RTEMS 6.1-rc1
Modules | Data Structures | Macros
 CSI Register Masks
struct  CSI_Type
#define CSI_BASE   (0x402BC000u)
#define CSI   ((CSI_Type *)CSI_BASE)
#define CSI_BASE_ADDRS   { CSI_BASE }
#define CSI_BASE_PTRS   { CSI }
#define CSI_IRQS   { CSI_IRQn }
#define CSI_BASE   (0x40800000u)
#define CSI_CSICR1_PIXEL_BIT_MASK   CSI_CR1_PIXEL_BIT_MASK
#define CSI_CSICR1_PIXEL_BIT_SHIFT   CSI_CR1_PIXEL_BIT_SHIFT
#define CSI_CSICR1_PIXEL_BIT(x)   CSI_CR1_PIXEL_BIT(x)
#define CSI_CSICR1_REDGE_MASK   CSI_CR1_REDGE_MASK
#define CSI_CSICR1_REDGE_SHIFT   CSI_CR1_REDGE_SHIFT
#define CSI_CSICR1_REDGE(x)   CSI_CR1_REDGE(x)
#define CSI_CSICR1_INV_PCLK_MASK   CSI_CR1_INV_PCLK_MASK
#define CSI_CSICR1_INV_PCLK_SHIFT   CSI_CR1_INV_PCLK_SHIFT
#define CSI_CSICR1_INV_PCLK(x)   CSI_CR1_INV_PCLK(x)
#define CSI_CSICR1_INV_DATA_MASK   CSI_CR1_INV_DATA_MASK
#define CSI_CSICR1_INV_DATA_SHIFT   CSI_CR1_INV_DATA_SHIFT
#define CSI_CSICR1_INV_DATA(x)   CSI_CR1_INV_DATA(x)
#define CSI_CSICR1_GCLK_MODE_MASK   CSI_CR1_GCLK_MODE_MASK
#define CSI_CSICR1_GCLK_MODE_SHIFT   CSI_CR1_GCLK_MODE_SHIFT
#define CSI_CSICR1_GCLK_MODE(x)   CSI_CR1_GCLK_MODE(x)
#define CSI_CSICR1_CLR_RXFIFO_MASK   CSI_CR1_CLR_RXFIFO_MASK
#define CSI_CSICR1_CLR_RXFIFO_SHIFT   CSI_CR1_CLR_RXFIFO_SHIFT
#define CSI_CSICR1_CLR_RXFIFO(x)   CSI_CR1_CLR_RXFIFO(x)
#define CSI_CSICR1_CLR_STATFIFO_MASK   CSI_CR1_CLR_STATFIFO_MASK
#define CSI_CSICR1_CLR_STATFIFO_SHIFT   CSI_CR1_CLR_STATFIFO_SHIFT
#define CSI_CSICR1_CLR_STATFIFO(x)   CSI_CR1_CLR_STATFIFO(x)
#define CSI_CSICR1_PACK_DIR_MASK   CSI_CR1_PACK_DIR_MASK
#define CSI_CSICR1_PACK_DIR_SHIFT   CSI_CR1_PACK_DIR_SHIFT
#define CSI_CSICR1_PACK_DIR(x)   CSI_CR1_PACK_DIR(x)
#define CSI_CSICR1_FCC_MASK   CSI_CR1_FCC_MASK
#define CSI_CSICR1_FCC_SHIFT   CSI_CR1_FCC_SHIFT
#define CSI_CSICR1_FCC(x)   CSI_CR1_FCC(x)
#define CSI_CSICR1_CCIR_EN_MASK   CSI_CR1_CCIR_EN_MASK
#define CSI_CSICR1_CCIR_EN_SHIFT   CSI_CR1_CCIR_EN_SHIFT
#define CSI_CSICR1_CCIR_EN(x)   CSI_CR1_CCIR_EN(x)
#define CSI_CSICR1_HSYNC_POL_MASK   CSI_CR1_HSYNC_POL_MASK
#define CSI_CSICR1_HSYNC_POL_SHIFT   CSI_CR1_HSYNC_POL_SHIFT
#define CSI_CSICR1_HSYNC_POL(x)   CSI_CR1_HSYNC_POL(x)
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE_MASK   CSI_CR1_HISTOGRAM_CALC_DONE_IE_MASK
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE_SHIFT   CSI_CR1_HISTOGRAM_CALC_DONE_IE_SHIFT
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE(x)   CSI_CR1_HISTOGRAM_CALC_DONE_IE(x)
#define CSI_CSICR1_SOF_INTEN_MASK   CSI_CR1_SOF_INTEN_MASK
#define CSI_CSICR1_SOF_INTEN_SHIFT   CSI_CR1_SOF_INTEN_SHIFT
#define CSI_CSICR1_SOF_INTEN(x)   CSI_CR1_SOF_INTEN(x)
#define CSI_CSICR1_SOF_POL_MASK   CSI_CR1_SOF_POL_MASK
#define CSI_CSICR1_SOF_POL_SHIFT   CSI_CR1_SOF_POL_SHIFT
#define CSI_CSICR1_SOF_POL(x)   CSI_CR1_SOF_POL(x)
#define CSI_CSICR1_RXFF_INTEN_MASK   CSI_CR1_RXFF_INTEN_MASK
#define CSI_CSICR1_RXFF_INTEN_SHIFT   CSI_CR1_RXFF_INTEN_SHIFT
#define CSI_CSICR1_RXFF_INTEN(x)   CSI_CR1_RXFF_INTEN(x)
#define CSI_CSICR1_FB1_DMA_DONE_INTEN_MASK   CSI_CR1_FB1_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_FB1_DMA_DONE_INTEN_SHIFT   CSI_CR1_FB1_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_FB1_DMA_DONE_INTEN(x)   CSI_CR1_FB1_DMA_DONE_INTEN(x)
#define CSI_CSICR1_FB2_DMA_DONE_INTEN_MASK   CSI_CR1_FB2_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_FB2_DMA_DONE_INTEN_SHIFT   CSI_CR1_FB2_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_FB2_DMA_DONE_INTEN(x)   CSI_CR1_FB2_DMA_DONE_INTEN(x)
#define CSI_CSICR1_STATFF_INTEN_MASK   CSI_CR1_STATFF_INTEN_MASK
#define CSI_CSICR1_STATFF_INTEN_SHIFT   CSI_CR1_STATFF_INTEN_SHIFT
#define CSI_CSICR1_STATFF_INTEN(x)   CSI_CR1_STATFF_INTEN(x)
#define CSI_CSICR1_SFF_DMA_DONE_INTEN_MASK   CSI_CR1_SFF_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_SFF_DMA_DONE_INTEN_SHIFT   CSI_CR1_SFF_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_SFF_DMA_DONE_INTEN(x)   CSI_CR1_SFF_DMA_DONE_INTEN(x)
#define CSI_CSICR1_RF_OR_INTEN_MASK   CSI_CR1_RF_OR_INTEN_MASK
#define CSI_CSICR1_RF_OR_INTEN_SHIFT   CSI_CR1_RF_OR_INTEN_SHIFT
#define CSI_CSICR1_RF_OR_INTEN(x)   CSI_CR1_RF_OR_INTEN(x)
#define CSI_CSICR1_SF_OR_INTEN_MASK   CSI_CR1_SF_OR_INTEN_MASK
#define CSI_CSICR1_SF_OR_INTEN_SHIFT   CSI_CR1_SF_OR_INTEN_SHIFT
#define CSI_CSICR1_SF_OR_INTEN(x)   CSI_CR1_SF_OR_INTEN(x)
#define CSI_CSICR1_COF_INT_EN_MASK   CSI_CR1_COF_INT_EN_MASK
#define CSI_CSICR1_COF_INT_EN_SHIFT   CSI_CR1_COF_INT_EN_SHIFT
#define CSI_CSICR1_COF_INT_EN(x)   CSI_CR1_COF_INT_EN(x)
#define CSI_CSICR1_VIDEO_MODE_MASK   CSI_CR1_VIDEO_MODE_MASK
#define CSI_CSICR1_VIDEO_MODE_SHIFT   CSI_CR1_VIDEO_MODE_SHIFT
#define CSI_CSICR1_VIDEO_MODE(x)   CSI_CR1_VIDEO_MODE(x)
#define CSI_CSICR1_EOF_INT_EN_MASK   CSI_CR1_EOF_INT_EN_MASK
#define CSI_CSICR1_EOF_INT_EN_SHIFT   CSI_CR1_EOF_INT_EN_SHIFT
#define CSI_CSICR1_EOF_INT_EN(x)   CSI_CR1_EOF_INT_EN(x)
#define CSI_CSICR1_EXT_VSYNC_MASK   CSI_CR1_EXT_VSYNC_MASK
#define CSI_CSICR1_EXT_VSYNC_SHIFT   CSI_CR1_EXT_VSYNC_SHIFT
#define CSI_CSICR1_EXT_VSYNC(x)   CSI_CR1_EXT_VSYNC(x)
#define CSI_CSICR1_SWAP16_EN_MASK   CSI_CR1_SWAP16_EN_MASK
#define CSI_CSICR1_SWAP16_EN_SHIFT   CSI_CR1_SWAP16_EN_SHIFT
#define CSI_CSICR1_SWAP16_EN(x)   CSI_CR1_SWAP16_EN(x)
#define CSI_CSICR2_HSC_MASK   CSI_CR2_HSC_MASK
#define CSI_CSICR2_HSC_SHIFT   CSI_CR2_HSC_SHIFT
#define CSI_CSICR2_HSC(x)   CSI_CR2_HSC(x)
#define CSI_CSICR2_VSC_MASK   CSI_CR2_VSC_MASK
#define CSI_CSICR2_VSC_SHIFT   CSI_CR2_VSC_SHIFT
#define CSI_CSICR2_VSC(x)   CSI_CR2_VSC(x)
#define CSI_CSICR2_LVRM_MASK   CSI_CR2_LVRM_MASK
#define CSI_CSICR2_LVRM_SHIFT   CSI_CR2_LVRM_SHIFT
#define CSI_CSICR2_LVRM(x)   CSI_CR2_LVRM(x)
#define CSI_CSICR2_BTS_MASK   CSI_CR2_BTS_MASK
#define CSI_CSICR2_BTS_SHIFT   CSI_CR2_BTS_SHIFT
#define CSI_CSICR2_BTS(x)   CSI_CR2_BTS(x)
#define CSI_CSICR2_SCE_MASK   CSI_CR2_SCE_MASK
#define CSI_CSICR2_SCE_SHIFT   CSI_CR2_SCE_SHIFT
#define CSI_CSICR2_SCE(x)   CSI_CR2_SCE(x)
#define CSI_CSICR2_AFS_MASK   CSI_CR2_AFS_MASK
#define CSI_CSICR2_AFS_SHIFT   CSI_CR2_AFS_SHIFT
#define CSI_CSICR2_AFS(x)   CSI_CR2_AFS(x)
#define CSI_CSICR2_DRM_MASK   CSI_CR2_DRM_MASK
#define CSI_CSICR2_DRM_SHIFT   CSI_CR2_DRM_SHIFT
#define CSI_CSICR2_DRM(x)   CSI_CR2_DRM(x)
#define CSI_CSICR2_DMA_BURST_TYPE_SFF_MASK   CSI_CR2_DMA_BURST_TYPE_SFF_MASK
#define CSI_CSICR2_DMA_BURST_TYPE_SFF_SHIFT   CSI_CR2_DMA_BURST_TYPE_SFF_SHIFT
#define CSI_CSICR2_DMA_BURST_TYPE_SFF(x)   CSI_CR2_DMA_BURST_TYPE_SFF(x)
#define CSI_CSICR2_DMA_BURST_TYPE_RFF_MASK   CSI_CR2_DMA_BURST_TYPE_RFF_MASK
#define CSI_CSICR2_DMA_BURST_TYPE_RFF_SHIFT   CSI_CR2_DMA_BURST_TYPE_RFF_SHIFT
#define CSI_CSICR2_DMA_BURST_TYPE_RFF(x)   CSI_CR2_DMA_BURST_TYPE_RFF(x)
#define CSI_CSICR3_ECC_AUTO_EN_MASK   CSI_CR3_ECC_AUTO_EN_MASK
#define CSI_CSICR3_ECC_AUTO_EN_SHIFT   CSI_CR3_ECC_AUTO_EN_SHIFT
#define CSI_CSICR3_ECC_AUTO_EN(x)   CSI_CR3_ECC_AUTO_EN(x)
#define CSI_CSICR3_ECC_INT_EN_MASK   CSI_CR3_ECC_INT_EN_MASK
#define CSI_CSICR3_ECC_INT_EN_SHIFT   CSI_CR3_ECC_INT_EN_SHIFT
#define CSI_CSICR3_ECC_INT_EN(x)   CSI_CR3_ECC_INT_EN(x)
#define CSI_CSICR3_ZERO_PACK_EN_MASK   CSI_CR3_ZERO_PACK_EN_MASK
#define CSI_CSICR3_ZERO_PACK_EN_SHIFT   CSI_CR3_ZERO_PACK_EN_SHIFT
#define CSI_CSICR3_ZERO_PACK_EN(x)   CSI_CR3_ZERO_PACK_EN(x)
#define CSI_CSICR3_SENSOR_16BITS_MASK   CSI_CR3_SENSOR_16BITS_MASK
#define CSI_CSICR3_SENSOR_16BITS_SHIFT   CSI_CR3_SENSOR_16BITS_SHIFT
#define CSI_CSICR3_SENSOR_16BITS(x)   CSI_CR3_SENSOR_16BITS(x)
#define CSI_CSICR3_RxFF_LEVEL_MASK   CSI_CR3_RxFF_LEVEL_MASK
#define CSI_CSICR3_RxFF_LEVEL_SHIFT   CSI_CR3_RxFF_LEVEL_SHIFT
#define CSI_CSICR3_RxFF_LEVEL(x)   CSI_CR3_RxFF_LEVEL(x)
#define CSI_CSICR3_HRESP_ERR_EN_MASK   CSI_CR3_HRESP_ERR_EN_MASK
#define CSI_CSICR3_HRESP_ERR_EN_SHIFT   CSI_CR3_HRESP_ERR_EN_SHIFT
#define CSI_CSICR3_HRESP_ERR_EN(x)   CSI_CR3_HRESP_ERR_EN(x)
#define CSI_CSICR3_STATFF_LEVEL_MASK   CSI_CR3_STATFF_LEVEL_MASK
#define CSI_CSICR3_STATFF_LEVEL_SHIFT   CSI_CR3_STATFF_LEVEL_SHIFT
#define CSI_CSICR3_STATFF_LEVEL(x)   CSI_CR3_STATFF_LEVEL(x)
#define CSI_CSICR3_DMA_REQ_EN_SFF_MASK   CSI_CR3_DMA_REQ_EN_SFF_MASK
#define CSI_CSICR3_DMA_REQ_EN_SFF_SHIFT   CSI_CR3_DMA_REQ_EN_SFF_SHIFT
#define CSI_CSICR3_DMA_REQ_EN_SFF(x)   CSI_CR3_DMA_REQ_EN_SFF(x)
#define CSI_CSICR3_DMA_REQ_EN_RFF_MASK   CSI_CR3_DMA_REQ_EN_RFF_MASK
#define CSI_CSICR3_DMA_REQ_EN_RFF_SHIFT   CSI_CR3_DMA_REQ_EN_RFF_SHIFT
#define CSI_CSICR3_DMA_REQ_EN_RFF(x)   CSI_CR3_DMA_REQ_EN_RFF(x)
#define CSI_CSICR3_DMA_REFLASH_SFF_MASK   CSI_CR3_DMA_REFLASH_SFF_MASK
#define CSI_CSICR3_DMA_REFLASH_SFF_SHIFT   CSI_CR3_DMA_REFLASH_SFF_SHIFT
#define CSI_CSICR3_DMA_REFLASH_SFF(x)   CSI_CR3_DMA_REFLASH_SFF(x)
#define CSI_CSICR3_DMA_REFLASH_RFF_MASK   CSI_CR3_DMA_REFLASH_RFF_MASK
#define CSI_CSICR3_DMA_REFLASH_RFF_SHIFT   CSI_CR3_DMA_REFLASH_RFF_SHIFT
#define CSI_CSICR3_DMA_REFLASH_RFF(x)   CSI_CR3_DMA_REFLASH_RFF(x)
#define CSI_CSICR3_FRMCNT_RST_MASK   CSI_CR3_FRMCNT_RST_MASK
#define CSI_CSICR3_FRMCNT_RST_SHIFT   CSI_CR3_FRMCNT_RST_SHIFT
#define CSI_CSICR3_FRMCNT_RST(x)   CSI_CR3_FRMCNT_RST(x)
#define CSI_CSICR3_FRMCNT_MASK   CSI_CR3_FRMCNT_MASK
#define CSI_CSICR3_FRMCNT_SHIFT   CSI_CR3_FRMCNT_SHIFT
#define CSI_CSICR3_FRMCNT(x)   CSI_CR3_FRMCNT(x)
#define CSI_CSISTATFIFO_STAT_MASK   CSI_STATFIFO_STAT_MASK
#define CSI_CSISTATFIFO_STAT_SHIFT   CSI_STATFIFO_STAT_SHIFT
#define CSI_CSISTATFIFO_STAT(x)   CSI_STATFIFO_STAT(x)
#define CSI_CSIRFIFO_IMAGE_MASK   CSI_RFIFO_IMAGE_MASK
#define CSI_CSIRFIFO_IMAGE_SHIFT   CSI_RFIFO_IMAGE_SHIFT
#define CSI_CSIRFIFO_IMAGE(x)   CSI_RFIFO_IMAGE(x)
#define CSI_CSIRXCNT_RXCNT_MASK   CSI_RXCNT_RXCNT_MASK
#define CSI_CSIRXCNT_RXCNT_SHIFT   CSI_RXCNT_RXCNT_SHIFT
#define CSI_CSIRXCNT_RXCNT(x)   CSI_RXCNT_RXCNT(x)
#define CSI_CSISR_DRDY_MASK   CSI_SR_DRDY_MASK
#define CSI_CSISR_DRDY_SHIFT   CSI_SR_DRDY_SHIFT
#define CSI_CSISR_DRDY(x)   CSI_SR_DRDY(x)
#define CSI_CSISR_ECC_INT_MASK   CSI_SR_ECC_INT_MASK
#define CSI_CSISR_ECC_INT_SHIFT   CSI_SR_ECC_INT_SHIFT
#define CSI_CSISR_ECC_INT(x)   CSI_SR_ECC_INT(x)
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT_MASK   CSI_SR_HISTOGRAM_CALC_DONE_INT_MASK
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT_SHIFT   CSI_SR_HISTOGRAM_CALC_DONE_INT_SHIFT
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT(x)   CSI_SR_HISTOGRAM_CALC_DONE_INT(x)
#define CSI_CSISR_HRESP_ERR_INT_MASK   CSI_SR_HRESP_ERR_INT_MASK
#define CSI_CSISR_HRESP_ERR_INT_SHIFT   CSI_SR_HRESP_ERR_INT_SHIFT
#define CSI_CSISR_HRESP_ERR_INT(x)   CSI_SR_HRESP_ERR_INT(x)
#define CSI_CSISR_COF_INT_MASK   CSI_SR_COF_INT_MASK
#define CSI_CSISR_COF_INT_SHIFT   CSI_SR_COF_INT_SHIFT
#define CSI_CSISR_COF_INT(x)   CSI_SR_COF_INT(x)
#define CSI_CSISR_F1_INT_MASK   CSI_SR_F1_INT_MASK
#define CSI_CSISR_F1_INT_SHIFT   CSI_SR_F1_INT_SHIFT
#define CSI_CSISR_F1_INT(x)   CSI_SR_F1_INT(x)
#define CSI_CSISR_F2_INT_MASK   CSI_SR_F2_INT_MASK
#define CSI_CSISR_F2_INT_SHIFT   CSI_SR_F2_INT_SHIFT
#define CSI_CSISR_F2_INT(x)   CSI_SR_F2_INT(x)
#define CSI_CSISR_SOF_INT_MASK   CSI_SR_SOF_INT_MASK
#define CSI_CSISR_SOF_INT_SHIFT   CSI_SR_SOF_INT_SHIFT
#define CSI_CSISR_SOF_INT(x)   CSI_SR_SOF_INT(x)
#define CSI_CSISR_EOF_INT_MASK   CSI_SR_EOF_INT_MASK
#define CSI_CSISR_EOF_INT_SHIFT   CSI_SR_EOF_INT_SHIFT
#define CSI_CSISR_EOF_INT(x)   CSI_SR_EOF_INT(x)
#define CSI_CSISR_RxFF_INT_MASK   CSI_SR_RxFF_INT_MASK
#define CSI_CSISR_RxFF_INT_SHIFT   CSI_SR_RxFF_INT_SHIFT
#define CSI_CSISR_RxFF_INT(x)   CSI_SR_RxFF_INT(x)
#define CSI_CSISR_DMA_TSF_DONE_FB1_MASK   CSI_SR_DMA_TSF_DONE_FB1_MASK
#define CSI_CSISR_DMA_TSF_DONE_FB1_SHIFT   CSI_SR_DMA_TSF_DONE_FB1_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_FB1(x)   CSI_SR_DMA_TSF_DONE_FB1(x)
#define CSI_CSISR_DMA_TSF_DONE_FB2_MASK   CSI_SR_DMA_TSF_DONE_FB2_MASK
#define CSI_CSISR_DMA_TSF_DONE_FB2_SHIFT   CSI_SR_DMA_TSF_DONE_FB2_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_FB2(x)   CSI_SR_DMA_TSF_DONE_FB2(x)
#define CSI_CSISR_STATFF_INT_MASK   CSI_SR_STATFF_INT_MASK
#define CSI_CSISR_STATFF_INT_SHIFT   CSI_SR_STATFF_INT_SHIFT
#define CSI_CSISR_STATFF_INT(x)   CSI_SR_STATFF_INT(x)
#define CSI_CSISR_DMA_TSF_DONE_SFF_MASK   CSI_SR_DMA_TSF_DONE_SFF_MASK
#define CSI_CSISR_DMA_TSF_DONE_SFF_SHIFT   CSI_SR_DMA_TSF_DONE_SFF_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_SFF(x)   CSI_SR_DMA_TSF_DONE_SFF(x)
#define CSI_CSISR_RF_OR_INT_MASK   CSI_SR_RF_OR_INT_MASK
#define CSI_CSISR_RF_OR_INT_SHIFT   CSI_SR_RF_OR_INT_SHIFT
#define CSI_CSISR_RF_OR_INT(x)   CSI_SR_RF_OR_INT(x)
#define CSI_CSISR_SF_OR_INT_MASK   CSI_SR_SF_OR_INT_MASK
#define CSI_CSISR_SF_OR_INT_SHIFT   CSI_SR_SF_OR_INT_SHIFT
#define CSI_CSISR_SF_OR_INT(x)   CSI_SR_SF_OR_INT(x)
#define CSI_CSISR_DMA_FIELD1_DONE_MASK   CSI_SR_DMA_FIELD1_DONE_MASK
#define CSI_CSISR_DMA_FIELD1_DONE_SHIFT   CSI_SR_DMA_FIELD1_DONE_SHIFT
#define CSI_CSISR_DMA_FIELD1_DONE(x)   CSI_SR_DMA_FIELD1_DONE(x)
#define CSI_CSISR_DMA_FIELD0_DONE_MASK   CSI_SR_DMA_FIELD0_DONE_MASK
#define CSI_CSISR_DMA_FIELD0_DONE_SHIFT   CSI_SR_DMA_FIELD0_DONE_SHIFT
#define CSI_CSISR_DMA_FIELD0_DONE(x)   CSI_SR_DMA_FIELD0_DONE(x)
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR_MASK   CSI_SR_BASEADDR_CHHANGE_ERROR_MASK
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR_SHIFT   CSI_SR_BASEADDR_CHHANGE_ERROR_SHIFT
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR(x)   CSI_SR_BASEADDR_CHHANGE_ERROR(x)
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF_MASK   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF_MASK
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF_SHIFT   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF_SHIFT
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF(x)   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF(x)
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF_MASK   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF_MASK
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF_SHIFT   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF_SHIFT
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF(x)   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF(x)
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1_MASK   CSI_DMASA_FB1_DMA_START_ADDR_FB1_MASK
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1_SHIFT   CSI_DMASA_FB1_DMA_START_ADDR_FB1_SHIFT
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1(x)   CSI_DMASA_FB1_DMA_START_ADDR_FB1(x)
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2_MASK   CSI_DMASA_FB2_DMA_START_ADDR_FB2_MASK
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2_SHIFT   CSI_DMASA_FB2_DMA_START_ADDR_FB2_SHIFT
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2(x)   CSI_DMASA_FB2_DMA_START_ADDR_FB2(x)
#define CSI_CSIFBUF_PARA_FBUF_STRIDE_MASK   CSI_FBUF_PARA_FBUF_STRIDE_MASK
#define CSI_CSIFBUF_PARA_FBUF_STRIDE_SHIFT   CSI_FBUF_PARA_FBUF_STRIDE_SHIFT
#define CSI_CSIFBUF_PARA_FBUF_STRIDE(x)   CSI_FBUF_PARA_FBUF_STRIDE(x)
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE_MASK   CSI_FBUF_PARA_DEINTERLACE_STRIDE_MASK
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE_SHIFT   CSI_FBUF_PARA_DEINTERLACE_STRIDE_SHIFT
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE(x)   CSI_FBUF_PARA_DEINTERLACE_STRIDE(x)
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT_MASK   CSI_IMAG_PARA_IMAGE_HEIGHT_MASK
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT_SHIFT   CSI_IMAG_PARA_IMAGE_HEIGHT_SHIFT
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT(x)   CSI_IMAG_PARA_IMAGE_HEIGHT(x)
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH_MASK   CSI_IMAG_PARA_IMAGE_WIDTH_MASK
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH_SHIFT   CSI_IMAG_PARA_IMAGE_WIDTH_SHIFT
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH(x)   CSI_IMAG_PARA_IMAGE_WIDTH(x)
#define CSI_CSICR18_NTSC_EN_MASK   CSI_CR18_NTSC_EN_MASK
#define CSI_CSICR18_NTSC_EN_SHIFT   CSI_CR18_NTSC_EN_SHIFT
#define CSI_CSICR18_NTSC_EN(x)   CSI_CR18_NTSC_EN(x)
#define CSI_CSICR18_TVDECODER_IN_EN_MASK   CSI_CR18_TVDECODER_IN_EN_MASK
#define CSI_CSICR18_TVDECODER_IN_EN_SHIFT   CSI_CR18_TVDECODER_IN_EN_SHIFT
#define CSI_CSICR18_TVDECODER_IN_EN(x)   CSI_CR18_TVDECODER_IN_EN(x)
#define CSI_CSICR18_DEINTERLACE_EN_MASK   CSI_CR18_DEINTERLACE_EN_MASK
#define CSI_CSICR18_DEINTERLACE_EN_SHIFT   CSI_CR18_DEINTERLACE_EN_SHIFT
#define CSI_CSICR18_DEINTERLACE_EN(x)   CSI_CR18_DEINTERLACE_EN(x)
#define CSI_CSICR18_PARALLEL24_EN_MASK   CSI_CR18_PARALLEL24_EN_MASK
#define CSI_CSICR18_PARALLEL24_EN_SHIFT   CSI_CR18_PARALLEL24_EN_SHIFT
#define CSI_CSICR18_PARALLEL24_EN(x)   CSI_CR18_PARALLEL24_EN(x)
#define CSI_CSICR18_BASEADDR_SWITCH_EN_MASK   CSI_CR18_BASEADDR_SWITCH_EN_MASK
#define CSI_CSICR18_BASEADDR_SWITCH_EN_SHIFT   CSI_CR18_BASEADDR_SWITCH_EN_SHIFT
#define CSI_CSICR18_BASEADDR_SWITCH_EN(x)   CSI_CR18_BASEADDR_SWITCH_EN(x)
#define CSI_CSICR18_BASEADDR_SWITCH_SEL_MASK   CSI_CR18_BASEADDR_SWITCH_SEL_MASK
#define CSI_CSICR18_BASEADDR_SWITCH_SEL_SHIFT   CSI_CR18_BASEADDR_SWITCH_SEL_SHIFT
#define CSI_CSICR18_BASEADDR_SWITCH_SEL(x)   CSI_CR18_BASEADDR_SWITCH_SEL(x)
#define CSI_CSICR18_FIELD0_DONE_IE_MASK   CSI_CR18_FIELD0_DONE_IE_MASK
#define CSI_CSICR18_FIELD0_DONE_IE_SHIFT   CSI_CR18_FIELD0_DONE_IE_SHIFT
#define CSI_CSICR18_FIELD0_DONE_IE(x)   CSI_CR18_FIELD0_DONE_IE(x)
#define CSI_CSICR18_DMA_FIELD1_DONE_IE_MASK   CSI_CR18_DMA_FIELD1_DONE_IE_MASK
#define CSI_CSICR18_DMA_FIELD1_DONE_IE_SHIFT   CSI_CR18_DMA_FIELD1_DONE_IE_SHIFT
#define CSI_CSICR18_DMA_FIELD1_DONE_IE(x)   CSI_CR18_DMA_FIELD1_DONE_IE(x)
#define CSI_CSICR18_LAST_DMA_REQ_SEL_MASK   CSI_CR18_LAST_DMA_REQ_SEL_MASK
#define CSI_CSICR18_LAST_DMA_REQ_SEL_SHIFT   CSI_CR18_LAST_DMA_REQ_SEL_SHIFT
#define CSI_CSICR18_LAST_DMA_REQ_SEL(x)   CSI_CR18_LAST_DMA_REQ_SEL(x)
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE_MASK   CSI_CR18_BASEADDR_CHANGE_ERROR_IE_MASK
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE_SHIFT   CSI_CR18_BASEADDR_CHANGE_ERROR_IE_SHIFT
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE(x)   CSI_CR18_BASEADDR_CHANGE_ERROR_IE(x)
#define CSI_CSICR18_RGB888A_FORMAT_SEL_MASK   CSI_CR18_RGB888A_FORMAT_SEL_MASK
#define CSI_CSICR18_RGB888A_FORMAT_SEL_SHIFT   CSI_CR18_RGB888A_FORMAT_SEL_SHIFT
#define CSI_CSICR18_RGB888A_FORMAT_SEL(x)   CSI_CR18_RGB888A_FORMAT_SEL(x)
#define CSI_CSICR18_AHB_HPROT_MASK   CSI_CR18_AHB_HPROT_MASK
#define CSI_CSICR18_AHB_HPROT_SHIFT   CSI_CR18_AHB_HPROT_SHIFT
#define CSI_CSICR18_AHB_HPROT(x)   CSI_CR18_AHB_HPROT(x)
#define CSI_CSICR18_MASK_OPTION_MASK   CSI_CR18_MASK_OPTION_MASK
#define CSI_CSICR18_MASK_OPTION_SHIFT   CSI_CR18_MASK_OPTION_SHIFT
#define CSI_CSICR18_MASK_OPTION(x)   CSI_CR18_MASK_OPTION(x)
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT_MASK   CSI_CR18_MIPI_DOUBLE_CMPNT_MASK
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT_SHIFT   CSI_CR18_MIPI_DOUBLE_CMPNT_SHIFT
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT(x)   CSI_CR18_MIPI_DOUBLE_CMPNT(x)
#define CSI_CSICR18_MIPI_YU_SWAP_MASK   CSI_CR18_MIPI_YU_SWAP_MASK
#define CSI_CSICR18_MIPI_YU_SWAP_SHIFT   CSI_CR18_MIPI_YU_SWAP_SHIFT
#define CSI_CSICR18_MIPI_YU_SWAP(x)   CSI_CR18_MIPI_YU_SWAP(x)
#define CSI_CSICR18_DATA_FROM_MIPI_MASK   CSI_CR18_DATA_FROM_MIPI_MASK
#define CSI_CSICR18_DATA_FROM_MIPI_SHIFT   CSI_CR18_DATA_FROM_MIPI_SHIFT
#define CSI_CSICR18_DATA_FROM_MIPI(x)   CSI_CR18_DATA_FROM_MIPI(x)
#define CSI_CSICR18_LINE_STRIDE_EN_MASK   CSI_CR18_LINE_STRIDE_EN_MASK
#define CSI_CSICR18_LINE_STRIDE_EN_SHIFT   CSI_CR18_LINE_STRIDE_EN_SHIFT
#define CSI_CSICR18_LINE_STRIDE_EN(x)   CSI_CR18_LINE_STRIDE_EN(x)
#define CSI_CSICR18_MIPI_DATA_FORMAT_MASK   CSI_CR18_MIPI_DATA_FORMAT_MASK
#define CSI_CSICR18_MIPI_DATA_FORMAT_SHIFT   CSI_CR18_MIPI_DATA_FORMAT_SHIFT
#define CSI_CSICR18_MIPI_DATA_FORMAT(x)   CSI_CR18_MIPI_DATA_FORMAT(x)
#define CSI_CSICR18_CSI_ENABLE_MASK   CSI_CR18_CSI_ENABLE_MASK
#define CSI_CSICR18_CSI_ENABLE_SHIFT   CSI_CR18_CSI_ENABLE_SHIFT
#define CSI_CSICR18_CSI_ENABLE(x)   CSI_CR18_CSI_ENABLE(x)
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_MASK   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_MASK
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_SHIFT   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_SHIFT
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL(x)   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL(x)
#define CSI_CSICR20_THRESHOLD_MASK   CSI_CR20_THRESHOLD_MASK
