHIFT   (29U)
#define DCP_CTRL_SET_PRESENT_CRYPTO(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_SET_PRESENT_CRYPTO_MASK)
#define DCP_CTRL_SET_CLKGATE_MASK   (0x40000000U)
#define DCP_CTRL_SET_CLKGATE_SHIFT   (30U)
#define DCP_CTRL_SET_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_CLKGATE_SHIFT)) & DCP_CTRL_SET_CLKGATE_MASK)
#define DCP_CTRL_SET_SFTRST_MASK   (0x80000000U)
#define DCP_CTRL_SET_SFTRST_SHIFT   (31U)
#define DCP_CTRL_SET_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_SFTRST_SHIFT)) & DCP_CTRL_SET_SFTRST_MASK)
CTRL_CLR - DCP control register 0
#define DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_MASK   (0xFFU)
#define DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_SHIFT   (0U)
#define DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_CLR_RSVD_CSC_INTERRUPT_ENABLE_MASK   (0x100U)
#define DCP_CTRL_CLR_RSVD_CSC_INTERRUPT_ENABLE_SHIFT   (8U)
#define DCP_CTRL_CLR_RSVD_CSC_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_RSVD_CSC_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_CLR_RSVD_CSC_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_SWITCHING_MASK   (0x200000U)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_SWITCHING_SHIFT   (21U)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_SWITCHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_ENABLE_CONTEXT_SWITCHING_SHIFT)) & DCP_CTRL_CLR_ENABLE_CONTEXT_SWITCHING_MASK)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_CACHING_MASK   (0x400000U)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_CACHING_SHIFT   (22U)
#define DCP_CTRL_CLR_ENABLE_CONTEXT_CACHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_ENABLE_CONTEXT_CACHING_SHIFT)) & DCP_CTRL_CLR_ENABLE_CONTEXT_CACHING_MASK)
#define DCP_CTRL_CLR_GATHER_RESIDUAL_WRITES_MASK   (0x800000U)
#define DCP_CTRL_CLR_GATHER_RESIDUAL_WRITES_SHIFT   (23U)
#define DCP_CTRL_CLR_GATHER_RESIDUAL_WRITES(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_GATHER_RESIDUAL_WRITES_SHIFT)) & DCP_CTRL_CLR_GATHER_RESIDUAL_WRITES_MASK)
#define DCP_CTRL_CLR_PRESENT_SHA_MASK   (0x10000000U)
#define DCP_CTRL_CLR_PRESENT_SHA_SHIFT   (28U)
#define DCP_CTRL_CLR_PRESENT_SHA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_PRESENT_SHA_SHIFT)) & DCP_CTRL_CLR_PRESENT_SHA_MASK)
#define DCP_CTRL_CLR_PRESENT_CRYPTO_MASK   (0x20000000U)
#define DCP_CTRL_CLR_PRESENT_CRYPTO_SHIFT   (29U)
#define DCP_CTRL_CLR_PRESENT_CRYPTO(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_CLR_PRESENT_CRYPTO_MASK)
#define DCP_CTRL_CLR_CLKGATE_MASK   (0x40000000U)
#define DCP_CTRL_CLR_CLKGATE_SHIFT   (30U)
#define DCP_CTRL_CLR_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_CLKGATE_SHIFT)) & DCP_CTRL_CLR_CLKGATE_MASK)
#define DCP_CTRL_CLR_SFTRST_MASK   (0x80000000U)
#define DCP_CTRL_CLR_SFTRST_SHIFT   (31U)
#define DCP_CTRL_CLR_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_SFTRST_SHIFT)) & DCP_CTRL_CLR_SFTRST_MASK)
CTRL_TOG - DCP control register 0
#define DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_MASK   (0xFFU)
#define DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_SHIFT   (0U)
#define DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_TOG_RSVD_CSC_INTERRUPT_ENABLE_MASK   (0x100U)
#define DCP_CTRL_TOG_RSVD_CSC_INTERRUPT_ENABLE_SHIFT   (8U)
#define DCP_CTRL_TOG_RSVD_CSC_INTERRUPT_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_RSVD_CSC_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_TOG_RSVD_CSC_INTERRUPT_ENABLE_MASK)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_SWITCHING_MASK   (0x200000U)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_SWITCHING_SHIFT   (21U)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_SWITCHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_ENABLE_CONTEXT_SWITCHING_SHIFT)) & DCP_CTRL_TOG_ENABLE_CONTEXT_SWITCHING_MASK)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_CACHING_MASK   (0x400000U)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_CACHING_SHIFT   (22U)
#define DCP_CTRL_TOG_ENABLE_CONTEXT_CACHING(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_ENABLE_CONTEXT_CACHING_SHIFT)) & DCP_CTRL_TOG_ENABLE_CONTEXT_CACHING_MASK)
#define DCP_CTRL_TOG_GATHER_RESIDUAL_WRITES_MASK   (0x800000U)
#define DCP_CTRL_TOG_GATHER_RESIDUAL_WRITES_SHIFT   (23U)
#define DCP_CTRL_TOG_GATHER_RESIDUAL_WRITES(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_GATHER_RESIDUAL_WRITES_SHIFT)) & DCP_CTRL_TOG_GATHER_RESIDUAL_WRITES_MASK)
#define DCP_CTRL_TOG_PRESENT_SHA_MASK   (0x10000000U)
#define DCP_CTRL_TOG_PRESENT_SHA_SHIFT   (28U)
#define DCP_CTRL_TOG_PRESENT_SHA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_PRESENT_SHA_SHIFT)) & DCP_CTRL_TOG_PRESENT_SHA_MASK)
#define DCP_CTRL_TOG_PRESENT_CRYPTO_MASK   (0x20000000U)
#define DCP_CTRL_TOG_PRESENT_CRYPTO_SHIFT   (29U)
#define DCP_CTRL_TOG_PRESENT_CRYPTO(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_TOG_PRESENT_CRYPTO_MASK)
#define DCP_CTRL_TOG_CLKGATE_MASK   (0x40000000U)
#define DCP_CTRL_TOG_CLKGATE_SHIFT   (30U)
#define DCP_CTRL_TOG_CLKGATE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_CLKGATE_SHIFT)) & DCP_CTRL_TOG_CLKGATE_MASK)
#define DCP_CTRL_TOG_SFTRST_MASK   (0x80000000U)
#define DCP_CTRL_TOG_SFTRST_SHIFT   (31U)
#define DCP_CTRL_TOG_SFTRST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_SFTRST_SHIFT)) & DCP_CTRL_TOG_SFTRST_MASK)
STAT - DCP status register
#define DCP_STAT_IRQ_MASK   (0xFU)
#define DCP_STAT_IRQ_SHIFT   (0U)
#define DCP_STAT_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_IRQ_SHIFT)) & DCP_STAT_IRQ_MASK)
#define DCP_STAT_RSVD_IRQ_MASK   (0x100U)
#define DCP_STAT_RSVD_IRQ_SHIFT   (8U)
#define DCP_STAT_RSVD_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_RSVD_IRQ_SHIFT)) & DCP_STAT_RSVD_IRQ_MASK)
#define DCP_STAT_READY_CHANNELS_MASK   (0xFF0000U)
#define DCP_STAT_READY_CHANNELS_SHIFT   (16U)
#define DCP_STAT_READY_CHANNELS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_READY_CHANNELS_SHIFT)) & DCP_STAT_READY_CHANNELS_MASK)
#define DCP_STAT_CUR_CHANNEL_MASK   (0xF000000U)
#define DCP_STAT_CUR_CHANNEL_SHIFT   (24U)
#define DCP_STAT_CUR_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CUR_CHANNEL_SHIFT)) & DCP_STAT_CUR_CHANNEL_MASK)
#define DCP_STAT_OTP_KEY_READY_MASK   (0x10000000U)
#define DCP_STAT_OTP_KEY_READY_SHIFT   (28U)
#define DCP_STAT_OTP_KEY_READY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_OTP_KEY_READY_SHIFT)) & DCP_STAT_OTP_KEY_READY_MASK)
STAT_SET - DCP status register
#define DCP_STAT_SET_IRQ_MASK   (0xFU)
#define DCP_STAT_SET_IRQ_SHIFT   (0U)
#define DCP_STAT_SET_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_IRQ_SHIFT)) & DCP_STAT_SET_IRQ_MASK)
#define DCP_STAT_SET_RSVD_IRQ_MASK   (0x100U)
#define DCP_STAT_SET_RSVD_IRQ_SHIFT   (8U)
#define DCP_STAT_SET_RSVD_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_RSVD_IRQ_SHIFT)) & DCP_STAT_SET_RSVD_IRQ_MASK)
#define DCP_STAT_SET_READY_CHANNELS_MASK   (0xFF0000U)
#define DCP_STAT_SET_READY_CHANNELS_SHIFT   (16U)
#define DCP_STAT_SET_READY_CHANNELS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_READY_CHANNELS_SHIFT)) & DCP_STAT_SET_READY_CHANNELS_MASK)
#define DCP_STAT_SET_CUR_CHANNEL_MASK   (0xF000000U)
#define DCP_STAT_SET_CUR_CHANNEL_SHIFT   (24U)
#define DCP_STAT_SET_CUR_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_CUR_CHANNEL_SHIFT)) & DCP_STAT_SET_CUR_CHANNEL_MASK)
#define DCP_STAT_SET_OTP_KEY_READY_MASK   (0x10000000U)
#define DCP_STAT_SET_OTP_KEY_READY_SHIFT   (28U)
#define DCP_STAT_SET_OTP_KEY_READY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_OTP_KEY_READY_SHIFT)) & DCP_STAT_SET_OTP_KEY_READY_MASK)
STAT_CLR - DCP status register
#define DCP_STAT_CLR_IRQ_MASK   (0xFU)
#define DCP_STAT_CLR_IRQ_SHIFT   (0U)
#define DCP_STAT_CLR_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_IRQ_SHIFT)) & DCP_STAT_CLR_IRQ_MASK)
#define DCP_STAT_CLR_RSVD_IRQ_MASK   (0x100U)
#define DCP_STAT_CLR_RSVD_IRQ_SHIFT   (8U)
#define DCP_STAT_CLR_RSVD_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_RSVD_IRQ_SHIFT)) & DCP_STAT_CLR_RSVD_IRQ_MASK)
#define DCP_STAT_CLR_READY_CHANNELS_MASK   (0xFF0000U)
#define DCP_STAT_CLR_READY_CHANNELS_SHIFT   (16U)
#define DCP_STAT_CLR_READY_CHANNELS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_READY_CHANNELS_SHIFT)) & DCP_STAT_CLR_READY_CHANNELS_MASK)
#define DCP_STAT_CLR_CUR_CHANNEL_MASK   (0xF000000U)
#define DCP_STAT_CLR_CUR_CHANNEL_SHIFT   (24U)
#define DCP_STAT_CLR_CUR_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_CUR_CHANNEL_SHIFT)) & DCP_STAT_CLR_CUR_CHANNEL_MASK)
#define DCP_STAT_CLR_OTP_KEY_READY_MASK   (0x10000000U)
#define DCP_STAT_CLR_OTP_KEY_READY_SHIFT   (28U)
#define DCP_STAT_CLR_OTP_KEY_READY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_OTP_KEY_READY_SHIFT)) & DCP_STAT_CLR_OTP_KEY_READY_MASK)
STAT_TOG - DCP status register
#define DCP_STAT_TOG_IRQ_MASK   (0xFU)
#define DCP_STAT_TOG_IRQ_SHIFT   (0U)
#define DCP_STAT_TOG_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_IRQ_SHIFT)) & DCP_STAT_TOG_IRQ_MASK)
#define DCP_STAT_TOG_RSVD_IRQ_MASK   (0x100U)
#define DCP_STAT_TOG_RSVD_IRQ_SHIFT   (8U)
#define DCP_STAT_TOG_RSVD_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_RSVD_IRQ_SHIFT)) & DCP_STAT_TOG_RSVD_IRQ_MASK)
#define DCP_STAT_TOG_READY_CHANNELS_MASK   (0xFF0000U)
#define DCP_STAT_TOG_READY_CHANNELS_SHIFT   (16U)
#define DCP_STAT_TOG_READY_CHANNELS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_READY_CHANNELS_SHIFT)) & DCP_STAT_TOG_READY_CHANNELS_MASK)
#define DCP_STAT_TOG_CUR_CHANNEL_MASK   (0xF000000U)
#define DCP_STAT_TOG_CUR_CHANNEL_SHIFT   (24U)
#define DCP_STAT_TOG_CUR_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_CUR_CHANNEL_SHIFT)) & DCP_STAT_TOG_CUR_CHANNEL_MASK)
#define DCP_STAT_TOG_OTP_KEY_READY_MASK   (0x10000000U)
#define DCP_STAT_TOG_OTP_KEY_READY_SHIFT   (28U)
#define DCP_STAT_TOG_OTP_KEY_READY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_OTP_KEY_READY_SHIFT)) & DCP_STAT_TOG_OTP_KEY_READY_MASK)
CHANNELCTRL - DCP channel control register
#define DCP_CHANNELCTRL_ENABLE_CHANNEL_MASK   (0xFFU)
#define DCP_CHANNELCTRL_ENABLE_CHANNEL_SHIFT   (0U)
#define DCP_CHANNELCTRL_ENABLE_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_ENABLE_CHANNEL_MASK)
#define DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_MASK   (0xFF00U)
#define DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_SHIFT   (8U)
#define DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_MASK)
#define DCP_CHANNELCTRL_CH0_IRQ_MERGED_MASK   (0x10000U)
#define DCP_CHANNELCTRL_CH0_IRQ_MERGED_SHIFT   (16U)
#define DCP_CHANNELCTRL_CH0_IRQ_MERGED(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CH0_IRQ_MERGED_SHIFT)) & DCP_CHANNELCTRL_CH0_IRQ_MERGED_MASK)
#define DCP_CHANNELCTRL_RSVD_MASK   (0xFFFE0000U)
#define DCP_CHANNELCTRL_RSVD_SHIFT   (17U)
#define DCP_CHANNELCTRL_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_RSVD_SHIFT)) & DCP_CHANNELCTRL_RSVD_MASK)
CHANNELCTRL_SET - DCP channel control register
