RTEMS 6.1-rc1
#define DCIC_DCICRC_COUNT   (16U)
#define DCIC_DCICRS_COUNT   (16U)
#define DCIC_DCICRRS_COUNT   (16U)
#define DCIC_DCICRCS_COUNT   (16U)
DCICC - DCIC Control Register
#define DCIC_DCICC_IC_EN_MASK   (0x1U)
#define DCIC_DCICC_IC_EN_SHIFT   (0U)
#define DCIC_DCICC_IC_EN(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_IC_EN_SHIFT)) & DCIC_DCICC_IC_EN_MASK)
#define DCIC_DCICC_DE_POL_MASK   (0x10U)
#define DCIC_DCICC_DE_POL_SHIFT   (4U)
#define DCIC_DCICC_DE_POL(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_DE_POL_SHIFT)) & DCIC_DCICC_DE_POL_MASK)
#define DCIC_DCICC_HSYNC_POL_MASK   (0x20U)
#define DCIC_DCICC_HSYNC_POL_SHIFT   (5U)
#define DCIC_DCICC_HSYNC_POL(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_HSYNC_POL_SHIFT)) & DCIC_DCICC_HSYNC_POL_MASK)
#define DCIC_DCICC_VSYNC_POL_MASK   (0x40U)
#define DCIC_DCICC_VSYNC_POL_SHIFT   (6U)
#define DCIC_DCICC_VSYNC_POL(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_VSYNC_POL_SHIFT)) & DCIC_DCICC_VSYNC_POL_MASK)
#define DCIC_DCICC_CLK_POL_MASK   (0x80U)
#define DCIC_DCICC_CLK_POL_SHIFT   (7U)
#define DCIC_DCICC_CLK_POL(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_CLK_POL_SHIFT)) & DCIC_DCICC_CLK_POL_MASK)
DCICIC - DCIC Interrupt Control Register
#define DCIC_DCICIC_EI_MASK_MASK   (0x1U)
#define DCIC_DCICIC_EI_MASK_SHIFT   (0U)
#define DCIC_DCICIC_EI_MASK(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EI_MASK_SHIFT)) & DCIC_DCICIC_EI_MASK_MASK)
#define DCIC_DCICIC_FI_MASK_MASK   (0x2U)
#define DCIC_DCICIC_FI_MASK_SHIFT   (1U)
#define DCIC_DCICIC_FI_MASK(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FI_MASK_SHIFT)) & DCIC_DCICIC_FI_MASK_MASK)
#define DCIC_DCICIC_FREEZE_MASK_MASK   (0x8U)
#define DCIC_DCICIC_FREEZE_MASK_SHIFT   (3U)
#define DCIC_DCICIC_FREEZE_MASK(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FREEZE_MASK_SHIFT)) & DCIC_DCICIC_FREEZE_MASK_MASK)
#define DCIC_DCICIC_EXT_SIG_EN_MASK   (0x10000U)
#define DCIC_DCICIC_EXT_SIG_EN_SHIFT   (16U)
#define DCIC_DCICIC_EXT_SIG_EN(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EXT_SIG_EN_SHIFT)) & DCIC_DCICIC_EXT_SIG_EN_MASK)
DCICS - DCIC Status Register
#define DCIC_DCICS_ROI_MATCH_STAT_MASK   (0xFFFFU)
#define DCIC_DCICS_ROI_MATCH_STAT_SHIFT   (0U)
#define DCIC_DCICS_ROI_MATCH_STAT(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_ROI_MATCH_STAT_SHIFT)) & DCIC_DCICS_ROI_MATCH_STAT_MASK)
#define DCIC_DCICS_EI_STAT_MASK   (0x10000U)
#define DCIC_DCICS_EI_STAT_SHIFT   (16U)
#define DCIC_DCICS_EI_STAT(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_EI_STAT_SHIFT)) & DCIC_DCICS_EI_STAT_MASK)
#define DCIC_DCICS_FI_STAT_MASK   (0x20000U)
#define DCIC_DCICS_FI_STAT_SHIFT   (17U)
#define DCIC_DCICS_FI_STAT(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_FI_STAT_SHIFT)) & DCIC_DCICS_FI_STAT_MASK)