#define CSI_CSICR20_THRESHOLD_SHIFT   CSI_CR20_THRESHOLD_SHIFT
#define CSI_CSICR20_THRESHOLD(x)   CSI_CR20_THRESHOLD(x)
#define CSI_CSICR20_BINARY_EN_MASK   CSI_CR20_BINARY_EN_MASK
#define CSI_CSICR20_BINARY_EN_SHIFT   CSI_CR20_BINARY_EN_SHIFT
#define CSI_CSICR20_BINARY_EN(x)   CSI_CR20_BINARY_EN(x)
#define CSI_CSICR20_QR_DATA_FORMAT_MASK   CSI_CR20_QR_DATA_FORMAT_MASK
#define CSI_CSICR20_QR_DATA_FORMAT_SHIFT   CSI_CR20_QR_DATA_FORMAT_SHIFT
#define CSI_CSICR20_QR_DATA_FORMAT(x)   CSI_CR20_QR_DATA_FORMAT(x)
#define CSI_CSICR20_BIG_END_MASK   CSI_CR20_BIG_END_MASK
#define CSI_CSICR20_BIG_END_SHIFT   CSI_CR20_BIG_END_SHIFT
#define CSI_CSICR20_BIG_END(x)   CSI_CR20_BIG_END(x)
#define CSI_CSICR20_10BIT_NEW_EN_MASK   CSI_CR20_10BIT_NEW_EN_MASK
#define CSI_CSICR20_10BIT_NEW_EN_SHIFT   CSI_CR20_10BIT_NEW_EN_SHIFT
#define CSI_CSICR20_10BIT_NEW_EN(x)   CSI_CR20_10BIT_NEW_EN(x)
#define CSI_CSICR20_HISTOGRAM_EN_MASK   CSI_CR20_HISTOGRAM_EN_MASK
#define CSI_CSICR20_HISTOGRAM_EN_SHIFT   CSI_CR20_HISTOGRAM_EN_SHIFT
#define CSI_CSICR20_HISTOGRAM_EN(x)   CSI_CR20_HISTOGRAM_EN(x)
#define CSI_CSICR20_QRCODE_EN_MASK   CSI_CR20_QRCODE_EN_MASK
#define CSI_CSICR20_QRCODE_EN_SHIFT   CSI_CR20_QRCODE_EN_SHIFT
#define CSI_CSICR20_QRCODE_EN(x)   CSI_CR20_QRCODE_EN(x)
#define CSI_CSICR21_PIXEL_COUNTERS_MASK   CSI_CR21_PIXEL_COUNTERS_MASK
#define CSI_CSICR21_PIXEL_COUNTERS_SHIFT   CSI_CR21_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR21_PIXEL_COUNTERS(x)   CSI_CR21_PIXEL_COUNTERS(x)
#define CSI_CSICR22_PIXEL_COUNTERS_MASK   CSI_CR22_PIXEL_COUNTERS_MASK
#define CSI_CSICR22_PIXEL_COUNTERS_SHIFT   CSI_CR22_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR22_PIXEL_COUNTERS(x)   CSI_CR22_PIXEL_COUNTERS(x)
#define CSI_CSICR23_PIXEL_COUNTERS_MASK   CSI_CR23_PIXEL_COUNTERS_MASK
#define CSI_CSICR23_PIXEL_COUNTERS_SHIFT   CSI_CR23_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR23_PIXEL_COUNTERS(x)   CSI_CR23_PIXEL_COUNTERS(x)
#define CSI_CSICR24_PIXEL_COUNTERS_MASK   CSI_CR24_PIXEL_COUNTERS_MASK
#define CSI_CSICR24_PIXEL_COUNTERS_SHIFT   CSI_CR24_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR24_PIXEL_COUNTERS(x)   CSI_CR24_PIXEL_COUNTERS(x)
#define CSI_CSICR25_PIXEL_COUNTERS_MASK   CSI_CR25_PIXEL_COUNTERS_MASK
#define CSI_CSICR25_PIXEL_COUNTERS_SHIFT   CSI_CR25_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR25_PIXEL_COUNTERS(x)   CSI_CR25_PIXEL_COUNTERS(x)
#define CSI_CSICR26_PIXEL_COUNTERS_MASK   CSI_CR26_PIXEL_COUNTERS_MASK
#define CSI_CSICR26_PIXEL_COUNTERS_SHIFT   CSI_CR26_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR26_PIXEL_COUNTERS(x)   CSI_CR26_PIXEL_COUNTERS(x)
#define CSI_CSICR27_PIXEL_COUNTERS_MASK   CSI_CR27_PIXEL_COUNTERS_MASK
#define CSI_CSICR27_PIXEL_COUNTERS_SHIFT   CSI_CR27_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR27_PIXEL_COUNTERS(x)   CSI_CR27_PIXEL_COUNTERS(x)
#define CSI_CSICR28_PIXEL_COUNTERS_MASK   CSI_CR28_PIXEL_COUNTERS_MASK
#define CSI_CSICR28_PIXEL_COUNTERS_SHIFT   CSI_CR28_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR28_PIXEL_COUNTERS(x)   CSI_CR28_PIXEL_COUNTERS(x)
#define CSI_CSICR29_PIXEL_COUNTERS_MASK   CSI_CR29_PIXEL_COUNTERS_MASK
#define CSI_CSICR29_PIXEL_COUNTERS_SHIFT   CSI_CR29_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR29_PIXEL_COUNTERS(x)   CSI_CR29_PIXEL_COUNTERS(x)
#define CSI_CSICR30_PIXEL_COUNTERS_MASK   CSI_CR30_PIXEL_COUNTERS_MASK
#define CSI_CSICR30_PIXEL_COUNTERS_SHIFT   CSI_CR30_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR30_PIXEL_COUNTERS(x)   CSI_CR30_PIXEL_COUNTERS(x)
#define CSI_CSICR31_PIXEL_COUNTERS_MASK   CSI_CR31_PIXEL_COUNTERS_MASK
#define CSI_CSICR31_PIXEL_COUNTERS_SHIFT   CSI_CR31_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR31_PIXEL_COUNTERS(x)   CSI_CR31_PIXEL_COUNTERS(x)
#define CSI_CSICR32_PIXEL_COUNTERS_MASK   CSI_CR32_PIXEL_COUNTERS_MASK
#define CSI_CSICR32_PIXEL_COUNTERS_SHIFT   CSI_CR32_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR32_PIXEL_COUNTERS(x)   CSI_CR32_PIXEL_COUNTERS(x)
#define CSI_CSICR33_PIXEL_COUNTERS_MASK   CSI_CR33_PIXEL_COUNTERS_MASK
#define CSI_CSICR33_PIXEL_COUNTERS_SHIFT   CSI_CR33_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR33_PIXEL_COUNTERS(x)   CSI_CR33_PIXEL_COUNTERS(x)
#define CSI_CSICR34_PIXEL_COUNTERS_MASK   CSI_CR34_PIXEL_COUNTERS_MASK
#define CSI_CSICR34_PIXEL_COUNTERS_SHIFT   CSI_CR34_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR34_PIXEL_COUNTERS(x)   CSI_CR34_PIXEL_COUNTERS(x)
#define CSI_CSICR35_PIXEL_COUNTERS_MASK   CSI_CR35_PIXEL_COUNTERS_MASK
#define CSI_CSICR35_PIXEL_COUNTERS_SHIFT   CSI_CR35_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR35_PIXEL_COUNTERS(x)   CSI_CR35_PIXEL_COUNTERS(x)
#define CSI_CSICR36_PIXEL_COUNTERS_MASK   CSI_CR36_PIXEL_COUNTERS_MASK
#define CSI_CSICR36_PIXEL_COUNTERS_SHIFT   CSI_CR36_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR36_PIXEL_COUNTERS(x)   CSI_CR36_PIXEL_COUNTERS(x)
#define CSI_CSICR37_PIXEL_COUNTERS_MASK   CSI_CR37_PIXEL_COUNTERS_MASK
#define CSI_CSICR37_PIXEL_COUNTERS_SHIFT   CSI_CR37_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR37_PIXEL_COUNTERS(x)   CSI_CR37_PIXEL_COUNTERS(x)
#define CSI_CSICR38_PIXEL_COUNTERS_MASK   CSI_CR38_PIXEL_COUNTERS_MASK
#define CSI_CSICR38_PIXEL_COUNTERS_SHIFT   CSI_CR38_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR38_PIXEL_COUNTERS(x)   CSI_CR38_PIXEL_COUNTERS(x)
#define CSI_CSICR39_PIXEL_COUNTERS_MASK   CSI_CR39_PIXEL_COUNTERS_MASK
#define CSI_CSICR39_PIXEL_COUNTERS_SHIFT   CSI_CR39_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR39_PIXEL_COUNTERS(x)   CSI_CR39_PIXEL_COUNTERS(x)
#define CSI_CSICR40_PIXEL_COUNTERS_MASK   CSI_CR40_PIXEL_COUNTERS_MASK
#define CSI_CSICR40_PIXEL_COUNTERS_SHIFT   CSI_CR40_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR40_PIXEL_COUNTERS(x)   CSI_CR40_PIXEL_COUNTERS(x)
#define CSI_CSICR41_PIXEL_COUNTERS_MASK   CSI_CR41_PIXEL_COUNTERS_MASK
#define CSI_CSICR41_PIXEL_COUNTERS_SHIFT   CSI_CR41_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR41_PIXEL_COUNTERS(x)   CSI_CR41_PIXEL_COUNTERS(x)
#define CSI_CSICR42_PIXEL_COUNTERS_MASK   CSI_CR42_PIXEL_COUNTERS_MASK
#define CSI_CSICR42_PIXEL_COUNTERS_SHIFT   CSI_CR42_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR42_PIXEL_COUNTERS(x)   CSI_CR42_PIXEL_COUNTERS(x)
#define CSI_CSICR43_PIXEL_COUNTERS_MASK   CSI_CR43_PIXEL_COUNTERS_MASK
#define CSI_CSICR43_PIXEL_COUNTERS_SHIFT   CSI_CR43_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR43_PIXEL_COUNTERS(x)   CSI_CR43_PIXEL_COUNTERS(x)
#define CSI_CSICR44_PIXEL_COUNTERS_MASK   CSI_CR44_PIXEL_COUNTERS_MASK
#define CSI_CSICR44_PIXEL_COUNTERS_SHIFT   CSI_CR44_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR44_PIXEL_COUNTERS(x)   CSI_CR44_PIXEL_COUNTERS(x)
#define CSI_CSICR45_PIXEL_COUNTERS_MASK   CSI_CR45_PIXEL_COUNTERS_MASK
#define CSI_CSICR45_PIXEL_COUNTERS_SHIFT   CSI_CR45_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR45_PIXEL_COUNTERS(x)   CSI_CR45_PIXEL_COUNTERS(x)
#define CSI_CSICR46_PIXEL_COUNTERS_MASK   CSI_CR46_PIXEL_COUNTERS_MASK
#define CSI_CSICR46_PIXEL_COUNTERS_SHIFT   CSI_CR46_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR46_PIXEL_COUNTERS(x)   CSI_CR46_PIXEL_COUNTERS(x)
#define CSI_CSICR47_PIXEL_COUNTERS_MASK   CSI_CR47_PIXEL_COUNTERS_MASK
#define CSI_CSICR47_PIXEL_COUNTERS_SHIFT   CSI_CR47_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR47_PIXEL_COUNTERS(x)   CSI_CR47_PIXEL_COUNTERS(x)
#define CSI_CSICR48_PIXEL_COUNTERS_MASK   CSI_CR48_PIXEL_COUNTERS_MASK
#define CSI_CSICR48_PIXEL_COUNTERS_SHIFT   CSI_CR48_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR48_PIXEL_COUNTERS(x)   CSI_CR48_PIXEL_COUNTERS(x)
#define CSI_CSICR49_PIXEL_COUNTERS_MASK   CSI_CR49_PIXEL_COUNTERS_MASK
#define CSI_CSICR49_PIXEL_COUNTERS_SHIFT   CSI_CR49_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR49_PIXEL_COUNTERS(x)   CSI_CR49_PIXEL_COUNTERS(x)
#define CSI_CSICR50_PIXEL_COUNTERS_MASK   CSI_CR50_PIXEL_COUNTERS_MASK
#define CSI_CSICR50_PIXEL_COUNTERS_SHIFT   CSI_CR50_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR50_PIXEL_COUNTERS(x)   CSI_CR50_PIXEL_COUNTERS(x)
#define CSI_CSICR51_PIXEL_COUNTERS_MASK   CSI_CR51_PIXEL_COUNTERS_MASK
#define CSI_CSICR51_PIXEL_COUNTERS_SHIFT   CSI_CR51_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR51_PIXEL_COUNTERS(x)   CSI_CR51_PIXEL_COUNTERS(x)
#define CSI_CSICR52_PIXEL_COUNTERS_MASK   CSI_CR52_PIXEL_COUNTERS_MASK
#define CSI_CSICR52_PIXEL_COUNTERS_SHIFT   CSI_CR52_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR52_PIXEL_COUNTERS(x)   CSI_CR52_PIXEL_COUNTERS(x)
#define CSI_CSICR53_PIXEL_COUNTERS_MASK   CSI_CR53_PIXEL_COUNTERS_MASK
#define CSI_CSICR53_PIXEL_COUNTERS_SHIFT   CSI_CR53_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR53_PIXEL_COUNTERS(x)   CSI_CR53_PIXEL_COUNTERS(x)
#define CSI_CSICR54_PIXEL_COUNTERS_MASK   CSI_CR54_PIXEL_COUNTERS_MASK
#define CSI_CSICR54_PIXEL_COUNTERS_SHIFT   CSI_CR54_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR54_PIXEL_COUNTERS(x)   CSI_CR54_PIXEL_COUNTERS(x)
#define CSI_CSICR55_PIXEL_COUNTERS_MASK   CSI_CR55_PIXEL_COUNTERS_MASK
#define CSI_CSICR55_PIXEL_COUNTERS_SHIFT   CSI_CR55_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR55_PIXEL_COUNTERS(x)   CSI_CR55_PIXEL_COUNTERS(x)
#define CSI_CSICR56_PIXEL_COUNTERS_MASK   CSI_CR56_PIXEL_COUNTERS_MASK
#define CSI_CSICR56_PIXEL_COUNTERS_SHIFT   CSI_CR56_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR56_PIXEL_COUNTERS(x)   CSI_CR56_PIXEL_COUNTERS(x)
#define CSI_CSICR57_PIXEL_COUNTERS_MASK   CSI_CR57_PIXEL_COUNTERS_MASK
#define CSI_CSICR57_PIXEL_COUNTERS_SHIFT   CSI_CR57_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR57_PIXEL_COUNTERS(x)   CSI_CR57_PIXEL_COUNTERS(x)
#define CSI_CSICR58_PIXEL_COUNTERS_MASK   CSI_CR58_PIXEL_COUNTERS_MASK
#define CSI_CSICR58_PIXEL_COUNTERS_SHIFT   CSI_CR58_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR58_PIXEL_COUNTERS(x)   CSI_CR58_PIXEL_COUNTERS(x)
#define CSI_CSICR59_PIXEL_COUNTERS_MASK   CSI_CR59_PIXEL_COUNTERS_MASK
#define CSI_CSICR59_PIXEL_COUNTERS_SHIFT   CSI_CR59_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR59_PIXEL_COUNTERS(x)   CSI_CR59_PIXEL_COUNTERS(x)
#define CSI_CSICR60_PIXEL_COUNTERS_MASK   CSI_CR60_PIXEL_COUNTERS_MASK
#define CSI_CSICR60_PIXEL_COUNTERS_SHIFT   CSI_CR60_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR60_PIXEL_COUNTERS(x)   CSI_CR60_PIXEL_COUNTERS(x)
#define CSI_CSICR61_PIXEL_COUNTERS_MASK   CSI_CR61_PIXEL_COUNTERS_MASK
#define CSI_CSICR61_PIXEL_COUNTERS_SHIFT   CSI_CR61_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR61_PIXEL_COUNTERS(x)   CSI_CR61_PIXEL_COUNTERS(x)
#define CSI_CSICR62_PIXEL_COUNTERS_MASK   CSI_CR62_PIXEL_COUNTERS_MASK
#define CSI_CSICR62_PIXEL_COUNTERS_SHIFT   CSI_CR62_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR62_PIXEL_COUNTERS(x)   CSI_CR62_PIXEL_COUNTERS(x)
#define CSI_CSICR63_PIXEL_COUNTERS_MASK   CSI_CR63_PIXEL_COUNTERS_MASK
#define CSI_CSICR63_PIXEL_COUNTERS_SHIFT   CSI_CR63_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR63_PIXEL_COUNTERS(x)   CSI_CR63_PIXEL_COUNTERS(x)
#define CSI_CSICR64_PIXEL_COUNTERS_MASK   CSI_CR64_PIXEL_COUNTERS_MASK
#define CSI_CSICR64_PIXEL_COUNTERS_SHIFT   CSI_CR64_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR64_PIXEL_COUNTERS(x)   CSI_CR64_PIXEL_COUNTERS(x)
#define CSI_CSICR65_PIXEL_COUNTERS_MASK   CSI_CR65_PIXEL_COUNTERS_MASK
#define CSI_CSICR65_PIXEL_COUNTERS_SHIFT   CSI_CR65_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR65_PIXEL_COUNTERS(x)   CSI_CR65_PIXEL_COUNTERS(x)
#define CSI_CSICR66_PIXEL_COUNTERS_MASK   CSI_CR66_PIXEL_COUNTERS_MASK
#define CSI_CSICR66_PIXEL_COUNTERS_SHIFT   CSI_CR66_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR66_PIXEL_COUNTERS(x)   CSI_CR66_PIXEL_COUNTERS(x)
#define CSI_CSICR67_PIXEL_COUNTERS_MASK   CSI_CR67_PIXEL_COUNTERS_MASK
#define CSI_CSICR67_PIXEL_COUNTERS_SHIFT   CSI_CR67_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR67_PIXEL_COUNTERS(x)   CSI_CR67_PIXEL_COUNTERS(x)
#define CSI_CSICR68_PIXEL_COUNTERS_MASK   CSI_CR68_PIXEL_COUNTERS_MASK
#define CSI_CSICR68_PIXEL_COUNTERS_SHIFT   CSI_CR68_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR68_PIXEL_COUNTERS(x)   CSI_CR68_PIXEL_COUNTERS(x)
#define CSI_CSICR69_PIXEL_COUNTERS_MASK   CSI_CR69_PIXEL_COUNTERS_MASK
#define CSI_CSICR69_PIXEL_COUNTERS_SHIFT   CSI_CR69_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR69_PIXEL_COUNTERS(x)   CSI_CR69_PIXEL_COUNTERS(x)
#define CSI_CSICR70_PIXEL_COUNTERS_MASK   CSI_CR70_PIXEL_COUNTERS_MASK
#define CSI_CSICR70_PIXEL_COUNTERS_SHIFT   CSI_CR70_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR70_PIXEL_COUNTERS(x)   CSI_CR70_PIXEL_COUNTERS(x)
#define CSI_CSICR71_PIXEL_COUNTERS_MASK   CSI_CR71_PIXEL_COUNTERS_MASK
#define CSI_CSICR71_PIXEL_COUNTERS_SHIFT   CSI_CR71_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR71_PIXEL_COUNTERS(x)   CSI_CR71_PIXEL_COUNTERS(x)
#define CSI_CSICR72_PIXEL_COUNTERS_MASK   CSI_CR72_PIXEL_COUNTERS_MASK
#define CSI_CSICR72_PIXEL_COUNTERS_SHIFT   CSI_CR72_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR72_PIXEL_COUNTERS(x)   CSI_CR72_PIXEL_COUNTERS(x)
#define CSI_CSICR73_PIXEL_COUNTERS_MASK   CSI_CR73_PIXEL_COUNTERS_MASK
#define CSI_CSICR73_PIXEL_COUNTERS_SHIFT   CSI_CR73_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR73_PIXEL_COUNTERS(x)   CSI_CR73_PIXEL_COUNTERS(x)
#define CSI_CSICR74_PIXEL_COUNTERS_MASK   CSI_CR74_PIXEL_COUNTERS_MASK
#define CSI_CSICR74_PIXEL_COUNTERS_SHIFT   CSI_CR74_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR74_PIXEL_COUNTERS(x)   CSI_CR74_PIXEL_COUNTERS(x)
#define CSI_CSICR75_PIXEL_COUNTERS_MASK   CSI_CR75_PIXEL_COUNTERS_MASK
#define CSI_CSICR75_PIXEL_COUNTERS_SHIFT   CSI_CR75_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR75_PIXEL_COUNTERS(x)   CSI_CR75_PIXEL_COUNTERS(x)
#define CSI_CSICR76_PIXEL_COUNTERS_MASK   CSI_CR76_PIXEL_COUNTERS_MASK
#define CSI_CSICR76_PIXEL_COUNTERS_SHIFT   CSI_CR76_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR76_PIXEL_COUNTERS(x)   CSI_CR76_PIXEL_COUNTERS(x)
#define CSI_CSICR77_PIXEL_COUNTERS_MASK   CSI_CR77_PIXEL_COUNTERS_MASK
#define CSI_CSICR77_PIXEL_COUNTERS_SHIFT   CSI_CR77_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR77_PIXEL_COUNTERS(x)   CSI_CR77_PIXEL_COUNTERS(x)
#define CSI_CSICR78_PIXEL_COUNTERS_MASK   CSI_CR78_PIXEL_COUNTERS_MASK
#define CSI_CSICR78_PIXEL_COUNTERS_SHIFT   CSI_CR78_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR78_PIXEL_COUNTERS(x)   CSI_CR78_PIXEL_COUNTERS(x)
#define CSI_CSICR79_PIXEL_COUNTERS_MASK   CSI_CR79_PIXEL_COUNTERS_MASK
#define CSI_CSICR79_PIXEL_COUNTERS_SHIFT   CSI_CR79_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR79_PIXEL_COUNTERS(x)   CSI_CR79_PIXEL_COUNTERS(x)
#define CSI_CSICR80_PIXEL_COUNTERS_MASK   CSI_CR80_PIXEL_COUNTERS_MASK
#define CSI_CSICR80_PIXEL_COUNTERS_SHIFT   CSI_CR80_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR80_PIXEL_COUNTERS(x)   CSI_CR80_PIXEL_COUNTERS(x)
#define CSI_CSICR81_PIXEL_COUNTERS_MASK   CSI_CR81_PIXEL_COUNTERS_MASK
#define CSI_CSICR81_PIXEL_COUNTERS_SHIFT   CSI_CR81_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR81_PIXEL_COUNTERS(x)   CSI_CR81_PIXEL_COUNTERS(x)
#define CSI_CSICR82_PIXEL_COUNTERS_MASK   CSI_CR82_PIXEL_COUNTERS_MASK
#define CSI_CSICR82_PIXEL_COUNTERS_SHIFT   CSI_CR82_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR82_PIXEL_COUNTERS(x)   CSI_CR82_PIXEL_COUNTERS(x)
#define CSI_CSICR83_PIXEL_COUNTERS_MASK   CSI_CR83_PIXEL_COUNTERS_MASK
#define CSI_CSICR83_PIXEL_COUNTERS_SHIFT   CSI_CR83_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR83_PIXEL_COUNTERS(x)   CSI_CR83_PIXEL_COUNTERS(x)
#define CSI_CSICR84_PIXEL_COUNTERS_MASK   CSI_CR84_PIXEL_COUNTERS_MASK
#define CSI_CSICR84_PIXEL_COUNTERS_SHIFT   CSI_CR84_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR84_PIXEL_COUNTERS(x)   CSI_CR84_PIXEL_COUNTERS(x)
#define CSI_CSICR85_PIXEL_COUNTERS_MASK   CSI_CR85_PIXEL_COUNTERS_MASK
#define CSI_CSICR85_PIXEL_COUNTERS_SHIFT   CSI_CR85_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR85_PIXEL_COUNTERS(x)   CSI_CR85_PIXEL_COUNTERS(x)
#define CSI_CSICR86_PIXEL_COUNTERS_MASK   CSI_CR86_PIXEL_COUNTERS_MASK
#define CSI_CSICR86_PIXEL_COUNTERS_SHIFT   CSI_CR86_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR86_PIXEL_COUNTERS(x)   CSI_CR86_PIXEL_COUNTERS(x)
#define CSI_CSICR87_PIXEL_COUNTERS_MASK   CSI_CR87_PIXEL_COUNTERS_MASK
#define CSI_CSICR87_PIXEL_COUNTERS_SHIFT   CSI_CR87_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR87_PIXEL_COUNTERS(x)   CSI_CR87_PIXEL_COUNTERS(x)
#define CSI_CSICR88_PIXEL_COUNTERS_MASK   CSI_CR88_PIXEL_COUNTERS_MASK
#define CSI_CSICR88_PIXEL_COUNTERS_SHIFT   CSI_CR88_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR88_PIXEL_COUNTERS(x)   CSI_CR88_PIXEL_COUNTERS(x)
#define CSI_CSICR89_PIXEL_COUNTERS_MASK   CSI_CR89_PIXEL_COUNTERS_MASK
#define CSI_CSICR89_PIXEL_COUNTERS_SHIFT   CSI_CR89_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR89_PIXEL_COUNTERS(x)   CSI_CR89_PIXEL_COUNTERS(x)
#define CSI_CSICR90_PIXEL_COUNTERS_MASK   CSI_CR90_PIXEL_COUNTERS_MASK
#define CSI_CSICR90_PIXEL_COUNTERS_SHIFT   CSI_CR90_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR90_PIXEL_COUNTERS(x)   CSI_CR90_PIXEL_COUNTERS(x)
#define CSI_CSICR91_PIXEL_COUNTERS_MASK   CSI_CR91_PIXEL_COUNTERS_MASK
#define CSI_CSICR91_PIXEL_COUNTERS_SHIFT   CSI_CR91_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR91_PIXEL_COUNTERS(x)   CSI_CR91_PIXEL_COUNTERS(x)
#define CSI_CSICR92_PIXEL_COUNTERS_MASK   CSI_CR92_PIXEL_COUNTERS_MASK
#define CSI_CSICR92_PIXEL_COUNTERS_SHIFT   CSI_CR92_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR92_PIXEL_COUNTERS(x)   CSI_CR92_PIXEL_COUNTERS(x)
#define CSI_CSICR93_PIXEL_COUNTERS_MASK   CSI_CR93_PIXEL_COUNTERS_MASK
#define CSI_CSICR93_PIXEL_COUNTERS_SHIFT   CSI_CR93_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR93_PIXEL_COUNTERS(x)   CSI_CR93_PIXEL_COUNTERS(x)
#define CSI_CSICR94_PIXEL_COUNTERS_MASK   CSI_CR94_PIXEL_COUNTERS_MASK
#define CSI_CSICR94_PIXEL_COUNTERS_SHIFT   CSI_CR94_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR94_PIXEL_COUNTERS(x)   CSI_CR94_PIXEL_COUNTERS(x)
#define CSI_CSICR95_PIXEL_COUNTERS_MASK   CSI_CR95_PIXEL_COUNTERS_MASK
#define CSI_CSICR95_PIXEL_COUNTERS_SHIFT   CSI_CR95_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR95_PIXEL_COUNTERS(x)   CSI_CR95_PIXEL_COUNTERS(x)
#define CSI_CSICR96_PIXEL_COUNTERS_MASK   CSI_CR96_PIXEL_COUNTERS_MASK
#define CSI_CSICR96_PIXEL_COUNTERS_SHIFT   CSI_CR96_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR96_PIXEL_COUNTERS(x)   CSI_CR96_PIXEL_COUNTERS(x)
#define CSI_CSICR97_PIXEL_COUNTERS_MASK   CSI_CR97_PIXEL_COUNTERS_MASK
#define CSI_CSICR97_PIXEL_COUNTERS_SHIFT   CSI_CR97_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR97_PIXEL_COUNTERS(x)   CSI_CR97_PIXEL_COUNTERS(x)
#define CSI_CSICR98_PIXEL_COUNTERS_MASK   CSI_CR98_PIXEL_COUNTERS_MASK
#define CSI_CSICR98_PIXEL_COUNTERS_SHIFT   CSI_CR98_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR98_PIXEL_COUNTERS(x)   CSI_CR98_PIXEL_COUNTERS(x)
#define CSI_CSICR99_PIXEL_COUNTERS_MASK   CSI_CR99_PIXEL_COUNTERS_MASK
#define CSI_CSICR99_PIXEL_COUNTERS_SHIFT   CSI_CR99_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR99_PIXEL_COUNTERS(x)   CSI_CR99_PIXEL_COUNTERS(x)
#define CSI_CSICR100_PIXEL_COUNTERS_MASK   CSI_CR100_PIXEL_COUNTERS_MASK
#define CSI_CSICR100_PIXEL_COUNTERS_SHIFT   CSI_CR100_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR100_PIXEL_COUNTERS(x)   CSI_CR100_PIXEL_COUNTERS(x)
#define CSI_CSICR101_PIXEL_COUNTERS_MASK   CSI_CR101_PIXEL_COUNTERS_MASK
#define CSI_CSICR101_PIXEL_COUNTERS_SHIFT   CSI_CR101_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR101_PIXEL_COUNTERS(x)   CSI_CR101_PIXEL_COUNTERS(x)
#define CSI_CSICR102_PIXEL_COUNTERS_MASK   CSI_CR102_PIXEL_COUNTERS_MASK
#define CSI_CSICR102_PIXEL_COUNTERS_SHIFT   CSI_CR102_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR102_PIXEL_COUNTERS(x)   CSI_CR102_PIXEL_COUNTERS(x)
#define CSI_CSICR103_PIXEL_COUNTERS_MASK   CSI_CR103_PIXEL_COUNTERS_MASK
#define CSI_CSICR103_PIXEL_COUNTERS_SHIFT   CSI_CR103_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR103_PIXEL_COUNTERS(x)   CSI_CR103_PIXEL_COUNTERS(x)
#define CSI_CSICR104_PIXEL_COUNTERS_MASK   CSI_CR104_PIXEL_COUNTERS_MASK
