RTEMS 6.1-rc1
#define CCM_OBS_OBSERVE_CONTROL_COUNT   (6U)
#define CCM_OBS_OBSERVE_CONTROL_SET_COUNT   (6U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_COUNT   (6U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_COUNT   (6U)
#define CCM_OBS_OBSERVE_STATUS0_COUNT   (6U)
#define CCM_OBS_OBSERVE_AUTHEN_COUNT   (6U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_COUNT   (6U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_COUNT   (6U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_COUNT   (6U)
#define CCM_OBS_OBSERVE_FREQUENCY_CURRENT_COUNT   (6U)
#define CCM_OBS_OBSERVE_FREQUENCY_MIN_COUNT   (6U)
#define CCM_OBS_OBSERVE_FREQUENCY_MAX_COUNT   (6U)
OBSERVE_CONTROL - Observe control
#define CCM_OBS_OBSERVE_CONTROL_SELECT_MASK   (0x1FFU)
#define CCM_OBS_OBSERVE_CONTROL_SELECT_SHIFT   (0U)
#define CCM_OBS_OBSERVE_CONTROL_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SELECT_MASK)
#define CCM_OBS_OBSERVE_CONTROL_RAW_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_CONTROL_RAW_SHIFT   (12U)
#define CCM_OBS_OBSERVE_CONTROL_RAW(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RAW_MASK)
#define CCM_OBS_OBSERVE_CONTROL_INV_MASK   (0x2000U)
#define CCM_OBS_OBSERVE_CONTROL_INV_SHIFT   (13U)
#define CCM_OBS_OBSERVE_CONTROL_INV(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_INV_MASK)
#define CCM_OBS_OBSERVE_CONTROL_RESET_MASK   (0x8000U)
#define CCM_OBS_OBSERVE_CONTROL_RESET_SHIFT   (15U)
#define CCM_OBS_OBSERVE_CONTROL_RESET(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RESET_MASK)
#define CCM_OBS_OBSERVE_CONTROL_DIVIDE_MASK   (0xFF0000U)
#define CCM_OBS_OBSERVE_CONTROL_DIVIDE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_CONTROL_DIVIDE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_DIVIDE_MASK)
#define CCM_OBS_OBSERVE_CONTROL_OFF_MASK   (0x1000000U)
#define CCM_OBS_OBSERVE_CONTROL_OFF_SHIFT   (24U)
#define CCM_OBS_OBSERVE_CONTROL_OFF(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_OFF_MASK)
OBSERVE_CONTROL_SET - Observe control
#define CCM_OBS_OBSERVE_CONTROL_SET_SELECT_MASK   (0x1FFU)
#define CCM_OBS_OBSERVE_CONTROL_SET_SELECT_SHIFT   (0U)
#define CCM_OBS_OBSERVE_CONTROL_SET_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_SELECT_MASK)
#define CCM_OBS_OBSERVE_CONTROL_SET_RAW_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_CONTROL_SET_RAW_SHIFT   (12U)
#define CCM_OBS_OBSERVE_CONTROL_SET_RAW(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RAW_MASK)
#define CCM_OBS_OBSERVE_CONTROL_SET_INV_MASK   (0x2000U)
#define CCM_OBS_OBSERVE_CONTROL_SET_INV_SHIFT   (13U)
#define CCM_OBS_OBSERVE_CONTROL_SET_INV(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_INV_MASK)
#define CCM_OBS_OBSERVE_CONTROL_SET_RESET_MASK   (0x8000U)
#define CCM_OBS_OBSERVE_CONTROL_SET_RESET_SHIFT   (15U)
#define CCM_OBS_OBSERVE_CONTROL_SET_RESET(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RESET_MASK)
#define CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_MASK   (0xFF0000U)
#define CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_MASK)
#define CCM_OBS_OBSERVE_CONTROL_SET_OFF_MASK   (0x1000000U)
#define CCM_OBS_OBSERVE_CONTROL_SET_OFF_SHIFT   (24U)
#define CCM_OBS_OBSERVE_CONTROL_SET_OFF(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_OFF_MASK)
OBSERVE_CONTROL_CLR - Observe control
#define CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_MASK   (0x1FFU)
#define CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_SHIFT   (0U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_MASK)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RAW_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RAW_SHIFT   (12U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RAW(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RAW_MASK)
#define CCM_OBS_OBSERVE_CONTROL_CLR_INV_MASK   (0x2000U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_INV_SHIFT   (13U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_INV(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_INV_MASK)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RESET_MASK   (0x8000U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RESET_SHIFT   (15U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_RESET(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RESET_MASK)
#define CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_MASK   (0xFF0000U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_MASK)
#define CCM_OBS_OBSERVE_CONTROL_CLR_OFF_MASK   (0x1000000U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_OFF_SHIFT   (24U)
#define CCM_OBS_OBSERVE_CONTROL_CLR_OFF(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_OFF_MASK)
OBSERVE_CONTROL_TOG - Observe control
#define CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_MASK   (0x1FFU)
#define CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_SHIFT   (0U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_MASK)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RAW_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RAW_SHIFT   (12U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RAW(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RAW_MASK)