DCICRC - DCIC ROI Config Register
#define DCIC_DCICRC_START_OFFSET_X_MASK   (0x1FFFU)
#define DCIC_DCICRC_START_OFFSET_X_SHIFT   (0U)
#define DCIC_DCICRC_START_OFFSET_X(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_START_OFFSET_X_SHIFT)) & DCIC_DCICRC_START_OFFSET_X_MASK)
#define DCIC_DCICRC_START_OFFSET_Y_MASK   (0xFFF0000U)
#define DCIC_DCICRC_START_OFFSET_Y_SHIFT   (16U)
#define DCIC_DCICRC_START_OFFSET_Y(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_START_OFFSET_Y_SHIFT)) & DCIC_DCICRC_START_OFFSET_Y_MASK)
#define DCIC_DCICRC_ROI_FREEZE_MASK   (0x40000000U)
#define DCIC_DCICRC_ROI_FREEZE_SHIFT   (30U)
#define DCIC_DCICRC_ROI_FREEZE(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_FREEZE_SHIFT)) & DCIC_DCICRC_ROI_FREEZE_MASK)
#define DCIC_DCICRC_ROI_EN_MASK   (0x80000000U)
#define DCIC_DCICRC_ROI_EN_SHIFT   (31U)
#define DCIC_DCICRC_ROI_EN(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_EN_SHIFT)) & DCIC_DCICRC_ROI_EN_MASK)
DCICRS - DCIC ROI Size Register
#define DCIC_DCICRS_END_OFFSET_X_MASK   (0x1FFFU)
#define DCIC_DCICRS_END_OFFSET_X_SHIFT   (0U)
#define DCIC_DCICRS_END_OFFSET_X(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRS_END_OFFSET_X_SHIFT)) & DCIC_DCICRS_END_OFFSET_X_MASK)
#define DCIC_DCICRS_END_OFFSET_Y_MASK   (0xFFF0000U)
#define DCIC_DCICRS_END_OFFSET_Y_SHIFT   (16U)
#define DCIC_DCICRS_END_OFFSET_Y(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRS_END_OFFSET_Y_SHIFT)) & DCIC_DCICRS_END_OFFSET_Y_MASK)
DCICRRS - DCIC ROI Reference Signature Register
#define DCIC_DCICRRS_REFERENCE_SIGNATURE_MASK   (0xFFFFFFFFU)
#define DCIC_DCICRRS_REFERENCE_SIGNATURE_SHIFT   (0U)
#define DCIC_DCICRRS_REFERENCE_SIGNATURE(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRRS_REFERENCE_SIGNATURE_SHIFT)) & DCIC_DCICRRS_REFERENCE_SIGNATURE_MASK)
DCICRCS - DCIC ROI Calculated Signature Register
#define DCIC_DCICRCS_CALCULATED_SIGNATURE_MASK   (0xFFFFFFFFU)
#define DCIC_DCICRCS_CALCULATED_SIGNATURE_SHIFT   (0U)
#define DCIC_DCICRCS_CALCULATED_SIGNATURE(x)   (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRCS_CALCULATED_SIGNATURE_SHIFT)) & DCIC_DCICRCS_CALCULATED_SIGNATURE_MASK)
◆ DCIC_DCICC_CLK_POL [1/2]
#define DCIC_DCICC_CLK_POL (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_CLK_POL_SHIFT)) & DCIC_DCICC_CLK_POL_MASK)
CLK_POL 0b0..Not inverted (default). 0b1..Inverted.
◆ DCIC_DCICC_CLK_POL [2/2]
◆ DCIC_DCICC_DE_POL [1/2]
#define DCIC_DCICC_DE_POL (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_DE_POL_SHIFT)) & DCIC_DCICC_DE_POL_MASK)
DE_POL 0b0..Active High. 0b1..Active Low.
◆ DCIC_DCICC_DE_POL [2/2]
◆ DCIC_DCICC_HSYNC_POL [1/2]
#define DCIC_DCICC_HSYNC_POL (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_HSYNC_POL_SHIFT)) & DCIC_DCICC_HSYNC_POL_MASK)
HSYNC_POL 0b0..Active High. 0b1..Active Low.