#define DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_MASK   (0xFFU)
#define DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_SHIFT   (0U)
#define DCP_CHANNELCTRL_SET_ENABLE_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_MASK)
#define DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_MASK   (0xFF00U)
#define DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_SHIFT   (8U)
#define DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_MASK)
#define DCP_CHANNELCTRL_SET_CH0_IRQ_MERGED_MASK   (0x10000U)
#define DCP_CHANNELCTRL_SET_CH0_IRQ_MERGED_SHIFT   (16U)
#define DCP_CHANNELCTRL_SET_CH0_IRQ_MERGED(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_CH0_IRQ_MERGED_SHIFT)) & DCP_CHANNELCTRL_SET_CH0_IRQ_MERGED_MASK)
#define DCP_CHANNELCTRL_SET_RSVD_MASK   (0xFFFE0000U)
#define DCP_CHANNELCTRL_SET_RSVD_SHIFT   (17U)
#define DCP_CHANNELCTRL_SET_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_RSVD_SHIFT)) & DCP_CHANNELCTRL_SET_RSVD_MASK)
CHANNELCTRL_CLR - DCP channel control register
#define DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_MASK   (0xFFU)
#define DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_SHIFT   (0U)
#define DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_MASK)
#define DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_MASK   (0xFF00U)
#define DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_SHIFT   (8U)
#define DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_MASK)
#define DCP_CHANNELCTRL_CLR_CH0_IRQ_MERGED_MASK   (0x10000U)
#define DCP_CHANNELCTRL_CLR_CH0_IRQ_MERGED_SHIFT   (16U)
#define DCP_CHANNELCTRL_CLR_CH0_IRQ_MERGED(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_CH0_IRQ_MERGED_SHIFT)) & DCP_CHANNELCTRL_CLR_CH0_IRQ_MERGED_MASK)
#define DCP_CHANNELCTRL_CLR_RSVD_MASK   (0xFFFE0000U)
#define DCP_CHANNELCTRL_CLR_RSVD_SHIFT   (17U)
#define DCP_CHANNELCTRL_CLR_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_RSVD_SHIFT)) & DCP_CHANNELCTRL_CLR_RSVD_MASK)
CHANNELCTRL_TOG - DCP channel control register
#define DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_MASK   (0xFFU)
#define DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_SHIFT   (0U)
#define DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_MASK)
#define DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_MASK   (0xFF00U)
#define DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_SHIFT   (8U)
#define DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_MASK)
#define DCP_CHANNELCTRL_TOG_CH0_IRQ_MERGED_MASK   (0x10000U)
#define DCP_CHANNELCTRL_TOG_CH0_IRQ_MERGED_SHIFT   (16U)
#define DCP_CHANNELCTRL_TOG_CH0_IRQ_MERGED(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_CH0_IRQ_MERGED_SHIFT)) & DCP_CHANNELCTRL_TOG_CH0_IRQ_MERGED_MASK)
#define DCP_CHANNELCTRL_TOG_RSVD_MASK   (0xFFFE0000U)
#define DCP_CHANNELCTRL_TOG_RSVD_SHIFT   (17U)
#define DCP_CHANNELCTRL_TOG_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_RSVD_SHIFT)) & DCP_CHANNELCTRL_TOG_RSVD_MASK)
CAPABILITY0 - DCP capability 0 register
#define DCP_CAPABILITY0_NUM_KEYS_MASK   (0xFFU)
#define DCP_CAPABILITY0_NUM_KEYS_SHIFT   (0U)
#define DCP_CAPABILITY0_NUM_KEYS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY0_NUM_KEYS_SHIFT)) & DCP_CAPABILITY0_NUM_KEYS_MASK)
#define DCP_CAPABILITY0_NUM_CHANNELS_MASK   (0xF00U)
#define DCP_CAPABILITY0_NUM_CHANNELS_SHIFT   (8U)
#define DCP_CAPABILITY0_NUM_CHANNELS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY0_NUM_CHANNELS_SHIFT)) & DCP_CAPABILITY0_NUM_CHANNELS_MASK)
#define DCP_CAPABILITY0_RSVD_MASK   (0x1FFFF000U)
#define DCP_CAPABILITY0_RSVD_SHIFT   (12U)
#define DCP_CAPABILITY0_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY0_RSVD_SHIFT)) & DCP_CAPABILITY0_RSVD_MASK)
#define DCP_CAPABILITY0_DISABLE_UNIQUE_KEY_MASK   (0x20000000U)
#define DCP_CAPABILITY0_DISABLE_UNIQUE_KEY_SHIFT   (29U)
#define DCP_CAPABILITY0_DISABLE_UNIQUE_KEY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY0_DISABLE_UNIQUE_KEY_SHIFT)) & DCP_CAPABILITY0_DISABLE_UNIQUE_KEY_MASK)
#define DCP_CAPABILITY0_DISABLE_DECRYPT_MASK   (0x80000000U)
#define DCP_CAPABILITY0_DISABLE_DECRYPT_SHIFT   (31U)
#define DCP_CAPABILITY0_DISABLE_DECRYPT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY0_DISABLE_DECRYPT_SHIFT)) & DCP_CAPABILITY0_DISABLE_DECRYPT_MASK)
CAPABILITY1 - DCP capability 1 register
#define DCP_CAPABILITY1_CIPHER_ALGORITHMS_MASK   (0xFFFFU)
#define DCP_CAPABILITY1_CIPHER_ALGORITHMS_SHIFT   (0U)
#define DCP_CAPABILITY1_CIPHER_ALGORITHMS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY1_CIPHER_ALGORITHMS_SHIFT)) & DCP_CAPABILITY1_CIPHER_ALGORITHMS_MASK)
#define DCP_CAPABILITY1_HASH_ALGORITHMS_MASK   (0xFFFF0000U)
#define DCP_CAPABILITY1_HASH_ALGORITHMS_SHIFT   (16U)
#define DCP_CAPABILITY1_HASH_ALGORITHMS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY1_HASH_ALGORITHMS_SHIFT)) & DCP_CAPABILITY1_HASH_ALGORITHMS_MASK)
CONTEXT - DCP context buffer pointer
#define DCP_CONTEXT_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_CONTEXT_ADDR_SHIFT   (0U)
#define DCP_CONTEXT_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CONTEXT_ADDR_SHIFT)) & DCP_CONTEXT_ADDR_MASK)
KEY - DCP key index
#define DCP_KEY_SUBWORD_MASK   (0x3U)
#define DCP_KEY_SUBWORD_SHIFT   (0U)
#define DCP_KEY_SUBWORD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEY_SUBWORD_SHIFT)) & DCP_KEY_SUBWORD_MASK)
#define DCP_KEY_RSVD_SUBWORD_MASK   (0xCU)
#define DCP_KEY_RSVD_SUBWORD_SHIFT   (2U)
#define DCP_KEY_RSVD_SUBWORD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEY_RSVD_SUBWORD_SHIFT)) & DCP_KEY_RSVD_SUBWORD_MASK)
#define DCP_KEY_INDEX_MASK   (0x30U)
#define DCP_KEY_INDEX_SHIFT   (4U)
#define DCP_KEY_INDEX(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEY_INDEX_SHIFT)) & DCP_KEY_INDEX_MASK)
#define DCP_KEY_RSVD_INDEX_MASK   (0xC0U)
#define DCP_KEY_RSVD_INDEX_SHIFT   (6U)
#define DCP_KEY_RSVD_INDEX(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEY_RSVD_INDEX_SHIFT)) & DCP_KEY_RSVD_INDEX_MASK)
#define DCP_KEY_RSVD_MASK   (0xFFFFFF00U)
#define DCP_KEY_RSVD_SHIFT   (8U)
#define DCP_KEY_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEY_RSVD_SHIFT)) & DCP_KEY_RSVD_MASK)
KEYDATA - DCP key data
#define DCP_KEYDATA_DATA_MASK   (0xFFFFFFFFU)
#define DCP_KEYDATA_DATA_SHIFT   (0U)
#define DCP_KEYDATA_DATA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_KEYDATA_DATA_SHIFT)) & DCP_KEYDATA_DATA_MASK)
PACKET0 - DCP work packet 0 status register
#define DCP_PACKET0_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_PACKET0_ADDR_SHIFT   (0U)
#define DCP_PACKET0_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET0_ADDR_SHIFT)) & DCP_PACKET0_ADDR_MASK)
PACKET1 - DCP work packet 1 status register
#define DCP_PACKET1_INTERRUPT_MASK   (0x1U)
#define DCP_PACKET1_INTERRUPT_SHIFT   (0U)
#define DCP_PACKET1_INTERRUPT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_INTERRUPT_SHIFT)) & DCP_PACKET1_INTERRUPT_MASK)
#define DCP_PACKET1_DECR_SEMAPHORE_MASK   (0x2U)
#define DCP_PACKET1_DECR_SEMAPHORE_SHIFT   (1U)
#define DCP_PACKET1_DECR_SEMAPHORE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_DECR_SEMAPHORE_SHIFT)) & DCP_PACKET1_DECR_SEMAPHORE_MASK)
#define DCP_PACKET1_CHAIN_MASK   (0x4U)
#define DCP_PACKET1_CHAIN_SHIFT   (2U)
#define DCP_PACKET1_CHAIN(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CHAIN_SHIFT)) & DCP_PACKET1_CHAIN_MASK)
#define DCP_PACKET1_CHAIN_CONTIGUOUS_MASK   (0x8U)
#define DCP_PACKET1_CHAIN_CONTIGUOUS_SHIFT   (3U)
#define DCP_PACKET1_CHAIN_CONTIGUOUS(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CHAIN_CONTIGUOUS_SHIFT)) & DCP_PACKET1_CHAIN_CONTIGUOUS_MASK)
#define DCP_PACKET1_ENABLE_MEMCOPY_MASK   (0x10U)
#define DCP_PACKET1_ENABLE_MEMCOPY_SHIFT   (4U)
#define DCP_PACKET1_ENABLE_MEMCOPY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_ENABLE_MEMCOPY_SHIFT)) & DCP_PACKET1_ENABLE_MEMCOPY_MASK)
#define DCP_PACKET1_ENABLE_CIPHER_MASK   (0x20U)
#define DCP_PACKET1_ENABLE_CIPHER_SHIFT   (5U)
#define DCP_PACKET1_ENABLE_CIPHER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_ENABLE_CIPHER_SHIFT)) & DCP_PACKET1_ENABLE_CIPHER_MASK)
#define DCP_PACKET1_ENABLE_HASH_MASK   (0x40U)
#define DCP_PACKET1_ENABLE_HASH_SHIFT   (6U)
#define DCP_PACKET1_ENABLE_HASH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_ENABLE_HASH_SHIFT)) & DCP_PACKET1_ENABLE_HASH_MASK)
#define DCP_PACKET1_ENABLE_BLIT_MASK   (0x80U)
#define DCP_PACKET1_ENABLE_BLIT_SHIFT   (7U)
#define DCP_PACKET1_ENABLE_BLIT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_ENABLE_BLIT_SHIFT)) & DCP_PACKET1_ENABLE_BLIT_MASK)
#define DCP_PACKET1_CIPHER_ENCRYPT_MASK   (0x100U)
#define DCP_PACKET1_CIPHER_ENCRYPT_SHIFT   (8U)
#define DCP_PACKET1_CIPHER_ENCRYPT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CIPHER_ENCRYPT_SHIFT)) & DCP_PACKET1_CIPHER_ENCRYPT_MASK)
#define DCP_PACKET1_CIPHER_INIT_MASK   (0x200U)
#define DCP_PACKET1_CIPHER_INIT_SHIFT   (9U)
#define DCP_PACKET1_CIPHER_INIT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CIPHER_INIT_SHIFT)) & DCP_PACKET1_CIPHER_INIT_MASK)
#define DCP_PACKET1_OTP_KEY_MASK   (0x400U)
#define DCP_PACKET1_OTP_KEY_SHIFT   (10U)
#define DCP_PACKET1_OTP_KEY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_OTP_KEY_SHIFT)) & DCP_PACKET1_OTP_KEY_MASK)
#define DCP_PACKET1_PAYLOAD_KEY_MASK   (0x800U)
#define DCP_PACKET1_PAYLOAD_KEY_SHIFT   (11U)
#define DCP_PACKET1_PAYLOAD_KEY(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_PAYLOAD_KEY_SHIFT)) & DCP_PACKET1_PAYLOAD_KEY_MASK)
#define DCP_PACKET1_HASH_INIT_MASK   (0x1000U)
#define DCP_PACKET1_HASH_INIT_SHIFT   (12U)
#define DCP_PACKET1_HASH_INIT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_HASH_INIT_SHIFT)) & DCP_PACKET1_HASH_INIT_MASK)
#define DCP_PACKET1_HASH_TERM_MASK   (0x2000U)
#define DCP_PACKET1_HASH_TERM_SHIFT   (13U)
#define DCP_PACKET1_HASH_TERM(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_HASH_TERM_SHIFT)) & DCP_PACKET1_HASH_TERM_MASK)
#define DCP_PACKET1_CHECK_HASH_MASK   (0x4000U)
#define DCP_PACKET1_CHECK_HASH_SHIFT   (14U)
#define DCP_PACKET1_CHECK_HASH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CHECK_HASH_SHIFT)) & DCP_PACKET1_CHECK_HASH_MASK)
#define DCP_PACKET1_HASH_OUTPUT_MASK   (0x8000U)
#define DCP_PACKET1_HASH_OUTPUT_SHIFT   (15U)
#define DCP_PACKET1_HASH_OUTPUT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_HASH_OUTPUT_SHIFT)) & DCP_PACKET1_HASH_OUTPUT_MASK)
#define DCP_PACKET1_CONSTANT_FILL_MASK   (0x10000U)
#define DCP_PACKET1_CONSTANT_FILL_SHIFT   (16U)
#define DCP_PACKET1_CONSTANT_FILL(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CONSTANT_FILL_SHIFT)) & DCP_PACKET1_CONSTANT_FILL_MASK)
#define DCP_PACKET1_TEST_SEMA_IRQ_MASK   (0x20000U)
#define DCP_PACKET1_TEST_SEMA_IRQ_SHIFT   (17U)
#define DCP_PACKET1_TEST_SEMA_IRQ(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_TEST_SEMA_IRQ_SHIFT)) & DCP_PACKET1_TEST_SEMA_IRQ_MASK)
#define DCP_PACKET1_KEY_BYTESWAP_MASK   (0x40000U)
#define DCP_PACKET1_KEY_BYTESWAP_SHIFT   (18U)