#define CCM_OBS_OBSERVE_CONTROL_TOG_INV_MASK   (0x2000U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_INV_SHIFT   (13U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_INV(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_INV_MASK)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RESET_MASK   (0x8000U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RESET_SHIFT   (15U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_RESET(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RESET_MASK)
#define CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_MASK   (0xFF0000U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_MASK)
#define CCM_OBS_OBSERVE_CONTROL_TOG_OFF_MASK   (0x1000000U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_OFF_SHIFT   (24U)
#define CCM_OBS_OBSERVE_CONTROL_TOG_OFF(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_OFF_MASK)
OBSERVE_STATUS0 - Observe status
#define CCM_OBS_OBSERVE_STATUS0_SELECT_MASK   (0x1FFU)
#define CCM_OBS_OBSERVE_STATUS0_SELECT_SHIFT   (0U)
#define CCM_OBS_OBSERVE_STATUS0_SELECT(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_SELECT_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_SELECT_MASK)
#define CCM_OBS_OBSERVE_STATUS0_RAW_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_STATUS0_RAW_SHIFT   (12U)
#define CCM_OBS_OBSERVE_STATUS0_RAW(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RAW_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RAW_MASK)
#define CCM_OBS_OBSERVE_STATUS0_INV_MASK   (0x2000U)
#define CCM_OBS_OBSERVE_STATUS0_INV_SHIFT   (13U)
#define CCM_OBS_OBSERVE_STATUS0_INV(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_INV_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_INV_MASK)
#define CCM_OBS_OBSERVE_STATUS0_RESET_MASK   (0x8000U)
#define CCM_OBS_OBSERVE_STATUS0_RESET_SHIFT   (15U)
#define CCM_OBS_OBSERVE_STATUS0_RESET(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RESET_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RESET_MASK)
#define CCM_OBS_OBSERVE_STATUS0_DIVIDE_MASK   (0xFF0000U)
#define CCM_OBS_OBSERVE_STATUS0_DIVIDE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_STATUS0_DIVIDE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_DIVIDE_MASK)
#define CCM_OBS_OBSERVE_STATUS0_OFF_MASK   (0x1000000U)
#define CCM_OBS_OBSERVE_STATUS0_OFF_SHIFT   (24U)
#define CCM_OBS_OBSERVE_STATUS0_OFF(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_OFF_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_OFF_MASK)
OBSERVE_AUTHEN - Observe access control
#define CCM_OBS_OBSERVE_AUTHEN_TZ_USER_MASK   (0x1U)
#define CCM_OBS_OBSERVE_AUTHEN_TZ_USER_SHIFT   (0U)
#define CCM_OBS_OBSERVE_AUTHEN_TZ_USER(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_USER_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TZ_NS_MASK   (0x2U)
#define CCM_OBS_OBSERVE_AUTHEN_TZ_NS_SHIFT   (1U)
#define CCM_OBS_OBSERVE_AUTHEN_TZ_NS(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_NS_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_MASK   (0x10U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_SHIFT   (4U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_MASK   (0xF00U)
#define CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_SHIFT   (8U)
#define CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_SHIFT   (12U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_MASK   (0x10000U)
#define CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_MASK   (0x100000U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_SHIFT   (20U)
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_MASK)
OBSERVE_AUTHEN_SET - Observe access control
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_MASK   (0x1U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_SHIFT   (0U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_MASK   (0x2U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_SHIFT   (1U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_MASK   (0x10U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_SHIFT   (4U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_MASK   (0xF00U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_SHIFT   (8U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_SHIFT   (12U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_MASK   (0x10000U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_MASK   (0x100000U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_SHIFT   (20U)
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_MASK)
OBSERVE_AUTHEN_CLR - Observe access control
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_MASK   (0x1U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_SHIFT   (0U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_MASK   (0x2U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_SHIFT   (1U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_MASK   (0x10U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_SHIFT   (4U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_MASK   (0xF00U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_SHIFT   (8U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_SHIFT   (12U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_MASK   (0x10000U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_MASK   (0x100000U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_SHIFT   (20U)
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_MASK)
OBSERVE_AUTHEN_TOG - Observe access control