#define CSI_CSICR104_PIXEL_COUNTERS_SHIFT   CSI_CR104_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR104_PIXEL_COUNTERS(x)   CSI_CR104_PIXEL_COUNTERS(x)
#define CSI_CSICR105_PIXEL_COUNTERS_MASK   CSI_CR105_PIXEL_COUNTERS_MASK
#define CSI_CSICR105_PIXEL_COUNTERS_SHIFT   CSI_CR105_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR105_PIXEL_COUNTERS(x)   CSI_CR105_PIXEL_COUNTERS(x)
#define CSI_CSICR106_PIXEL_COUNTERS_MASK   CSI_CR106_PIXEL_COUNTERS_MASK
#define CSI_CSICR106_PIXEL_COUNTERS_SHIFT   CSI_CR106_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR106_PIXEL_COUNTERS(x)   CSI_CR106_PIXEL_COUNTERS(x)
#define CSI_CSICR107_PIXEL_COUNTERS_MASK   CSI_CR107_PIXEL_COUNTERS_MASK
#define CSI_CSICR107_PIXEL_COUNTERS_SHIFT   CSI_CR107_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR107_PIXEL_COUNTERS(x)   CSI_CR107_PIXEL_COUNTERS(x)
#define CSI_CSICR108_PIXEL_COUNTERS_MASK   CSI_CR108_PIXEL_COUNTERS_MASK
#define CSI_CSICR108_PIXEL_COUNTERS_SHIFT   CSI_CR108_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR108_PIXEL_COUNTERS(x)   CSI_CR108_PIXEL_COUNTERS(x)
#define CSI_CSICR109_PIXEL_COUNTERS_MASK   CSI_CR109_PIXEL_COUNTERS_MASK
#define CSI_CSICR109_PIXEL_COUNTERS_SHIFT   CSI_CR109_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR109_PIXEL_COUNTERS(x)   CSI_CR109_PIXEL_COUNTERS(x)
#define CSI_CSICR110_PIXEL_COUNTERS_MASK   CSI_CR110_PIXEL_COUNTERS_MASK
#define CSI_CSICR110_PIXEL_COUNTERS_SHIFT   CSI_CR110_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR110_PIXEL_COUNTERS(x)   CSI_CR110_PIXEL_COUNTERS(x)
#define CSI_CSICR111_PIXEL_COUNTERS_MASK   CSI_CR111_PIXEL_COUNTERS_MASK
#define CSI_CSICR111_PIXEL_COUNTERS_SHIFT   CSI_CR111_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR111_PIXEL_COUNTERS(x)   CSI_CR111_PIXEL_COUNTERS(x)
#define CSI_CSICR112_PIXEL_COUNTERS_MASK   CSI_CR112_PIXEL_COUNTERS_MASK
#define CSI_CSICR112_PIXEL_COUNTERS_SHIFT   CSI_CR112_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR112_PIXEL_COUNTERS(x)   CSI_CR112_PIXEL_COUNTERS(x)
#define CSI_CSICR113_PIXEL_COUNTERS_MASK   CSI_CR113_PIXEL_COUNTERS_MASK
#define CSI_CSICR113_PIXEL_COUNTERS_SHIFT   CSI_CR113_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR113_PIXEL_COUNTERS(x)   CSI_CR113_PIXEL_COUNTERS(x)
#define CSI_CSICR114_PIXEL_COUNTERS_MASK   CSI_CR114_PIXEL_COUNTERS_MASK
#define CSI_CSICR114_PIXEL_COUNTERS_SHIFT   CSI_CR114_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR114_PIXEL_COUNTERS(x)   CSI_CR114_PIXEL_COUNTERS(x)
#define CSI_CSICR115_PIXEL_COUNTERS_MASK   CSI_CR115_PIXEL_COUNTERS_MASK
#define CSI_CSICR115_PIXEL_COUNTERS_SHIFT   CSI_CR115_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR115_PIXEL_COUNTERS(x)   CSI_CR115_PIXEL_COUNTERS(x)
#define CSI_CSICR116_PIXEL_COUNTERS_MASK   CSI_CR116_PIXEL_COUNTERS_MASK
#define CSI_CSICR116_PIXEL_COUNTERS_SHIFT   CSI_CR116_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR116_PIXEL_COUNTERS(x)   CSI_CR116_PIXEL_COUNTERS(x)
#define CSI_CSICR117_PIXEL_COUNTERS_MASK   CSI_CR117_PIXEL_COUNTERS_MASK
#define CSI_CSICR117_PIXEL_COUNTERS_SHIFT   CSI_CR117_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR117_PIXEL_COUNTERS(x)   CSI_CR117_PIXEL_COUNTERS(x)
#define CSI_CSICR118_PIXEL_COUNTERS_MASK   CSI_CR118_PIXEL_COUNTERS_MASK
#define CSI_CSICR118_PIXEL_COUNTERS_SHIFT   CSI_CR118_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR118_PIXEL_COUNTERS(x)   CSI_CR118_PIXEL_COUNTERS(x)
#define CSI_CSICR119_PIXEL_COUNTERS_MASK   CSI_CR119_PIXEL_COUNTERS_MASK
#define CSI_CSICR119_PIXEL_COUNTERS_SHIFT   CSI_CR119_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR119_PIXEL_COUNTERS(x)   CSI_CR119_PIXEL_COUNTERS(x)
#define CSI_CSICR120_PIXEL_COUNTERS_MASK   CSI_CR120_PIXEL_COUNTERS_MASK
#define CSI_CSICR120_PIXEL_COUNTERS_SHIFT   CSI_CR120_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR120_PIXEL_COUNTERS(x)   CSI_CR120_PIXEL_COUNTERS(x)
#define CSI_CSICR121_PIXEL_COUNTERS_MASK   CSI_CR121_PIXEL_COUNTERS_MASK
#define CSI_CSICR121_PIXEL_COUNTERS_SHIFT   CSI_CR121_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR121_PIXEL_COUNTERS(x)   CSI_CR121_PIXEL_COUNTERS(x)
#define CSI_CSICR122_PIXEL_COUNTERS_MASK   CSI_CR122_PIXEL_COUNTERS_MASK
#define CSI_CSICR122_PIXEL_COUNTERS_SHIFT   CSI_CR122_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR122_PIXEL_COUNTERS(x)   CSI_CR122_PIXEL_COUNTERS(x)
#define CSI_CSICR123_PIXEL_COUNTERS_MASK   CSI_CR123_PIXEL_COUNTERS_MASK
#define CSI_CSICR123_PIXEL_COUNTERS_SHIFT   CSI_CR123_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR123_PIXEL_COUNTERS(x)   CSI_CR123_PIXEL_COUNTERS(x)
#define CSI_CSICR124_PIXEL_COUNTERS_MASK   CSI_CR124_PIXEL_COUNTERS_MASK
#define CSI_CSICR124_PIXEL_COUNTERS_SHIFT   CSI_CR124_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR124_PIXEL_COUNTERS(x)   CSI_CR124_PIXEL_COUNTERS(x)
#define CSI_CSICR125_PIXEL_COUNTERS_MASK   CSI_CR125_PIXEL_COUNTERS_MASK
#define CSI_CSICR125_PIXEL_COUNTERS_SHIFT   CSI_CR125_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR125_PIXEL_COUNTERS(x)   CSI_CR125_PIXEL_COUNTERS(x)
#define CSI_CSICR126_PIXEL_COUNTERS_MASK   CSI_CR126_PIXEL_COUNTERS_MASK
#define CSI_CSICR126_PIXEL_COUNTERS_SHIFT   CSI_CR126_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR126_PIXEL_COUNTERS(x)   CSI_CR126_PIXEL_COUNTERS(x)
#define CSI_CSICR127_PIXEL_COUNTERS_MASK   CSI_CR127_PIXEL_COUNTERS_MASK
#define CSI_CSICR127_PIXEL_COUNTERS_SHIFT   CSI_CR127_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR127_PIXEL_COUNTERS(x)   CSI_CR127_PIXEL_COUNTERS(x)
#define CSI_CSICR128_PIXEL_COUNTERS_MASK   CSI_CR128_PIXEL_COUNTERS_MASK
#define CSI_CSICR128_PIXEL_COUNTERS_SHIFT   CSI_CR128_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR128_PIXEL_COUNTERS(x)   CSI_CR128_PIXEL_COUNTERS(x)
#define CSI_CSICR129_PIXEL_COUNTERS_MASK   CSI_CR129_PIXEL_COUNTERS_MASK
#define CSI_CSICR129_PIXEL_COUNTERS_SHIFT   CSI_CR129_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR129_PIXEL_COUNTERS(x)   CSI_CR129_PIXEL_COUNTERS(x)
#define CSI_CSICR130_PIXEL_COUNTERS_MASK   CSI_CR130_PIXEL_COUNTERS_MASK
#define CSI_CSICR130_PIXEL_COUNTERS_SHIFT   CSI_CR130_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR130_PIXEL_COUNTERS(x)   CSI_CR130_PIXEL_COUNTERS(x)
#define CSI_CSICR131_PIXEL_COUNTERS_MASK   CSI_CR131_PIXEL_COUNTERS_MASK
#define CSI_CSICR131_PIXEL_COUNTERS_SHIFT   CSI_CR131_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR131_PIXEL_COUNTERS(x)   CSI_CR131_PIXEL_COUNTERS(x)
#define CSI_CSICR132_PIXEL_COUNTERS_MASK   CSI_CR132_PIXEL_COUNTERS_MASK
#define CSI_CSICR132_PIXEL_COUNTERS_SHIFT   CSI_CR132_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR132_PIXEL_COUNTERS(x)   CSI_CR132_PIXEL_COUNTERS(x)
#define CSI_CSICR133_PIXEL_COUNTERS_MASK   CSI_CR133_PIXEL_COUNTERS_MASK
#define CSI_CSICR133_PIXEL_COUNTERS_SHIFT   CSI_CR133_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR133_PIXEL_COUNTERS(x)   CSI_CR133_PIXEL_COUNTERS(x)
#define CSI_CSICR134_PIXEL_COUNTERS_MASK   CSI_CR134_PIXEL_COUNTERS_MASK
#define CSI_CSICR134_PIXEL_COUNTERS_SHIFT   CSI_CR134_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR134_PIXEL_COUNTERS(x)   CSI_CR134_PIXEL_COUNTERS(x)
#define CSI_CSICR135_PIXEL_COUNTERS_MASK   CSI_CR135_PIXEL_COUNTERS_MASK
#define CSI_CSICR135_PIXEL_COUNTERS_SHIFT   CSI_CR135_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR135_PIXEL_COUNTERS(x)   CSI_CR135_PIXEL_COUNTERS(x)
#define CSI_CSICR136_PIXEL_COUNTERS_MASK   CSI_CR136_PIXEL_COUNTERS_MASK
#define CSI_CSICR136_PIXEL_COUNTERS_SHIFT   CSI_CR136_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR136_PIXEL_COUNTERS(x)   CSI_CR136_PIXEL_COUNTERS(x)
#define CSI_CSICR137_PIXEL_COUNTERS_MASK   CSI_CR137_PIXEL_COUNTERS_MASK
#define CSI_CSICR137_PIXEL_COUNTERS_SHIFT   CSI_CR137_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR137_PIXEL_COUNTERS(x)   CSI_CR137_PIXEL_COUNTERS(x)
#define CSI_CSICR138_PIXEL_COUNTERS_MASK   CSI_CR138_PIXEL_COUNTERS_MASK
#define CSI_CSICR138_PIXEL_COUNTERS_SHIFT   CSI_CR138_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR138_PIXEL_COUNTERS(x)   CSI_CR138_PIXEL_COUNTERS(x)
#define CSI_CSICR139_PIXEL_COUNTERS_MASK   CSI_CR139_PIXEL_COUNTERS_MASK
#define CSI_CSICR139_PIXEL_COUNTERS_SHIFT   CSI_CR139_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR139_PIXEL_COUNTERS(x)   CSI_CR139_PIXEL_COUNTERS(x)
#define CSI_CSICR140_PIXEL_COUNTERS_MASK   CSI_CR140_PIXEL_COUNTERS_MASK
#define CSI_CSICR140_PIXEL_COUNTERS_SHIFT   CSI_CR140_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR140_PIXEL_COUNTERS(x)   CSI_CR140_PIXEL_COUNTERS(x)
#define CSI_CSICR141_PIXEL_COUNTERS_MASK   CSI_CR141_PIXEL_COUNTERS_MASK
#define CSI_CSICR141_PIXEL_COUNTERS_SHIFT   CSI_CR141_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR141_PIXEL_COUNTERS(x)   CSI_CR141_PIXEL_COUNTERS(x)
#define CSI_CSICR142_PIXEL_COUNTERS_MASK   CSI_CR142_PIXEL_COUNTERS_MASK
#define CSI_CSICR142_PIXEL_COUNTERS_SHIFT   CSI_CR142_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR142_PIXEL_COUNTERS(x)   CSI_CR142_PIXEL_COUNTERS(x)
#define CSI_CSICR143_PIXEL_COUNTERS_MASK   CSI_CR143_PIXEL_COUNTERS_MASK
#define CSI_CSICR143_PIXEL_COUNTERS_SHIFT   CSI_CR143_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR143_PIXEL_COUNTERS(x)   CSI_CR143_PIXEL_COUNTERS(x)
#define CSI_CSICR144_PIXEL_COUNTERS_MASK   CSI_CR144_PIXEL_COUNTERS_MASK
#define CSI_CSICR144_PIXEL_COUNTERS_SHIFT   CSI_CR144_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR144_PIXEL_COUNTERS(x)   CSI_CR144_PIXEL_COUNTERS(x)
#define CSI_CSICR145_PIXEL_COUNTERS_MASK   CSI_CR145_PIXEL_COUNTERS_MASK
#define CSI_CSICR145_PIXEL_COUNTERS_SHIFT   CSI_CR145_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR145_PIXEL_COUNTERS(x)   CSI_CR145_PIXEL_COUNTERS(x)
#define CSI_CSICR146_PIXEL_COUNTERS_MASK   CSI_CR146_PIXEL_COUNTERS_MASK
#define CSI_CSICR146_PIXEL_COUNTERS_SHIFT   CSI_CR146_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR146_PIXEL_COUNTERS(x)   CSI_CR146_PIXEL_COUNTERS(x)
#define CSI_CSICR147_PIXEL_COUNTERS_MASK   CSI_CR147_PIXEL_COUNTERS_MASK
#define CSI_CSICR147_PIXEL_COUNTERS_SHIFT   CSI_CR147_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR147_PIXEL_COUNTERS(x)   CSI_CR147_PIXEL_COUNTERS(x)
#define CSI_CSICR148_PIXEL_COUNTERS_MASK   CSI_CR148_PIXEL_COUNTERS_MASK
#define CSI_CSICR148_PIXEL_COUNTERS_SHIFT   CSI_CR148_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR148_PIXEL_COUNTERS(x)   CSI_CR148_PIXEL_COUNTERS(x)
#define CSI_CSICR149_PIXEL_COUNTERS_MASK   CSI_CR149_PIXEL_COUNTERS_MASK
#define CSI_CSICR149_PIXEL_COUNTERS_SHIFT   CSI_CR149_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR149_PIXEL_COUNTERS(x)   CSI_CR149_PIXEL_COUNTERS(x)
#define CSI_CSICR150_PIXEL_COUNTERS_MASK   CSI_CR150_PIXEL_COUNTERS_MASK
#define CSI_CSICR150_PIXEL_COUNTERS_SHIFT   CSI_CR150_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR150_PIXEL_COUNTERS(x)   CSI_CR150_PIXEL_COUNTERS(x)
#define CSI_CSICR151_PIXEL_COUNTERS_MASK   CSI_CR151_PIXEL_COUNTERS_MASK
#define CSI_CSICR151_PIXEL_COUNTERS_SHIFT   CSI_CR151_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR151_PIXEL_COUNTERS(x)   CSI_CR151_PIXEL_COUNTERS(x)
#define CSI_CSICR152_PIXEL_COUNTERS_MASK   CSI_CR152_PIXEL_COUNTERS_MASK
#define CSI_CSICR152_PIXEL_COUNTERS_SHIFT   CSI_CR152_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR152_PIXEL_COUNTERS(x)   CSI_CR152_PIXEL_COUNTERS(x)
#define CSI_CSICR153_PIXEL_COUNTERS_MASK   CSI_CR153_PIXEL_COUNTERS_MASK
#define CSI_CSICR153_PIXEL_COUNTERS_SHIFT   CSI_CR153_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR153_PIXEL_COUNTERS(x)   CSI_CR153_PIXEL_COUNTERS(x)
#define CSI_CSICR154_PIXEL_COUNTERS_MASK   CSI_CR154_PIXEL_COUNTERS_MASK
#define CSI_CSICR154_PIXEL_COUNTERS_SHIFT   CSI_CR154_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR154_PIXEL_COUNTERS(x)   CSI_CR154_PIXEL_COUNTERS(x)
#define CSI_CSICR155_PIXEL_COUNTERS_MASK   CSI_CR155_PIXEL_COUNTERS_MASK
#define CSI_CSICR155_PIXEL_COUNTERS_SHIFT   CSI_CR155_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR155_PIXEL_COUNTERS(x)   CSI_CR155_PIXEL_COUNTERS(x)
#define CSI_CSICR156_PIXEL_COUNTERS_MASK   CSI_CR156_PIXEL_COUNTERS_MASK
#define CSI_CSICR156_PIXEL_COUNTERS_SHIFT   CSI_CR156_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR156_PIXEL_COUNTERS(x)   CSI_CR156_PIXEL_COUNTERS(x)
#define CSI_CSICR157_PIXEL_COUNTERS_MASK   CSI_CR157_PIXEL_COUNTERS_MASK
#define CSI_CSICR157_PIXEL_COUNTERS_SHIFT   CSI_CR157_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR157_PIXEL_COUNTERS(x)   CSI_CR157_PIXEL_COUNTERS(x)
#define CSI_CSICR158_PIXEL_COUNTERS_MASK   CSI_CR158_PIXEL_COUNTERS_MASK
#define CSI_CSICR158_PIXEL_COUNTERS_SHIFT   CSI_CR158_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR158_PIXEL_COUNTERS(x)   CSI_CR158_PIXEL_COUNTERS(x)
#define CSI_CSICR159_PIXEL_COUNTERS_MASK   CSI_CR159_PIXEL_COUNTERS_MASK
#define CSI_CSICR159_PIXEL_COUNTERS_SHIFT   CSI_CR159_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR159_PIXEL_COUNTERS(x)   CSI_CR159_PIXEL_COUNTERS(x)
#define CSI_CSICR160_PIXEL_COUNTERS_MASK   CSI_CR160_PIXEL_COUNTERS_MASK
#define CSI_CSICR160_PIXEL_COUNTERS_SHIFT   CSI_CR160_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR160_PIXEL_COUNTERS(x)   CSI_CR160_PIXEL_COUNTERS(x)
#define CSI_CSICR161_PIXEL_COUNTERS_MASK   CSI_CR161_PIXEL_COUNTERS_MASK
#define CSI_CSICR161_PIXEL_COUNTERS_SHIFT   CSI_CR161_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR161_PIXEL_COUNTERS(x)   CSI_CR161_PIXEL_COUNTERS(x)
#define CSI_CSICR162_PIXEL_COUNTERS_MASK   CSI_CR162_PIXEL_COUNTERS_MASK
#define CSI_CSICR162_PIXEL_COUNTERS_SHIFT   CSI_CR162_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR162_PIXEL_COUNTERS(x)   CSI_CR162_PIXEL_COUNTERS(x)
#define CSI_CSICR163_PIXEL_COUNTERS_MASK   CSI_CR163_PIXEL_COUNTERS_MASK
#define CSI_CSICR163_PIXEL_COUNTERS_SHIFT   CSI_CR163_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR163_PIXEL_COUNTERS(x)   CSI_CR163_PIXEL_COUNTERS(x)
#define CSI_CSICR164_PIXEL_COUNTERS_MASK   CSI_CR164_PIXEL_COUNTERS_MASK
#define CSI_CSICR164_PIXEL_COUNTERS_SHIFT   CSI_CR164_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR164_PIXEL_COUNTERS(x)   CSI_CR164_PIXEL_COUNTERS(x)
#define CSI_CSICR165_PIXEL_COUNTERS_MASK   CSI_CR165_PIXEL_COUNTERS_MASK
#define CSI_CSICR165_PIXEL_COUNTERS_SHIFT   CSI_CR165_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR165_PIXEL_COUNTERS(x)   CSI_CR165_PIXEL_COUNTERS(x)
#define CSI_CSICR166_PIXEL_COUNTERS_MASK   CSI_CR166_PIXEL_COUNTERS_MASK
#define CSI_CSICR166_PIXEL_COUNTERS_SHIFT   CSI_CR166_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR166_PIXEL_COUNTERS(x)   CSI_CR166_PIXEL_COUNTERS(x)
#define CSI_CSICR167_PIXEL_COUNTERS_MASK   CSI_CR167_PIXEL_COUNTERS_MASK
#define CSI_CSICR167_PIXEL_COUNTERS_SHIFT   CSI_CR167_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR167_PIXEL_COUNTERS(x)   CSI_CR167_PIXEL_COUNTERS(x)
#define CSI_CSICR168_PIXEL_COUNTERS_MASK   CSI_CR168_PIXEL_COUNTERS_MASK
#define CSI_CSICR168_PIXEL_COUNTERS_SHIFT   CSI_CR168_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR168_PIXEL_COUNTERS(x)   CSI_CR168_PIXEL_COUNTERS(x)
#define CSI_CSICR169_PIXEL_COUNTERS_MASK   CSI_CR169_PIXEL_COUNTERS_MASK
#define CSI_CSICR169_PIXEL_COUNTERS_SHIFT   CSI_CR169_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR169_PIXEL_COUNTERS(x)   CSI_CR169_PIXEL_COUNTERS(x)
#define CSI_CSICR170_PIXEL_COUNTERS_MASK   CSI_CR170_PIXEL_COUNTERS_MASK
#define CSI_CSICR170_PIXEL_COUNTERS_SHIFT   CSI_CR170_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR170_PIXEL_COUNTERS(x)   CSI_CR170_PIXEL_COUNTERS(x)
#define CSI_CSICR171_PIXEL_COUNTERS_MASK   CSI_CR171_PIXEL_COUNTERS_MASK
#define CSI_CSICR171_PIXEL_COUNTERS_SHIFT   CSI_CR171_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR171_PIXEL_COUNTERS(x)   CSI_CR171_PIXEL_COUNTERS(x)
#define CSI_CSICR172_PIXEL_COUNTERS_MASK   CSI_CR172_PIXEL_COUNTERS_MASK
#define CSI_CSICR172_PIXEL_COUNTERS_SHIFT   CSI_CR172_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR172_PIXEL_COUNTERS(x)   CSI_CR172_PIXEL_COUNTERS(x)
#define CSI_CSICR173_PIXEL_COUNTERS_MASK   CSI_CR173_PIXEL_COUNTERS_MASK
#define CSI_CSICR173_PIXEL_COUNTERS_SHIFT   CSI_CR173_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR173_PIXEL_COUNTERS(x)   CSI_CR173_PIXEL_COUNTERS(x)
#define CSI_CSICR174_PIXEL_COUNTERS_MASK   CSI_CR174_PIXEL_COUNTERS_MASK
#define CSI_CSICR174_PIXEL_COUNTERS_SHIFT   CSI_CR174_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR174_PIXEL_COUNTERS(x)   CSI_CR174_PIXEL_COUNTERS(x)
#define CSI_CSICR175_PIXEL_COUNTERS_MASK   CSI_CR175_PIXEL_COUNTERS_MASK
#define CSI_CSICR175_PIXEL_COUNTERS_SHIFT   CSI_CR175_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR175_PIXEL_COUNTERS(x)   CSI_CR175_PIXEL_COUNTERS(x)
#define CSI_CSICR176_PIXEL_COUNTERS_MASK   CSI_CR176_PIXEL_COUNTERS_MASK
#define CSI_CSICR176_PIXEL_COUNTERS_SHIFT   CSI_CR176_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR176_PIXEL_COUNTERS(x)   CSI_CR176_PIXEL_COUNTERS(x)
#define CSI_CSICR177_PIXEL_COUNTERS_MASK   CSI_CR177_PIXEL_COUNTERS_MASK
#define CSI_CSICR177_PIXEL_COUNTERS_SHIFT   CSI_CR177_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR177_PIXEL_COUNTERS(x)   CSI_CR177_PIXEL_COUNTERS(x)
#define CSI_CSICR178_PIXEL_COUNTERS_MASK   CSI_CR178_PIXEL_COUNTERS_MASK
#define CSI_CSICR178_PIXEL_COUNTERS_SHIFT   CSI_CR178_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR178_PIXEL_COUNTERS(x)   CSI_CR178_PIXEL_COUNTERS(x)
#define CSI_CSICR179_PIXEL_COUNTERS_MASK   CSI_CR179_PIXEL_COUNTERS_MASK
#define CSI_CSICR179_PIXEL_COUNTERS_SHIFT   CSI_CR179_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR179_PIXEL_COUNTERS(x)   CSI_CR179_PIXEL_COUNTERS(x)
#define CSI_CSICR180_PIXEL_COUNTERS_MASK   CSI_CR180_PIXEL_COUNTERS_MASK
#define CSI_CSICR180_PIXEL_COUNTERS_SHIFT   CSI_CR180_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR180_PIXEL_COUNTERS(x)   CSI_CR180_PIXEL_COUNTERS(x)
#define CSI_CSICR181_PIXEL_COUNTERS_MASK   CSI_CR181_PIXEL_COUNTERS_MASK
#define CSI_CSICR181_PIXEL_COUNTERS_SHIFT   CSI_CR181_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR181_PIXEL_COUNTERS(x)   CSI_CR181_PIXEL_COUNTERS(x)
#define CSI_CSICR182_PIXEL_COUNTERS_MASK   CSI_CR182_PIXEL_COUNTERS_MASK
#define CSI_CSICR182_PIXEL_COUNTERS_SHIFT   CSI_CR182_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR182_PIXEL_COUNTERS(x)   CSI_CR182_PIXEL_COUNTERS(x)
#define CSI_CSICR183_PIXEL_COUNTERS_MASK   CSI_CR183_PIXEL_COUNTERS_MASK
#define CSI_CSICR183_PIXEL_COUNTERS_SHIFT   CSI_CR183_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR183_PIXEL_COUNTERS(x)   CSI_CR183_PIXEL_COUNTERS(x)
#define CSI_CSICR184_PIXEL_COUNTERS_MASK   CSI_CR184_PIXEL_COUNTERS_MASK
#define CSI_CSICR184_PIXEL_COUNTERS_SHIFT   CSI_CR184_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR184_PIXEL_COUNTERS(x)   CSI_CR184_PIXEL_COUNTERS(x)
#define CSI_CSICR185_PIXEL_COUNTERS_MASK   CSI_CR185_PIXEL_COUNTERS_MASK
#define CSI_CSICR185_PIXEL_COUNTERS_SHIFT   CSI_CR185_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR185_PIXEL_COUNTERS(x)   CSI_CR185_PIXEL_COUNTERS(x)
#define CSI_CSICR186_PIXEL_COUNTERS_MASK   CSI_CR186_PIXEL_COUNTERS_MASK
#define CSI_CSICR186_PIXEL_COUNTERS_SHIFT   CSI_CR186_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR186_PIXEL_COUNTERS(x)   CSI_CR186_PIXEL_COUNTERS(x)
#define CSI_CSICR187_PIXEL_COUNTERS_MASK   CSI_CR187_PIXEL_COUNTERS_MASK
#define CSI_CSICR187_PIXEL_COUNTERS_SHIFT   CSI_CR187_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR187_PIXEL_COUNTERS(x)   CSI_CR187_PIXEL_COUNTERS(x)
#define CSI_CSICR188_PIXEL_COUNTERS_MASK   CSI_CR188_PIXEL_COUNTERS_MASK
#define CSI_CSICR188_PIXEL_COUNTERS_SHIFT   CSI_CR188_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR188_PIXEL_COUNTERS(x)   CSI_CR188_PIXEL_COUNTERS(x)
#define CSI_CSICR189_PIXEL_COUNTERS_MASK   CSI_CR189_PIXEL_COUNTERS_MASK
#define CSI_CSICR189_PIXEL_COUNTERS_SHIFT   CSI_CR189_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR189_PIXEL_COUNTERS(x)   CSI_CR189_PIXEL_COUNTERS(x)
#define CSI_CSICR190_PIXEL_COUNTERS_MASK   CSI_CR190_PIXEL_COUNTERS_MASK
#define CSI_CSICR190_PIXEL_COUNTERS_SHIFT   CSI_CR190_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR190_PIXEL_COUNTERS(x)   CSI_CR190_PIXEL_COUNTERS(x)