#define DCP_PACKET1_KEY_BYTESWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_KEY_BYTESWAP_SHIFT)) & DCP_PACKET1_KEY_BYTESWAP_MASK)
#define DCP_PACKET1_KEY_WORDSWAP_MASK   (0x80000U)
#define DCP_PACKET1_KEY_WORDSWAP_SHIFT   (19U)
#define DCP_PACKET1_KEY_WORDSWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_KEY_WORDSWAP_SHIFT)) & DCP_PACKET1_KEY_WORDSWAP_MASK)
#define DCP_PACKET1_INPUT_BYTESWAP_MASK   (0x100000U)
#define DCP_PACKET1_INPUT_BYTESWAP_SHIFT   (20U)
#define DCP_PACKET1_INPUT_BYTESWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_INPUT_BYTESWAP_SHIFT)) & DCP_PACKET1_INPUT_BYTESWAP_MASK)
#define DCP_PACKET1_INPUT_WORDSWAP_MASK   (0x200000U)
#define DCP_PACKET1_INPUT_WORDSWAP_SHIFT   (21U)
#define DCP_PACKET1_INPUT_WORDSWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_INPUT_WORDSWAP_SHIFT)) & DCP_PACKET1_INPUT_WORDSWAP_MASK)
#define DCP_PACKET1_OUTPUT_BYTESWAP_MASK   (0x400000U)
#define DCP_PACKET1_OUTPUT_BYTESWAP_SHIFT   (22U)
#define DCP_PACKET1_OUTPUT_BYTESWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_OUTPUT_BYTESWAP_SHIFT)) & DCP_PACKET1_OUTPUT_BYTESWAP_MASK)
#define DCP_PACKET1_OUTPUT_WORDSWAP_MASK   (0x800000U)
#define DCP_PACKET1_OUTPUT_WORDSWAP_SHIFT   (23U)
#define DCP_PACKET1_OUTPUT_WORDSWAP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_OUTPUT_WORDSWAP_SHIFT)) & DCP_PACKET1_OUTPUT_WORDSWAP_MASK)
#define DCP_PACKET1_TAG_MASK   (0xFF000000U)
#define DCP_PACKET1_TAG_SHIFT   (24U)
#define DCP_PACKET1_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_TAG_SHIFT)) & DCP_PACKET1_TAG_MASK)
PACKET2 - DCP work packet 2 status register
#define DCP_PACKET2_CIPHER_SELECT_MASK   (0xFU)
#define DCP_PACKET2_CIPHER_SELECT_SHIFT   (0U)
#define DCP_PACKET2_CIPHER_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_CIPHER_SELECT_SHIFT)) & DCP_PACKET2_CIPHER_SELECT_MASK)
#define DCP_PACKET2_CIPHER_MODE_MASK   (0xF0U)
#define DCP_PACKET2_CIPHER_MODE_SHIFT   (4U)
#define DCP_PACKET2_CIPHER_MODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_CIPHER_MODE_SHIFT)) & DCP_PACKET2_CIPHER_MODE_MASK)
#define DCP_PACKET2_KEY_SELECT_MASK   (0xFF00U)
#define DCP_PACKET2_KEY_SELECT_SHIFT   (8U)
#define DCP_PACKET2_KEY_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_KEY_SELECT_SHIFT)) & DCP_PACKET2_KEY_SELECT_MASK)
#define DCP_PACKET2_HASH_SELECT_MASK   (0xF0000U)
#define DCP_PACKET2_HASH_SELECT_SHIFT   (16U)
#define DCP_PACKET2_HASH_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_HASH_SELECT_SHIFT)) & DCP_PACKET2_HASH_SELECT_MASK)
#define DCP_PACKET2_RSVD_MASK   (0xF00000U)
#define DCP_PACKET2_RSVD_SHIFT   (20U)
#define DCP_PACKET2_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_RSVD_SHIFT)) & DCP_PACKET2_RSVD_MASK)
#define DCP_PACKET2_CIPHER_CFG_MASK   (0xFF000000U)
#define DCP_PACKET2_CIPHER_CFG_SHIFT   (24U)
#define DCP_PACKET2_CIPHER_CFG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_CIPHER_CFG_SHIFT)) & DCP_PACKET2_CIPHER_CFG_MASK)
PACKET3 - DCP work packet 3 status register
#define DCP_PACKET3_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_PACKET3_ADDR_SHIFT   (0U)
#define DCP_PACKET3_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET3_ADDR_SHIFT)) & DCP_PACKET3_ADDR_MASK)
PACKET4 - DCP work packet 4 status register
#define DCP_PACKET4_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_PACKET4_ADDR_SHIFT   (0U)
#define DCP_PACKET4_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET4_ADDR_SHIFT)) & DCP_PACKET4_ADDR_MASK)
PACKET5 - DCP work packet 5 status register
#define DCP_PACKET5_COUNT_MASK   (0xFFFFFFFFU)
#define DCP_PACKET5_COUNT_SHIFT   (0U)
#define DCP_PACKET5_COUNT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET5_COUNT_SHIFT)) & DCP_PACKET5_COUNT_MASK)
PACKET6 - DCP work packet 6 status register
#define DCP_PACKET6_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_PACKET6_ADDR_SHIFT   (0U)
#define DCP_PACKET6_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PACKET6_ADDR_SHIFT)) & DCP_PACKET6_ADDR_MASK)
CH0CMDPTR - DCP channel 0 command pointer address register
#define DCP_CH0CMDPTR_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_CH0CMDPTR_ADDR_SHIFT   (0U)
#define DCP_CH0CMDPTR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0CMDPTR_ADDR_SHIFT)) & DCP_CH0CMDPTR_ADDR_MASK)
CH0SEMA - DCP channel 0 semaphore register
#define DCP_CH0SEMA_INCREMENT_MASK   (0xFFU)
#define DCP_CH0SEMA_INCREMENT_SHIFT   (0U)
#define DCP_CH0SEMA_INCREMENT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0SEMA_INCREMENT_SHIFT)) & DCP_CH0SEMA_INCREMENT_MASK)
#define DCP_CH0SEMA_VALUE_MASK   (0xFF0000U)
#define DCP_CH0SEMA_VALUE_SHIFT   (16U)
#define DCP_CH0SEMA_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0SEMA_VALUE_SHIFT)) & DCP_CH0SEMA_VALUE_MASK)
CH0STAT - DCP channel 0 status register
#define DCP_CH0STAT_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH0STAT_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH0STAT_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_RSVD_COMPLETE_SHIFT)) & DCP_CH0STAT_RSVD_COMPLETE_MASK)
#define DCP_CH0STAT_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH0STAT_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH0STAT_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_HASH_MISMATCH_SHIFT)) & DCP_CH0STAT_HASH_MISMATCH_MASK)
#define DCP_CH0STAT_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH0STAT_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH0STAT_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_SETUP_SHIFT)) & DCP_CH0STAT_ERROR_SETUP_MASK)
#define DCP_CH0STAT_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH0STAT_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH0STAT_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_PACKET_SHIFT)) & DCP_CH0STAT_ERROR_PACKET_MASK)
#define DCP_CH0STAT_ERROR_SRC_MASK   (0x10U)
#define DCP_CH0STAT_ERROR_SRC_SHIFT   (4U)
#define DCP_CH0STAT_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_SRC_SHIFT)) & DCP_CH0STAT_ERROR_SRC_MASK)
#define DCP_CH0STAT_ERROR_DST_MASK   (0x20U)
#define DCP_CH0STAT_ERROR_DST_SHIFT   (5U)
#define DCP_CH0STAT_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_DST_SHIFT)) & DCP_CH0STAT_ERROR_DST_MASK)
#define DCP_CH0STAT_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH0STAT_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH0STAT_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_PAGEFAULT_SHIFT)) & DCP_CH0STAT_ERROR_PAGEFAULT_MASK)
#define DCP_CH0STAT_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH0STAT_ERROR_CODE_SHIFT   (16U)
#define DCP_CH0STAT_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_CODE_SHIFT)) & DCP_CH0STAT_ERROR_CODE_MASK)
#define DCP_CH0STAT_TAG_MASK   (0xFF000000U)
#define DCP_CH0STAT_TAG_SHIFT   (24U)
#define DCP_CH0STAT_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TAG_SHIFT)) & DCP_CH0STAT_TAG_MASK)
CH0STAT_SET - DCP channel 0 status register
#define DCP_CH0STAT_SET_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH0STAT_SET_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH0STAT_SET_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_RSVD_COMPLETE_SHIFT)) & DCP_CH0STAT_SET_RSVD_COMPLETE_MASK)
#define DCP_CH0STAT_SET_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH0STAT_SET_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH0STAT_SET_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_HASH_MISMATCH_SHIFT)) & DCP_CH0STAT_SET_HASH_MISMATCH_MASK)
#define DCP_CH0STAT_SET_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH0STAT_SET_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH0STAT_SET_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_SETUP_SHIFT)) & DCP_CH0STAT_SET_ERROR_SETUP_MASK)
#define DCP_CH0STAT_SET_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH0STAT_SET_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH0STAT_SET_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_PACKET_SHIFT)) & DCP_CH0STAT_SET_ERROR_PACKET_MASK)
#define DCP_CH0STAT_SET_ERROR_SRC_MASK   (0x10U)
#define DCP_CH0STAT_SET_ERROR_SRC_SHIFT   (4U)
#define DCP_CH0STAT_SET_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_SRC_SHIFT)) & DCP_CH0STAT_SET_ERROR_SRC_MASK)
#define DCP_CH0STAT_SET_ERROR_DST_MASK   (0x20U)
#define DCP_CH0STAT_SET_ERROR_DST_SHIFT   (5U)
#define DCP_CH0STAT_SET_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_DST_SHIFT)) & DCP_CH0STAT_SET_ERROR_DST_MASK)
#define DCP_CH0STAT_SET_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH0STAT_SET_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH0STAT_SET_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_PAGEFAULT_SHIFT)) & DCP_CH0STAT_SET_ERROR_PAGEFAULT_MASK)
#define DCP_CH0STAT_SET_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH0STAT_SET_ERROR_CODE_SHIFT   (16U)
#define DCP_CH0STAT_SET_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH0STAT_SET_ERROR_CODE_MASK)
#define DCP_CH0STAT_SET_TAG_MASK   (0xFF000000U)
#define DCP_CH0STAT_SET_TAG_SHIFT   (24U)
#define DCP_CH0STAT_SET_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_TAG_SHIFT)) & DCP_CH0STAT_SET_TAG_MASK)
CH0STAT_CLR - DCP channel 0 status register
#define DCP_CH0STAT_CLR_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH0STAT_CLR_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH0STAT_CLR_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_RSVD_COMPLETE_SHIFT)) & DCP_CH0STAT_CLR_RSVD_COMPLETE_MASK)
#define DCP_CH0STAT_CLR_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH0STAT_CLR_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH0STAT_CLR_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_HASH_MISMATCH_SHIFT)) & DCP_CH0STAT_CLR_HASH_MISMATCH_MASK)
#define DCP_CH0STAT_CLR_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH0STAT_CLR_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH0STAT_CLR_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_SETUP_SHIFT)) & DCP_CH0STAT_CLR_ERROR_SETUP_MASK)
#define DCP_CH0STAT_CLR_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH0STAT_CLR_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH0STAT_CLR_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_PACKET_SHIFT)) & DCP_CH0STAT_CLR_ERROR_PACKET_MASK)
#define DCP_CH0STAT_CLR_ERROR_SRC_MASK   (0x10U)
#define DCP_CH0STAT_CLR_ERROR_SRC_SHIFT   (4U)
#define DCP_CH0STAT_CLR_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_SRC_SHIFT)) & DCP_CH0STAT_CLR_ERROR_SRC_MASK)
#define DCP_CH0STAT_CLR_ERROR_DST_MASK   (0x20U)
#define DCP_CH0STAT_CLR_ERROR_DST_SHIFT   (5U)
#define DCP_CH0STAT_CLR_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_DST_SHIFT)) & DCP_CH0STAT_CLR_ERROR_DST_MASK)
#define DCP_CH0STAT_CLR_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH0STAT_CLR_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH0STAT_CLR_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_PAGEFAULT_SHIFT)) & DCP_CH0STAT_CLR_ERROR_PAGEFAULT_MASK)
#define DCP_CH0STAT_CLR_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH0STAT_CLR_ERROR_CODE_SHIFT   (16U)