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_MASK   (0x1U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_SHIFT   (0U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_MASK   (0x2U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_SHIFT   (1U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_MASK   (0x10U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_SHIFT   (4U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_MASK   (0xF00U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_SHIFT   (8U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_MASK   (0x1000U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_SHIFT   (12U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_MASK   (0x10000U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_SHIFT   (16U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_MASK)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_MASK   (0x100000U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_SHIFT   (20U)
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_MASK)
OBSERVE_FREQUENCY_CURRENT - Current frequency detected
#define CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_MASK   (0xFFFFFFFFU)
#define CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_SHIFT   (0U)
#define CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_MASK)
OBSERVE_FREQUENCY_MIN - Minimum frequency detected
#define CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_MASK   (0xFFFFFFFFU)
#define CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_SHIFT   (0U)
#define CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_MASK)
OBSERVE_FREQUENCY_MAX - Maximum frequency detected
#define CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_MASK   (0xFFFFFFFFU)
#define CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_SHIFT   (0U)
#define CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY(x)   (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE_MASK)
DOMAIN_MODE - Low power and access control by domain
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_DOMAIN_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST_MASK)
LOCK_LIST - Lock white list
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE_MASK)
LOCK_MODE - Lock low power and access mode
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ_MASK)
LOCK_TZ - Lock truszone setting
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_LOCK_TZ [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS_MASK)
TZ_NS - Non-secure access
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_NS [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER_MASK)
TZ_USER - User access
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_TZ_USER [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST_MASK)
WHITE_LIST - White list
◆ CCM_OBS_OBSERVE_AUTHEN_CLR_WHITE_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE_MASK)
DOMAIN_MODE - Low power and access control by domain 0b1..Clock works in domain mode. 0b0..Clock does not work in domain mode.
◆ CCM_OBS_OBSERVE_AUTHEN_DOMAIN_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST_MASK)
LOCK_LIST - Lock white list 0b0..White list is not locked. 0b1..White list is locked.
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE_MASK)
LOCK_MODE - Lock low power and access mode 0b0..MODE is not locked. 0b1..MODE is locked.
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ_MASK)
LOCK_TZ - Lock truszone setting 0b0..Trustzone setting is not locked. 0b1..Trustzone setting is locked.
◆ CCM_OBS_OBSERVE_AUTHEN_LOCK_TZ [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_DOMAIN_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_LOCK_TZ [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_TZ_NS [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_TZ_USER [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_SET_WHITE_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_DOMAIN_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_MODE [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_LOCK_TZ [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_NS [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_TZ_USER [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST_MASK)
◆ CCM_OBS_OBSERVE_AUTHEN_TOG_WHITE_LIST [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TZ_NS [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TZ_NS (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_NS_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_NS_MASK)
TZ_NS - Non-secure access 0b0..Cannot be changed in Non-secure mode. 0b1..Can be changed in Non-secure mode.
◆ CCM_OBS_OBSERVE_AUTHEN_TZ_NS [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_TZ_USER [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_TZ_USER (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_TZ_USER_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_TZ_USER_MASK)
TZ_USER - User access 0b1..Clock can be changed in user mode. 0b0..Clock cannot be changed in user mode.
◆ CCM_OBS_OBSERVE_AUTHEN_TZ_USER [2/2]
◆ CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST [1/2]
#define CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_SHIFT)) & CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST_MASK)
WHITE_LIST - White list 0b1111..All domain can change. 0b0010..Domain 1 can change. 0b0011..Domain 0 and domain 1 can change. 0b0000..No domain can change. 0b0100..Domain 2 can change. 0b0001..Domain 0 can change.