#define CSI_CSICR191_PIXEL_COUNTERS_MASK   CSI_CR191_PIXEL_COUNTERS_MASK
#define CSI_CSICR191_PIXEL_COUNTERS_SHIFT   CSI_CR191_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR191_PIXEL_COUNTERS(x)   CSI_CR191_PIXEL_COUNTERS(x)
#define CSI_CSICR192_PIXEL_COUNTERS_MASK   CSI_CR192_PIXEL_COUNTERS_MASK
#define CSI_CSICR192_PIXEL_COUNTERS_SHIFT   CSI_CR192_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR192_PIXEL_COUNTERS(x)   CSI_CR192_PIXEL_COUNTERS(x)
#define CSI_CSICR193_PIXEL_COUNTERS_MASK   CSI_CR193_PIXEL_COUNTERS_MASK
#define CSI_CSICR193_PIXEL_COUNTERS_SHIFT   CSI_CR193_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR193_PIXEL_COUNTERS(x)   CSI_CR193_PIXEL_COUNTERS(x)
#define CSI_CSICR194_PIXEL_COUNTERS_MASK   CSI_CR194_PIXEL_COUNTERS_MASK
#define CSI_CSICR194_PIXEL_COUNTERS_SHIFT   CSI_CR194_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR194_PIXEL_COUNTERS(x)   CSI_CR194_PIXEL_COUNTERS(x)
#define CSI_CSICR195_PIXEL_COUNTERS_MASK   CSI_CR195_PIXEL_COUNTERS_MASK
#define CSI_CSICR195_PIXEL_COUNTERS_SHIFT   CSI_CR195_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR195_PIXEL_COUNTERS(x)   CSI_CR195_PIXEL_COUNTERS(x)
#define CSI_CSICR196_PIXEL_COUNTERS_MASK   CSI_CR196_PIXEL_COUNTERS_MASK
#define CSI_CSICR196_PIXEL_COUNTERS_SHIFT   CSI_CR196_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR196_PIXEL_COUNTERS(x)   CSI_CR196_PIXEL_COUNTERS(x)
#define CSI_CSICR197_PIXEL_COUNTERS_MASK   CSI_CR197_PIXEL_COUNTERS_MASK
#define CSI_CSICR197_PIXEL_COUNTERS_SHIFT   CSI_CR197_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR197_PIXEL_COUNTERS(x)   CSI_CR197_PIXEL_COUNTERS(x)
#define CSI_CSICR198_PIXEL_COUNTERS_MASK   CSI_CR198_PIXEL_COUNTERS_MASK
#define CSI_CSICR198_PIXEL_COUNTERS_SHIFT   CSI_CR198_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR198_PIXEL_COUNTERS(x)   CSI_CR198_PIXEL_COUNTERS(x)
#define CSI_CSICR199_PIXEL_COUNTERS_MASK   CSI_CR199_PIXEL_COUNTERS_MASK
#define CSI_CSICR199_PIXEL_COUNTERS_SHIFT   CSI_CR199_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR199_PIXEL_COUNTERS(x)   CSI_CR199_PIXEL_COUNTERS(x)
#define CSI_CSICR200_PIXEL_COUNTERS_MASK   CSI_CR200_PIXEL_COUNTERS_MASK
#define CSI_CSICR200_PIXEL_COUNTERS_SHIFT   CSI_CR200_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR200_PIXEL_COUNTERS(x)   CSI_CR200_PIXEL_COUNTERS(x)
#define CSI_CSICR201_PIXEL_COUNTERS_MASK   CSI_CR201_PIXEL_COUNTERS_MASK
#define CSI_CSICR201_PIXEL_COUNTERS_SHIFT   CSI_CR201_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR201_PIXEL_COUNTERS(x)   CSI_CR201_PIXEL_COUNTERS(x)
#define CSI_CSICR202_PIXEL_COUNTERS_MASK   CSI_CR202_PIXEL_COUNTERS_MASK
#define CSI_CSICR202_PIXEL_COUNTERS_SHIFT   CSI_CR202_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR202_PIXEL_COUNTERS(x)   CSI_CR202_PIXEL_COUNTERS(x)
#define CSI_CSICR203_PIXEL_COUNTERS_MASK   CSI_CR203_PIXEL_COUNTERS_MASK
#define CSI_CSICR203_PIXEL_COUNTERS_SHIFT   CSI_CR203_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR203_PIXEL_COUNTERS(x)   CSI_CR203_PIXEL_COUNTERS(x)
#define CSI_CSICR204_PIXEL_COUNTERS_MASK   CSI_CR204_PIXEL_COUNTERS_MASK
#define CSI_CSICR204_PIXEL_COUNTERS_SHIFT   CSI_CR204_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR204_PIXEL_COUNTERS(x)   CSI_CR204_PIXEL_COUNTERS(x)
#define CSI_CSICR205_PIXEL_COUNTERS_MASK   CSI_CR205_PIXEL_COUNTERS_MASK
#define CSI_CSICR205_PIXEL_COUNTERS_SHIFT   CSI_CR205_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR205_PIXEL_COUNTERS(x)   CSI_CR205_PIXEL_COUNTERS(x)
#define CSI_CSICR206_PIXEL_COUNTERS_MASK   CSI_CR206_PIXEL_COUNTERS_MASK
#define CSI_CSICR206_PIXEL_COUNTERS_SHIFT   CSI_CR206_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR206_PIXEL_COUNTERS(x)   CSI_CR206_PIXEL_COUNTERS(x)
#define CSI_CSICR207_PIXEL_COUNTERS_MASK   CSI_CR207_PIXEL_COUNTERS_MASK
#define CSI_CSICR207_PIXEL_COUNTERS_SHIFT   CSI_CR207_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR207_PIXEL_COUNTERS(x)   CSI_CR207_PIXEL_COUNTERS(x)
#define CSI_CSICR208_PIXEL_COUNTERS_MASK   CSI_CR208_PIXEL_COUNTERS_MASK
#define CSI_CSICR208_PIXEL_COUNTERS_SHIFT   CSI_CR208_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR208_PIXEL_COUNTERS(x)   CSI_CR208_PIXEL_COUNTERS(x)
#define CSI_CSICR209_PIXEL_COUNTERS_MASK   CSI_CR209_PIXEL_COUNTERS_MASK
#define CSI_CSICR209_PIXEL_COUNTERS_SHIFT   CSI_CR209_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR209_PIXEL_COUNTERS(x)   CSI_CR209_PIXEL_COUNTERS(x)
#define CSI_CSICR210_PIXEL_COUNTERS_MASK   CSI_CR210_PIXEL_COUNTERS_MASK
#define CSI_CSICR210_PIXEL_COUNTERS_SHIFT   CSI_CR210_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR210_PIXEL_COUNTERS(x)   CSI_CR210_PIXEL_COUNTERS(x)
#define CSI_CSICR211_PIXEL_COUNTERS_MASK   CSI_CR211_PIXEL_COUNTERS_MASK
#define CSI_CSICR211_PIXEL_COUNTERS_SHIFT   CSI_CR211_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR211_PIXEL_COUNTERS(x)   CSI_CR211_PIXEL_COUNTERS(x)
#define CSI_CSICR212_PIXEL_COUNTERS_MASK   CSI_CR212_PIXEL_COUNTERS_MASK
#define CSI_CSICR212_PIXEL_COUNTERS_SHIFT   CSI_CR212_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR212_PIXEL_COUNTERS(x)   CSI_CR212_PIXEL_COUNTERS(x)
#define CSI_CSICR213_PIXEL_COUNTERS_MASK   CSI_CR213_PIXEL_COUNTERS_MASK
#define CSI_CSICR213_PIXEL_COUNTERS_SHIFT   CSI_CR213_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR213_PIXEL_COUNTERS(x)   CSI_CR213_PIXEL_COUNTERS(x)
#define CSI_CSICR214_PIXEL_COUNTERS_MASK   CSI_CR214_PIXEL_COUNTERS_MASK
#define CSI_CSICR214_PIXEL_COUNTERS_SHIFT   CSI_CR214_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR214_PIXEL_COUNTERS(x)   CSI_CR214_PIXEL_COUNTERS(x)
#define CSI_CSICR215_PIXEL_COUNTERS_MASK   CSI_CR215_PIXEL_COUNTERS_MASK
#define CSI_CSICR215_PIXEL_COUNTERS_SHIFT   CSI_CR215_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR215_PIXEL_COUNTERS(x)   CSI_CR215_PIXEL_COUNTERS(x)
#define CSI_CSICR216_PIXEL_COUNTERS_MASK   CSI_CR216_PIXEL_COUNTERS_MASK
#define CSI_CSICR216_PIXEL_COUNTERS_SHIFT   CSI_CR216_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR216_PIXEL_COUNTERS(x)   CSI_CR216_PIXEL_COUNTERS(x)
#define CSI_CSICR217_PIXEL_COUNTERS_MASK   CSI_CR217_PIXEL_COUNTERS_MASK
#define CSI_CSICR217_PIXEL_COUNTERS_SHIFT   CSI_CR217_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR217_PIXEL_COUNTERS(x)   CSI_CR217_PIXEL_COUNTERS(x)
#define CSI_CSICR218_PIXEL_COUNTERS_MASK   CSI_CR218_PIXEL_COUNTERS_MASK
#define CSI_CSICR218_PIXEL_COUNTERS_SHIFT   CSI_CR218_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR218_PIXEL_COUNTERS(x)   CSI_CR218_PIXEL_COUNTERS(x)
#define CSI_CSICR219_PIXEL_COUNTERS_MASK   CSI_CR219_PIXEL_COUNTERS_MASK
#define CSI_CSICR219_PIXEL_COUNTERS_SHIFT   CSI_CR219_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR219_PIXEL_COUNTERS(x)   CSI_CR219_PIXEL_COUNTERS(x)
#define CSI_CSICR220_PIXEL_COUNTERS_MASK   CSI_CR220_PIXEL_COUNTERS_MASK
#define CSI_CSICR220_PIXEL_COUNTERS_SHIFT   CSI_CR220_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR220_PIXEL_COUNTERS(x)   CSI_CR220_PIXEL_COUNTERS(x)
#define CSI_CSICR221_PIXEL_COUNTERS_MASK   CSI_CR221_PIXEL_COUNTERS_MASK
#define CSI_CSICR221_PIXEL_COUNTERS_SHIFT   CSI_CR221_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR221_PIXEL_COUNTERS(x)   CSI_CR221_PIXEL_COUNTERS(x)
#define CSI_CSICR222_PIXEL_COUNTERS_MASK   CSI_CR222_PIXEL_COUNTERS_MASK
#define CSI_CSICR222_PIXEL_COUNTERS_SHIFT   CSI_CR222_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR222_PIXEL_COUNTERS(x)   CSI_CR222_PIXEL_COUNTERS(x)
#define CSI_CSICR223_PIXEL_COUNTERS_MASK   CSI_CR223_PIXEL_COUNTERS_MASK
#define CSI_CSICR223_PIXEL_COUNTERS_SHIFT   CSI_CR223_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR223_PIXEL_COUNTERS(x)   CSI_CR223_PIXEL_COUNTERS(x)
#define CSI_CSICR224_PIXEL_COUNTERS_MASK   CSI_CR224_PIXEL_COUNTERS_MASK
#define CSI_CSICR224_PIXEL_COUNTERS_SHIFT   CSI_CR224_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR224_PIXEL_COUNTERS(x)   CSI_CR224_PIXEL_COUNTERS(x)
#define CSI_CSICR225_PIXEL_COUNTERS_MASK   CSI_CR225_PIXEL_COUNTERS_MASK
#define CSI_CSICR225_PIXEL_COUNTERS_SHIFT   CSI_CR225_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR225_PIXEL_COUNTERS(x)   CSI_CR225_PIXEL_COUNTERS(x)
#define CSI_CSICR226_PIXEL_COUNTERS_MASK   CSI_CR226_PIXEL_COUNTERS_MASK
#define CSI_CSICR226_PIXEL_COUNTERS_SHIFT   CSI_CR226_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR226_PIXEL_COUNTERS(x)   CSI_CR226_PIXEL_COUNTERS(x)
#define CSI_CSICR227_PIXEL_COUNTERS_MASK   CSI_CR227_PIXEL_COUNTERS_MASK
#define CSI_CSICR227_PIXEL_COUNTERS_SHIFT   CSI_CR227_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR227_PIXEL_COUNTERS(x)   CSI_CR227_PIXEL_COUNTERS(x)
#define CSI_CSICR228_PIXEL_COUNTERS_MASK   CSI_CR228_PIXEL_COUNTERS_MASK
#define CSI_CSICR228_PIXEL_COUNTERS_SHIFT   CSI_CR228_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR228_PIXEL_COUNTERS(x)   CSI_CR228_PIXEL_COUNTERS(x)
#define CSI_CSICR229_PIXEL_COUNTERS_MASK   CSI_CR229_PIXEL_COUNTERS_MASK
#define CSI_CSICR229_PIXEL_COUNTERS_SHIFT   CSI_CR229_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR229_PIXEL_COUNTERS(x)   CSI_CR229_PIXEL_COUNTERS(x)
#define CSI_CSICR230_PIXEL_COUNTERS_MASK   CSI_CR230_PIXEL_COUNTERS_MASK
#define CSI_CSICR230_PIXEL_COUNTERS_SHIFT   CSI_CR230_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR230_PIXEL_COUNTERS(x)   CSI_CR230_PIXEL_COUNTERS(x)
#define CSI_CSICR231_PIXEL_COUNTERS_MASK   CSI_CR231_PIXEL_COUNTERS_MASK
#define CSI_CSICR231_PIXEL_COUNTERS_SHIFT   CSI_CR231_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR231_PIXEL_COUNTERS(x)   CSI_CR231_PIXEL_COUNTERS(x)
#define CSI_CSICR232_PIXEL_COUNTERS_MASK   CSI_CR232_PIXEL_COUNTERS_MASK
#define CSI_CSICR232_PIXEL_COUNTERS_SHIFT   CSI_CR232_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR232_PIXEL_COUNTERS(x)   CSI_CR232_PIXEL_COUNTERS(x)
#define CSI_CSICR233_PIXEL_COUNTERS_MASK   CSI_CR233_PIXEL_COUNTERS_MASK
#define CSI_CSICR233_PIXEL_COUNTERS_SHIFT   CSI_CR233_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR233_PIXEL_COUNTERS(x)   CSI_CR233_PIXEL_COUNTERS(x)
#define CSI_CSICR234_PIXEL_COUNTERS_MASK   CSI_CR234_PIXEL_COUNTERS_MASK
#define CSI_CSICR234_PIXEL_COUNTERS_SHIFT   CSI_CR234_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR234_PIXEL_COUNTERS(x)   CSI_CR234_PIXEL_COUNTERS(x)
#define CSI_CSICR235_PIXEL_COUNTERS_MASK   CSI_CR235_PIXEL_COUNTERS_MASK
#define CSI_CSICR235_PIXEL_COUNTERS_SHIFT   CSI_CR235_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR235_PIXEL_COUNTERS(x)   CSI_CR235_PIXEL_COUNTERS(x)
#define CSI_CSICR236_PIXEL_COUNTERS_MASK   CSI_CR236_PIXEL_COUNTERS_MASK
#define CSI_CSICR236_PIXEL_COUNTERS_SHIFT   CSI_CR236_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR236_PIXEL_COUNTERS(x)   CSI_CR236_PIXEL_COUNTERS(x)
#define CSI_CSICR237_PIXEL_COUNTERS_MASK   CSI_CR237_PIXEL_COUNTERS_MASK
#define CSI_CSICR237_PIXEL_COUNTERS_SHIFT   CSI_CR237_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR237_PIXEL_COUNTERS(x)   CSI_CR237_PIXEL_COUNTERS(x)
#define CSI_CSICR238_PIXEL_COUNTERS_MASK   CSI_CR238_PIXEL_COUNTERS_MASK
#define CSI_CSICR238_PIXEL_COUNTERS_SHIFT   CSI_CR238_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR238_PIXEL_COUNTERS(x)   CSI_CR238_PIXEL_COUNTERS(x)
#define CSI_CSICR239_PIXEL_COUNTERS_MASK   CSI_CR239_PIXEL_COUNTERS_MASK
#define CSI_CSICR239_PIXEL_COUNTERS_SHIFT   CSI_CR239_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR239_PIXEL_COUNTERS(x)   CSI_CR239_PIXEL_COUNTERS(x)
#define CSI_CSICR240_PIXEL_COUNTERS_MASK   CSI_CR240_PIXEL_COUNTERS_MASK
#define CSI_CSICR240_PIXEL_COUNTERS_SHIFT   CSI_CR240_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR240_PIXEL_COUNTERS(x)   CSI_CR240_PIXEL_COUNTERS(x)
#define CSI_CSICR241_PIXEL_COUNTERS_MASK   CSI_CR241_PIXEL_COUNTERS_MASK
#define CSI_CSICR241_PIXEL_COUNTERS_SHIFT   CSI_CR241_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR241_PIXEL_COUNTERS(x)   CSI_CR241_PIXEL_COUNTERS(x)
#define CSI_CSICR242_PIXEL_COUNTERS_MASK   CSI_CR242_PIXEL_COUNTERS_MASK
#define CSI_CSICR242_PIXEL_COUNTERS_SHIFT   CSI_CR242_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR242_PIXEL_COUNTERS(x)   CSI_CR242_PIXEL_COUNTERS(x)
#define CSI_CSICR243_PIXEL_COUNTERS_MASK   CSI_CR243_PIXEL_COUNTERS_MASK
#define CSI_CSICR243_PIXEL_COUNTERS_SHIFT   CSI_CR243_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR243_PIXEL_COUNTERS(x)   CSI_CR243_PIXEL_COUNTERS(x)
#define CSI_CSICR244_PIXEL_COUNTERS_MASK   CSI_CR244_PIXEL_COUNTERS_MASK
#define CSI_CSICR244_PIXEL_COUNTERS_SHIFT   CSI_CR244_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR244_PIXEL_COUNTERS(x)   CSI_CR244_PIXEL_COUNTERS(x)
#define CSI_CSICR245_PIXEL_COUNTERS_MASK   CSI_CR245_PIXEL_COUNTERS_MASK
#define CSI_CSICR245_PIXEL_COUNTERS_SHIFT   CSI_CR245_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR245_PIXEL_COUNTERS(x)   CSI_CR245_PIXEL_COUNTERS(x)
#define CSI_CSICR246_PIXEL_COUNTERS_MASK   CSI_CR246_PIXEL_COUNTERS_MASK
#define CSI_CSICR246_PIXEL_COUNTERS_SHIFT   CSI_CR246_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR246_PIXEL_COUNTERS(x)   CSI_CR246_PIXEL_COUNTERS(x)
#define CSI_CSICR247_PIXEL_COUNTERS_MASK   CSI_CR247_PIXEL_COUNTERS_MASK
#define CSI_CSICR247_PIXEL_COUNTERS_SHIFT   CSI_CR247_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR247_PIXEL_COUNTERS(x)   CSI_CR247_PIXEL_COUNTERS(x)
#define CSI_CSICR248_PIXEL_COUNTERS_MASK   CSI_CR248_PIXEL_COUNTERS_MASK
#define CSI_CSICR248_PIXEL_COUNTERS_SHIFT   CSI_CR248_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR248_PIXEL_COUNTERS(x)   CSI_CR248_PIXEL_COUNTERS(x)
#define CSI_CSICR249_PIXEL_COUNTERS_MASK   CSI_CR249_PIXEL_COUNTERS_MASK
#define CSI_CSICR249_PIXEL_COUNTERS_SHIFT   CSI_CR249_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR249_PIXEL_COUNTERS(x)   CSI_CR249_PIXEL_COUNTERS(x)
#define CSI_CSICR250_PIXEL_COUNTERS_MASK   CSI_CR250_PIXEL_COUNTERS_MASK
#define CSI_CSICR250_PIXEL_COUNTERS_SHIFT   CSI_CR250_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR250_PIXEL_COUNTERS(x)   CSI_CR250_PIXEL_COUNTERS(x)
#define CSI_CSICR251_PIXEL_COUNTERS_MASK   CSI_CR251_PIXEL_COUNTERS_MASK
#define CSI_CSICR251_PIXEL_COUNTERS_SHIFT   CSI_CR251_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR251_PIXEL_COUNTERS(x)   CSI_CR251_PIXEL_COUNTERS(x)
#define CSI_CSICR252_PIXEL_COUNTERS_MASK   CSI_CR252_PIXEL_COUNTERS_MASK
#define CSI_CSICR252_PIXEL_COUNTERS_SHIFT   CSI_CR252_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR252_PIXEL_COUNTERS(x)   CSI_CR252_PIXEL_COUNTERS(x)
#define CSI_CSICR253_PIXEL_COUNTERS_MASK   CSI_CR253_PIXEL_COUNTERS_MASK
#define CSI_CSICR253_PIXEL_COUNTERS_SHIFT   CSI_CR253_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR253_PIXEL_COUNTERS(x)   CSI_CR253_PIXEL_COUNTERS(x)
#define CSI_CSICR254_PIXEL_COUNTERS_MASK   CSI_CR254_PIXEL_COUNTERS_MASK
#define CSI_CSICR254_PIXEL_COUNTERS_SHIFT   CSI_CR254_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR254_PIXEL_COUNTERS(x)   CSI_CR254_PIXEL_COUNTERS(x)
#define CSI_CSICR255_PIXEL_COUNTERS_MASK   CSI_CR255_PIXEL_COUNTERS_MASK
#define CSI_CSICR255_PIXEL_COUNTERS_SHIFT   CSI_CR255_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR255_PIXEL_COUNTERS(x)   CSI_CR255_PIXEL_COUNTERS(x)
#define CSI_CSICR256_PIXEL_COUNTERS_MASK   CSI_CR256_PIXEL_COUNTERS_MASK
#define CSI_CSICR256_PIXEL_COUNTERS_SHIFT   CSI_CR256_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR256_PIXEL_COUNTERS(x)   CSI_CR256_PIXEL_COUNTERS(x)
#define CSI_CSICR257_PIXEL_COUNTERS_MASK   CSI_CR257_PIXEL_COUNTERS_MASK
#define CSI_CSICR257_PIXEL_COUNTERS_SHIFT   CSI_CR257_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR257_PIXEL_COUNTERS(x)   CSI_CR257_PIXEL_COUNTERS(x)
#define CSI_CSICR258_PIXEL_COUNTERS_MASK   CSI_CR258_PIXEL_COUNTERS_MASK
#define CSI_CSICR258_PIXEL_COUNTERS_SHIFT   CSI_CR258_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR258_PIXEL_COUNTERS(x)   CSI_CR258_PIXEL_COUNTERS(x)
#define CSI_CSICR259_PIXEL_COUNTERS_MASK   CSI_CR259_PIXEL_COUNTERS_MASK
#define CSI_CSICR259_PIXEL_COUNTERS_SHIFT   CSI_CR259_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR259_PIXEL_COUNTERS(x)   CSI_CR259_PIXEL_COUNTERS(x)
#define CSI_CSICR260_PIXEL_COUNTERS_MASK   CSI_CR260_PIXEL_COUNTERS_MASK
#define CSI_CSICR260_PIXEL_COUNTERS_SHIFT   CSI_CR260_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR260_PIXEL_COUNTERS(x)   CSI_CR260_PIXEL_COUNTERS(x)
#define CSI_CSICR261_PIXEL_COUNTERS_MASK   CSI_CR261_PIXEL_COUNTERS_MASK
#define CSI_CSICR261_PIXEL_COUNTERS_SHIFT   CSI_CR261_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR261_PIXEL_COUNTERS(x)   CSI_CR261_PIXEL_COUNTERS(x)
#define CSI_CSICR262_PIXEL_COUNTERS_MASK   CSI_CR262_PIXEL_COUNTERS_MASK
#define CSI_CSICR262_PIXEL_COUNTERS_SHIFT   CSI_CR262_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR262_PIXEL_COUNTERS(x)   CSI_CR262_PIXEL_COUNTERS(x)
#define CSI_CSICR263_PIXEL_COUNTERS_MASK   CSI_CR263_PIXEL_COUNTERS_MASK
#define CSI_CSICR263_PIXEL_COUNTERS_SHIFT   CSI_CR263_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR263_PIXEL_COUNTERS(x)   CSI_CR263_PIXEL_COUNTERS(x)
#define CSI_CSICR264_PIXEL_COUNTERS_MASK   CSI_CR264_PIXEL_COUNTERS_MASK
#define CSI_CSICR264_PIXEL_COUNTERS_SHIFT   CSI_CR264_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR264_PIXEL_COUNTERS(x)   CSI_CR264_PIXEL_COUNTERS(x)
#define CSI_CSICR265_PIXEL_COUNTERS_MASK   CSI_CR265_PIXEL_COUNTERS_MASK
#define CSI_CSICR265_PIXEL_COUNTERS_SHIFT   CSI_CR265_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR265_PIXEL_COUNTERS(x)   CSI_CR265_PIXEL_COUNTERS(x)
#define CSI_CSICR266_PIXEL_COUNTERS_MASK   CSI_CR266_PIXEL_COUNTERS_MASK
#define CSI_CSICR266_PIXEL_COUNTERS_SHIFT   CSI_CR266_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR266_PIXEL_COUNTERS(x)   CSI_CR266_PIXEL_COUNTERS(x)
#define CSI_CSICR267_PIXEL_COUNTERS_MASK   CSI_CR267_PIXEL_COUNTERS_MASK
#define CSI_CSICR267_PIXEL_COUNTERS_SHIFT   CSI_CR267_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR267_PIXEL_COUNTERS(x)   CSI_CR267_PIXEL_COUNTERS(x)
#define CSI_CSICR268_PIXEL_COUNTERS_MASK   CSI_CR268_PIXEL_COUNTERS_MASK
#define CSI_CSICR268_PIXEL_COUNTERS_SHIFT   CSI_CR268_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR268_PIXEL_COUNTERS(x)   CSI_CR268_PIXEL_COUNTERS(x)
#define CSI_CSICR269_PIXEL_COUNTERS_MASK   CSI_CR269_PIXEL_COUNTERS_MASK
#define CSI_CSICR269_PIXEL_COUNTERS_SHIFT   CSI_CR269_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR269_PIXEL_COUNTERS(x)   CSI_CR269_PIXEL_COUNTERS(x)
#define CSI_CSICR270_PIXEL_COUNTERS_MASK   CSI_CR270_PIXEL_COUNTERS_MASK
#define CSI_CSICR270_PIXEL_COUNTERS_SHIFT   CSI_CR270_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR270_PIXEL_COUNTERS(x)   CSI_CR270_PIXEL_COUNTERS(x)
#define CSI_CSICR271_PIXEL_COUNTERS_MASK   CSI_CR271_PIXEL_COUNTERS_MASK
#define CSI_CSICR271_PIXEL_COUNTERS_SHIFT   CSI_CR271_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR271_PIXEL_COUNTERS(x)   CSI_CR271_PIXEL_COUNTERS(x)
#define CSI_CSICR272_PIXEL_COUNTERS_MASK   CSI_CR272_PIXEL_COUNTERS_MASK
#define CSI_CSICR272_PIXEL_COUNTERS_SHIFT   CSI_CR272_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR272_PIXEL_COUNTERS(x)   CSI_CR272_PIXEL_COUNTERS(x)
#define CSI_CSICR273_PIXEL_COUNTERS_MASK   CSI_CR273_PIXEL_COUNTERS_MASK
#define CSI_CSICR273_PIXEL_COUNTERS_SHIFT   CSI_CR273_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR273_PIXEL_COUNTERS(x)   CSI_CR273_PIXEL_COUNTERS(x)
#define CSI_CSICR274_PIXEL_COUNTERS_MASK   CSI_CR274_PIXEL_COUNTERS_MASK
#define CSI_CSICR274_PIXEL_COUNTERS_SHIFT   CSI_CR274_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR274_PIXEL_COUNTERS(x)   CSI_CR274_PIXEL_COUNTERS(x)
#define CSI_CSICR275_PIXEL_COUNTERS_MASK   CSI_CR275_PIXEL_COUNTERS_MASK
#define CSI_CSICR275_PIXEL_COUNTERS_SHIFT   CSI_CR275_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR275_PIXEL_COUNTERS(x)   CSI_CR275_PIXEL_COUNTERS(x)
#define CSI_CSICR276_PIXEL_COUNTERS_MASK   CSI_CR276_PIXEL_COUNTERS_MASK
#define CSI_CSICR276_PIXEL_COUNTERS_SHIFT   CSI_CR276_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR276_PIXEL_COUNTERS(x)   CSI_CR276_PIXEL_COUNTERS(x)
#define CSI_BASE   (0x40800000u)
#define CSI   ((CSI_Type *)CSI_BASE)
#define CSI_BASE_ADDRS   { CSI_BASE }
#define CSI_BASE_PTRS   { CSI }
#define CSI_IRQS   { CSI_IRQn }