#define DCP_CH0STAT_CLR_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH0STAT_CLR_ERROR_CODE_MASK)
#define DCP_CH0STAT_CLR_TAG_MASK   (0xFF000000U)
#define DCP_CH0STAT_CLR_TAG_SHIFT   (24U)
#define DCP_CH0STAT_CLR_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_TAG_SHIFT)) & DCP_CH0STAT_CLR_TAG_MASK)
CH0STAT_TOG - DCP channel 0 status register
#define DCP_CH0STAT_TOG_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH0STAT_TOG_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH0STAT_TOG_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_RSVD_COMPLETE_SHIFT)) & DCP_CH0STAT_TOG_RSVD_COMPLETE_MASK)
#define DCP_CH0STAT_TOG_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH0STAT_TOG_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH0STAT_TOG_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_HASH_MISMATCH_SHIFT)) & DCP_CH0STAT_TOG_HASH_MISMATCH_MASK)
#define DCP_CH0STAT_TOG_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH0STAT_TOG_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH0STAT_TOG_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_SETUP_SHIFT)) & DCP_CH0STAT_TOG_ERROR_SETUP_MASK)
#define DCP_CH0STAT_TOG_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH0STAT_TOG_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH0STAT_TOG_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_PACKET_SHIFT)) & DCP_CH0STAT_TOG_ERROR_PACKET_MASK)
#define DCP_CH0STAT_TOG_ERROR_SRC_MASK   (0x10U)
#define DCP_CH0STAT_TOG_ERROR_SRC_SHIFT   (4U)
#define DCP_CH0STAT_TOG_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_SRC_SHIFT)) & DCP_CH0STAT_TOG_ERROR_SRC_MASK)
#define DCP_CH0STAT_TOG_ERROR_DST_MASK   (0x20U)
#define DCP_CH0STAT_TOG_ERROR_DST_SHIFT   (5U)
#define DCP_CH0STAT_TOG_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_DST_SHIFT)) & DCP_CH0STAT_TOG_ERROR_DST_MASK)
#define DCP_CH0STAT_TOG_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH0STAT_TOG_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH0STAT_TOG_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_PAGEFAULT_SHIFT)) & DCP_CH0STAT_TOG_ERROR_PAGEFAULT_MASK)
#define DCP_CH0STAT_TOG_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH0STAT_TOG_ERROR_CODE_SHIFT   (16U)
#define DCP_CH0STAT_TOG_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH0STAT_TOG_ERROR_CODE_MASK)
#define DCP_CH0STAT_TOG_TAG_MASK   (0xFF000000U)
#define DCP_CH0STAT_TOG_TAG_SHIFT   (24U)
#define DCP_CH0STAT_TOG_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_TAG_SHIFT)) & DCP_CH0STAT_TOG_TAG_MASK)
CH0OPTS - DCP channel 0 options register
#define DCP_CH0OPTS_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH0OPTS_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH0OPTS_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_RECOVERY_TIMER_SHIFT)) & DCP_CH0OPTS_RECOVERY_TIMER_MASK)
#define DCP_CH0OPTS_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH0OPTS_RSVD_SHIFT   (16U)
#define DCP_CH0OPTS_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_RSVD_SHIFT)) & DCP_CH0OPTS_RSVD_MASK)
CH0OPTS_SET - DCP channel 0 options register
#define DCP_CH0OPTS_SET_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH0OPTS_SET_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH0OPTS_SET_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_SET_RECOVERY_TIMER_SHIFT)) & DCP_CH0OPTS_SET_RECOVERY_TIMER_MASK)
#define DCP_CH0OPTS_SET_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH0OPTS_SET_RSVD_SHIFT   (16U)
#define DCP_CH0OPTS_SET_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_SET_RSVD_SHIFT)) & DCP_CH0OPTS_SET_RSVD_MASK)
CH0OPTS_CLR - DCP channel 0 options register
#define DCP_CH0OPTS_CLR_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH0OPTS_CLR_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH0OPTS_CLR_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_CLR_RECOVERY_TIMER_SHIFT)) & DCP_CH0OPTS_CLR_RECOVERY_TIMER_MASK)
#define DCP_CH0OPTS_CLR_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH0OPTS_CLR_RSVD_SHIFT   (16U)
#define DCP_CH0OPTS_CLR_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_CLR_RSVD_SHIFT)) & DCP_CH0OPTS_CLR_RSVD_MASK)
CH0OPTS_TOG - DCP channel 0 options register
#define DCP_CH0OPTS_TOG_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH0OPTS_TOG_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH0OPTS_TOG_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_TOG_RECOVERY_TIMER_SHIFT)) & DCP_CH0OPTS_TOG_RECOVERY_TIMER_MASK)
#define DCP_CH0OPTS_TOG_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH0OPTS_TOG_RSVD_SHIFT   (16U)
#define DCP_CH0OPTS_TOG_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH0OPTS_TOG_RSVD_SHIFT)) & DCP_CH0OPTS_TOG_RSVD_MASK)
CH1CMDPTR - DCP channel 1 command pointer address register
#define DCP_CH1CMDPTR_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_CH1CMDPTR_ADDR_SHIFT   (0U)
#define DCP_CH1CMDPTR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1CMDPTR_ADDR_SHIFT)) & DCP_CH1CMDPTR_ADDR_MASK)
CH1SEMA - DCP channel 1 semaphore register
#define DCP_CH1SEMA_INCREMENT_MASK   (0xFFU)
#define DCP_CH1SEMA_INCREMENT_SHIFT   (0U)
#define DCP_CH1SEMA_INCREMENT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1SEMA_INCREMENT_SHIFT)) & DCP_CH1SEMA_INCREMENT_MASK)
#define DCP_CH1SEMA_VALUE_MASK   (0xFF0000U)
#define DCP_CH1SEMA_VALUE_SHIFT   (16U)
#define DCP_CH1SEMA_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1SEMA_VALUE_SHIFT)) & DCP_CH1SEMA_VALUE_MASK)
CH1STAT - DCP channel 1 status register
#define DCP_CH1STAT_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH1STAT_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH1STAT_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_RSVD_COMPLETE_SHIFT)) & DCP_CH1STAT_RSVD_COMPLETE_MASK)
#define DCP_CH1STAT_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH1STAT_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH1STAT_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_HASH_MISMATCH_SHIFT)) & DCP_CH1STAT_HASH_MISMATCH_MASK)
#define DCP_CH1STAT_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH1STAT_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH1STAT_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_SETUP_SHIFT)) & DCP_CH1STAT_ERROR_SETUP_MASK)
#define DCP_CH1STAT_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH1STAT_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH1STAT_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_PACKET_SHIFT)) & DCP_CH1STAT_ERROR_PACKET_MASK)
#define DCP_CH1STAT_ERROR_SRC_MASK   (0x10U)
#define DCP_CH1STAT_ERROR_SRC_SHIFT   (4U)
#define DCP_CH1STAT_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_SRC_SHIFT)) & DCP_CH1STAT_ERROR_SRC_MASK)
#define DCP_CH1STAT_ERROR_DST_MASK   (0x20U)
#define DCP_CH1STAT_ERROR_DST_SHIFT   (5U)
#define DCP_CH1STAT_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_DST_SHIFT)) & DCP_CH1STAT_ERROR_DST_MASK)
#define DCP_CH1STAT_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH1STAT_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH1STAT_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_PAGEFAULT_SHIFT)) & DCP_CH1STAT_ERROR_PAGEFAULT_MASK)
#define DCP_CH1STAT_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH1STAT_ERROR_CODE_SHIFT   (16U)
#define DCP_CH1STAT_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_CODE_SHIFT)) & DCP_CH1STAT_ERROR_CODE_MASK)
#define DCP_CH1STAT_TAG_MASK   (0xFF000000U)
#define DCP_CH1STAT_TAG_SHIFT   (24U)
#define DCP_CH1STAT_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TAG_SHIFT)) & DCP_CH1STAT_TAG_MASK)
CH1STAT_SET - DCP channel 1 status register
#define DCP_CH1STAT_SET_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH1STAT_SET_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH1STAT_SET_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_RSVD_COMPLETE_SHIFT)) & DCP_CH1STAT_SET_RSVD_COMPLETE_MASK)
#define DCP_CH1STAT_SET_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH1STAT_SET_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH1STAT_SET_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_HASH_MISMATCH_SHIFT)) & DCP_CH1STAT_SET_HASH_MISMATCH_MASK)
#define DCP_CH1STAT_SET_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH1STAT_SET_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH1STAT_SET_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_SETUP_SHIFT)) & DCP_CH1STAT_SET_ERROR_SETUP_MASK)
#define DCP_CH1STAT_SET_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH1STAT_SET_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH1STAT_SET_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_PACKET_SHIFT)) & DCP_CH1STAT_SET_ERROR_PACKET_MASK)
#define DCP_CH1STAT_SET_ERROR_SRC_MASK   (0x10U)
#define DCP_CH1STAT_SET_ERROR_SRC_SHIFT   (4U)
#define DCP_CH1STAT_SET_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_SRC_SHIFT)) & DCP_CH1STAT_SET_ERROR_SRC_MASK)
#define DCP_CH1STAT_SET_ERROR_DST_MASK   (0x20U)
#define DCP_CH1STAT_SET_ERROR_DST_SHIFT   (5U)
#define DCP_CH1STAT_SET_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_DST_SHIFT)) & DCP_CH1STAT_SET_ERROR_DST_MASK)
#define DCP_CH1STAT_SET_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH1STAT_SET_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH1STAT_SET_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_PAGEFAULT_SHIFT)) & DCP_CH1STAT_SET_ERROR_PAGEFAULT_MASK)
#define DCP_CH1STAT_SET_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH1STAT_SET_ERROR_CODE_SHIFT   (16U)
#define DCP_CH1STAT_SET_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH1STAT_SET_ERROR_CODE_MASK)
#define DCP_CH1STAT_SET_TAG_MASK   (0xFF000000U)
#define DCP_CH1STAT_SET_TAG_SHIFT   (24U)
#define DCP_CH1STAT_SET_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_TAG_SHIFT)) & DCP_CH1STAT_SET_TAG_MASK)
CH1STAT_CLR - DCP channel 1 status register
#define DCP_CH1STAT_CLR_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH1STAT_CLR_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH1STAT_CLR_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_RSVD_COMPLETE_SHIFT)) & DCP_CH1STAT_CLR_RSVD_COMPLETE_MASK)
#define DCP_CH1STAT_CLR_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH1STAT_CLR_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH1STAT_CLR_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_HASH_MISMATCH_SHIFT)) & DCP_CH1STAT_CLR_HASH_MISMATCH_MASK)
#define DCP_CH1STAT_CLR_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH1STAT_CLR_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH1STAT_CLR_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_SETUP_SHIFT)) & DCP_CH1STAT_CLR_ERROR_SETUP_MASK)
#define DCP_CH1STAT_CLR_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH1STAT_CLR_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH1STAT_CLR_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_PACKET_SHIFT)) & DCP_CH1STAT_CLR_ERROR_PACKET_MASK)
#define DCP_CH1STAT_CLR_ERROR_SRC_MASK   (0x10U)
#define DCP_CH1STAT_CLR_ERROR_SRC_SHIFT   (4U)