◆ DCIC_DCICC_HSYNC_POL [2/2]
◆ DCIC_DCICC_IC_EN [1/2]
#define DCIC_DCICC_IC_EN (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_IC_EN_SHIFT)) & DCIC_DCICC_IC_EN_MASK)
IC_EN 0b0..Disabled 0b1..Enabled
◆ DCIC_DCICC_IC_EN [2/2]
◆ DCIC_DCICC_VSYNC_POL [1/2]
#define DCIC_DCICC_VSYNC_POL (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICC_VSYNC_POL_SHIFT)) & DCIC_DCICC_VSYNC_POL_MASK)
VSYNC_POL 0b0..Active High. 0b1..Active Low.
◆ DCIC_DCICC_VSYNC_POL [2/2]
◆ DCIC_DCICIC_EI_MASK [1/2]
#define DCIC_DCICIC_EI_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EI_MASK_SHIFT)) & DCIC_DCICIC_EI_MASK_MASK)
EI_MASK 0b0..Mask disabled - Interrupt assertion enabled 0b1..Mask enabled - Interrupt assertion disabled
◆ DCIC_DCICIC_EI_MASK [2/2]
◆ DCIC_DCICIC_EXT_SIG_EN [1/2]
#define DCIC_DCICIC_EXT_SIG_EN (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_EXT_SIG_EN_SHIFT)) & DCIC_DCICIC_EXT_SIG_EN_MASK)
EXT_SIG_EN 0b0..Disabled 0b1..Enabled
◆ DCIC_DCICIC_EXT_SIG_EN [2/2]
◆ DCIC_DCICIC_FI_MASK [1/2]
#define DCIC_DCICIC_FI_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FI_MASK_SHIFT)) & DCIC_DCICIC_FI_MASK_MASK)
FI_MASK 0b0..Mask disabled - Interrupt assertion enabled 0b1..Mask enabled - Interrupt assertion disabled
◆ DCIC_DCICIC_FI_MASK [2/2]
◆ DCIC_DCICIC_FREEZE_MASK [1/2]
#define DCIC_DCICIC_FREEZE_MASK (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICIC_FREEZE_MASK_SHIFT)) & DCIC_DCICIC_FREEZE_MASK_MASK)
FREEZE_MASK 0b0..Masks change allowed 0b1..Masks are frozen
◆ DCIC_DCICIC_FREEZE_MASK [2/2]
◆ DCIC_DCICRC_ROI_EN [1/2]
#define DCIC_DCICRC_ROI_EN (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_EN_SHIFT)) & DCIC_DCICRC_ROI_EN_MASK)
ROI_EN 0b0..Disabled 0b1..Enabled
◆ DCIC_DCICRC_ROI_EN [2/2]
◆ DCIC_DCICRC_ROI_FREEZE [1/2]
#define DCIC_DCICRC_ROI_FREEZE (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICRC_ROI_FREEZE_SHIFT)) & DCIC_DCICRC_ROI_FREEZE_MASK)
ROI_FREEZE 0b0..ROI configuration can be changed 0b1..ROI configuration is frozen
◆ DCIC_DCICRC_ROI_FREEZE [2/2]
◆ DCIC_DCICS_EI_STAT [1/2]
#define DCIC_DCICS_EI_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_EI_STAT_SHIFT)) & DCIC_DCICS_EI_STAT_MASK)
EI_STAT 0b0..No pending Interrupt 0b1..Pending Interrupt
◆ DCIC_DCICS_EI_STAT [2/2]
◆ DCIC_DCICS_FI_STAT [1/2]
#define DCIC_DCICS_FI_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_FI_STAT_SHIFT)) & DCIC_DCICS_FI_STAT_MASK)
FI_STAT 0b0..No pending Interrupt 0b1..Pending Interrupt
◆ DCIC_DCICS_FI_STAT [2/2]
◆ DCIC_DCICS_ROI_MATCH_STAT [1/2]
#define DCIC_DCICS_ROI_MATCH_STAT (   x)    (((uint32_t)(((uint32_t)(x)) << DCIC_DCICS_ROI_MATCH_STAT_SHIFT)) & DCIC_DCICS_ROI_MATCH_STAT_MASK)
ROI_MATCH_STAT 0b0000000000000000..ROI calculated CRC matches expected signature 0b0000000000000001..Mismatch at ROI calculated CRC
◆ DCIC_DCICS_ROI_MATCH_STAT [2/2]