#define CSI_CSICR1_PIXEL_BIT_MASK   CSI_CR1_PIXEL_BIT_MASK
#define CSI_CSICR1_PIXEL_BIT_SHIFT   CSI_CR1_PIXEL_BIT_SHIFT
#define CSI_CSICR1_PIXEL_BIT(x)   CSI_CR1_PIXEL_BIT(x)
#define CSI_CSICR1_REDGE_MASK   CSI_CR1_REDGE_MASK
#define CSI_CSICR1_REDGE_SHIFT   CSI_CR1_REDGE_SHIFT
#define CSI_CSICR1_REDGE(x)   CSI_CR1_REDGE(x)
#define CSI_CSICR1_INV_PCLK_MASK   CSI_CR1_INV_PCLK_MASK
#define CSI_CSICR1_INV_PCLK_SHIFT   CSI_CR1_INV_PCLK_SHIFT
#define CSI_CSICR1_INV_PCLK(x)   CSI_CR1_INV_PCLK(x)
#define CSI_CSICR1_INV_DATA_MASK   CSI_CR1_INV_DATA_MASK
#define CSI_CSICR1_INV_DATA_SHIFT   CSI_CR1_INV_DATA_SHIFT
#define CSI_CSICR1_INV_DATA(x)   CSI_CR1_INV_DATA(x)
#define CSI_CSICR1_GCLK_MODE_MASK   CSI_CR1_GCLK_MODE_MASK
#define CSI_CSICR1_GCLK_MODE_SHIFT   CSI_CR1_GCLK_MODE_SHIFT
#define CSI_CSICR1_GCLK_MODE(x)   CSI_CR1_GCLK_MODE(x)
#define CSI_CSICR1_CLR_RXFIFO_MASK   CSI_CR1_CLR_RXFIFO_MASK
#define CSI_CSICR1_CLR_RXFIFO_SHIFT   CSI_CR1_CLR_RXFIFO_SHIFT
#define CSI_CSICR1_CLR_RXFIFO(x)   CSI_CR1_CLR_RXFIFO(x)
#define CSI_CSICR1_CLR_STATFIFO_MASK   CSI_CR1_CLR_STATFIFO_MASK
#define CSI_CSICR1_CLR_STATFIFO_SHIFT   CSI_CR1_CLR_STATFIFO_SHIFT
#define CSI_CSICR1_CLR_STATFIFO(x)   CSI_CR1_CLR_STATFIFO(x)
#define CSI_CSICR1_PACK_DIR_MASK   CSI_CR1_PACK_DIR_MASK
#define CSI_CSICR1_PACK_DIR_SHIFT   CSI_CR1_PACK_DIR_SHIFT
#define CSI_CSICR1_PACK_DIR(x)   CSI_CR1_PACK_DIR(x)
#define CSI_CSICR1_FCC_MASK   CSI_CR1_FCC_MASK
#define CSI_CSICR1_FCC_SHIFT   CSI_CR1_FCC_SHIFT
#define CSI_CSICR1_FCC(x)   CSI_CR1_FCC(x)
#define CSI_CSICR1_CCIR_EN_MASK   CSI_CR1_CCIR_EN_MASK
#define CSI_CSICR1_CCIR_EN_SHIFT   CSI_CR1_CCIR_EN_SHIFT
#define CSI_CSICR1_CCIR_EN(x)   CSI_CR1_CCIR_EN(x)
#define CSI_CSICR1_HSYNC_POL_MASK   CSI_CR1_HSYNC_POL_MASK
#define CSI_CSICR1_HSYNC_POL_SHIFT   CSI_CR1_HSYNC_POL_SHIFT
#define CSI_CSICR1_HSYNC_POL(x)   CSI_CR1_HSYNC_POL(x)
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE_MASK   CSI_CR1_HISTOGRAM_CALC_DONE_IE_MASK
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE_SHIFT   CSI_CR1_HISTOGRAM_CALC_DONE_IE_SHIFT
#define CSI_CSICR1_HISTOGRAM_CALC_DONE_IE(x)   CSI_CR1_HISTOGRAM_CALC_DONE_IE(x)
#define CSI_CSICR1_SOF_INTEN_MASK   CSI_CR1_SOF_INTEN_MASK
#define CSI_CSICR1_SOF_INTEN_SHIFT   CSI_CR1_SOF_INTEN_SHIFT
#define CSI_CSICR1_SOF_INTEN(x)   CSI_CR1_SOF_INTEN(x)
#define CSI_CSICR1_SOF_POL_MASK   CSI_CR1_SOF_POL_MASK
#define CSI_CSICR1_SOF_POL_SHIFT   CSI_CR1_SOF_POL_SHIFT
#define CSI_CSICR1_SOF_POL(x)   CSI_CR1_SOF_POL(x)
#define CSI_CSICR1_RXFF_INTEN_MASK   CSI_CR1_RXFF_INTEN_MASK
#define CSI_CSICR1_RXFF_INTEN_SHIFT   CSI_CR1_RXFF_INTEN_SHIFT
#define CSI_CSICR1_RXFF_INTEN(x)   CSI_CR1_RXFF_INTEN(x)
#define CSI_CSICR1_FB1_DMA_DONE_INTEN_MASK   CSI_CR1_FB1_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_FB1_DMA_DONE_INTEN_SHIFT   CSI_CR1_FB1_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_FB1_DMA_DONE_INTEN(x)   CSI_CR1_FB1_DMA_DONE_INTEN(x)
#define CSI_CSICR1_FB2_DMA_DONE_INTEN_MASK   CSI_CR1_FB2_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_FB2_DMA_DONE_INTEN_SHIFT   CSI_CR1_FB2_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_FB2_DMA_DONE_INTEN(x)   CSI_CR1_FB2_DMA_DONE_INTEN(x)
#define CSI_CSICR1_STATFF_INTEN_MASK   CSI_CR1_STATFF_INTEN_MASK
#define CSI_CSICR1_STATFF_INTEN_SHIFT   CSI_CR1_STATFF_INTEN_SHIFT
#define CSI_CSICR1_STATFF_INTEN(x)   CSI_CR1_STATFF_INTEN(x)
#define CSI_CSICR1_SFF_DMA_DONE_INTEN_MASK   CSI_CR1_SFF_DMA_DONE_INTEN_MASK
#define CSI_CSICR1_SFF_DMA_DONE_INTEN_SHIFT   CSI_CR1_SFF_DMA_DONE_INTEN_SHIFT
#define CSI_CSICR1_SFF_DMA_DONE_INTEN(x)   CSI_CR1_SFF_DMA_DONE_INTEN(x)
#define CSI_CSICR1_RF_OR_INTEN_MASK   CSI_CR1_RF_OR_INTEN_MASK
#define CSI_CSICR1_RF_OR_INTEN_SHIFT   CSI_CR1_RF_OR_INTEN_SHIFT
#define CSI_CSICR1_RF_OR_INTEN(x)   CSI_CR1_RF_OR_INTEN(x)
#define CSI_CSICR1_SF_OR_INTEN_MASK   CSI_CR1_SF_OR_INTEN_MASK
#define CSI_CSICR1_SF_OR_INTEN_SHIFT   CSI_CR1_SF_OR_INTEN_SHIFT
#define CSI_CSICR1_SF_OR_INTEN(x)   CSI_CR1_SF_OR_INTEN(x)
#define CSI_CSICR1_COF_INT_EN_MASK   CSI_CR1_COF_INT_EN_MASK
#define CSI_CSICR1_COF_INT_EN_SHIFT   CSI_CR1_COF_INT_EN_SHIFT
#define CSI_CSICR1_COF_INT_EN(x)   CSI_CR1_COF_INT_EN(x)
#define CSI_CSICR1_VIDEO_MODE_MASK   CSI_CR1_VIDEO_MODE_MASK
#define CSI_CSICR1_VIDEO_MODE_SHIFT   CSI_CR1_VIDEO_MODE_SHIFT
#define CSI_CSICR1_VIDEO_MODE(x)   CSI_CR1_VIDEO_MODE(x)
#define CSI_CSICR1_EOF_INT_EN_MASK   CSI_CR1_EOF_INT_EN_MASK
#define CSI_CSICR1_EOF_INT_EN_SHIFT   CSI_CR1_EOF_INT_EN_SHIFT
#define CSI_CSICR1_EOF_INT_EN(x)   CSI_CR1_EOF_INT_EN(x)
#define CSI_CSICR1_EXT_VSYNC_MASK   CSI_CR1_EXT_VSYNC_MASK
#define CSI_CSICR1_EXT_VSYNC_SHIFT   CSI_CR1_EXT_VSYNC_SHIFT
#define CSI_CSICR1_EXT_VSYNC(x)   CSI_CR1_EXT_VSYNC(x)
#define CSI_CSICR1_SWAP16_EN_MASK   CSI_CR1_SWAP16_EN_MASK
#define CSI_CSICR1_SWAP16_EN_SHIFT   CSI_CR1_SWAP16_EN_SHIFT
#define CSI_CSICR1_SWAP16_EN(x)   CSI_CR1_SWAP16_EN(x)
#define CSI_CSICR2_HSC_MASK   CSI_CR2_HSC_MASK
#define CSI_CSICR2_HSC_SHIFT   CSI_CR2_HSC_SHIFT
#define CSI_CSICR2_HSC(x)   CSI_CR2_HSC(x)
#define CSI_CSICR2_VSC_MASK   CSI_CR2_VSC_MASK
#define CSI_CSICR2_VSC_SHIFT   CSI_CR2_VSC_SHIFT
#define CSI_CSICR2_VSC(x)   CSI_CR2_VSC(x)
#define CSI_CSICR2_LVRM_MASK   CSI_CR2_LVRM_MASK
#define CSI_CSICR2_LVRM_SHIFT   CSI_CR2_LVRM_SHIFT
#define CSI_CSICR2_LVRM(x)   CSI_CR2_LVRM(x)
#define CSI_CSICR2_BTS_MASK   CSI_CR2_BTS_MASK
#define CSI_CSICR2_BTS_SHIFT   CSI_CR2_BTS_SHIFT
#define CSI_CSICR2_BTS(x)   CSI_CR2_BTS(x)
#define CSI_CSICR2_SCE_MASK   CSI_CR2_SCE_MASK
#define CSI_CSICR2_SCE_SHIFT   CSI_CR2_SCE_SHIFT
#define CSI_CSICR2_SCE(x)   CSI_CR2_SCE(x)
#define CSI_CSICR2_AFS_MASK   CSI_CR2_AFS_MASK
#define CSI_CSICR2_AFS_SHIFT   CSI_CR2_AFS_SHIFT
#define CSI_CSICR2_AFS(x)   CSI_CR2_AFS(x)
#define CSI_CSICR2_DRM_MASK   CSI_CR2_DRM_MASK
#define CSI_CSICR2_DRM_SHIFT   CSI_CR2_DRM_SHIFT
#define CSI_CSICR2_DRM(x)   CSI_CR2_DRM(x)
#define CSI_CSICR2_DMA_BURST_TYPE_SFF_MASK   CSI_CR2_DMA_BURST_TYPE_SFF_MASK
#define CSI_CSICR2_DMA_BURST_TYPE_SFF_SHIFT   CSI_CR2_DMA_BURST_TYPE_SFF_SHIFT
#define CSI_CSICR2_DMA_BURST_TYPE_SFF(x)   CSI_CR2_DMA_BURST_TYPE_SFF(x)
#define CSI_CSICR2_DMA_BURST_TYPE_RFF_MASK   CSI_CR2_DMA_BURST_TYPE_RFF_MASK
#define CSI_CSICR2_DMA_BURST_TYPE_RFF_SHIFT   CSI_CR2_DMA_BURST_TYPE_RFF_SHIFT
#define CSI_CSICR2_DMA_BURST_TYPE_RFF(x)   CSI_CR2_DMA_BURST_TYPE_RFF(x)
#define CSI_CSICR3_ECC_AUTO_EN_MASK   CSI_CR3_ECC_AUTO_EN_MASK
#define CSI_CSICR3_ECC_AUTO_EN_SHIFT   CSI_CR3_ECC_AUTO_EN_SHIFT
#define CSI_CSICR3_ECC_AUTO_EN(x)   CSI_CR3_ECC_AUTO_EN(x)
#define CSI_CSICR3_ECC_INT_EN_MASK   CSI_CR3_ECC_INT_EN_MASK
#define CSI_CSICR3_ECC_INT_EN_SHIFT   CSI_CR3_ECC_INT_EN_SHIFT
#define CSI_CSICR3_ECC_INT_EN(x)   CSI_CR3_ECC_INT_EN(x)
#define CSI_CSICR3_ZERO_PACK_EN_MASK   CSI_CR3_ZERO_PACK_EN_MASK
#define CSI_CSICR3_ZERO_PACK_EN_SHIFT   CSI_CR3_ZERO_PACK_EN_SHIFT
#define CSI_CSICR3_ZERO_PACK_EN(x)   CSI_CR3_ZERO_PACK_EN(x)
#define CSI_CSICR3_SENSOR_16BITS_MASK   CSI_CR3_SENSOR_16BITS_MASK
#define CSI_CSICR3_SENSOR_16BITS_SHIFT   CSI_CR3_SENSOR_16BITS_SHIFT
#define CSI_CSICR3_SENSOR_16BITS(x)   CSI_CR3_SENSOR_16BITS(x)
#define CSI_CSICR3_RxFF_LEVEL_MASK   CSI_CR3_RxFF_LEVEL_MASK
#define CSI_CSICR3_RxFF_LEVEL_SHIFT   CSI_CR3_RxFF_LEVEL_SHIFT
#define CSI_CSICR3_RxFF_LEVEL(x)   CSI_CR3_RxFF_LEVEL(x)
#define CSI_CSICR3_HRESP_ERR_EN_MASK   CSI_CR3_HRESP_ERR_EN_MASK
#define CSI_CSICR3_HRESP_ERR_EN_SHIFT   CSI_CR3_HRESP_ERR_EN_SHIFT
#define CSI_CSICR3_HRESP_ERR_EN(x)   CSI_CR3_HRESP_ERR_EN(x)
#define CSI_CSICR3_STATFF_LEVEL_MASK   CSI_CR3_STATFF_LEVEL_MASK
#define CSI_CSICR3_STATFF_LEVEL_SHIFT   CSI_CR3_STATFF_LEVEL_SHIFT
#define CSI_CSICR3_STATFF_LEVEL(x)   CSI_CR3_STATFF_LEVEL(x)
#define CSI_CSICR3_DMA_REQ_EN_SFF_MASK   CSI_CR3_DMA_REQ_EN_SFF_MASK
#define CSI_CSICR3_DMA_REQ_EN_SFF_SHIFT   CSI_CR3_DMA_REQ_EN_SFF_SHIFT
#define CSI_CSICR3_DMA_REQ_EN_SFF(x)   CSI_CR3_DMA_REQ_EN_SFF(x)
#define CSI_CSICR3_DMA_REQ_EN_RFF_MASK   CSI_CR3_DMA_REQ_EN_RFF_MASK
#define CSI_CSICR3_DMA_REQ_EN_RFF_SHIFT   CSI_CR3_DMA_REQ_EN_RFF_SHIFT
#define CSI_CSICR3_DMA_REQ_EN_RFF(x)   CSI_CR3_DMA_REQ_EN_RFF(x)
#define CSI_CSICR3_DMA_REFLASH_SFF_MASK   CSI_CR3_DMA_REFLASH_SFF_MASK
#define CSI_CSICR3_DMA_REFLASH_SFF_SHIFT   CSI_CR3_DMA_REFLASH_SFF_SHIFT
#define CSI_CSICR3_DMA_REFLASH_SFF(x)   CSI_CR3_DMA_REFLASH_SFF(x)
#define CSI_CSICR3_DMA_REFLASH_RFF_MASK   CSI_CR3_DMA_REFLASH_RFF_MASK
#define CSI_CSICR3_DMA_REFLASH_RFF_SHIFT   CSI_CR3_DMA_REFLASH_RFF_SHIFT
#define CSI_CSICR3_DMA_REFLASH_RFF(x)   CSI_CR3_DMA_REFLASH_RFF(x)
#define CSI_CSICR3_FRMCNT_RST_MASK   CSI_CR3_FRMCNT_RST_MASK
#define CSI_CSICR3_FRMCNT_RST_SHIFT   CSI_CR3_FRMCNT_RST_SHIFT
#define CSI_CSICR3_FRMCNT_RST(x)   CSI_CR3_FRMCNT_RST(x)
#define CSI_CSICR3_FRMCNT_MASK   CSI_CR3_FRMCNT_MASK
#define CSI_CSICR3_FRMCNT_SHIFT   CSI_CR3_FRMCNT_SHIFT
#define CSI_CSICR3_FRMCNT(x)   CSI_CR3_FRMCNT(x)
#define CSI_CSISTATFIFO_STAT_MASK   CSI_STATFIFO_STAT_MASK
#define CSI_CSISTATFIFO_STAT_SHIFT   CSI_STATFIFO_STAT_SHIFT
#define CSI_CSISTATFIFO_STAT(x)   CSI_STATFIFO_STAT(x)
#define CSI_CSIRFIFO_IMAGE_MASK   CSI_RFIFO_IMAGE_MASK
#define CSI_CSIRFIFO_IMAGE_SHIFT   CSI_RFIFO_IMAGE_SHIFT
#define CSI_CSIRFIFO_IMAGE(x)   CSI_RFIFO_IMAGE(x)
#define CSI_CSIRXCNT_RXCNT_MASK   CSI_RXCNT_RXCNT_MASK
#define CSI_CSIRXCNT_RXCNT_SHIFT   CSI_RXCNT_RXCNT_SHIFT
#define CSI_CSIRXCNT_RXCNT(x)   CSI_RXCNT_RXCNT(x)
#define CSI_CSISR_DRDY_MASK   CSI_SR_DRDY_MASK
#define CSI_CSISR_DRDY_SHIFT   CSI_SR_DRDY_SHIFT
#define CSI_CSISR_DRDY(x)   CSI_SR_DRDY(x)
#define CSI_CSISR_ECC_INT_MASK   CSI_SR_ECC_INT_MASK
#define CSI_CSISR_ECC_INT_SHIFT   CSI_SR_ECC_INT_SHIFT
#define CSI_CSISR_ECC_INT(x)   CSI_SR_ECC_INT(x)
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT_MASK   CSI_SR_HISTOGRAM_CALC_DONE_INT_MASK
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT_SHIFT   CSI_SR_HISTOGRAM_CALC_DONE_INT_SHIFT
#define CSI_CSISR_HISTOGRAM_CALC_DONE_INT(x)   CSI_SR_HISTOGRAM_CALC_DONE_INT(x)
#define CSI_CSISR_HRESP_ERR_INT_MASK   CSI_SR_HRESP_ERR_INT_MASK
#define CSI_CSISR_HRESP_ERR_INT_SHIFT   CSI_SR_HRESP_ERR_INT_SHIFT
#define CSI_CSISR_HRESP_ERR_INT(x)   CSI_SR_HRESP_ERR_INT(x)
#define CSI_CSISR_COF_INT_MASK   CSI_SR_COF_INT_MASK
#define CSI_CSISR_COF_INT_SHIFT   CSI_SR_COF_INT_SHIFT
#define CSI_CSISR_COF_INT(x)   CSI_SR_COF_INT(x)
#define CSI_CSISR_F1_INT_MASK   CSI_SR_F1_INT_MASK
#define CSI_CSISR_F1_INT_SHIFT   CSI_SR_F1_INT_SHIFT
#define CSI_CSISR_F1_INT(x)   CSI_SR_F1_INT(x)
#define CSI_CSISR_F2_INT_MASK   CSI_SR_F2_INT_MASK
#define CSI_CSISR_F2_INT_SHIFT   CSI_SR_F2_INT_SHIFT
#define CSI_CSISR_F2_INT(x)   CSI_SR_F2_INT(x)
#define CSI_CSISR_SOF_INT_MASK   CSI_SR_SOF_INT_MASK
#define CSI_CSISR_SOF_INT_SHIFT   CSI_SR_SOF_INT_SHIFT
#define CSI_CSISR_SOF_INT(x)   CSI_SR_SOF_INT(x)
#define CSI_CSISR_EOF_INT_MASK   CSI_SR_EOF_INT_MASK
#define CSI_CSISR_EOF_INT_SHIFT   CSI_SR_EOF_INT_SHIFT
#define CSI_CSISR_EOF_INT(x)   CSI_SR_EOF_INT(x)
#define CSI_CSISR_RxFF_INT_MASK   CSI_SR_RxFF_INT_MASK
#define CSI_CSISR_RxFF_INT_SHIFT   CSI_SR_RxFF_INT_SHIFT
#define CSI_CSISR_RxFF_INT(x)   CSI_SR_RxFF_INT(x)
#define CSI_CSISR_DMA_TSF_DONE_FB1_MASK   CSI_SR_DMA_TSF_DONE_FB1_MASK
#define CSI_CSISR_DMA_TSF_DONE_FB1_SHIFT   CSI_SR_DMA_TSF_DONE_FB1_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_FB1(x)   CSI_SR_DMA_TSF_DONE_FB1(x)
#define CSI_CSISR_DMA_TSF_DONE_FB2_MASK   CSI_SR_DMA_TSF_DONE_FB2_MASK
#define CSI_CSISR_DMA_TSF_DONE_FB2_SHIFT   CSI_SR_DMA_TSF_DONE_FB2_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_FB2(x)   CSI_SR_DMA_TSF_DONE_FB2(x)
#define CSI_CSISR_STATFF_INT_MASK   CSI_SR_STATFF_INT_MASK
#define CSI_CSISR_STATFF_INT_SHIFT   CSI_SR_STATFF_INT_SHIFT
#define CSI_CSISR_STATFF_INT(x)   CSI_SR_STATFF_INT(x)
#define CSI_CSISR_DMA_TSF_DONE_SFF_MASK   CSI_SR_DMA_TSF_DONE_SFF_MASK
#define CSI_CSISR_DMA_TSF_DONE_SFF_SHIFT   CSI_SR_DMA_TSF_DONE_SFF_SHIFT
#define CSI_CSISR_DMA_TSF_DONE_SFF(x)   CSI_SR_DMA_TSF_DONE_SFF(x)
#define CSI_CSISR_RF_OR_INT_MASK   CSI_SR_RF_OR_INT_MASK
#define CSI_CSISR_RF_OR_INT_SHIFT   CSI_SR_RF_OR_INT_SHIFT
#define CSI_CSISR_RF_OR_INT(x)   CSI_SR_RF_OR_INT(x)
#define CSI_CSISR_SF_OR_INT_MASK   CSI_SR_SF_OR_INT_MASK
#define CSI_CSISR_SF_OR_INT_SHIFT   CSI_SR_SF_OR_INT_SHIFT
#define CSI_CSISR_SF_OR_INT(x)   CSI_SR_SF_OR_INT(x)
#define CSI_CSISR_DMA_FIELD1_DONE_MASK   CSI_SR_DMA_FIELD1_DONE_MASK
#define CSI_CSISR_DMA_FIELD1_DONE_SHIFT   CSI_SR_DMA_FIELD1_DONE_SHIFT
#define CSI_CSISR_DMA_FIELD1_DONE(x)   CSI_SR_DMA_FIELD1_DONE(x)
#define CSI_CSISR_DMA_FIELD0_DONE_MASK   CSI_SR_DMA_FIELD0_DONE_MASK
#define CSI_CSISR_DMA_FIELD0_DONE_SHIFT   CSI_SR_DMA_FIELD0_DONE_SHIFT
#define CSI_CSISR_DMA_FIELD0_DONE(x)   CSI_SR_DMA_FIELD0_DONE(x)
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR_MASK   CSI_SR_BASEADDR_CHHANGE_ERROR_MASK
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR_SHIFT   CSI_SR_BASEADDR_CHHANGE_ERROR_SHIFT
#define CSI_CSISR_BASEADDR_CHHANGE_ERROR(x)   CSI_SR_BASEADDR_CHHANGE_ERROR(x)
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF_MASK   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF_MASK
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF_SHIFT   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF_SHIFT
#define CSI_CSIDMASA_STATFIFO_DMA_START_ADDR_SFF(x)   CSI_DMASA_STATFIFO_DMA_START_ADDR_SFF(x)
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF_MASK   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF_MASK
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF_SHIFT   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF_SHIFT
#define CSI_CSIDMATS_STATFIFO_DMA_TSF_SIZE_SFF(x)   CSI_DMATS_STATFIFO_DMA_TSF_SIZE_SFF(x)
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1_MASK   CSI_DMASA_FB1_DMA_START_ADDR_FB1_MASK
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1_SHIFT   CSI_DMASA_FB1_DMA_START_ADDR_FB1_SHIFT
#define CSI_CSIDMASA_FB1_DMA_START_ADDR_FB1(x)   CSI_DMASA_FB1_DMA_START_ADDR_FB1(x)
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2_MASK   CSI_DMASA_FB2_DMA_START_ADDR_FB2_MASK
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2_SHIFT   CSI_DMASA_FB2_DMA_START_ADDR_FB2_SHIFT
#define CSI_CSIDMASA_FB2_DMA_START_ADDR_FB2(x)   CSI_DMASA_FB2_DMA_START_ADDR_FB2(x)
#define CSI_CSIFBUF_PARA_FBUF_STRIDE_MASK   CSI_FBUF_PARA_FBUF_STRIDE_MASK
#define CSI_CSIFBUF_PARA_FBUF_STRIDE_SHIFT   CSI_FBUF_PARA_FBUF_STRIDE_SHIFT
#define CSI_CSIFBUF_PARA_FBUF_STRIDE(x)   CSI_FBUF_PARA_FBUF_STRIDE(x)
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE_MASK   CSI_FBUF_PARA_DEINTERLACE_STRIDE_MASK
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE_SHIFT   CSI_FBUF_PARA_DEINTERLACE_STRIDE_SHIFT
#define CSI_CSIFBUF_PARA_DEINTERLACE_STRIDE(x)   CSI_FBUF_PARA_DEINTERLACE_STRIDE(x)
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT_MASK   CSI_IMAG_PARA_IMAGE_HEIGHT_MASK
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT_SHIFT   CSI_IMAG_PARA_IMAGE_HEIGHT_SHIFT
#define CSI_CSIIMAG_PARA_IMAGE_HEIGHT(x)   CSI_IMAG_PARA_IMAGE_HEIGHT(x)
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH_MASK   CSI_IMAG_PARA_IMAGE_WIDTH_MASK
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH_SHIFT   CSI_IMAG_PARA_IMAGE_WIDTH_SHIFT
#define CSI_CSIIMAG_PARA_IMAGE_WIDTH(x)   CSI_IMAG_PARA_IMAGE_WIDTH(x)
#define CSI_CSICR18_NTSC_EN_MASK   CSI_CR18_NTSC_EN_MASK
#define CSI_CSICR18_NTSC_EN_SHIFT   CSI_CR18_NTSC_EN_SHIFT
#define CSI_CSICR18_NTSC_EN(x)   CSI_CR18_NTSC_EN(x)
#define CSI_CSICR18_TVDECODER_IN_EN_MASK   CSI_CR18_TVDECODER_IN_EN_MASK
#define CSI_CSICR18_TVDECODER_IN_EN_SHIFT   CSI_CR18_TVDECODER_IN_EN_SHIFT
#define CSI_CSICR18_TVDECODER_IN_EN(x)   CSI_CR18_TVDECODER_IN_EN(x)
#define CSI_CSICR18_DEINTERLACE_EN_MASK   CSI_CR18_DEINTERLACE_EN_MASK
#define CSI_CSICR18_DEINTERLACE_EN_SHIFT   CSI_CR18_DEINTERLACE_EN_SHIFT
#define CSI_CSICR18_DEINTERLACE_EN(x)   CSI_CR18_DEINTERLACE_EN(x)
#define CSI_CSICR18_PARALLEL24_EN_MASK   CSI_CR18_PARALLEL24_EN_MASK
#define CSI_CSICR18_PARALLEL24_EN_SHIFT   CSI_CR18_PARALLEL24_EN_SHIFT
#define CSI_CSICR18_PARALLEL24_EN(x)   CSI_CR18_PARALLEL24_EN(x)
#define CSI_CSICR18_BASEADDR_SWITCH_EN_MASK   CSI_CR18_BASEADDR_SWITCH_EN_MASK
#define CSI_CSICR18_BASEADDR_SWITCH_EN_SHIFT   CSI_CR18_BASEADDR_SWITCH_EN_SHIFT
#define CSI_CSICR18_BASEADDR_SWITCH_EN(x)   CSI_CR18_BASEADDR_SWITCH_EN(x)
#define CSI_CSICR18_BASEADDR_SWITCH_SEL_MASK   CSI_CR18_BASEADDR_SWITCH_SEL_MASK
#define CSI_CSICR18_BASEADDR_SWITCH_SEL_SHIFT   CSI_CR18_BASEADDR_SWITCH_SEL_SHIFT
#define CSI_CSICR18_BASEADDR_SWITCH_SEL(x)   CSI_CR18_BASEADDR_SWITCH_SEL(x)
#define CSI_CSICR18_FIELD0_DONE_IE_MASK   CSI_CR18_FIELD0_DONE_IE_MASK
#define CSI_CSICR18_FIELD0_DONE_IE_SHIFT   CSI_CR18_FIELD0_DONE_IE_SHIFT
#define CSI_CSICR18_FIELD0_DONE_IE(x)   CSI_CR18_FIELD0_DONE_IE(x)
#define CSI_CSICR18_DMA_FIELD1_DONE_IE_MASK   CSI_CR18_DMA_FIELD1_DONE_IE_MASK
#define CSI_CSICR18_DMA_FIELD1_DONE_IE_SHIFT   CSI_CR18_DMA_FIELD1_DONE_IE_SHIFT
#define CSI_CSICR18_DMA_FIELD1_DONE_IE(x)   CSI_CR18_DMA_FIELD1_DONE_IE(x)
#define CSI_CSICR18_LAST_DMA_REQ_SEL_MASK   CSI_CR18_LAST_DMA_REQ_SEL_MASK
#define CSI_CSICR18_LAST_DMA_REQ_SEL_SHIFT   CSI_CR18_LAST_DMA_REQ_SEL_SHIFT
#define CSI_CSICR18_LAST_DMA_REQ_SEL(x)   CSI_CR18_LAST_DMA_REQ_SEL(x)
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE_MASK   CSI_CR18_BASEADDR_CHANGE_ERROR_IE_MASK
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE_SHIFT   CSI_CR18_BASEADDR_CHANGE_ERROR_IE_SHIFT
#define CSI_CSICR18_BASEADDR_CHANGE_ERROR_IE(x)   CSI_CR18_BASEADDR_CHANGE_ERROR_IE(x)
#define CSI_CSICR18_RGB888A_FORMAT_SEL_MASK   CSI_CR18_RGB888A_FORMAT_SEL_MASK
#define CSI_CSICR18_RGB888A_FORMAT_SEL_SHIFT   CSI_CR18_RGB888A_FORMAT_SEL_SHIFT
#define CSI_CSICR18_RGB888A_FORMAT_SEL(x)   CSI_CR18_RGB888A_FORMAT_SEL(x)
#define CSI_CSICR18_AHB_HPROT_MASK   CSI_CR18_AHB_HPROT_MASK
#define CSI_CSICR18_AHB_HPROT_SHIFT   CSI_CR18_AHB_HPROT_SHIFT
#define CSI_CSICR18_AHB_HPROT(x)   CSI_CR18_AHB_HPROT(x)
#define CSI_CSICR18_MASK_OPTION_MASK   CSI_CR18_MASK_OPTION_MASK
#define CSI_CSICR18_MASK_OPTION_SHIFT   CSI_CR18_MASK_OPTION_SHIFT
#define CSI_CSICR18_MASK_OPTION(x)   CSI_CR18_MASK_OPTION(x)
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT_MASK   CSI_CR18_MIPI_DOUBLE_CMPNT_MASK
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT_SHIFT   CSI_CR18_MIPI_DOUBLE_CMPNT_SHIFT
#define CSI_CSICR18_MIPI_DOUBLE_CMPNT(x)   CSI_CR18_MIPI_DOUBLE_CMPNT(x)
#define CSI_CSICR18_MIPI_YU_SWAP_MASK   CSI_CR18_MIPI_YU_SWAP_MASK
#define CSI_CSICR18_MIPI_YU_SWAP_SHIFT   CSI_CR18_MIPI_YU_SWAP_SHIFT
#define CSI_CSICR18_MIPI_YU_SWAP(x)   CSI_CR18_MIPI_YU_SWAP(x)
#define CSI_CSICR18_DATA_FROM_MIPI_MASK   CSI_CR18_DATA_FROM_MIPI_MASK
#define CSI_CSICR18_DATA_FROM_MIPI_SHIFT   CSI_CR18_DATA_FROM_MIPI_SHIFT
#define CSI_CSICR18_DATA_FROM_MIPI(x)   CSI_CR18_DATA_FROM_MIPI(x)
#define CSI_CSICR18_LINE_STRIDE_EN_MASK   CSI_CR18_LINE_STRIDE_EN_MASK
#define CSI_CSICR18_LINE_STRIDE_EN_SHIFT   CSI_CR18_LINE_STRIDE_EN_SHIFT
#define CSI_CSICR18_LINE_STRIDE_EN(x)   CSI_CR18_LINE_STRIDE_EN(x)
#define CSI_CSICR18_MIPI_DATA_FORMAT_MASK   CSI_CR18_MIPI_DATA_FORMAT_MASK
#define CSI_CSICR18_MIPI_DATA_FORMAT_SHIFT   CSI_CR18_MIPI_DATA_FORMAT_SHIFT
#define CSI_CSICR18_MIPI_DATA_FORMAT(x)   CSI_CR18_MIPI_DATA_FORMAT(x)
#define CSI_CSICR18_CSI_ENABLE_MASK   CSI_CR18_CSI_ENABLE_MASK
#define CSI_CSICR18_CSI_ENABLE_SHIFT   CSI_CR18_CSI_ENABLE_SHIFT
#define CSI_CSICR18_CSI_ENABLE(x)   CSI_CR18_CSI_ENABLE(x)
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_MASK   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_MASK
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_SHIFT   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL_SHIFT
#define CSI_CSICR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL(x)   CSI_CR19_DMA_RFIFO_HIGHEST_FIFO_LEVEL(x)
#define CSI_CSICR20_THRESHOLD_MASK   CSI_CR20_THRESHOLD_MASK
#define CSI_CSICR20_THRESHOLD_SHIFT   CSI_CR20_THRESHOLD_SHIFT
#define CSI_CSICR20_THRESHOLD(x)   CSI_CR20_THRESHOLD(x)
#define CSI_CSICR20_BINARY_EN_MASK   CSI_CR20_BINARY_EN_MASK
#define CSI_CSICR20_BINARY_EN_SHIFT   CSI_CR20_BINARY_EN_SHIFT
#define CSI_CSICR20_BINARY_EN(x)   CSI_CR20_BINARY_EN(x)
#define CSI_CSICR20_QR_DATA_FORMAT_MASK   CSI_CR20_QR_DATA_FORMAT_MASK
#define CSI_CSICR20_QR_DATA_FORMAT_SHIFT   CSI_CR20_QR_DATA_FORMAT_SHIFT
#define CSI_CSICR20_QR_DATA_FORMAT(x)   CSI_CR20_QR_DATA_FORMAT(x)