#define DCP_CH1STAT_CLR_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_SRC_SHIFT)) & DCP_CH1STAT_CLR_ERROR_SRC_MASK)
#define DCP_CH1STAT_CLR_ERROR_DST_MASK   (0x20U)
#define DCP_CH1STAT_CLR_ERROR_DST_SHIFT   (5U)
#define DCP_CH1STAT_CLR_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_DST_SHIFT)) & DCP_CH1STAT_CLR_ERROR_DST_MASK)
#define DCP_CH1STAT_CLR_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH1STAT_CLR_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH1STAT_CLR_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_PAGEFAULT_SHIFT)) & DCP_CH1STAT_CLR_ERROR_PAGEFAULT_MASK)
#define DCP_CH1STAT_CLR_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH1STAT_CLR_ERROR_CODE_SHIFT   (16U)
#define DCP_CH1STAT_CLR_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH1STAT_CLR_ERROR_CODE_MASK)
#define DCP_CH1STAT_CLR_TAG_MASK   (0xFF000000U)
#define DCP_CH1STAT_CLR_TAG_SHIFT   (24U)
#define DCP_CH1STAT_CLR_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_TAG_SHIFT)) & DCP_CH1STAT_CLR_TAG_MASK)
CH1STAT_TOG - DCP channel 1 status register
#define DCP_CH1STAT_TOG_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH1STAT_TOG_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH1STAT_TOG_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_RSVD_COMPLETE_SHIFT)) & DCP_CH1STAT_TOG_RSVD_COMPLETE_MASK)
#define DCP_CH1STAT_TOG_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH1STAT_TOG_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH1STAT_TOG_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_HASH_MISMATCH_SHIFT)) & DCP_CH1STAT_TOG_HASH_MISMATCH_MASK)
#define DCP_CH1STAT_TOG_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH1STAT_TOG_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH1STAT_TOG_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_SETUP_SHIFT)) & DCP_CH1STAT_TOG_ERROR_SETUP_MASK)
#define DCP_CH1STAT_TOG_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH1STAT_TOG_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH1STAT_TOG_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_PACKET_SHIFT)) & DCP_CH1STAT_TOG_ERROR_PACKET_MASK)
#define DCP_CH1STAT_TOG_ERROR_SRC_MASK   (0x10U)
#define DCP_CH1STAT_TOG_ERROR_SRC_SHIFT   (4U)
#define DCP_CH1STAT_TOG_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_SRC_SHIFT)) & DCP_CH1STAT_TOG_ERROR_SRC_MASK)
#define DCP_CH1STAT_TOG_ERROR_DST_MASK   (0x20U)
#define DCP_CH1STAT_TOG_ERROR_DST_SHIFT   (5U)
#define DCP_CH1STAT_TOG_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_DST_SHIFT)) & DCP_CH1STAT_TOG_ERROR_DST_MASK)
#define DCP_CH1STAT_TOG_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH1STAT_TOG_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH1STAT_TOG_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_PAGEFAULT_SHIFT)) & DCP_CH1STAT_TOG_ERROR_PAGEFAULT_MASK)
#define DCP_CH1STAT_TOG_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH1STAT_TOG_ERROR_CODE_SHIFT   (16U)
#define DCP_CH1STAT_TOG_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH1STAT_TOG_ERROR_CODE_MASK)
#define DCP_CH1STAT_TOG_TAG_MASK   (0xFF000000U)
#define DCP_CH1STAT_TOG_TAG_SHIFT   (24U)
#define DCP_CH1STAT_TOG_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_TAG_SHIFT)) & DCP_CH1STAT_TOG_TAG_MASK)
CH1OPTS - DCP channel 1 options register
#define DCP_CH1OPTS_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH1OPTS_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH1OPTS_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_RECOVERY_TIMER_SHIFT)) & DCP_CH1OPTS_RECOVERY_TIMER_MASK)
#define DCP_CH1OPTS_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH1OPTS_RSVD_SHIFT   (16U)
#define DCP_CH1OPTS_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_RSVD_SHIFT)) & DCP_CH1OPTS_RSVD_MASK)
CH1OPTS_SET - DCP channel 1 options register
#define DCP_CH1OPTS_SET_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH1OPTS_SET_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH1OPTS_SET_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_SET_RECOVERY_TIMER_SHIFT)) & DCP_CH1OPTS_SET_RECOVERY_TIMER_MASK)
#define DCP_CH1OPTS_SET_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH1OPTS_SET_RSVD_SHIFT   (16U)
#define DCP_CH1OPTS_SET_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_SET_RSVD_SHIFT)) & DCP_CH1OPTS_SET_RSVD_MASK)
CH1OPTS_CLR - DCP channel 1 options register
#define DCP_CH1OPTS_CLR_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH1OPTS_CLR_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH1OPTS_CLR_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_CLR_RECOVERY_TIMER_SHIFT)) & DCP_CH1OPTS_CLR_RECOVERY_TIMER_MASK)
#define DCP_CH1OPTS_CLR_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH1OPTS_CLR_RSVD_SHIFT   (16U)
#define DCP_CH1OPTS_CLR_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_CLR_RSVD_SHIFT)) & DCP_CH1OPTS_CLR_RSVD_MASK)
CH1OPTS_TOG - DCP channel 1 options register
#define DCP_CH1OPTS_TOG_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH1OPTS_TOG_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH1OPTS_TOG_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_TOG_RECOVERY_TIMER_SHIFT)) & DCP_CH1OPTS_TOG_RECOVERY_TIMER_MASK)
#define DCP_CH1OPTS_TOG_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH1OPTS_TOG_RSVD_SHIFT   (16U)
#define DCP_CH1OPTS_TOG_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH1OPTS_TOG_RSVD_SHIFT)) & DCP_CH1OPTS_TOG_RSVD_MASK)
CH2CMDPTR - DCP channel 2 command pointer address register
#define DCP_CH2CMDPTR_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_CH2CMDPTR_ADDR_SHIFT   (0U)
#define DCP_CH2CMDPTR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2CMDPTR_ADDR_SHIFT)) & DCP_CH2CMDPTR_ADDR_MASK)
CH2SEMA - DCP channel 2 semaphore register
#define DCP_CH2SEMA_INCREMENT_MASK   (0xFFU)
#define DCP_CH2SEMA_INCREMENT_SHIFT   (0U)
#define DCP_CH2SEMA_INCREMENT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2SEMA_INCREMENT_SHIFT)) & DCP_CH2SEMA_INCREMENT_MASK)
#define DCP_CH2SEMA_VALUE_MASK   (0xFF0000U)
#define DCP_CH2SEMA_VALUE_SHIFT   (16U)
#define DCP_CH2SEMA_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2SEMA_VALUE_SHIFT)) & DCP_CH2SEMA_VALUE_MASK)
CH2STAT - DCP channel 2 status register
#define DCP_CH2STAT_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH2STAT_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH2STAT_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_RSVD_COMPLETE_SHIFT)) & DCP_CH2STAT_RSVD_COMPLETE_MASK)
#define DCP_CH2STAT_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH2STAT_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH2STAT_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_HASH_MISMATCH_SHIFT)) & DCP_CH2STAT_HASH_MISMATCH_MASK)
#define DCP_CH2STAT_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH2STAT_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH2STAT_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_SETUP_SHIFT)) & DCP_CH2STAT_ERROR_SETUP_MASK)
#define DCP_CH2STAT_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH2STAT_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH2STAT_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_PACKET_SHIFT)) & DCP_CH2STAT_ERROR_PACKET_MASK)
#define DCP_CH2STAT_ERROR_SRC_MASK   (0x10U)
#define DCP_CH2STAT_ERROR_SRC_SHIFT   (4U)
#define DCP_CH2STAT_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_SRC_SHIFT)) & DCP_CH2STAT_ERROR_SRC_MASK)
#define DCP_CH2STAT_ERROR_DST_MASK   (0x20U)
#define DCP_CH2STAT_ERROR_DST_SHIFT   (5U)
#define DCP_CH2STAT_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_DST_SHIFT)) & DCP_CH2STAT_ERROR_DST_MASK)
#define DCP_CH2STAT_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH2STAT_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH2STAT_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_PAGEFAULT_SHIFT)) & DCP_CH2STAT_ERROR_PAGEFAULT_MASK)
#define DCP_CH2STAT_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH2STAT_ERROR_CODE_SHIFT   (16U)
#define DCP_CH2STAT_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_CODE_SHIFT)) & DCP_CH2STAT_ERROR_CODE_MASK)
#define DCP_CH2STAT_TAG_MASK   (0xFF000000U)
#define DCP_CH2STAT_TAG_SHIFT   (24U)
#define DCP_CH2STAT_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TAG_SHIFT)) & DCP_CH2STAT_TAG_MASK)
CH2STAT_SET - DCP channel 2 status register
#define DCP_CH2STAT_SET_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH2STAT_SET_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH2STAT_SET_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_RSVD_COMPLETE_SHIFT)) & DCP_CH2STAT_SET_RSVD_COMPLETE_MASK)
#define DCP_CH2STAT_SET_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH2STAT_SET_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH2STAT_SET_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_HASH_MISMATCH_SHIFT)) & DCP_CH2STAT_SET_HASH_MISMATCH_MASK)
#define DCP_CH2STAT_SET_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH2STAT_SET_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH2STAT_SET_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_SETUP_SHIFT)) & DCP_CH2STAT_SET_ERROR_SETUP_MASK)
#define DCP_CH2STAT_SET_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH2STAT_SET_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH2STAT_SET_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_PACKET_SHIFT)) & DCP_CH2STAT_SET_ERROR_PACKET_MASK)
#define DCP_CH2STAT_SET_ERROR_SRC_MASK   (0x10U)
#define DCP_CH2STAT_SET_ERROR_SRC_SHIFT   (4U)
#define DCP_CH2STAT_SET_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_SRC_SHIFT)) & DCP_CH2STAT_SET_ERROR_SRC_MASK)
#define DCP_CH2STAT_SET_ERROR_DST_MASK   (0x20U)
#define DCP_CH2STAT_SET_ERROR_DST_SHIFT   (5U)
#define DCP_CH2STAT_SET_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_DST_SHIFT)) & DCP_CH2STAT_SET_ERROR_DST_MASK)
#define DCP_CH2STAT_SET_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH2STAT_SET_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH2STAT_SET_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_PAGEFAULT_SHIFT)) & DCP_CH2STAT_SET_ERROR_PAGEFAULT_MASK)
#define DCP_CH2STAT_SET_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH2STAT_SET_ERROR_CODE_SHIFT   (16U)
#define DCP_CH2STAT_SET_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH2STAT_SET_ERROR_CODE_MASK)
#define DCP_CH2STAT_SET_TAG_MASK   (0xFF000000U)
#define DCP_CH2STAT_SET_TAG_SHIFT   (24U)
#define DCP_CH2STAT_SET_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_TAG_SHIFT)) & DCP_CH2STAT_SET_TAG_MASK)
CH2STAT_CLR - DCP channel 2 status register
#define DCP_CH2STAT_CLR_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH2STAT_CLR_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH2STAT_CLR_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_RSVD_COMPLETE_SHIFT)) & DCP_CH2STAT_CLR_RSVD_COMPLETE_MASK)
#define DCP_CH2STAT_CLR_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH2STAT_CLR_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH2STAT_CLR_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_HASH_MISMATCH_SHIFT)) & DCP_CH2STAT_CLR_HASH_MISMATCH_MASK)
#define DCP_CH2STAT_CLR_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH2STAT_CLR_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH2STAT_CLR_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_SETUP_SHIFT)) & DCP_CH2STAT_CLR_ERROR_SETUP_MASK)
#define DCP_CH2STAT_CLR_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH2STAT_CLR_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH2STAT_CLR_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_PACKET_SHIFT)) & DCP_CH2STAT_CLR_ERROR_PACKET_MASK)
#define DCP_CH2STAT_CLR_ERROR_SRC_MASK   (0x10U)
#define DCP_CH2STAT_CLR_ERROR_SRC_SHIFT   (4U)
#define DCP_CH2STAT_CLR_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_SRC_SHIFT)) & DCP_CH2STAT_CLR_ERROR_SRC_MASK)
#define DCP_CH2STAT_CLR_ERROR_DST_MASK   (0x20U)
#define DCP_CH2STAT_CLR_ERROR_DST_SHIFT   (5U)
#define DCP_CH2STAT_CLR_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_DST_SHIFT)) & DCP_CH2STAT_CLR_ERROR_DST_MASK)
#define DCP_CH2STAT_CLR_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH2STAT_CLR_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH2STAT_CLR_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_PAGEFAULT_SHIFT)) & DCP_CH2STAT_CLR_ERROR_PAGEFAULT_MASK)
#define DCP_CH2STAT_CLR_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH2STAT_CLR_ERROR_CODE_SHIFT   (16U)
#define DCP_CH2STAT_CLR_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH2STAT_CLR_ERROR_CODE_MASK)
#define DCP_CH2STAT_CLR_TAG_MASK   (0xFF000000U)
#define DCP_CH2STAT_CLR_TAG_SHIFT   (24U)
#define DCP_CH2STAT_CLR_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_TAG_SHIFT)) & DCP_CH2STAT_CLR_TAG_MASK)
CH2STAT_TOG - DCP channel 2 status register
#define DCP_CH2STAT_TOG_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH2STAT_TOG_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH2STAT_TOG_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_RSVD_COMPLETE_SHIFT)) & DCP_CH2STAT_TOG_RSVD_COMPLETE_MASK)
#define DCP_CH2STAT_TOG_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH2STAT_TOG_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH2STAT_TOG_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_HASH_MISMATCH_SHIFT)) & DCP_CH2STAT_TOG_HASH_MISMATCH_MASK)
#define DCP_CH2STAT_TOG_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH2STAT_TOG_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH2STAT_TOG_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_SETUP_SHIFT)) & DCP_CH2STAT_TOG_ERROR_SETUP_MASK)
#define DCP_CH2STAT_TOG_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH2STAT_TOG_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH2STAT_TOG_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_PACKET_SHIFT)) & DCP_CH2STAT_TOG_ERROR_PACKET_MASK)
#define DCP_CH2STAT_TOG_ERROR_SRC_MASK   (0x10U)
#define DCP_CH2STAT_TOG_ERROR_SRC_SHIFT   (4U)
#define DCP_CH2STAT_TOG_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_SRC_SHIFT)) & DCP_CH2STAT_TOG_ERROR_SRC_MASK)
#define DCP_CH2STAT_TOG_ERROR_DST_MASK   (0x20U)
#define DCP_CH2STAT_TOG_ERROR_DST_SHIFT   (5U)
#define DCP_CH2STAT_TOG_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_DST_SHIFT)) & DCP_CH2STAT_TOG_ERROR_DST_MASK)
#define DCP_CH2STAT_TOG_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH2STAT_TOG_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH2STAT_TOG_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_PAGEFAULT_SHIFT)) & DCP_CH2STAT_TOG_ERROR_PAGEFAULT_MASK)
#define DCP_CH2STAT_TOG_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH2STAT_TOG_ERROR_CODE_SHIFT   (16U)
#define DCP_CH2STAT_TOG_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH2STAT_TOG_ERROR_CODE_MASK)
#define DCP_CH2STAT_TOG_TAG_MASK   (0xFF000000U)
#define DCP_CH2STAT_TOG_TAG_SHIFT   (24U)
#define DCP_CH2STAT_TOG_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_TAG_SHIFT)) & DCP_CH2STAT_TOG_TAG_MASK)
CH2OPTS - DCP channel 2 options register
#define DCP_CH2OPTS_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH2OPTS_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH2OPTS_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_RECOVERY_TIMER_SHIFT)) & DCP_CH2OPTS_RECOVERY_TIMER_MASK)
#define DCP_CH2OPTS_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH2OPTS_RSVD_SHIFT   (16U)
#define DCP_CH2OPTS_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_RSVD_SHIFT)) & DCP_CH2OPTS_RSVD_MASK)
CH2OPTS_SET - DCP channel 2 options register
#define DCP_CH2OPTS_SET_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH2OPTS_SET_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH2OPTS_SET_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_SET_RECOVERY_TIMER_SHIFT)) & DCP_CH2OPTS_SET_RECOVERY_TIMER_MASK)
#define DCP_CH2OPTS_SET_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH2OPTS_SET_RSVD_SHIFT   (16U)
#define DCP_CH2OPTS_SET_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_SET_RSVD_SHIFT)) & DCP_CH2OPTS_SET_RSVD_MASK)
CH2OPTS_CLR - DCP channel 2 options register
#define DCP_CH2OPTS_CLR_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH2OPTS_CLR_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH2OPTS_CLR_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_CLR_RECOVERY_TIMER_SHIFT)) & DCP_CH2OPTS_CLR_RECOVERY_TIMER_MASK)
#define DCP_CH2OPTS_CLR_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH2OPTS_CLR_RSVD_SHIFT   (16U)
#define DCP_CH2OPTS_CLR_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_CLR_RSVD_SHIFT)) & DCP_CH2OPTS_CLR_RSVD_MASK)
CH2OPTS_TOG - DCP channel 2 options register
#define DCP_CH2OPTS_TOG_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH2OPTS_TOG_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH2OPTS_TOG_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_TOG_RECOVERY_TIMER_SHIFT)) & DCP_CH2OPTS_TOG_RECOVERY_TIMER_MASK)
#define DCP_CH2OPTS_TOG_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH2OPTS_TOG_RSVD_SHIFT   (16U)
#define DCP_CH2OPTS_TOG_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH2OPTS_TOG_RSVD_SHIFT)) & DCP_CH2OPTS_TOG_RSVD_MASK)
CH3CMDPTR - DCP channel 3 command pointer address register
#define DCP_CH3CMDPTR_ADDR_MASK   (0xFFFFFFFFU)
#define DCP_CH3CMDPTR_ADDR_SHIFT   (0U)
#define DCP_CH3CMDPTR_ADDR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3CMDPTR_ADDR_SHIFT)) & DCP_CH3CMDPTR_ADDR_MASK)
CH3SEMA - DCP channel 3 semaphore register
#define DCP_CH3SEMA_INCREMENT_MASK   (0xFFU)
#define DCP_CH3SEMA_INCREMENT_SHIFT   (0U)
#define DCP_CH3SEMA_INCREMENT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3SEMA_INCREMENT_SHIFT)) & DCP_CH3SEMA_INCREMENT_MASK)
#define DCP_CH3SEMA_VALUE_MASK   (0xFF0000U)
#define DCP_CH3SEMA_VALUE_SHIFT   (16U)
#define DCP_CH3SEMA_VALUE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3SEMA_VALUE_SHIFT)) & DCP_CH3SEMA_VALUE_MASK)
CH3STAT - DCP channel 3 status register
#define DCP_CH3STAT_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH3STAT_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH3STAT_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_RSVD_COMPLETE_SHIFT)) & DCP_CH3STAT_RSVD_COMPLETE_MASK)
#define DCP_CH3STAT_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH3STAT_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH3STAT_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_HASH_MISMATCH_SHIFT)) & DCP_CH3STAT_HASH_MISMATCH_MASK)
#define DCP_CH3STAT_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH3STAT_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH3STAT_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_SETUP_SHIFT)) & DCP_CH3STAT_ERROR_SETUP_MASK)
#define DCP_CH3STAT_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH3STAT_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH3STAT_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_PACKET_SHIFT)) & DCP_CH3STAT_ERROR_PACKET_MASK)
#define DCP_CH3STAT_ERROR_SRC_MASK   (0x10U)
#define DCP_CH3STAT_ERROR_SRC_SHIFT   (4U)
#define DCP_CH3STAT_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_SRC_SHIFT)) & DCP_CH3STAT_ERROR_SRC_MASK)
#define DCP_CH3STAT_ERROR_DST_MASK   (0x20U)
#define DCP_CH3STAT_ERROR_DST_SHIFT   (5U)
#define DCP_CH3STAT_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_DST_SHIFT)) & DCP_CH3STAT_ERROR_DST_MASK)
#define DCP_CH3STAT_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH3STAT_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH3STAT_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_PAGEFAULT_SHIFT)) & DCP_CH3STAT_ERROR_PAGEFAULT_MASK)
#define DCP_CH3STAT_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH3STAT_ERROR_CODE_SHIFT   (16U)
#define DCP_CH3STAT_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_CODE_SHIFT)) & DCP_CH3STAT_ERROR_CODE_MASK)
#define DCP_CH3STAT_TAG_MASK   (0xFF000000U)
#define DCP_CH3STAT_TAG_SHIFT   (24U)
#define DCP_CH3STAT_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TAG_SHIFT)) & DCP_CH3STAT_TAG_MASK)
CH3STAT_SET - DCP channel 3 status register
#define DCP_CH3STAT_SET_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH3STAT_SET_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH3STAT_SET_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_RSVD_COMPLETE_SHIFT)) & DCP_CH3STAT_SET_RSVD_COMPLETE_MASK)
#define DCP_CH3STAT_SET_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH3STAT_SET_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH3STAT_SET_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_HASH_MISMATCH_SHIFT)) & DCP_CH3STAT_SET_HASH_MISMATCH_MASK)
#define DCP_CH3STAT_SET_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH3STAT_SET_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH3STAT_SET_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_SETUP_SHIFT)) & DCP_CH3STAT_SET_ERROR_SETUP_MASK)
#define DCP_CH3STAT_SET_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH3STAT_SET_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH3STAT_SET_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_PACKET_SHIFT)) & DCP_CH3STAT_SET_ERROR_PACKET_MASK)
#define DCP_CH3STAT_SET_ERROR_SRC_MASK   (0x10U)
#define DCP_CH3STAT_SET_ERROR_SRC_SHIFT   (4U)
#define DCP_CH3STAT_SET_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_SRC_SHIFT)) & DCP_CH3STAT_SET_ERROR_SRC_MASK)
#define DCP_CH3STAT_SET_ERROR_DST_MASK   (0x20U)
#define DCP_CH3STAT_SET_ERROR_DST_SHIFT   (5U)
#define DCP_CH3STAT_SET_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_DST_SHIFT)) & DCP_CH3STAT_SET_ERROR_DST_MASK)
#define DCP_CH3STAT_SET_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH3STAT_SET_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH3STAT_SET_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_PAGEFAULT_SHIFT)) & DCP_CH3STAT_SET_ERROR_PAGEFAULT_MASK)
#define DCP_CH3STAT_SET_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH3STAT_SET_ERROR_CODE_SHIFT   (16U)
#define DCP_CH3STAT_SET_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH3STAT_SET_ERROR_CODE_MASK)
#define DCP_CH3STAT_SET_TAG_MASK   (0xFF000000U)