#define CSI_CSICR20_BIG_END_MASK   CSI_CR20_BIG_END_MASK
#define CSI_CSICR20_BIG_END_SHIFT   CSI_CR20_BIG_END_SHIFT
#define CSI_CSICR20_BIG_END(x)   CSI_CR20_BIG_END(x)
#define CSI_CSICR20_10BIT_NEW_EN_MASK   CSI_CR20_10BIT_NEW_EN_MASK
#define CSI_CSICR20_10BIT_NEW_EN_SHIFT   CSI_CR20_10BIT_NEW_EN_SHIFT
#define CSI_CSICR20_10BIT_NEW_EN(x)   CSI_CR20_10BIT_NEW_EN(x)
#define CSI_CSICR20_HISTOGRAM_EN_MASK   CSI_CR20_HISTOGRAM_EN_MASK
#define CSI_CSICR20_HISTOGRAM_EN_SHIFT   CSI_CR20_HISTOGRAM_EN_SHIFT
#define CSI_CSICR20_HISTOGRAM_EN(x)   CSI_CR20_HISTOGRAM_EN(x)
#define CSI_CSICR20_QRCODE_EN_MASK   CSI_CR20_QRCODE_EN_MASK
#define CSI_CSICR20_QRCODE_EN_SHIFT   CSI_CR20_QRCODE_EN_SHIFT
#define CSI_CSICR20_QRCODE_EN(x)   CSI_CR20_QRCODE_EN(x)
#define CSI_CSICR21_PIXEL_COUNTERS_MASK   CSI_CR21_PIXEL_COUNTERS_MASK
#define CSI_CSICR21_PIXEL_COUNTERS_SHIFT   CSI_CR21_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR21_PIXEL_COUNTERS(x)   CSI_CR21_PIXEL_COUNTERS(x)
#define CSI_CSICR22_PIXEL_COUNTERS_MASK   CSI_CR22_PIXEL_COUNTERS_MASK
#define CSI_CSICR22_PIXEL_COUNTERS_SHIFT   CSI_CR22_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR22_PIXEL_COUNTERS(x)   CSI_CR22_PIXEL_COUNTERS(x)
#define CSI_CSICR23_PIXEL_COUNTERS_MASK   CSI_CR23_PIXEL_COUNTERS_MASK
#define CSI_CSICR23_PIXEL_COUNTERS_SHIFT   CSI_CR23_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR23_PIXEL_COUNTERS(x)   CSI_CR23_PIXEL_COUNTERS(x)
#define CSI_CSICR24_PIXEL_COUNTERS_MASK   CSI_CR24_PIXEL_COUNTERS_MASK
#define CSI_CSICR24_PIXEL_COUNTERS_SHIFT   CSI_CR24_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR24_PIXEL_COUNTERS(x)   CSI_CR24_PIXEL_COUNTERS(x)
#define CSI_CSICR25_PIXEL_COUNTERS_MASK   CSI_CR25_PIXEL_COUNTERS_MASK
#define CSI_CSICR25_PIXEL_COUNTERS_SHIFT   CSI_CR25_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR25_PIXEL_COUNTERS(x)   CSI_CR25_PIXEL_COUNTERS(x)
#define CSI_CSICR26_PIXEL_COUNTERS_MASK   CSI_CR26_PIXEL_COUNTERS_MASK
#define CSI_CSICR26_PIXEL_COUNTERS_SHIFT   CSI_CR26_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR26_PIXEL_COUNTERS(x)   CSI_CR26_PIXEL_COUNTERS(x)
#define CSI_CSICR27_PIXEL_COUNTERS_MASK   CSI_CR27_PIXEL_COUNTERS_MASK
#define CSI_CSICR27_PIXEL_COUNTERS_SHIFT   CSI_CR27_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR27_PIXEL_COUNTERS(x)   CSI_CR27_PIXEL_COUNTERS(x)
#define CSI_CSICR28_PIXEL_COUNTERS_MASK   CSI_CR28_PIXEL_COUNTERS_MASK
#define CSI_CSICR28_PIXEL_COUNTERS_SHIFT   CSI_CR28_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR28_PIXEL_COUNTERS(x)   CSI_CR28_PIXEL_COUNTERS(x)
#define CSI_CSICR29_PIXEL_COUNTERS_MASK   CSI_CR29_PIXEL_COUNTERS_MASK
#define CSI_CSICR29_PIXEL_COUNTERS_SHIFT   CSI_CR29_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR29_PIXEL_COUNTERS(x)   CSI_CR29_PIXEL_COUNTERS(x)
#define CSI_CSICR30_PIXEL_COUNTERS_MASK   CSI_CR30_PIXEL_COUNTERS_MASK
#define CSI_CSICR30_PIXEL_COUNTERS_SHIFT   CSI_CR30_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR30_PIXEL_COUNTERS(x)   CSI_CR30_PIXEL_COUNTERS(x)
#define CSI_CSICR31_PIXEL_COUNTERS_MASK   CSI_CR31_PIXEL_COUNTERS_MASK
#define CSI_CSICR31_PIXEL_COUNTERS_SHIFT   CSI_CR31_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR31_PIXEL_COUNTERS(x)   CSI_CR31_PIXEL_COUNTERS(x)
#define CSI_CSICR32_PIXEL_COUNTERS_MASK   CSI_CR32_PIXEL_COUNTERS_MASK
#define CSI_CSICR32_PIXEL_COUNTERS_SHIFT   CSI_CR32_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR32_PIXEL_COUNTERS(x)   CSI_CR32_PIXEL_COUNTERS(x)
#define CSI_CSICR33_PIXEL_COUNTERS_MASK   CSI_CR33_PIXEL_COUNTERS_MASK
#define CSI_CSICR33_PIXEL_COUNTERS_SHIFT   CSI_CR33_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR33_PIXEL_COUNTERS(x)   CSI_CR33_PIXEL_COUNTERS(x)
#define CSI_CSICR34_PIXEL_COUNTERS_MASK   CSI_CR34_PIXEL_COUNTERS_MASK
#define CSI_CSICR34_PIXEL_COUNTERS_SHIFT   CSI_CR34_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR34_PIXEL_COUNTERS(x)   CSI_CR34_PIXEL_COUNTERS(x)
#define CSI_CSICR35_PIXEL_COUNTERS_MASK   CSI_CR35_PIXEL_COUNTERS_MASK
#define CSI_CSICR35_PIXEL_COUNTERS_SHIFT   CSI_CR35_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR35_PIXEL_COUNTERS(x)   CSI_CR35_PIXEL_COUNTERS(x)
#define CSI_CSICR36_PIXEL_COUNTERS_MASK   CSI_CR36_PIXEL_COUNTERS_MASK
#define CSI_CSICR36_PIXEL_COUNTERS_SHIFT   CSI_CR36_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR36_PIXEL_COUNTERS(x)   CSI_CR36_PIXEL_COUNTERS(x)
#define CSI_CSICR37_PIXEL_COUNTERS_MASK   CSI_CR37_PIXEL_COUNTERS_MASK
#define CSI_CSICR37_PIXEL_COUNTERS_SHIFT   CSI_CR37_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR37_PIXEL_COUNTERS(x)   CSI_CR37_PIXEL_COUNTERS(x)
#define CSI_CSICR38_PIXEL_COUNTERS_MASK   CSI_CR38_PIXEL_COUNTERS_MASK
#define CSI_CSICR38_PIXEL_COUNTERS_SHIFT   CSI_CR38_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR38_PIXEL_COUNTERS(x)   CSI_CR38_PIXEL_COUNTERS(x)
#define CSI_CSICR39_PIXEL_COUNTERS_MASK   CSI_CR39_PIXEL_COUNTERS_MASK
#define CSI_CSICR39_PIXEL_COUNTERS_SHIFT   CSI_CR39_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR39_PIXEL_COUNTERS(x)   CSI_CR39_PIXEL_COUNTERS(x)
#define CSI_CSICR40_PIXEL_COUNTERS_MASK   CSI_CR40_PIXEL_COUNTERS_MASK
#define CSI_CSICR40_PIXEL_COUNTERS_SHIFT   CSI_CR40_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR40_PIXEL_COUNTERS(x)   CSI_CR40_PIXEL_COUNTERS(x)
#define CSI_CSICR41_PIXEL_COUNTERS_MASK   CSI_CR41_PIXEL_COUNTERS_MASK
#define CSI_CSICR41_PIXEL_COUNTERS_SHIFT   CSI_CR41_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR41_PIXEL_COUNTERS(x)   CSI_CR41_PIXEL_COUNTERS(x)
#define CSI_CSICR42_PIXEL_COUNTERS_MASK   CSI_CR42_PIXEL_COUNTERS_MASK
#define CSI_CSICR42_PIXEL_COUNTERS_SHIFT   CSI_CR42_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR42_PIXEL_COUNTERS(x)   CSI_CR42_PIXEL_COUNTERS(x)
#define CSI_CSICR43_PIXEL_COUNTERS_MASK   CSI_CR43_PIXEL_COUNTERS_MASK
#define CSI_CSICR43_PIXEL_COUNTERS_SHIFT   CSI_CR43_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR43_PIXEL_COUNTERS(x)   CSI_CR43_PIXEL_COUNTERS(x)
#define CSI_CSICR44_PIXEL_COUNTERS_MASK   CSI_CR44_PIXEL_COUNTERS_MASK
#define CSI_CSICR44_PIXEL_COUNTERS_SHIFT   CSI_CR44_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR44_PIXEL_COUNTERS(x)   CSI_CR44_PIXEL_COUNTERS(x)
#define CSI_CSICR45_PIXEL_COUNTERS_MASK   CSI_CR45_PIXEL_COUNTERS_MASK
#define CSI_CSICR45_PIXEL_COUNTERS_SHIFT   CSI_CR45_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR45_PIXEL_COUNTERS(x)   CSI_CR45_PIXEL_COUNTERS(x)
#define CSI_CSICR46_PIXEL_COUNTERS_MASK   CSI_CR46_PIXEL_COUNTERS_MASK
#define CSI_CSICR46_PIXEL_COUNTERS_SHIFT   CSI_CR46_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR46_PIXEL_COUNTERS(x)   CSI_CR46_PIXEL_COUNTERS(x)
#define CSI_CSICR47_PIXEL_COUNTERS_MASK   CSI_CR47_PIXEL_COUNTERS_MASK
#define CSI_CSICR47_PIXEL_COUNTERS_SHIFT   CSI_CR47_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR47_PIXEL_COUNTERS(x)   CSI_CR47_PIXEL_COUNTERS(x)
#define CSI_CSICR48_PIXEL_COUNTERS_MASK   CSI_CR48_PIXEL_COUNTERS_MASK
#define CSI_CSICR48_PIXEL_COUNTERS_SHIFT   CSI_CR48_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR48_PIXEL_COUNTERS(x)   CSI_CR48_PIXEL_COUNTERS(x)
#define CSI_CSICR49_PIXEL_COUNTERS_MASK   CSI_CR49_PIXEL_COUNTERS_MASK
#define CSI_CSICR49_PIXEL_COUNTERS_SHIFT   CSI_CR49_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR49_PIXEL_COUNTERS(x)   CSI_CR49_PIXEL_COUNTERS(x)
#define CSI_CSICR50_PIXEL_COUNTERS_MASK   CSI_CR50_PIXEL_COUNTERS_MASK
#define CSI_CSICR50_PIXEL_COUNTERS_SHIFT   CSI_CR50_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR50_PIXEL_COUNTERS(x)   CSI_CR50_PIXEL_COUNTERS(x)
#define CSI_CSICR51_PIXEL_COUNTERS_MASK   CSI_CR51_PIXEL_COUNTERS_MASK
#define CSI_CSICR51_PIXEL_COUNTERS_SHIFT   CSI_CR51_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR51_PIXEL_COUNTERS(x)   CSI_CR51_PIXEL_COUNTERS(x)
#define CSI_CSICR52_PIXEL_COUNTERS_MASK   CSI_CR52_PIXEL_COUNTERS_MASK
#define CSI_CSICR52_PIXEL_COUNTERS_SHIFT   CSI_CR52_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR52_PIXEL_COUNTERS(x)   CSI_CR52_PIXEL_COUNTERS(x)
#define CSI_CSICR53_PIXEL_COUNTERS_MASK   CSI_CR53_PIXEL_COUNTERS_MASK
#define CSI_CSICR53_PIXEL_COUNTERS_SHIFT   CSI_CR53_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR53_PIXEL_COUNTERS(x)   CSI_CR53_PIXEL_COUNTERS(x)
#define CSI_CSICR54_PIXEL_COUNTERS_MASK   CSI_CR54_PIXEL_COUNTERS_MASK
#define CSI_CSICR54_PIXEL_COUNTERS_SHIFT   CSI_CR54_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR54_PIXEL_COUNTERS(x)   CSI_CR54_PIXEL_COUNTERS(x)
#define CSI_CSICR55_PIXEL_COUNTERS_MASK   CSI_CR55_PIXEL_COUNTERS_MASK
#define CSI_CSICR55_PIXEL_COUNTERS_SHIFT   CSI_CR55_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR55_PIXEL_COUNTERS(x)   CSI_CR55_PIXEL_COUNTERS(x)
#define CSI_CSICR56_PIXEL_COUNTERS_MASK   CSI_CR56_PIXEL_COUNTERS_MASK
#define CSI_CSICR56_PIXEL_COUNTERS_SHIFT   CSI_CR56_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR56_PIXEL_COUNTERS(x)   CSI_CR56_PIXEL_COUNTERS(x)
#define CSI_CSICR57_PIXEL_COUNTERS_MASK   CSI_CR57_PIXEL_COUNTERS_MASK
#define CSI_CSICR57_PIXEL_COUNTERS_SHIFT   CSI_CR57_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR57_PIXEL_COUNTERS(x)   CSI_CR57_PIXEL_COUNTERS(x)
#define CSI_CSICR58_PIXEL_COUNTERS_MASK   CSI_CR58_PIXEL_COUNTERS_MASK
#define CSI_CSICR58_PIXEL_COUNTERS_SHIFT   CSI_CR58_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR58_PIXEL_COUNTERS(x)   CSI_CR58_PIXEL_COUNTERS(x)
#define CSI_CSICR59_PIXEL_COUNTERS_MASK   CSI_CR59_PIXEL_COUNTERS_MASK
#define CSI_CSICR59_PIXEL_COUNTERS_SHIFT   CSI_CR59_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR59_PIXEL_COUNTERS(x)   CSI_CR59_PIXEL_COUNTERS(x)
#define CSI_CSICR60_PIXEL_COUNTERS_MASK   CSI_CR60_PIXEL_COUNTERS_MASK
#define CSI_CSICR60_PIXEL_COUNTERS_SHIFT   CSI_CR60_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR60_PIXEL_COUNTERS(x)   CSI_CR60_PIXEL_COUNTERS(x)
#define CSI_CSICR61_PIXEL_COUNTERS_MASK   CSI_CR61_PIXEL_COUNTERS_MASK
#define CSI_CSICR61_PIXEL_COUNTERS_SHIFT   CSI_CR61_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR61_PIXEL_COUNTERS(x)   CSI_CR61_PIXEL_COUNTERS(x)
#define CSI_CSICR62_PIXEL_COUNTERS_MASK   CSI_CR62_PIXEL_COUNTERS_MASK
#define CSI_CSICR62_PIXEL_COUNTERS_SHIFT   CSI_CR62_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR62_PIXEL_COUNTERS(x)   CSI_CR62_PIXEL_COUNTERS(x)
#define CSI_CSICR63_PIXEL_COUNTERS_MASK   CSI_CR63_PIXEL_COUNTERS_MASK
#define CSI_CSICR63_PIXEL_COUNTERS_SHIFT   CSI_CR63_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR63_PIXEL_COUNTERS(x)   CSI_CR63_PIXEL_COUNTERS(x)
#define CSI_CSICR64_PIXEL_COUNTERS_MASK   CSI_CR64_PIXEL_COUNTERS_MASK
#define CSI_CSICR64_PIXEL_COUNTERS_SHIFT   CSI_CR64_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR64_PIXEL_COUNTERS(x)   CSI_CR64_PIXEL_COUNTERS(x)
#define CSI_CSICR65_PIXEL_COUNTERS_MASK   CSI_CR65_PIXEL_COUNTERS_MASK
#define CSI_CSICR65_PIXEL_COUNTERS_SHIFT   CSI_CR65_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR65_PIXEL_COUNTERS(x)   CSI_CR65_PIXEL_COUNTERS(x)
#define CSI_CSICR66_PIXEL_COUNTERS_MASK   CSI_CR66_PIXEL_COUNTERS_MASK
#define CSI_CSICR66_PIXEL_COUNTERS_SHIFT   CSI_CR66_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR66_PIXEL_COUNTERS(x)   CSI_CR66_PIXEL_COUNTERS(x)
#define CSI_CSICR67_PIXEL_COUNTERS_MASK   CSI_CR67_PIXEL_COUNTERS_MASK
#define CSI_CSICR67_PIXEL_COUNTERS_SHIFT   CSI_CR67_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR67_PIXEL_COUNTERS(x)   CSI_CR67_PIXEL_COUNTERS(x)
#define CSI_CSICR68_PIXEL_COUNTERS_MASK   CSI_CR68_PIXEL_COUNTERS_MASK
#define CSI_CSICR68_PIXEL_COUNTERS_SHIFT   CSI_CR68_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR68_PIXEL_COUNTERS(x)   CSI_CR68_PIXEL_COUNTERS(x)
#define CSI_CSICR69_PIXEL_COUNTERS_MASK   CSI_CR69_PIXEL_COUNTERS_MASK
#define CSI_CSICR69_PIXEL_COUNTERS_SHIFT   CSI_CR69_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR69_PIXEL_COUNTERS(x)   CSI_CR69_PIXEL_COUNTERS(x)
#define CSI_CSICR70_PIXEL_COUNTERS_MASK   CSI_CR70_PIXEL_COUNTERS_MASK
#define CSI_CSICR70_PIXEL_COUNTERS_SHIFT   CSI_CR70_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR70_PIXEL_COUNTERS(x)   CSI_CR70_PIXEL_COUNTERS(x)
#define CSI_CSICR71_PIXEL_COUNTERS_MASK   CSI_CR71_PIXEL_COUNTERS_MASK
#define CSI_CSICR71_PIXEL_COUNTERS_SHIFT   CSI_CR71_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR71_PIXEL_COUNTERS(x)   CSI_CR71_PIXEL_COUNTERS(x)
#define CSI_CSICR72_PIXEL_COUNTERS_MASK   CSI_CR72_PIXEL_COUNTERS_MASK
#define CSI_CSICR72_PIXEL_COUNTERS_SHIFT   CSI_CR72_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR72_PIXEL_COUNTERS(x)   CSI_CR72_PIXEL_COUNTERS(x)
#define CSI_CSICR73_PIXEL_COUNTERS_MASK   CSI_CR73_PIXEL_COUNTERS_MASK
#define CSI_CSICR73_PIXEL_COUNTERS_SHIFT   CSI_CR73_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR73_PIXEL_COUNTERS(x)   CSI_CR73_PIXEL_COUNTERS(x)
#define CSI_CSICR74_PIXEL_COUNTERS_MASK   CSI_CR74_PIXEL_COUNTERS_MASK
#define CSI_CSICR74_PIXEL_COUNTERS_SHIFT   CSI_CR74_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR74_PIXEL_COUNTERS(x)   CSI_CR74_PIXEL_COUNTERS(x)
#define CSI_CSICR75_PIXEL_COUNTERS_MASK   CSI_CR75_PIXEL_COUNTERS_MASK
#define CSI_CSICR75_PIXEL_COUNTERS_SHIFT   CSI_CR75_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR75_PIXEL_COUNTERS(x)   CSI_CR75_PIXEL_COUNTERS(x)
#define CSI_CSICR76_PIXEL_COUNTERS_MASK   CSI_CR76_PIXEL_COUNTERS_MASK
#define CSI_CSICR76_PIXEL_COUNTERS_SHIFT   CSI_CR76_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR76_PIXEL_COUNTERS(x)   CSI_CR76_PIXEL_COUNTERS(x)
#define CSI_CSICR77_PIXEL_COUNTERS_MASK   CSI_CR77_PIXEL_COUNTERS_MASK
#define CSI_CSICR77_PIXEL_COUNTERS_SHIFT   CSI_CR77_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR77_PIXEL_COUNTERS(x)   CSI_CR77_PIXEL_COUNTERS(x)
#define CSI_CSICR78_PIXEL_COUNTERS_MASK   CSI_CR78_PIXEL_COUNTERS_MASK
#define CSI_CSICR78_PIXEL_COUNTERS_SHIFT   CSI_CR78_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR78_PIXEL_COUNTERS(x)   CSI_CR78_PIXEL_COUNTERS(x)
#define CSI_CSICR79_PIXEL_COUNTERS_MASK   CSI_CR79_PIXEL_COUNTERS_MASK
#define CSI_CSICR79_PIXEL_COUNTERS_SHIFT   CSI_CR79_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR79_PIXEL_COUNTERS(x)   CSI_CR79_PIXEL_COUNTERS(x)
#define CSI_CSICR80_PIXEL_COUNTERS_MASK   CSI_CR80_PIXEL_COUNTERS_MASK
#define CSI_CSICR80_PIXEL_COUNTERS_SHIFT   CSI_CR80_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR80_PIXEL_COUNTERS(x)   CSI_CR80_PIXEL_COUNTERS(x)
#define CSI_CSICR81_PIXEL_COUNTERS_MASK   CSI_CR81_PIXEL_COUNTERS_MASK
#define CSI_CSICR81_PIXEL_COUNTERS_SHIFT   CSI_CR81_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR81_PIXEL_COUNTERS(x)   CSI_CR81_PIXEL_COUNTERS(x)
#define CSI_CSICR82_PIXEL_COUNTERS_MASK   CSI_CR82_PIXEL_COUNTERS_MASK
#define CSI_CSICR82_PIXEL_COUNTERS_SHIFT   CSI_CR82_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR82_PIXEL_COUNTERS(x)   CSI_CR82_PIXEL_COUNTERS(x)
#define CSI_CSICR83_PIXEL_COUNTERS_MASK   CSI_CR83_PIXEL_COUNTERS_MASK
#define CSI_CSICR83_PIXEL_COUNTERS_SHIFT   CSI_CR83_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR83_PIXEL_COUNTERS(x)   CSI_CR83_PIXEL_COUNTERS(x)
#define CSI_CSICR84_PIXEL_COUNTERS_MASK   CSI_CR84_PIXEL_COUNTERS_MASK
#define CSI_CSICR84_PIXEL_COUNTERS_SHIFT   CSI_CR84_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR84_PIXEL_COUNTERS(x)   CSI_CR84_PIXEL_COUNTERS(x)
#define CSI_CSICR85_PIXEL_COUNTERS_MASK   CSI_CR85_PIXEL_COUNTERS_MASK
#define CSI_CSICR85_PIXEL_COUNTERS_SHIFT   CSI_CR85_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR85_PIXEL_COUNTERS(x)   CSI_CR85_PIXEL_COUNTERS(x)
#define CSI_CSICR86_PIXEL_COUNTERS_MASK   CSI_CR86_PIXEL_COUNTERS_MASK
#define CSI_CSICR86_PIXEL_COUNTERS_SHIFT   CSI_CR86_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR86_PIXEL_COUNTERS(x)   CSI_CR86_PIXEL_COUNTERS(x)
#define CSI_CSICR87_PIXEL_COUNTERS_MASK   CSI_CR87_PIXEL_COUNTERS_MASK
#define CSI_CSICR87_PIXEL_COUNTERS_SHIFT   CSI_CR87_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR87_PIXEL_COUNTERS(x)   CSI_CR87_PIXEL_COUNTERS(x)
#define CSI_CSICR88_PIXEL_COUNTERS_MASK   CSI_CR88_PIXEL_COUNTERS_MASK
#define CSI_CSICR88_PIXEL_COUNTERS_SHIFT   CSI_CR88_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR88_PIXEL_COUNTERS(x)   CSI_CR88_PIXEL_COUNTERS(x)
#define CSI_CSICR89_PIXEL_COUNTERS_MASK   CSI_CR89_PIXEL_COUNTERS_MASK
#define CSI_CSICR89_PIXEL_COUNTERS_SHIFT   CSI_CR89_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR89_PIXEL_COUNTERS(x)   CSI_CR89_PIXEL_COUNTERS(x)
#define CSI_CSICR90_PIXEL_COUNTERS_MASK   CSI_CR90_PIXEL_COUNTERS_MASK
#define CSI_CSICR90_PIXEL_COUNTERS_SHIFT   CSI_CR90_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR90_PIXEL_COUNTERS(x)   CSI_CR90_PIXEL_COUNTERS(x)
#define CSI_CSICR91_PIXEL_COUNTERS_MASK   CSI_CR91_PIXEL_COUNTERS_MASK
#define CSI_CSICR91_PIXEL_COUNTERS_SHIFT   CSI_CR91_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR91_PIXEL_COUNTERS(x)   CSI_CR91_PIXEL_COUNTERS(x)
#define CSI_CSICR92_PIXEL_COUNTERS_MASK   CSI_CR92_PIXEL_COUNTERS_MASK
#define CSI_CSICR92_PIXEL_COUNTERS_SHIFT   CSI_CR92_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR92_PIXEL_COUNTERS(x)   CSI_CR92_PIXEL_COUNTERS(x)
#define CSI_CSICR93_PIXEL_COUNTERS_MASK   CSI_CR93_PIXEL_COUNTERS_MASK
#define CSI_CSICR93_PIXEL_COUNTERS_SHIFT   CSI_CR93_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR93_PIXEL_COUNTERS(x)   CSI_CR93_PIXEL_COUNTERS(x)
#define CSI_CSICR94_PIXEL_COUNTERS_MASK   CSI_CR94_PIXEL_COUNTERS_MASK
#define CSI_CSICR94_PIXEL_COUNTERS_SHIFT   CSI_CR94_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR94_PIXEL_COUNTERS(x)   CSI_CR94_PIXEL_COUNTERS(x)
#define CSI_CSICR95_PIXEL_COUNTERS_MASK   CSI_CR95_PIXEL_COUNTERS_MASK
#define CSI_CSICR95_PIXEL_COUNTERS_SHIFT   CSI_CR95_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR95_PIXEL_COUNTERS(x)   CSI_CR95_PIXEL_COUNTERS(x)
#define CSI_CSICR96_PIXEL_COUNTERS_MASK   CSI_CR96_PIXEL_COUNTERS_MASK
#define CSI_CSICR96_PIXEL_COUNTERS_SHIFT   CSI_CR96_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR96_PIXEL_COUNTERS(x)   CSI_CR96_PIXEL_COUNTERS(x)
#define CSI_CSICR97_PIXEL_COUNTERS_MASK   CSI_CR97_PIXEL_COUNTERS_MASK
#define CSI_CSICR97_PIXEL_COUNTERS_SHIFT   CSI_CR97_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR97_PIXEL_COUNTERS(x)   CSI_CR97_PIXEL_COUNTERS(x)
#define CSI_CSICR98_PIXEL_COUNTERS_MASK   CSI_CR98_PIXEL_COUNTERS_MASK
#define CSI_CSICR98_PIXEL_COUNTERS_SHIFT   CSI_CR98_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR98_PIXEL_COUNTERS(x)   CSI_CR98_PIXEL_COUNTERS(x)
#define CSI_CSICR99_PIXEL_COUNTERS_MASK   CSI_CR99_PIXEL_COUNTERS_MASK
#define CSI_CSICR99_PIXEL_COUNTERS_SHIFT   CSI_CR99_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR99_PIXEL_COUNTERS(x)   CSI_CR99_PIXEL_COUNTERS(x)
#define CSI_CSICR100_PIXEL_COUNTERS_MASK   CSI_CR100_PIXEL_COUNTERS_MASK
#define CSI_CSICR100_PIXEL_COUNTERS_SHIFT   CSI_CR100_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR100_PIXEL_COUNTERS(x)   CSI_CR100_PIXEL_COUNTERS(x)
#define CSI_CSICR101_PIXEL_COUNTERS_MASK   CSI_CR101_PIXEL_COUNTERS_MASK
#define CSI_CSICR101_PIXEL_COUNTERS_SHIFT   CSI_CR101_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR101_PIXEL_COUNTERS(x)   CSI_CR101_PIXEL_COUNTERS(x)
#define CSI_CSICR102_PIXEL_COUNTERS_MASK   CSI_CR102_PIXEL_COUNTERS_MASK
#define CSI_CSICR102_PIXEL_COUNTERS_SHIFT   CSI_CR102_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR102_PIXEL_COUNTERS(x)   CSI_CR102_PIXEL_COUNTERS(x)
#define CSI_CSICR103_PIXEL_COUNTERS_MASK   CSI_CR103_PIXEL_COUNTERS_MASK
#define CSI_CSICR103_PIXEL_COUNTERS_SHIFT   CSI_CR103_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR103_PIXEL_COUNTERS(x)   CSI_CR103_PIXEL_COUNTERS(x)
#define CSI_CSICR104_PIXEL_COUNTERS_MASK   CSI_CR104_PIXEL_COUNTERS_MASK
#define CSI_CSICR104_PIXEL_COUNTERS_SHIFT   CSI_CR104_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR104_PIXEL_COUNTERS(x)   CSI_CR104_PIXEL_COUNTERS(x)
#define CSI_CSICR105_PIXEL_COUNTERS_MASK   CSI_CR105_PIXEL_COUNTERS_MASK
#define CSI_CSICR105_PIXEL_COUNTERS_SHIFT   CSI_CR105_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR105_PIXEL_COUNTERS(x)   CSI_CR105_PIXEL_COUNTERS(x)
#define CSI_CSICR106_PIXEL_COUNTERS_MASK   CSI_CR106_PIXEL_COUNTERS_MASK
#define CSI_CSICR106_PIXEL_COUNTERS_SHIFT   CSI_CR106_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR106_PIXEL_COUNTERS(x)   CSI_CR106_PIXEL_COUNTERS(x)
#define CSI_CSICR107_PIXEL_COUNTERS_MASK   CSI_CR107_PIXEL_COUNTERS_MASK
#define CSI_CSICR107_PIXEL_COUNTERS_SHIFT   CSI_CR107_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR107_PIXEL_COUNTERS(x)   CSI_CR107_PIXEL_COUNTERS(x)
#define CSI_CSICR108_PIXEL_COUNTERS_MASK   CSI_CR108_PIXEL_COUNTERS_MASK
#define CSI_CSICR108_PIXEL_COUNTERS_SHIFT   CSI_CR108_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR108_PIXEL_COUNTERS(x)   CSI_CR108_PIXEL_COUNTERS(x)
#define CSI_CSICR109_PIXEL_COUNTERS_MASK   CSI_CR109_PIXEL_COUNTERS_MASK
#define CSI_CSICR109_PIXEL_COUNTERS_SHIFT   CSI_CR109_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR109_PIXEL_COUNTERS(x)   CSI_CR109_PIXEL_COUNTERS(x)
#define CSI_CSICR110_PIXEL_COUNTERS_MASK   CSI_CR110_PIXEL_COUNTERS_MASK
#define CSI_CSICR110_PIXEL_COUNTERS_SHIFT   CSI_CR110_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR110_PIXEL_COUNTERS(x)   CSI_CR110_PIXEL_COUNTERS(x)
#define CSI_CSICR111_PIXEL_COUNTERS_MASK   CSI_CR111_PIXEL_COUNTERS_MASK
#define CSI_CSICR111_PIXEL_COUNTERS_SHIFT   CSI_CR111_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR111_PIXEL_COUNTERS(x)   CSI_CR111_PIXEL_COUNTERS(x)
#define CSI_CSICR112_PIXEL_COUNTERS_MASK   CSI_CR112_PIXEL_COUNTERS_MASK
#define CSI_CSICR112_PIXEL_COUNTERS_SHIFT   CSI_CR112_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR112_PIXEL_COUNTERS(x)   CSI_CR112_PIXEL_COUNTERS(x)
#define CSI_CSICR113_PIXEL_COUNTERS_MASK   CSI_CR113_PIXEL_COUNTERS_MASK
#define CSI_CSICR113_PIXEL_COUNTERS_SHIFT   CSI_CR113_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR113_PIXEL_COUNTERS(x)   CSI_CR113_PIXEL_COUNTERS(x)
#define CSI_CSICR114_PIXEL_COUNTERS_MASK   CSI_CR114_PIXEL_COUNTERS_MASK
#define CSI_CSICR114_PIXEL_COUNTERS_SHIFT   CSI_CR114_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR114_PIXEL_COUNTERS(x)   CSI_CR114_PIXEL_COUNTERS(x)
#define CSI_CSICR115_PIXEL_COUNTERS_MASK   CSI_CR115_PIXEL_COUNTERS_MASK
#define CSI_CSICR115_PIXEL_COUNTERS_SHIFT   CSI_CR115_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR115_PIXEL_COUNTERS(x)   CSI_CR115_PIXEL_COUNTERS(x)
#define CSI_CSICR116_PIXEL_COUNTERS_MASK   CSI_CR116_PIXEL_COUNTERS_MASK
#define CSI_CSICR116_PIXEL_COUNTERS_SHIFT   CSI_CR116_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR116_PIXEL_COUNTERS(x)   CSI_CR116_PIXEL_COUNTERS(x)
#define CSI_CSICR117_PIXEL_COUNTERS_MASK   CSI_CR117_PIXEL_COUNTERS_MASK
#define CSI_CSICR117_PIXEL_COUNTERS_SHIFT   CSI_CR117_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR117_PIXEL_COUNTERS(x)   CSI_CR117_PIXEL_COUNTERS(x)
#define CSI_CSICR118_PIXEL_COUNTERS_MASK   CSI_CR118_PIXEL_COUNTERS_MASK
#define CSI_CSICR118_PIXEL_COUNTERS_SHIFT   CSI_CR118_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR118_PIXEL_COUNTERS(x)   CSI_CR118_PIXEL_COUNTERS(x)
#define CSI_CSICR119_PIXEL_COUNTERS_MASK   CSI_CR119_PIXEL_COUNTERS_MASK
#define CSI_CSICR119_PIXEL_COUNTERS_SHIFT   CSI_CR119_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR119_PIXEL_COUNTERS(x)   CSI_CR119_PIXEL_COUNTERS(x)
#define CSI_CSICR120_PIXEL_COUNTERS_MASK   CSI_CR120_PIXEL_COUNTERS_MASK
#define CSI_CSICR120_PIXEL_COUNTERS_SHIFT   CSI_CR120_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR120_PIXEL_COUNTERS(x)   CSI_CR120_PIXEL_COUNTERS(x)
#define CSI_CSICR121_PIXEL_COUNTERS_MASK   CSI_CR121_PIXEL_COUNTERS_MASK
#define CSI_CSICR121_PIXEL_COUNTERS_SHIFT   CSI_CR121_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR121_PIXEL_COUNTERS(x)   CSI_CR121_PIXEL_COUNTERS(x)
#define CSI_CSICR122_PIXEL_COUNTERS_MASK   CSI_CR122_PIXEL_COUNTERS_MASK
#define CSI_CSICR122_PIXEL_COUNTERS_SHIFT   CSI_CR122_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR122_PIXEL_COUNTERS(x)   CSI_CR122_PIXEL_COUNTERS(x)
#define CSI_CSICR123_PIXEL_COUNTERS_MASK   CSI_CR123_PIXEL_COUNTERS_MASK
#define CSI_CSICR123_PIXEL_COUNTERS_SHIFT   CSI_CR123_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR123_PIXEL_COUNTERS(x)   CSI_CR123_PIXEL_COUNTERS(x)
#define CSI_CSICR124_PIXEL_COUNTERS_MASK   CSI_CR124_PIXEL_COUNTERS_MASK
#define CSI_CSICR124_PIXEL_COUNTERS_SHIFT   CSI_CR124_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR124_PIXEL_COUNTERS(x)   CSI_CR124_PIXEL_COUNTERS(x)
#define CSI_CSICR125_PIXEL_COUNTERS_MASK   CSI_CR125_PIXEL_COUNTERS_MASK
#define CSI_CSICR125_PIXEL_COUNTERS_SHIFT   CSI_CR125_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR125_PIXEL_COUNTERS(x)   CSI_CR125_PIXEL_COUNTERS(x)
#define CSI_CSICR126_PIXEL_COUNTERS_MASK   CSI_CR126_PIXEL_COUNTERS_MASK
#define CSI_CSICR126_PIXEL_COUNTERS_SHIFT   CSI_CR126_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR126_PIXEL_COUNTERS(x)   CSI_CR126_PIXEL_COUNTERS(x)
#define CSI_CSICR127_PIXEL_COUNTERS_MASK   CSI_CR127_PIXEL_COUNTERS_MASK
#define CSI_CSICR127_PIXEL_COUNTERS_SHIFT   CSI_CR127_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR127_PIXEL_COUNTERS(x)   CSI_CR127_PIXEL_COUNTERS(x)
#define CSI_CSICR128_PIXEL_COUNTERS_MASK   CSI_CR128_PIXEL_COUNTERS_MASK
#define CSI_CSICR128_PIXEL_COUNTERS_SHIFT   CSI_CR128_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR128_PIXEL_COUNTERS(x)   CSI_CR128_PIXEL_COUNTERS(x)
#define CSI_CSICR129_PIXEL_COUNTERS_MASK   CSI_CR129_PIXEL_COUNTERS_MASK
#define CSI_CSICR129_PIXEL_COUNTERS_SHIFT   CSI_CR129_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR129_PIXEL_COUNTERS(x)   CSI_CR129_PIXEL_COUNTERS(x)
#define CSI_CSICR130_PIXEL_COUNTERS_MASK   CSI_CR130_PIXEL_COUNTERS_MASK
#define CSI_CSICR130_PIXEL_COUNTERS_SHIFT   CSI_CR130_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR130_PIXEL_COUNTERS(x)   CSI_CR130_PIXEL_COUNTERS(x)
#define CSI_CSICR131_PIXEL_COUNTERS_MASK   CSI_CR131_PIXEL_COUNTERS_MASK
#define CSI_CSICR131_PIXEL_COUNTERS_SHIFT   CSI_CR131_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR131_PIXEL_COUNTERS(x)   CSI_CR131_PIXEL_COUNTERS(x)
#define CSI_CSICR132_PIXEL_COUNTERS_MASK   CSI_CR132_PIXEL_COUNTERS_MASK
#define CSI_CSICR132_PIXEL_COUNTERS_SHIFT   CSI_CR132_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR132_PIXEL_COUNTERS(x)   CSI_CR132_PIXEL_COUNTERS(x)
#define CSI_CSICR133_PIXEL_COUNTERS_MASK   CSI_CR133_PIXEL_COUNTERS_MASK
#define CSI_CSICR133_PIXEL_COUNTERS_SHIFT   CSI_CR133_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR133_PIXEL_COUNTERS(x)   CSI_CR133_PIXEL_COUNTERS(x)
#define CSI_CSICR134_PIXEL_COUNTERS_MASK   CSI_CR134_PIXEL_COUNTERS_MASK
#define CSI_CSICR134_PIXEL_COUNTERS_SHIFT   CSI_CR134_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR134_PIXEL_COUNTERS(x)   CSI_CR134_PIXEL_COUNTERS(x)
#define CSI_CSICR135_PIXEL_COUNTERS_MASK   CSI_CR135_PIXEL_COUNTERS_MASK
#define CSI_CSICR135_PIXEL_COUNTERS_SHIFT   CSI_CR135_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR135_PIXEL_COUNTERS(x)   CSI_CR135_PIXEL_COUNTERS(x)
#define CSI_CSICR136_PIXEL_COUNTERS_MASK   CSI_CR136_PIXEL_COUNTERS_MASK
#define CSI_CSICR136_PIXEL_COUNTERS_SHIFT   CSI_CR136_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR136_PIXEL_COUNTERS(x)   CSI_CR136_PIXEL_COUNTERS(x)
#define CSI_CSICR137_PIXEL_COUNTERS_MASK   CSI_CR137_PIXEL_COUNTERS_MASK
#define CSI_CSICR137_PIXEL_COUNTERS_SHIFT   CSI_CR137_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR137_PIXEL_COUNTERS(x)   CSI_CR137_PIXEL_COUNTERS(x)
#define CSI_CSICR138_PIXEL_COUNTERS_MASK   CSI_CR138_PIXEL_COUNTERS_MASK
#define CSI_CSICR138_PIXEL_COUNTERS_SHIFT   CSI_CR138_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR138_PIXEL_COUNTERS(x)   CSI_CR138_PIXEL_COUNTERS(x)
#define CSI_CSICR139_PIXEL_COUNTERS_MASK   CSI_CR139_PIXEL_COUNTERS_MASK
#define CSI_CSICR139_PIXEL_COUNTERS_SHIFT   CSI_CR139_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR139_PIXEL_COUNTERS(x)   CSI_CR139_PIXEL_COUNTERS(x)
#define CSI_CSICR140_PIXEL_COUNTERS_MASK   CSI_CR140_PIXEL_COUNTERS_MASK
#define CSI_CSICR140_PIXEL_COUNTERS_SHIFT   CSI_CR140_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR140_PIXEL_COUNTERS(x)   CSI_CR140_PIXEL_COUNTERS(x)
#define CSI_CSICR141_PIXEL_COUNTERS_MASK   CSI_CR141_PIXEL_COUNTERS_MASK
#define CSI_CSICR141_PIXEL_COUNTERS_SHIFT   CSI_CR141_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR141_PIXEL_COUNTERS(x)   CSI_CR141_PIXEL_COUNTERS(x)
#define CSI_CSICR142_PIXEL_COUNTERS_MASK   CSI_CR142_PIXEL_COUNTERS_MASK
#define CSI_CSICR142_PIXEL_COUNTERS_SHIFT   CSI_CR142_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR142_PIXEL_COUNTERS(x)   CSI_CR142_PIXEL_COUNTERS(x)
#define CSI_CSICR143_PIXEL_COUNTERS_MASK   CSI_CR143_PIXEL_COUNTERS_MASK
#define CSI_CSICR143_PIXEL_COUNTERS_SHIFT   CSI_CR143_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR143_PIXEL_COUNTERS(x)   CSI_CR143_PIXEL_COUNTERS(x)
#define CSI_CSICR144_PIXEL_COUNTERS_MASK   CSI_CR144_PIXEL_COUNTERS_MASK
#define CSI_CSICR144_PIXEL_COUNTERS_SHIFT   CSI_CR144_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR144_PIXEL_COUNTERS(x)   CSI_CR144_PIXEL_COUNTERS(x)
#define CSI_CSICR145_PIXEL_COUNTERS_MASK   CSI_CR145_PIXEL_COUNTERS_MASK
#define CSI_CSICR145_PIXEL_COUNTERS_SHIFT   CSI_CR145_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR145_PIXEL_COUNTERS(x)   CSI_CR145_PIXEL_COUNTERS(x)
#define CSI_CSICR146_PIXEL_COUNTERS_MASK   CSI_CR146_PIXEL_COUNTERS_MASK
#define CSI_CSICR146_PIXEL_COUNTERS_SHIFT   CSI_CR146_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR146_PIXEL_COUNTERS(x)   CSI_CR146_PIXEL_COUNTERS(x)
#define CSI_CSICR147_PIXEL_COUNTERS_MASK   CSI_CR147_PIXEL_COUNTERS_MASK
#define CSI_CSICR147_PIXEL_COUNTERS_SHIFT   CSI_CR147_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR147_PIXEL_COUNTERS(x)   CSI_CR147_PIXEL_COUNTERS(x)
#define CSI_CSICR148_PIXEL_COUNTERS_MASK   CSI_CR148_PIXEL_COUNTERS_MASK
#define CSI_CSICR148_PIXEL_COUNTERS_SHIFT   CSI_CR148_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR148_PIXEL_COUNTERS(x)   CSI_CR148_PIXEL_COUNTERS(x)
#define CSI_CSICR149_PIXEL_COUNTERS_MASK   CSI_CR149_PIXEL_COUNTERS_MASK
#define CSI_CSICR149_PIXEL_COUNTERS_SHIFT   CSI_CR149_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR149_PIXEL_COUNTERS(x)   CSI_CR149_PIXEL_COUNTERS(x)
#define CSI_CSICR150_PIXEL_COUNTERS_MASK   CSI_CR150_PIXEL_COUNTERS_MASK
#define CSI_CSICR150_PIXEL_COUNTERS_SHIFT   CSI_CR150_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR150_PIXEL_COUNTERS(x)   CSI_CR150_PIXEL_COUNTERS(x)
#define CSI_CSICR151_PIXEL_COUNTERS_MASK   CSI_CR151_PIXEL_COUNTERS_MASK
#define CSI_CSICR151_PIXEL_COUNTERS_SHIFT   CSI_CR151_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR151_PIXEL_COUNTERS(x)   CSI_CR151_PIXEL_COUNTERS(x)
#define CSI_CSICR152_PIXEL_COUNTERS_MASK   CSI_CR152_PIXEL_COUNTERS_MASK
#define CSI_CSICR152_PIXEL_COUNTERS_SHIFT   CSI_CR152_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR152_PIXEL_COUNTERS(x)   CSI_CR152_PIXEL_COUNTERS(x)
#define CSI_CSICR153_PIXEL_COUNTERS_MASK   CSI_CR153_PIXEL_COUNTERS_MASK
#define CSI_CSICR153_PIXEL_COUNTERS_SHIFT   CSI_CR153_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR153_PIXEL_COUNTERS(x)   CSI_CR153_PIXEL_COUNTERS(x)
#define CSI_CSICR154_PIXEL_COUNTERS_MASK   CSI_CR154_PIXEL_COUNTERS_MASK
#define CSI_CSICR154_PIXEL_COUNTERS_SHIFT   CSI_CR154_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR154_PIXEL_COUNTERS(x)   CSI_CR154_PIXEL_COUNTERS(x)
#define CSI_CSICR155_PIXEL_COUNTERS_MASK   CSI_CR155_PIXEL_COUNTERS_MASK
#define CSI_CSICR155_PIXEL_COUNTERS_SHIFT   CSI_CR155_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR155_PIXEL_COUNTERS(x)   CSI_CR155_PIXEL_COUNTERS(x)
#define CSI_CSICR156_PIXEL_COUNTERS_MASK   CSI_CR156_PIXEL_COUNTERS_MASK
#define CSI_CSICR156_PIXEL_COUNTERS_SHIFT   CSI_CR156_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR156_PIXEL_COUNTERS(x)   CSI_CR156_PIXEL_COUNTERS(x)
#define CSI_CSICR157_PIXEL_COUNTERS_MASK   CSI_CR157_PIXEL_COUNTERS_MASK
#define CSI_CSICR157_PIXEL_COUNTERS_SHIFT   CSI_CR157_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR157_PIXEL_COUNTERS(x)   CSI_CR157_PIXEL_COUNTERS(x)
#define CSI_CSICR158_PIXEL_COUNTERS_MASK   CSI_CR158_PIXEL_COUNTERS_MASK
#define CSI_CSICR158_PIXEL_COUNTERS_SHIFT   CSI_CR158_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR158_PIXEL_COUNTERS(x)   CSI_CR158_PIXEL_COUNTERS(x)
#define CSI_CSICR159_PIXEL_COUNTERS_MASK   CSI_CR159_PIXEL_COUNTERS_MASK
#define CSI_CSICR159_PIXEL_COUNTERS_SHIFT   CSI_CR159_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR159_PIXEL_COUNTERS(x)   CSI_CR159_PIXEL_COUNTERS(x)
#define CSI_CSICR160_PIXEL_COUNTERS_MASK   CSI_CR160_PIXEL_COUNTERS_MASK
#define CSI_CSICR160_PIXEL_COUNTERS_SHIFT   CSI_CR160_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR160_PIXEL_COUNTERS(x)   CSI_CR160_PIXEL_COUNTERS(x)
#define CSI_CSICR161_PIXEL_COUNTERS_MASK   CSI_CR161_PIXEL_COUNTERS_MASK
#define CSI_CSICR161_PIXEL_COUNTERS_SHIFT   CSI_CR161_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR161_PIXEL_COUNTERS(x)   CSI_CR161_PIXEL_COUNTERS(x)
#define CSI_CSICR162_PIXEL_COUNTERS_MASK   CSI_CR162_PIXEL_COUNTERS_MASK
#define CSI_CSICR162_PIXEL_COUNTERS_SHIFT   CSI_CR162_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR162_PIXEL_COUNTERS(x)   CSI_CR162_PIXEL_COUNTERS(x)
#define CSI_CSICR163_PIXEL_COUNTERS_MASK   CSI_CR163_PIXEL_COUNTERS_MASK
#define CSI_CSICR163_PIXEL_COUNTERS_SHIFT   CSI_CR163_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR163_PIXEL_COUNTERS(x)   CSI_CR163_PIXEL_COUNTERS(x)
#define CSI_CSICR164_PIXEL_COUNTERS_MASK   CSI_CR164_PIXEL_COUNTERS_MASK
#define CSI_CSICR164_PIXEL_COUNTERS_SHIFT   CSI_CR164_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR164_PIXEL_COUNTERS(x)   CSI_CR164_PIXEL_COUNTERS(x)
#define CSI_CSICR165_PIXEL_COUNTERS_MASK   CSI_CR165_PIXEL_COUNTERS_MASK
#define CSI_CSICR165_PIXEL_COUNTERS_SHIFT   CSI_CR165_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR165_PIXEL_COUNTERS(x)   CSI_CR165_PIXEL_COUNTERS(x)
#define CSI_CSICR166_PIXEL_COUNTERS_MASK   CSI_CR166_PIXEL_COUNTERS_MASK
#define CSI_CSICR166_PIXEL_COUNTERS_SHIFT   CSI_CR166_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR166_PIXEL_COUNTERS(x)   CSI_CR166_PIXEL_COUNTERS(x)
#define CSI_CSICR167_PIXEL_COUNTERS_MASK   CSI_CR167_PIXEL_COUNTERS_MASK
#define CSI_CSICR167_PIXEL_COUNTERS_SHIFT   CSI_CR167_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR167_PIXEL_COUNTERS(x)   CSI_CR167_PIXEL_COUNTERS(x)
#define CSI_CSICR168_PIXEL_COUNTERS_MASK   CSI_CR168_PIXEL_COUNTERS_MASK
#define CSI_CSICR168_PIXEL_COUNTERS_SHIFT   CSI_CR168_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR168_PIXEL_COUNTERS(x)   CSI_CR168_PIXEL_COUNTERS(x)
#define CSI_CSICR169_PIXEL_COUNTERS_MASK   CSI_CR169_PIXEL_COUNTERS_MASK
#define CSI_CSICR169_PIXEL_COUNTERS_SHIFT   CSI_CR169_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR169_PIXEL_COUNTERS(x)   CSI_CR169_PIXEL_COUNTERS(x)
#define CSI_CSICR170_PIXEL_COUNTERS_MASK   CSI_CR170_PIXEL_COUNTERS_MASK
#define CSI_CSICR170_PIXEL_COUNTERS_SHIFT   CSI_CR170_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR170_PIXEL_COUNTERS(x)   CSI_CR170_PIXEL_COUNTERS(x)
#define CSI_CSICR171_PIXEL_COUNTERS_MASK   CSI_CR171_PIXEL_COUNTERS_MASK
#define CSI_CSICR171_PIXEL_COUNTERS_SHIFT   CSI_CR171_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR171_PIXEL_COUNTERS(x)   CSI_CR171_PIXEL_COUNTERS(x)
#define CSI_CSICR172_PIXEL_COUNTERS_MASK   CSI_CR172_PIXEL_COUNTERS_MASK
#define CSI_CSICR172_PIXEL_COUNTERS_SHIFT   CSI_CR172_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR172_PIXEL_COUNTERS(x)   CSI_CR172_PIXEL_COUNTERS(x)
#define CSI_CSICR173_PIXEL_COUNTERS_MASK   CSI_CR173_PIXEL_COUNTERS_MASK
#define CSI_CSICR173_PIXEL_COUNTERS_SHIFT   CSI_CR173_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR173_PIXEL_COUNTERS(x)   CSI_CR173_PIXEL_COUNTERS(x)
#define CSI_CSICR174_PIXEL_COUNTERS_MASK   CSI_CR174_PIXEL_COUNTERS_MASK
#define CSI_CSICR174_PIXEL_COUNTERS_SHIFT   CSI_CR174_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR174_PIXEL_COUNTERS(x)   CSI_CR174_PIXEL_COUNTERS(x)
#define CSI_CSICR175_PIXEL_COUNTERS_MASK   CSI_CR175_PIXEL_COUNTERS_MASK
#define CSI_CSICR175_PIXEL_COUNTERS_SHIFT   CSI_CR175_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR175_PIXEL_COUNTERS(x)   CSI_CR175_PIXEL_COUNTERS(x)
#define CSI_CSICR176_PIXEL_COUNTERS_MASK   CSI_CR176_PIXEL_COUNTERS_MASK
#define CSI_CSICR176_PIXEL_COUNTERS_SHIFT   CSI_CR176_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR176_PIXEL_COUNTERS(x)   CSI_CR176_PIXEL_COUNTERS(x)
#define CSI_CSICR177_PIXEL_COUNTERS_MASK   CSI_CR177_PIXEL_COUNTERS_MASK
#define CSI_CSICR177_PIXEL_COUNTERS_SHIFT   CSI_CR177_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR177_PIXEL_COUNTERS(x)   CSI_CR177_PIXEL_COUNTERS(x)
#define CSI_CSICR178_PIXEL_COUNTERS_MASK   CSI_CR178_PIXEL_COUNTERS_MASK
#define CSI_CSICR178_PIXEL_COUNTERS_SHIFT   CSI_CR178_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR178_PIXEL_COUNTERS(x)   CSI_CR178_PIXEL_COUNTERS(x)
#define CSI_CSICR179_PIXEL_COUNTERS_MASK   CSI_CR179_PIXEL_COUNTERS_MASK
#define CSI_CSICR179_PIXEL_COUNTERS_SHIFT   CSI_CR179_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR179_PIXEL_COUNTERS(x)   CSI_CR179_PIXEL_COUNTERS(x)
#define CSI_CSICR180_PIXEL_COUNTERS_MASK   CSI_CR180_PIXEL_COUNTERS_MASK
#define CSI_CSICR180_PIXEL_COUNTERS_SHIFT   CSI_CR180_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR180_PIXEL_COUNTERS(x)   CSI_CR180_PIXEL_COUNTERS(x)
#define CSI_CSICR181_PIXEL_COUNTERS_MASK   CSI_CR181_PIXEL_COUNTERS_MASK
#define CSI_CSICR181_PIXEL_COUNTERS_SHIFT   CSI_CR181_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR181_PIXEL_COUNTERS(x)   CSI_CR181_PIXEL_COUNTERS(x)
#define CSI_CSICR182_PIXEL_COUNTERS_MASK   CSI_CR182_PIXEL_COUNTERS_MASK
#define CSI_CSICR182_PIXEL_COUNTERS_SHIFT   CSI_CR182_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR182_PIXEL_COUNTERS(x)   CSI_CR182_PIXEL_COUNTERS(x)
#define CSI_CSICR183_PIXEL_COUNTERS_MASK   CSI_CR183_PIXEL_COUNTERS_MASK
#define CSI_CSICR183_PIXEL_COUNTERS_SHIFT   CSI_CR183_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR183_PIXEL_COUNTERS(x)   CSI_CR183_PIXEL_COUNTERS(x)
#define CSI_CSICR184_PIXEL_COUNTERS_MASK   CSI_CR184_PIXEL_COUNTERS_MASK
#define CSI_CSICR184_PIXEL_COUNTERS_SHIFT   CSI_CR184_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR184_PIXEL_COUNTERS(x)   CSI_CR184_PIXEL_COUNTERS(x)
#define CSI_CSICR185_PIXEL_COUNTERS_MASK   CSI_CR185_PIXEL_COUNTERS_MASK
#define CSI_CSICR185_PIXEL_COUNTERS_SHIFT   CSI_CR185_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR185_PIXEL_COUNTERS(x)   CSI_CR185_PIXEL_COUNTERS(x)
#define CSI_CSICR186_PIXEL_COUNTERS_MASK   CSI_CR186_PIXEL_COUNTERS_MASK
#define CSI_CSICR186_PIXEL_COUNTERS_SHIFT   CSI_CR186_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR186_PIXEL_COUNTERS(x)   CSI_CR186_PIXEL_COUNTERS(x)
#define CSI_CSICR187_PIXEL_COUNTERS_MASK   CSI_CR187_PIXEL_COUNTERS_MASK
#define CSI_CSICR187_PIXEL_COUNTERS_SHIFT   CSI_CR187_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR187_PIXEL_COUNTERS(x)   CSI_CR187_PIXEL_COUNTERS(x)
#define CSI_CSICR188_PIXEL_COUNTERS_MASK   CSI_CR188_PIXEL_COUNTERS_MASK
#define CSI_CSICR188_PIXEL_COUNTERS_SHIFT   CSI_CR188_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR188_PIXEL_COUNTERS(x)   CSI_CR188_PIXEL_COUNTERS(x)
#define CSI_CSICR189_PIXEL_COUNTERS_MASK   CSI_CR189_PIXEL_COUNTERS_MASK
#define CSI_CSICR189_PIXEL_COUNTERS_SHIFT   CSI_CR189_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR189_PIXEL_COUNTERS(x)   CSI_CR189_PIXEL_COUNTERS(x)
#define CSI_CSICR190_PIXEL_COUNTERS_MASK   CSI_CR190_PIXEL_COUNTERS_MASK
#define CSI_CSICR190_PIXEL_COUNTERS_SHIFT   CSI_CR190_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR190_PIXEL_COUNTERS(x)   CSI_CR190_PIXEL_COUNTERS(x)
#define CSI_CSICR191_PIXEL_COUNTERS_MASK   CSI_CR191_PIXEL_COUNTERS_MASK
#define CSI_CSICR191_PIXEL_COUNTERS_SHIFT   CSI_CR191_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR191_PIXEL_COUNTERS(x)   CSI_CR191_PIXEL_COUNTERS(x)
#define CSI_CSICR192_PIXEL_COUNTERS_MASK   CSI_CR192_PIXEL_COUNTERS_MASK
#define CSI_CSICR192_PIXEL_COUNTERS_SHIFT   CSI_CR192_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR192_PIXEL_COUNTERS(x)   CSI_CR192_PIXEL_COUNTERS(x)