#define DCP_CH3STAT_SET_TAG_SHIFT   (24U)
#define DCP_CH3STAT_SET_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_TAG_SHIFT)) & DCP_CH3STAT_SET_TAG_MASK)
CH3STAT_CLR - DCP channel 3 status register
#define DCP_CH3STAT_CLR_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH3STAT_CLR_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH3STAT_CLR_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_RSVD_COMPLETE_SHIFT)) & DCP_CH3STAT_CLR_RSVD_COMPLETE_MASK)
#define DCP_CH3STAT_CLR_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH3STAT_CLR_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH3STAT_CLR_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_HASH_MISMATCH_SHIFT)) & DCP_CH3STAT_CLR_HASH_MISMATCH_MASK)
#define DCP_CH3STAT_CLR_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH3STAT_CLR_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH3STAT_CLR_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_SETUP_SHIFT)) & DCP_CH3STAT_CLR_ERROR_SETUP_MASK)
#define DCP_CH3STAT_CLR_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH3STAT_CLR_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH3STAT_CLR_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_PACKET_SHIFT)) & DCP_CH3STAT_CLR_ERROR_PACKET_MASK)
#define DCP_CH3STAT_CLR_ERROR_SRC_MASK   (0x10U)
#define DCP_CH3STAT_CLR_ERROR_SRC_SHIFT   (4U)
#define DCP_CH3STAT_CLR_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_SRC_SHIFT)) & DCP_CH3STAT_CLR_ERROR_SRC_MASK)
#define DCP_CH3STAT_CLR_ERROR_DST_MASK   (0x20U)
#define DCP_CH3STAT_CLR_ERROR_DST_SHIFT   (5U)
#define DCP_CH3STAT_CLR_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_DST_SHIFT)) & DCP_CH3STAT_CLR_ERROR_DST_MASK)
#define DCP_CH3STAT_CLR_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH3STAT_CLR_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH3STAT_CLR_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_PAGEFAULT_SHIFT)) & DCP_CH3STAT_CLR_ERROR_PAGEFAULT_MASK)
#define DCP_CH3STAT_CLR_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH3STAT_CLR_ERROR_CODE_SHIFT   (16U)
#define DCP_CH3STAT_CLR_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH3STAT_CLR_ERROR_CODE_MASK)
#define DCP_CH3STAT_CLR_TAG_MASK   (0xFF000000U)
#define DCP_CH3STAT_CLR_TAG_SHIFT   (24U)
#define DCP_CH3STAT_CLR_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_TAG_SHIFT)) & DCP_CH3STAT_CLR_TAG_MASK)
CH3STAT_TOG - DCP channel 3 status register
#define DCP_CH3STAT_TOG_RSVD_COMPLETE_MASK   (0x1U)
#define DCP_CH3STAT_TOG_RSVD_COMPLETE_SHIFT   (0U)
#define DCP_CH3STAT_TOG_RSVD_COMPLETE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_RSVD_COMPLETE_SHIFT)) & DCP_CH3STAT_TOG_RSVD_COMPLETE_MASK)
#define DCP_CH3STAT_TOG_HASH_MISMATCH_MASK   (0x2U)
#define DCP_CH3STAT_TOG_HASH_MISMATCH_SHIFT   (1U)
#define DCP_CH3STAT_TOG_HASH_MISMATCH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_HASH_MISMATCH_SHIFT)) & DCP_CH3STAT_TOG_HASH_MISMATCH_MASK)
#define DCP_CH3STAT_TOG_ERROR_SETUP_MASK   (0x4U)
#define DCP_CH3STAT_TOG_ERROR_SETUP_SHIFT   (2U)
#define DCP_CH3STAT_TOG_ERROR_SETUP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_SETUP_SHIFT)) & DCP_CH3STAT_TOG_ERROR_SETUP_MASK)
#define DCP_CH3STAT_TOG_ERROR_PACKET_MASK   (0x8U)
#define DCP_CH3STAT_TOG_ERROR_PACKET_SHIFT   (3U)
#define DCP_CH3STAT_TOG_ERROR_PACKET(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_PACKET_SHIFT)) & DCP_CH3STAT_TOG_ERROR_PACKET_MASK)
#define DCP_CH3STAT_TOG_ERROR_SRC_MASK   (0x10U)
#define DCP_CH3STAT_TOG_ERROR_SRC_SHIFT   (4U)
#define DCP_CH3STAT_TOG_ERROR_SRC(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_SRC_SHIFT)) & DCP_CH3STAT_TOG_ERROR_SRC_MASK)
#define DCP_CH3STAT_TOG_ERROR_DST_MASK   (0x20U)
#define DCP_CH3STAT_TOG_ERROR_DST_SHIFT   (5U)
#define DCP_CH3STAT_TOG_ERROR_DST(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_DST_SHIFT)) & DCP_CH3STAT_TOG_ERROR_DST_MASK)
#define DCP_CH3STAT_TOG_ERROR_PAGEFAULT_MASK   (0x40U)
#define DCP_CH3STAT_TOG_ERROR_PAGEFAULT_SHIFT   (6U)
#define DCP_CH3STAT_TOG_ERROR_PAGEFAULT(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_PAGEFAULT_SHIFT)) & DCP_CH3STAT_TOG_ERROR_PAGEFAULT_MASK)
#define DCP_CH3STAT_TOG_ERROR_CODE_MASK   (0xFF0000U)
#define DCP_CH3STAT_TOG_ERROR_CODE_SHIFT   (16U)
#define DCP_CH3STAT_TOG_ERROR_CODE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH3STAT_TOG_ERROR_CODE_MASK)
#define DCP_CH3STAT_TOG_TAG_MASK   (0xFF000000U)
#define DCP_CH3STAT_TOG_TAG_SHIFT   (24U)
#define DCP_CH3STAT_TOG_TAG(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_TAG_SHIFT)) & DCP_CH3STAT_TOG_TAG_MASK)
CH3OPTS - DCP channel 3 options register
#define DCP_CH3OPTS_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH3OPTS_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH3OPTS_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_RECOVERY_TIMER_SHIFT)) & DCP_CH3OPTS_RECOVERY_TIMER_MASK)
#define DCP_CH3OPTS_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH3OPTS_RSVD_SHIFT   (16U)
#define DCP_CH3OPTS_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_RSVD_SHIFT)) & DCP_CH3OPTS_RSVD_MASK)
CH3OPTS_SET - DCP channel 3 options register
#define DCP_CH3OPTS_SET_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH3OPTS_SET_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH3OPTS_SET_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_SET_RECOVERY_TIMER_SHIFT)) & DCP_CH3OPTS_SET_RECOVERY_TIMER_MASK)
#define DCP_CH3OPTS_SET_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH3OPTS_SET_RSVD_SHIFT   (16U)
#define DCP_CH3OPTS_SET_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_SET_RSVD_SHIFT)) & DCP_CH3OPTS_SET_RSVD_MASK)
CH3OPTS_CLR - DCP channel 3 options register
#define DCP_CH3OPTS_CLR_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH3OPTS_CLR_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH3OPTS_CLR_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_CLR_RECOVERY_TIMER_SHIFT)) & DCP_CH3OPTS_CLR_RECOVERY_TIMER_MASK)
#define DCP_CH3OPTS_CLR_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH3OPTS_CLR_RSVD_SHIFT   (16U)
#define DCP_CH3OPTS_CLR_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_CLR_RSVD_SHIFT)) & DCP_CH3OPTS_CLR_RSVD_MASK)
CH3OPTS_TOG - DCP channel 3 options register
#define DCP_CH3OPTS_TOG_RECOVERY_TIMER_MASK   (0xFFFFU)
#define DCP_CH3OPTS_TOG_RECOVERY_TIMER_SHIFT   (0U)
#define DCP_CH3OPTS_TOG_RECOVERY_TIMER(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_TOG_RECOVERY_TIMER_SHIFT)) & DCP_CH3OPTS_TOG_RECOVERY_TIMER_MASK)
#define DCP_CH3OPTS_TOG_RSVD_MASK   (0xFFFF0000U)
#define DCP_CH3OPTS_TOG_RSVD_SHIFT   (16U)
#define DCP_CH3OPTS_TOG_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_CH3OPTS_TOG_RSVD_SHIFT)) & DCP_CH3OPTS_TOG_RSVD_MASK)
DBGSELECT - DCP debug select register
#define DCP_DBGSELECT_INDEX_MASK   (0xFFU)
#define DCP_DBGSELECT_INDEX_SHIFT   (0U)
#define DCP_DBGSELECT_INDEX(x)   (((uint32_t)(((uint32_t)(x)) << DCP_DBGSELECT_INDEX_SHIFT)) & DCP_DBGSELECT_INDEX_MASK)
#define DCP_DBGSELECT_RSVD_MASK   (0xFFFFFF00U)
#define DCP_DBGSELECT_RSVD_SHIFT   (8U)
#define DCP_DBGSELECT_RSVD(x)   (((uint32_t)(((uint32_t)(x)) << DCP_DBGSELECT_RSVD_SHIFT)) & DCP_DBGSELECT_RSVD_MASK)
DBGDATA - DCP debug data register
#define DCP_DBGDATA_DATA_MASK   (0xFFFFFFFFU)
#define DCP_DBGDATA_DATA_SHIFT   (0U)
#define DCP_DBGDATA_DATA(x)   (((uint32_t)(((uint32_t)(x)) << DCP_DBGDATA_DATA_SHIFT)) & DCP_DBGDATA_DATA_MASK)
PAGETABLE - DCP page table register
#define DCP_PAGETABLE_ENABLE_MASK   (0x1U)
#define DCP_PAGETABLE_ENABLE_SHIFT   (0U)
#define DCP_PAGETABLE_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PAGETABLE_ENABLE_SHIFT)) & DCP_PAGETABLE_ENABLE_MASK)
#define DCP_PAGETABLE_FLUSH_MASK   (0x2U)
#define DCP_PAGETABLE_FLUSH_SHIFT   (1U)
#define DCP_PAGETABLE_FLUSH(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PAGETABLE_FLUSH_SHIFT)) & DCP_PAGETABLE_FLUSH_MASK)
#define DCP_PAGETABLE_BASE_MASK   (0xFFFFFFFCU)
#define DCP_PAGETABLE_BASE_SHIFT   (2U)
#define DCP_PAGETABLE_BASE(x)   (((uint32_t)(((uint32_t)(x)) << DCP_PAGETABLE_BASE_SHIFT)) & DCP_PAGETABLE_BASE_MASK)
VERSION - DCP version register
#define DCP_VERSION_STEP_MASK   (0xFFFFU)
#define DCP_VERSION_STEP_SHIFT   (0U)
#define DCP_VERSION_STEP(x)   (((uint32_t)(((uint32_t)(x)) << DCP_VERSION_STEP_SHIFT)) & DCP_VERSION_STEP_MASK)
#define DCP_VERSION_MINOR_MASK   (0xFF0000U)
#define DCP_VERSION_MINOR_SHIFT   (16U)
#define DCP_VERSION_MINOR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_VERSION_MINOR_SHIFT)) & DCP_VERSION_MINOR_MASK)
#define DCP_VERSION_MAJOR_MASK   (0xFF000000U)
#define DCP_VERSION_MAJOR_SHIFT   (24U)
#define DCP_VERSION_MAJOR(x)   (((uint32_t)(((uint32_t)(x)) << DCP_VERSION_MAJOR_SHIFT)) & DCP_VERSION_MAJOR_MASK)
◆ DCP_CAPABILITY1_CIPHER_ALGORITHMS
#define DCP_CAPABILITY1_CIPHER_ALGORITHMS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY1_CIPHER_ALGORITHMS_SHIFT)) & DCP_CAPABILITY1_CIPHER_ALGORITHMS_MASK)
CIPHER_ALGORITHMS 0b0000000000000001..AES128
◆ DCP_CAPABILITY1_HASH_ALGORITHMS
#define DCP_CAPABILITY1_HASH_ALGORITHMS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CAPABILITY1_HASH_ALGORITHMS_SHIFT)) & DCP_CAPABILITY1_HASH_ALGORITHMS_MASK)
HASH_ALGORITHMS 0b0000000000000001..SHA1 0b0000000000000010..CRC32 0b0000000000000100..SHA256
◆ DCP_CH0STAT_CLR_ERROR_CODE
#define DCP_CH0STAT_CLR_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH0STAT_CLR_ERROR_CODE_MASK)
ERROR_CODE 0b00000001..Error signalled because the next pointer is 0x00000000 0b00000010..Error signalled because the semaphore is non-zero and neither chain bit is set 0b00000011..Error signalled because an error is reported reading/writing the context buffer 0b00000100..Error signalled because an error is reported reading/writing the payload 0b00000101..Error signalled because the control packet specifies an invalid mode select (for instance, blit + hash)
◆ DCP_CH0STAT_ERROR_CODE
#define DCP_CH0STAT_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_ERROR_CODE_SHIFT)) & DCP_CH0STAT_ERROR_CODE_MASK)
◆ DCP_CH0STAT_SET_ERROR_CODE
#define DCP_CH0STAT_SET_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH0STAT_SET_ERROR_CODE_MASK)
◆ DCP_CH0STAT_TOG_ERROR_CODE
#define DCP_CH0STAT_TOG_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH0STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH0STAT_TOG_ERROR_CODE_MASK)
◆ DCP_CH1STAT_CLR_ERROR_CODE
#define DCP_CH1STAT_CLR_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH1STAT_CLR_ERROR_CODE_MASK)
ERROR_CODE 0b00000001..Error is signalled because the next pointer is 0x00000000. 0b00000010..Error is signalled because the semaphore is of a non-zero value and neither of the chain bits is set. 0b00000011..Error is signalled because an error was reported when reading/writing the context buffer. 0b00000100..Error is signalled because an error was reported when reading/writing the payload. 0b00000101..Error is signalled because the control packet specifies an invalid mode select (for example, blit + hash).
◆ DCP_CH1STAT_ERROR_CODE
#define DCP_CH1STAT_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_ERROR_CODE_SHIFT)) & DCP_CH1STAT_ERROR_CODE_MASK)
◆ DCP_CH1STAT_SET_ERROR_CODE
#define DCP_CH1STAT_SET_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH1STAT_SET_ERROR_CODE_MASK)
◆ DCP_CH1STAT_TOG_ERROR_CODE
#define DCP_CH1STAT_TOG_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH1STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH1STAT_TOG_ERROR_CODE_MASK)
◆ DCP_CH2STAT_CLR_ERROR_CODE
#define DCP_CH2STAT_CLR_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH2STAT_CLR_ERROR_CODE_MASK)
ERROR_CODE 0b00000001..Error is signalled because the next pointer is 0x00000000. 0b00000010..Error is signalled because the semaphore is of a non-zero value and neither of the chain bits is set. 0b00000011..Error is signalled because an error was reported while reading/writing the context buffer. 0b00000100..Error is signalled because an error was reported while reading/writing the payload. 0b00000101..Error is signalled because the control packet specifies an invalid mode select (for instance, blit + hash).
◆ DCP_CH2STAT_ERROR_CODE
#define DCP_CH2STAT_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_ERROR_CODE_SHIFT)) & DCP_CH2STAT_ERROR_CODE_MASK)
◆ DCP_CH2STAT_SET_ERROR_CODE
#define DCP_CH2STAT_SET_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH2STAT_SET_ERROR_CODE_MASK)
◆ DCP_CH2STAT_TOG_ERROR_CODE
#define DCP_CH2STAT_TOG_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH2STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH2STAT_TOG_ERROR_CODE_MASK)
◆ DCP_CH3STAT_CLR_ERROR_CODE
#define DCP_CH3STAT_CLR_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_CLR_ERROR_CODE_SHIFT)) & DCP_CH3STAT_CLR_ERROR_CODE_MASK)
ERROR_CODE 0b00000001..Error is signalled because the next pointer is 0x00000000. 0b00000010..Error is signalled because the semaphore is of a non-zero value and neither of the chain bits is set. 0b00000011..Error is signalled because an error was reported while reading/writing the context buffer. 0b00000100..Error is signalled because an error was reported while reading/writing the payload. 0b00000101..Error is signalled because the control packet specifies an invalid mode select (for example, blit + hash).
◆ DCP_CH3STAT_ERROR_CODE
#define DCP_CH3STAT_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_ERROR_CODE_SHIFT)) & DCP_CH3STAT_ERROR_CODE_MASK)
◆ DCP_CH3STAT_SET_ERROR_CODE
#define DCP_CH3STAT_SET_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_SET_ERROR_CODE_SHIFT)) & DCP_CH3STAT_SET_ERROR_CODE_MASK)
◆ DCP_CH3STAT_TOG_ERROR_CODE
#define DCP_CH3STAT_TOG_ERROR_CODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CH3STAT_TOG_ERROR_CODE_SHIFT)) & DCP_CH3STAT_TOG_ERROR_CODE_MASK)
◆ DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL
#define DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_CLR_ENABLE_CHANNEL_MASK)
ENABLE_CHANNEL 0b00000001..CH0 0b00000010..CH1 0b00000100..CH2 0b00001000..CH3
◆ DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL
#define DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_CLR_HIGH_PRIORITY_CHANNEL_MASK)
HIGH_PRIORITY_CHANNEL 0b00000001..CH0 0b00000010..CH1 0b00000100..CH2 0b00001000..CH3
◆ DCP_CHANNELCTRL_ENABLE_CHANNEL
#define DCP_CHANNELCTRL_ENABLE_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_ENABLE_CHANNEL_MASK)
◆ DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL
#define DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_HIGH_PRIORITY_CHANNEL_MASK)
◆ DCP_CHANNELCTRL_SET_ENABLE_CHANNEL
#define DCP_CHANNELCTRL_SET_ENABLE_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_SET_ENABLE_CHANNEL_MASK)
◆ DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL
#define DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_SET_HIGH_PRIORITY_CHANNEL_MASK)
◆ DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL
#define DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_TOG_ENABLE_CHANNEL_MASK)
◆ DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL
#define DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_SHIFT)) & DCP_CHANNELCTRL_TOG_HIGH_PRIORITY_CHANNEL_MASK)
◆ DCP_CTRL_CHANNEL_INTERRUPT_ENABLE
#define DCP_CTRL_CHANNEL_INTERRUPT_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_CHANNEL_INTERRUPT_ENABLE_MASK)
CHANNEL_INTERRUPT_ENABLE 0b00000001..CH0 0b00000010..CH1 0b00000100..CH2 0b00001000..CH3
◆ DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE
#define DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_CLR_CHANNEL_INTERRUPT_ENABLE_MASK)
◆ DCP_CTRL_CLR_PRESENT_CRYPTO
#define DCP_CTRL_CLR_PRESENT_CRYPTO (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_CLR_PRESENT_CRYPTO_MASK)
PRESENT_CRYPTO 0b1..Present 0b0..Absent
◆ DCP_CTRL_CLR_PRESENT_SHA
#define DCP_CTRL_CLR_PRESENT_SHA (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_CLR_PRESENT_SHA_SHIFT)) & DCP_CTRL_CLR_PRESENT_SHA_MASK)
PRESENT_SHA 0b1..Present 0b0..Absent
◆ DCP_CTRL_PRESENT_CRYPTO
#define DCP_CTRL_PRESENT_CRYPTO (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_PRESENT_CRYPTO_MASK)
◆ DCP_CTRL_PRESENT_SHA
#define DCP_CTRL_PRESENT_SHA (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_PRESENT_SHA_SHIFT)) & DCP_CTRL_PRESENT_SHA_MASK)
◆ DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE
#define DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_SET_CHANNEL_INTERRUPT_ENABLE_MASK)
◆ DCP_CTRL_SET_PRESENT_CRYPTO
#define DCP_CTRL_SET_PRESENT_CRYPTO (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_SET_PRESENT_CRYPTO_MASK)
◆ DCP_CTRL_SET_PRESENT_SHA
#define DCP_CTRL_SET_PRESENT_SHA (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_SET_PRESENT_SHA_SHIFT)) & DCP_CTRL_SET_PRESENT_SHA_MASK)
◆ DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE
#define DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_SHIFT)) & DCP_CTRL_TOG_CHANNEL_INTERRUPT_ENABLE_MASK)
◆ DCP_CTRL_TOG_PRESENT_CRYPTO
#define DCP_CTRL_TOG_PRESENT_CRYPTO (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_PRESENT_CRYPTO_SHIFT)) & DCP_CTRL_TOG_PRESENT_CRYPTO_MASK)
◆ DCP_CTRL_TOG_PRESENT_SHA
#define DCP_CTRL_TOG_PRESENT_SHA (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_CTRL_TOG_PRESENT_SHA_SHIFT)) & DCP_CTRL_TOG_PRESENT_SHA_MASK)
◆ DCP_DBGSELECT_INDEX
#define DCP_DBGSELECT_INDEX (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_DBGSELECT_INDEX_SHIFT)) & DCP_DBGSELECT_INDEX_MASK)
INDEX 0b00000001..CONTROL 0b00010000..OTPKEY0 0b00010001..OTPKEY1 0b00010010..OTPKEY2 0b00010011..OTPKEY3
◆ DCP_PACKET1_CIPHER_ENCRYPT
#define DCP_PACKET1_CIPHER_ENCRYPT (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_CIPHER_ENCRYPT_SHIFT)) & DCP_PACKET1_CIPHER_ENCRYPT_MASK)
CIPHER_ENCRYPT 0b1..ENCRYPT 0b0..DECRYPT
◆ DCP_PACKET1_HASH_OUTPUT
#define DCP_PACKET1_HASH_OUTPUT (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET1_HASH_OUTPUT_SHIFT)) & DCP_PACKET1_HASH_OUTPUT_MASK)
HASH_OUTPUT 0b0..INPUT 0b1..OUTPUT
◆ DCP_PACKET2_CIPHER_MODE
#define DCP_PACKET2_CIPHER_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_CIPHER_MODE_SHIFT)) & DCP_PACKET2_CIPHER_MODE_MASK)
CIPHER_MODE 0b0000..ECB 0b0001..CBC
◆ DCP_PACKET2_CIPHER_SELECT
#define DCP_PACKET2_CIPHER_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_CIPHER_SELECT_SHIFT)) & DCP_PACKET2_CIPHER_SELECT_MASK)
CIPHER_SELECT 0b0000..AES128
◆ DCP_PACKET2_HASH_SELECT
#define DCP_PACKET2_HASH_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_HASH_SELECT_SHIFT)) & DCP_PACKET2_HASH_SELECT_MASK)
HASH_SELECT 0b0000..SHA1 0b0001..CRC32 0b0010..SHA256
◆ DCP_PACKET2_KEY_SELECT
#define DCP_PACKET2_KEY_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_PACKET2_KEY_SELECT_SHIFT)) & DCP_PACKET2_KEY_SELECT_MASK)
KEY_SELECT 0b00000000..KEY0 0b00000001..KEY1 0b00000010..KEY2 0b00000011..KEY3 0b11111110..UNIQUE_KEY 0b11111111..OTP_KEY
◆ DCP_STAT_CLR_CUR_CHANNEL
#define DCP_STAT_CLR_CUR_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_CUR_CHANNEL_SHIFT)) & DCP_STAT_CLR_CUR_CHANNEL_MASK)
CUR_CHANNEL 0b0000..None 0b0001..CH0 0b0010..CH1 0b0011..CH2 0b0100..CH3
◆ DCP_STAT_CLR_READY_CHANNELS
#define DCP_STAT_CLR_READY_CHANNELS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CLR_READY_CHANNELS_SHIFT)) & DCP_STAT_CLR_READY_CHANNELS_MASK)
READY_CHANNELS 0b00000001..CH0 0b00000010..CH1 0b00000100..CH2 0b00001000..CH3
◆ DCP_STAT_CUR_CHANNEL
#define DCP_STAT_CUR_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_CUR_CHANNEL_SHIFT)) & DCP_STAT_CUR_CHANNEL_MASK)
◆ DCP_STAT_READY_CHANNELS
#define DCP_STAT_READY_CHANNELS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_READY_CHANNELS_SHIFT)) & DCP_STAT_READY_CHANNELS_MASK)
◆ DCP_STAT_SET_CUR_CHANNEL
#define DCP_STAT_SET_CUR_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_CUR_CHANNEL_SHIFT)) & DCP_STAT_SET_CUR_CHANNEL_MASK)
◆ DCP_STAT_SET_READY_CHANNELS
#define DCP_STAT_SET_READY_CHANNELS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_SET_READY_CHANNELS_SHIFT)) & DCP_STAT_SET_READY_CHANNELS_MASK)
◆ DCP_STAT_TOG_CUR_CHANNEL
#define DCP_STAT_TOG_CUR_CHANNEL (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_CUR_CHANNEL_SHIFT)) & DCP_STAT_TOG_CUR_CHANNEL_MASK)
◆ DCP_STAT_TOG_READY_CHANNELS
#define DCP_STAT_TOG_READY_CHANNELS (   x)    (((uint32_t)(((uint32_t)(x)) << DCP_STAT_TOG_READY_CHANNELS_SHIFT)) & DCP_STAT_TOG_READY_CHANNELS_MASK)