#define CSI_CSICR193_PIXEL_COUNTERS_MASK   CSI_CR193_PIXEL_COUNTERS_MASK
#define CSI_CSICR193_PIXEL_COUNTERS_SHIFT   CSI_CR193_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR193_PIXEL_COUNTERS(x)   CSI_CR193_PIXEL_COUNTERS(x)
#define CSI_CSICR194_PIXEL_COUNTERS_MASK   CSI_CR194_PIXEL_COUNTERS_MASK
#define CSI_CSICR194_PIXEL_COUNTERS_SHIFT   CSI_CR194_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR194_PIXEL_COUNTERS(x)   CSI_CR194_PIXEL_COUNTERS(x)
#define CSI_CSICR195_PIXEL_COUNTERS_MASK   CSI_CR195_PIXEL_COUNTERS_MASK
#define CSI_CSICR195_PIXEL_COUNTERS_SHIFT   CSI_CR195_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR195_PIXEL_COUNTERS(x)   CSI_CR195_PIXEL_COUNTERS(x)
#define CSI_CSICR196_PIXEL_COUNTERS_MASK   CSI_CR196_PIXEL_COUNTERS_MASK
#define CSI_CSICR196_PIXEL_COUNTERS_SHIFT   CSI_CR196_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR196_PIXEL_COUNTERS(x)   CSI_CR196_PIXEL_COUNTERS(x)
#define CSI_CSICR197_PIXEL_COUNTERS_MASK   CSI_CR197_PIXEL_COUNTERS_MASK
#define CSI_CSICR197_PIXEL_COUNTERS_SHIFT   CSI_CR197_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR197_PIXEL_COUNTERS(x)   CSI_CR197_PIXEL_COUNTERS(x)
#define CSI_CSICR198_PIXEL_COUNTERS_MASK   CSI_CR198_PIXEL_COUNTERS_MASK
#define CSI_CSICR198_PIXEL_COUNTERS_SHIFT   CSI_CR198_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR198_PIXEL_COUNTERS(x)   CSI_CR198_PIXEL_COUNTERS(x)
#define CSI_CSICR199_PIXEL_COUNTERS_MASK   CSI_CR199_PIXEL_COUNTERS_MASK
#define CSI_CSICR199_PIXEL_COUNTERS_SHIFT   CSI_CR199_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR199_PIXEL_COUNTERS(x)   CSI_CR199_PIXEL_COUNTERS(x)
#define CSI_CSICR200_PIXEL_COUNTERS_MASK   CSI_CR200_PIXEL_COUNTERS_MASK
#define CSI_CSICR200_PIXEL_COUNTERS_SHIFT   CSI_CR200_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR200_PIXEL_COUNTERS(x)   CSI_CR200_PIXEL_COUNTERS(x)
#define CSI_CSICR201_PIXEL_COUNTERS_MASK   CSI_CR201_PIXEL_COUNTERS_MASK
#define CSI_CSICR201_PIXEL_COUNTERS_SHIFT   CSI_CR201_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR201_PIXEL_COUNTERS(x)   CSI_CR201_PIXEL_COUNTERS(x)
#define CSI_CSICR202_PIXEL_COUNTERS_MASK   CSI_CR202_PIXEL_COUNTERS_MASK
#define CSI_CSICR202_PIXEL_COUNTERS_SHIFT   CSI_CR202_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR202_PIXEL_COUNTERS(x)   CSI_CR202_PIXEL_COUNTERS(x)
#define CSI_CSICR203_PIXEL_COUNTERS_MASK   CSI_CR203_PIXEL_COUNTERS_MASK
#define CSI_CSICR203_PIXEL_COUNTERS_SHIFT   CSI_CR203_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR203_PIXEL_COUNTERS(x)   CSI_CR203_PIXEL_COUNTERS(x)
#define CSI_CSICR204_PIXEL_COUNTERS_MASK   CSI_CR204_PIXEL_COUNTERS_MASK
#define CSI_CSICR204_PIXEL_COUNTERS_SHIFT   CSI_CR204_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR204_PIXEL_COUNTERS(x)   CSI_CR204_PIXEL_COUNTERS(x)
#define CSI_CSICR205_PIXEL_COUNTERS_MASK   CSI_CR205_PIXEL_COUNTERS_MASK
#define CSI_CSICR205_PIXEL_COUNTERS_SHIFT   CSI_CR205_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR205_PIXEL_COUNTERS(x)   CSI_CR205_PIXEL_COUNTERS(x)
#define CSI_CSICR206_PIXEL_COUNTERS_MASK   CSI_CR206_PIXEL_COUNTERS_MASK
#define CSI_CSICR206_PIXEL_COUNTERS_SHIFT   CSI_CR206_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR206_PIXEL_COUNTERS(x)   CSI_CR206_PIXEL_COUNTERS(x)
#define CSI_CSICR207_PIXEL_COUNTERS_MASK   CSI_CR207_PIXEL_COUNTERS_MASK
#define CSI_CSICR207_PIXEL_COUNTERS_SHIFT   CSI_CR207_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR207_PIXEL_COUNTERS(x)   CSI_CR207_PIXEL_COUNTERS(x)
#define CSI_CSICR208_PIXEL_COUNTERS_MASK   CSI_CR208_PIXEL_COUNTERS_MASK
#define CSI_CSICR208_PIXEL_COUNTERS_SHIFT   CSI_CR208_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR208_PIXEL_COUNTERS(x)   CSI_CR208_PIXEL_COUNTERS(x)
#define CSI_CSICR209_PIXEL_COUNTERS_MASK   CSI_CR209_PIXEL_COUNTERS_MASK
#define CSI_CSICR209_PIXEL_COUNTERS_SHIFT   CSI_CR209_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR209_PIXEL_COUNTERS(x)   CSI_CR209_PIXEL_COUNTERS(x)
#define CSI_CSICR210_PIXEL_COUNTERS_MASK   CSI_CR210_PIXEL_COUNTERS_MASK
#define CSI_CSICR210_PIXEL_COUNTERS_SHIFT   CSI_CR210_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR210_PIXEL_COUNTERS(x)   CSI_CR210_PIXEL_COUNTERS(x)
#define CSI_CSICR211_PIXEL_COUNTERS_MASK   CSI_CR211_PIXEL_COUNTERS_MASK
#define CSI_CSICR211_PIXEL_COUNTERS_SHIFT   CSI_CR211_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR211_PIXEL_COUNTERS(x)   CSI_CR211_PIXEL_COUNTERS(x)
#define CSI_CSICR212_PIXEL_COUNTERS_MASK   CSI_CR212_PIXEL_COUNTERS_MASK
#define CSI_CSICR212_PIXEL_COUNTERS_SHIFT   CSI_CR212_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR212_PIXEL_COUNTERS(x)   CSI_CR212_PIXEL_COUNTERS(x)
#define CSI_CSICR213_PIXEL_COUNTERS_MASK   CSI_CR213_PIXEL_COUNTERS_MASK
#define CSI_CSICR213_PIXEL_COUNTERS_SHIFT   CSI_CR213_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR213_PIXEL_COUNTERS(x)   CSI_CR213_PIXEL_COUNTERS(x)
#define CSI_CSICR214_PIXEL_COUNTERS_MASK   CSI_CR214_PIXEL_COUNTERS_MASK
#define CSI_CSICR214_PIXEL_COUNTERS_SHIFT   CSI_CR214_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR214_PIXEL_COUNTERS(x)   CSI_CR214_PIXEL_COUNTERS(x)
#define CSI_CSICR215_PIXEL_COUNTERS_MASK   CSI_CR215_PIXEL_COUNTERS_MASK
#define CSI_CSICR215_PIXEL_COUNTERS_SHIFT   CSI_CR215_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR215_PIXEL_COUNTERS(x)   CSI_CR215_PIXEL_COUNTERS(x)
#define CSI_CSICR216_PIXEL_COUNTERS_MASK   CSI_CR216_PIXEL_COUNTERS_MASK
#define CSI_CSICR216_PIXEL_COUNTERS_SHIFT   CSI_CR216_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR216_PIXEL_COUNTERS(x)   CSI_CR216_PIXEL_COUNTERS(x)
#define CSI_CSICR217_PIXEL_COUNTERS_MASK   CSI_CR217_PIXEL_COUNTERS_MASK
#define CSI_CSICR217_PIXEL_COUNTERS_SHIFT   CSI_CR217_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR217_PIXEL_COUNTERS(x)   CSI_CR217_PIXEL_COUNTERS(x)
#define CSI_CSICR218_PIXEL_COUNTERS_MASK   CSI_CR218_PIXEL_COUNTERS_MASK
#define CSI_CSICR218_PIXEL_COUNTERS_SHIFT   CSI_CR218_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR218_PIXEL_COUNTERS(x)   CSI_CR218_PIXEL_COUNTERS(x)
#define CSI_CSICR219_PIXEL_COUNTERS_MASK   CSI_CR219_PIXEL_COUNTERS_MASK
#define CSI_CSICR219_PIXEL_COUNTERS_SHIFT   CSI_CR219_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR219_PIXEL_COUNTERS(x)   CSI_CR219_PIXEL_COUNTERS(x)
#define CSI_CSICR220_PIXEL_COUNTERS_MASK   CSI_CR220_PIXEL_COUNTERS_MASK
#define CSI_CSICR220_PIXEL_COUNTERS_SHIFT   CSI_CR220_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR220_PIXEL_COUNTERS(x)   CSI_CR220_PIXEL_COUNTERS(x)
#define CSI_CSICR221_PIXEL_COUNTERS_MASK   CSI_CR221_PIXEL_COUNTERS_MASK
#define CSI_CSICR221_PIXEL_COUNTERS_SHIFT   CSI_CR221_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR221_PIXEL_COUNTERS(x)   CSI_CR221_PIXEL_COUNTERS(x)
#define CSI_CSICR222_PIXEL_COUNTERS_MASK   CSI_CR222_PIXEL_COUNTERS_MASK
#define CSI_CSICR222_PIXEL_COUNTERS_SHIFT   CSI_CR222_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR222_PIXEL_COUNTERS(x)   CSI_CR222_PIXEL_COUNTERS(x)
#define CSI_CSICR223_PIXEL_COUNTERS_MASK   CSI_CR223_PIXEL_COUNTERS_MASK
#define CSI_CSICR223_PIXEL_COUNTERS_SHIFT   CSI_CR223_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR223_PIXEL_COUNTERS(x)   CSI_CR223_PIXEL_COUNTERS(x)
#define CSI_CSICR224_PIXEL_COUNTERS_MASK   CSI_CR224_PIXEL_COUNTERS_MASK
#define CSI_CSICR224_PIXEL_COUNTERS_SHIFT   CSI_CR224_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR224_PIXEL_COUNTERS(x)   CSI_CR224_PIXEL_COUNTERS(x)
#define CSI_CSICR225_PIXEL_COUNTERS_MASK   CSI_CR225_PIXEL_COUNTERS_MASK
#define CSI_CSICR225_PIXEL_COUNTERS_SHIFT   CSI_CR225_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR225_PIXEL_COUNTERS(x)   CSI_CR225_PIXEL_COUNTERS(x)
#define CSI_CSICR226_PIXEL_COUNTERS_MASK   CSI_CR226_PIXEL_COUNTERS_MASK
#define CSI_CSICR226_PIXEL_COUNTERS_SHIFT   CSI_CR226_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR226_PIXEL_COUNTERS(x)   CSI_CR226_PIXEL_COUNTERS(x)
#define CSI_CSICR227_PIXEL_COUNTERS_MASK   CSI_CR227_PIXEL_COUNTERS_MASK
#define CSI_CSICR227_PIXEL_COUNTERS_SHIFT   CSI_CR227_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR227_PIXEL_COUNTERS(x)   CSI_CR227_PIXEL_COUNTERS(x)
#define CSI_CSICR228_PIXEL_COUNTERS_MASK   CSI_CR228_PIXEL_COUNTERS_MASK
#define CSI_CSICR228_PIXEL_COUNTERS_SHIFT   CSI_CR228_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR228_PIXEL_COUNTERS(x)   CSI_CR228_PIXEL_COUNTERS(x)
#define CSI_CSICR229_PIXEL_COUNTERS_MASK   CSI_CR229_PIXEL_COUNTERS_MASK
#define CSI_CSICR229_PIXEL_COUNTERS_SHIFT   CSI_CR229_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR229_PIXEL_COUNTERS(x)   CSI_CR229_PIXEL_COUNTERS(x)
#define CSI_CSICR230_PIXEL_COUNTERS_MASK   CSI_CR230_PIXEL_COUNTERS_MASK
#define CSI_CSICR230_PIXEL_COUNTERS_SHIFT   CSI_CR230_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR230_PIXEL_COUNTERS(x)   CSI_CR230_PIXEL_COUNTERS(x)
#define CSI_CSICR231_PIXEL_COUNTERS_MASK   CSI_CR231_PIXEL_COUNTERS_MASK
#define CSI_CSICR231_PIXEL_COUNTERS_SHIFT   CSI_CR231_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR231_PIXEL_COUNTERS(x)   CSI_CR231_PIXEL_COUNTERS(x)
#define CSI_CSICR232_PIXEL_COUNTERS_MASK   CSI_CR232_PIXEL_COUNTERS_MASK
#define CSI_CSICR232_PIXEL_COUNTERS_SHIFT   CSI_CR232_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR232_PIXEL_COUNTERS(x)   CSI_CR232_PIXEL_COUNTERS(x)
#define CSI_CSICR233_PIXEL_COUNTERS_MASK   CSI_CR233_PIXEL_COUNTERS_MASK
#define CSI_CSICR233_PIXEL_COUNTERS_SHIFT   CSI_CR233_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR233_PIXEL_COUNTERS(x)   CSI_CR233_PIXEL_COUNTERS(x)
#define CSI_CSICR234_PIXEL_COUNTERS_MASK   CSI_CR234_PIXEL_COUNTERS_MASK
#define CSI_CSICR234_PIXEL_COUNTERS_SHIFT   CSI_CR234_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR234_PIXEL_COUNTERS(x)   CSI_CR234_PIXEL_COUNTERS(x)
#define CSI_CSICR235_PIXEL_COUNTERS_MASK   CSI_CR235_PIXEL_COUNTERS_MASK
#define CSI_CSICR235_PIXEL_COUNTERS_SHIFT   CSI_CR235_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR235_PIXEL_COUNTERS(x)   CSI_CR235_PIXEL_COUNTERS(x)
#define CSI_CSICR236_PIXEL_COUNTERS_MASK   CSI_CR236_PIXEL_COUNTERS_MASK
#define CSI_CSICR236_PIXEL_COUNTERS_SHIFT   CSI_CR236_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR236_PIXEL_COUNTERS(x)   CSI_CR236_PIXEL_COUNTERS(x)
#define CSI_CSICR237_PIXEL_COUNTERS_MASK   CSI_CR237_PIXEL_COUNTERS_MASK
#define CSI_CSICR237_PIXEL_COUNTERS_SHIFT   CSI_CR237_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR237_PIXEL_COUNTERS(x)   CSI_CR237_PIXEL_COUNTERS(x)
#define CSI_CSICR238_PIXEL_COUNTERS_MASK   CSI_CR238_PIXEL_COUNTERS_MASK
#define CSI_CSICR238_PIXEL_COUNTERS_SHIFT   CSI_CR238_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR238_PIXEL_COUNTERS(x)   CSI_CR238_PIXEL_COUNTERS(x)
#define CSI_CSICR239_PIXEL_COUNTERS_MASK   CSI_CR239_PIXEL_COUNTERS_MASK
#define CSI_CSICR239_PIXEL_COUNTERS_SHIFT   CSI_CR239_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR239_PIXEL_COUNTERS(x)   CSI_CR239_PIXEL_COUNTERS(x)
#define CSI_CSICR240_PIXEL_COUNTERS_MASK   CSI_CR240_PIXEL_COUNTERS_MASK
#define CSI_CSICR240_PIXEL_COUNTERS_SHIFT   CSI_CR240_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR240_PIXEL_COUNTERS(x)   CSI_CR240_PIXEL_COUNTERS(x)
#define CSI_CSICR241_PIXEL_COUNTERS_MASK   CSI_CR241_PIXEL_COUNTERS_MASK
#define CSI_CSICR241_PIXEL_COUNTERS_SHIFT   CSI_CR241_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR241_PIXEL_COUNTERS(x)   CSI_CR241_PIXEL_COUNTERS(x)
#define CSI_CSICR242_PIXEL_COUNTERS_MASK   CSI_CR242_PIXEL_COUNTERS_MASK
#define CSI_CSICR242_PIXEL_COUNTERS_SHIFT   CSI_CR242_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR242_PIXEL_COUNTERS(x)   CSI_CR242_PIXEL_COUNTERS(x)
#define CSI_CSICR243_PIXEL_COUNTERS_MASK   CSI_CR243_PIXEL_COUNTERS_MASK
#define CSI_CSICR243_PIXEL_COUNTERS_SHIFT   CSI_CR243_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR243_PIXEL_COUNTERS(x)   CSI_CR243_PIXEL_COUNTERS(x)
#define CSI_CSICR244_PIXEL_COUNTERS_MASK   CSI_CR244_PIXEL_COUNTERS_MASK
#define CSI_CSICR244_PIXEL_COUNTERS_SHIFT   CSI_CR244_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR244_PIXEL_COUNTERS(x)   CSI_CR244_PIXEL_COUNTERS(x)
#define CSI_CSICR245_PIXEL_COUNTERS_MASK   CSI_CR245_PIXEL_COUNTERS_MASK
#define CSI_CSICR245_PIXEL_COUNTERS_SHIFT   CSI_CR245_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR245_PIXEL_COUNTERS(x)   CSI_CR245_PIXEL_COUNTERS(x)
#define CSI_CSICR246_PIXEL_COUNTERS_MASK   CSI_CR246_PIXEL_COUNTERS_MASK
#define CSI_CSICR246_PIXEL_COUNTERS_SHIFT   CSI_CR246_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR246_PIXEL_COUNTERS(x)   CSI_CR246_PIXEL_COUNTERS(x)
#define CSI_CSICR247_PIXEL_COUNTERS_MASK   CSI_CR247_PIXEL_COUNTERS_MASK
#define CSI_CSICR247_PIXEL_COUNTERS_SHIFT   CSI_CR247_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR247_PIXEL_COUNTERS(x)   CSI_CR247_PIXEL_COUNTERS(x)
#define CSI_CSICR248_PIXEL_COUNTERS_MASK   CSI_CR248_PIXEL_COUNTERS_MASK
#define CSI_CSICR248_PIXEL_COUNTERS_SHIFT   CSI_CR248_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR248_PIXEL_COUNTERS(x)   CSI_CR248_PIXEL_COUNTERS(x)
#define CSI_CSICR249_PIXEL_COUNTERS_MASK   CSI_CR249_PIXEL_COUNTERS_MASK
#define CSI_CSICR249_PIXEL_COUNTERS_SHIFT   CSI_CR249_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR249_PIXEL_COUNTERS(x)   CSI_CR249_PIXEL_COUNTERS(x)
#define CSI_CSICR250_PIXEL_COUNTERS_MASK   CSI_CR250_PIXEL_COUNTERS_MASK
#define CSI_CSICR250_PIXEL_COUNTERS_SHIFT   CSI_CR250_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR250_PIXEL_COUNTERS(x)   CSI_CR250_PIXEL_COUNTERS(x)
#define CSI_CSICR251_PIXEL_COUNTERS_MASK   CSI_CR251_PIXEL_COUNTERS_MASK
#define CSI_CSICR251_PIXEL_COUNTERS_SHIFT   CSI_CR251_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR251_PIXEL_COUNTERS(x)   CSI_CR251_PIXEL_COUNTERS(x)
#define CSI_CSICR252_PIXEL_COUNTERS_MASK   CSI_CR252_PIXEL_COUNTERS_MASK
#define CSI_CSICR252_PIXEL_COUNTERS_SHIFT   CSI_CR252_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR252_PIXEL_COUNTERS(x)   CSI_CR252_PIXEL_COUNTERS(x)
#define CSI_CSICR253_PIXEL_COUNTERS_MASK   CSI_CR253_PIXEL_COUNTERS_MASK
#define CSI_CSICR253_PIXEL_COUNTERS_SHIFT   CSI_CR253_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR253_PIXEL_COUNTERS(x)   CSI_CR253_PIXEL_COUNTERS(x)
#define CSI_CSICR254_PIXEL_COUNTERS_MASK   CSI_CR254_PIXEL_COUNTERS_MASK
#define CSI_CSICR254_PIXEL_COUNTERS_SHIFT   CSI_CR254_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR254_PIXEL_COUNTERS(x)   CSI_CR254_PIXEL_COUNTERS(x)
#define CSI_CSICR255_PIXEL_COUNTERS_MASK   CSI_CR255_PIXEL_COUNTERS_MASK
#define CSI_CSICR255_PIXEL_COUNTERS_SHIFT   CSI_CR255_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR255_PIXEL_COUNTERS(x)   CSI_CR255_PIXEL_COUNTERS(x)
#define CSI_CSICR256_PIXEL_COUNTERS_MASK   CSI_CR256_PIXEL_COUNTERS_MASK
#define CSI_CSICR256_PIXEL_COUNTERS_SHIFT   CSI_CR256_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR256_PIXEL_COUNTERS(x)   CSI_CR256_PIXEL_COUNTERS(x)
#define CSI_CSICR257_PIXEL_COUNTERS_MASK   CSI_CR257_PIXEL_COUNTERS_MASK
#define CSI_CSICR257_PIXEL_COUNTERS_SHIFT   CSI_CR257_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR257_PIXEL_COUNTERS(x)   CSI_CR257_PIXEL_COUNTERS(x)
#define CSI_CSICR258_PIXEL_COUNTERS_MASK   CSI_CR258_PIXEL_COUNTERS_MASK
#define CSI_CSICR258_PIXEL_COUNTERS_SHIFT   CSI_CR258_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR258_PIXEL_COUNTERS(x)   CSI_CR258_PIXEL_COUNTERS(x)
#define CSI_CSICR259_PIXEL_COUNTERS_MASK   CSI_CR259_PIXEL_COUNTERS_MASK
#define CSI_CSICR259_PIXEL_COUNTERS_SHIFT   CSI_CR259_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR259_PIXEL_COUNTERS(x)   CSI_CR259_PIXEL_COUNTERS(x)
#define CSI_CSICR260_PIXEL_COUNTERS_MASK   CSI_CR260_PIXEL_COUNTERS_MASK
#define CSI_CSICR260_PIXEL_COUNTERS_SHIFT   CSI_CR260_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR260_PIXEL_COUNTERS(x)   CSI_CR260_PIXEL_COUNTERS(x)
#define CSI_CSICR261_PIXEL_COUNTERS_MASK   CSI_CR261_PIXEL_COUNTERS_MASK
#define CSI_CSICR261_PIXEL_COUNTERS_SHIFT   CSI_CR261_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR261_PIXEL_COUNTERS(x)   CSI_CR261_PIXEL_COUNTERS(x)
#define CSI_CSICR262_PIXEL_COUNTERS_MASK   CSI_CR262_PIXEL_COUNTERS_MASK
#define CSI_CSICR262_PIXEL_COUNTERS_SHIFT   CSI_CR262_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR262_PIXEL_COUNTERS(x)   CSI_CR262_PIXEL_COUNTERS(x)
#define CSI_CSICR263_PIXEL_COUNTERS_MASK   CSI_CR263_PIXEL_COUNTERS_MASK
#define CSI_CSICR263_PIXEL_COUNTERS_SHIFT   CSI_CR263_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR263_PIXEL_COUNTERS(x)   CSI_CR263_PIXEL_COUNTERS(x)
#define CSI_CSICR264_PIXEL_COUNTERS_MASK   CSI_CR264_PIXEL_COUNTERS_MASK
#define CSI_CSICR264_PIXEL_COUNTERS_SHIFT   CSI_CR264_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR264_PIXEL_COUNTERS(x)   CSI_CR264_PIXEL_COUNTERS(x)
#define CSI_CSICR265_PIXEL_COUNTERS_MASK   CSI_CR265_PIXEL_COUNTERS_MASK
#define CSI_CSICR265_PIXEL_COUNTERS_SHIFT   CSI_CR265_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR265_PIXEL_COUNTERS(x)   CSI_CR265_PIXEL_COUNTERS(x)
#define CSI_CSICR266_PIXEL_COUNTERS_MASK   CSI_CR266_PIXEL_COUNTERS_MASK
#define CSI_CSICR266_PIXEL_COUNTERS_SHIFT   CSI_CR266_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR266_PIXEL_COUNTERS(x)   CSI_CR266_PIXEL_COUNTERS(x)
#define CSI_CSICR267_PIXEL_COUNTERS_MASK   CSI_CR267_PIXEL_COUNTERS_MASK
#define CSI_CSICR267_PIXEL_COUNTERS_SHIFT   CSI_CR267_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR267_PIXEL_COUNTERS(x)   CSI_CR267_PIXEL_COUNTERS(x)
#define CSI_CSICR268_PIXEL_COUNTERS_MASK   CSI_CR268_PIXEL_COUNTERS_MASK
#define CSI_CSICR268_PIXEL_COUNTERS_SHIFT   CSI_CR268_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR268_PIXEL_COUNTERS(x)   CSI_CR268_PIXEL_COUNTERS(x)
#define CSI_CSICR269_PIXEL_COUNTERS_MASK   CSI_CR269_PIXEL_COUNTERS_MASK
#define CSI_CSICR269_PIXEL_COUNTERS_SHIFT   CSI_CR269_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR269_PIXEL_COUNTERS(x)   CSI_CR269_PIXEL_COUNTERS(x)
#define CSI_CSICR270_PIXEL_COUNTERS_MASK   CSI_CR270_PIXEL_COUNTERS_MASK
#define CSI_CSICR270_PIXEL_COUNTERS_SHIFT   CSI_CR270_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR270_PIXEL_COUNTERS(x)   CSI_CR270_PIXEL_COUNTERS(x)
#define CSI_CSICR271_PIXEL_COUNTERS_MASK   CSI_CR271_PIXEL_COUNTERS_MASK
#define CSI_CSICR271_PIXEL_COUNTERS_SHIFT   CSI_CR271_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR271_PIXEL_COUNTERS(x)   CSI_CR271_PIXEL_COUNTERS(x)
#define CSI_CSICR272_PIXEL_COUNTERS_MASK   CSI_CR272_PIXEL_COUNTERS_MASK
#define CSI_CSICR272_PIXEL_COUNTERS_SHIFT   CSI_CR272_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR272_PIXEL_COUNTERS(x)   CSI_CR272_PIXEL_COUNTERS(x)
#define CSI_CSICR273_PIXEL_COUNTERS_MASK   CSI_CR273_PIXEL_COUNTERS_MASK
#define CSI_CSICR273_PIXEL_COUNTERS_SHIFT   CSI_CR273_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR273_PIXEL_COUNTERS(x)   CSI_CR273_PIXEL_COUNTERS(x)
#define CSI_CSICR274_PIXEL_COUNTERS_MASK   CSI_CR274_PIXEL_COUNTERS_MASK
#define CSI_CSICR274_PIXEL_COUNTERS_SHIFT   CSI_CR274_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR274_PIXEL_COUNTERS(x)   CSI_CR274_PIXEL_COUNTERS(x)
#define CSI_CSICR275_PIXEL_COUNTERS_MASK   CSI_CR275_PIXEL_COUNTERS_MASK
#define CSI_CSICR275_PIXEL_COUNTERS_SHIFT   CSI_CR275_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR275_PIXEL_COUNTERS(x)   CSI_CR275_PIXEL_COUNTERS(x)
#define CSI_CSICR276_PIXEL_COUNTERS_MASK   CSI_CR276_PIXEL_COUNTERS_MASK
#define CSI_CSICR276_PIXEL_COUNTERS_SHIFT   CSI_CR276_PIXEL_COUNTERS_SHIFT
#define CSI_CSICR276_PIXEL_COUNTERS(x)   CSI_CR276_PIXEL_COUNTERS(x)
◆ CSI [1/3]
#define CSI   ((CSI_Type *)CSI_BASE)
Peripheral CSI base pointer
◆ CSI [2/3]
◆ CSI [3/3]
◆ CSI_BASE [1/3]
#define CSI_BASE   (0x402BC000u)
Peripheral CSI base address
◆ CSI_BASE [2/3]
#define CSI_BASE   (0x40800000u)
◆ CSI_BASE [3/3]
◆ CSI_BASE_ADDRS [1/3]
#define CSI_BASE_ADDRS   { CSI_BASE }
Array initializer of CSI peripheral base addresses
◆ CSI_BASE_ADDRS [2/3]
◆ CSI_BASE_ADDRS [3/3]
◆ CSI_BASE_PTRS [1/3]
#define CSI_BASE_PTRS   { CSI }
Array initializer of CSI peripheral base pointers
◆ CSI_BASE_PTRS [2/3]
◆ CSI_BASE_PTRS [3/3]
◆ CSI_IRQS [1/3]
#define CSI_IRQS   { CSI_IRQn }
Interrupt vectors for the CSI peripheral type
◆ CSI_IRQS [2/3]
◆ CSI_IRQS [3/3]