◆ CCM_OBS_OBSERVE_AUTHEN_WHITE_LIST [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE_MASK)
DIVIDE - Divider for observe signal
◆ CCM_OBS_OBSERVE_CONTROL_CLR_DIVIDE [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_CLR_INV [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_INV (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_INV_MASK)
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_CLR_INV [2/2]
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_CLR_OFF [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_OFF (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_OFF_MASK)
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_CLR_OFF [2/2]
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_CLR_RAW [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_RAW (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RAW_MASK)
RAW - Observe raw signal
◆ CCM_OBS_OBSERVE_CONTROL_CLR_RAW [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_CLR_RESET [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_RESET_MASK)
RESET - Reset observe divider
◆ CCM_OBS_OBSERVE_CONTROL_CLR_RESET [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_CLR_SELECT [1/2]
#define CCM_OBS_OBSERVE_CONTROL_CLR_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_CLR_SELECT_MASK)
SELECT - Observe signal selector
◆ CCM_OBS_OBSERVE_CONTROL_CLR_SELECT [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_DIVIDE [1/2]
#define CCM_OBS_OBSERVE_CONTROL_DIVIDE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_DIVIDE_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_DIVIDE [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_INV [1/2]
#define CCM_OBS_OBSERVE_CONTROL_INV (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_INV_MASK)
INV - Invert 0b0..Clock phase remain same. 0b1..Invert clock phase before measurement or send to IO.
◆ CCM_OBS_OBSERVE_CONTROL_INV [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_OFF [1/2]
#define CCM_OBS_OBSERVE_CONTROL_OFF (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_OFF_MASK)
OFF - Turn off 0b0..observe slice is on 0b1..observe slice is off
◆ CCM_OBS_OBSERVE_CONTROL_OFF [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_RAW [1/2]
#define CCM_OBS_OBSERVE_CONTROL_RAW (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RAW_MASK)
RAW - Observe raw signal 0b0..Select divided signal. 0b1..Select raw signal.
◆ CCM_OBS_OBSERVE_CONTROL_RAW [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_RESET [1/2]
#define CCM_OBS_OBSERVE_CONTROL_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_RESET_MASK)
RESET - Reset observe divider 0b0..No reset 0b1..Reset observe divider
◆ CCM_OBS_OBSERVE_CONTROL_RESET [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_SELECT [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SELECT_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_SELECT [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_SET_DIVIDE [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_SET_INV [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_INV (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_INV_MASK)
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_SET_INV [2/2]
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_SET_OFF [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_OFF (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_OFF_MASK)
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_SET_OFF [2/2]
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_SET_RAW [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_RAW (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RAW_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_SET_RAW [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_SET_RESET [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_RESET_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_SET_RESET [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_SET_SELECT [1/2]
#define CCM_OBS_OBSERVE_CONTROL_SET_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_SET_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_SET_SELECT_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_SET_SELECT [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_TOG_DIVIDE [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_TOG_INV [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_INV (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_INV_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_INV_MASK)
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_TOG_INV [2/2]
INV - Invert
◆ CCM_OBS_OBSERVE_CONTROL_TOG_OFF [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_OFF (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_OFF_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_OFF_MASK)
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_TOG_OFF [2/2]
OFF - Turn off
◆ CCM_OBS_OBSERVE_CONTROL_TOG_RAW [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_RAW (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RAW_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RAW_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_TOG_RAW [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_TOG_RESET [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_RESET_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_RESET_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_TOG_RESET [2/2]
◆ CCM_OBS_OBSERVE_CONTROL_TOG_SELECT [1/2]
#define CCM_OBS_OBSERVE_CONTROL_TOG_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_SHIFT)) & CCM_OBS_OBSERVE_CONTROL_TOG_SELECT_MASK)
◆ CCM_OBS_OBSERVE_CONTROL_TOG_SELECT [2/2]
◆ CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY [1/2]
#define CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY_MASK)
FREQUENCY - Frequency
◆ CCM_OBS_OBSERVE_FREQUENCY_CURRENT_FREQUENCY [2/2]
◆ CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY [1/2]
#define CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY_MASK)
◆ CCM_OBS_OBSERVE_FREQUENCY_MAX_FREQUENCY [2/2]
◆ CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY [1/2]
#define CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_SHIFT)) & CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY_MASK)
◆ CCM_OBS_OBSERVE_FREQUENCY_MIN_FREQUENCY [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_DIVIDE [1/2]
#define CCM_OBS_OBSERVE_STATUS0_DIVIDE (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_DIVIDE_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_DIVIDE_MASK)
DIVIDE - Divide value status. The clock will be divided by DIVIDE + 1.
◆ CCM_OBS_OBSERVE_STATUS0_DIVIDE [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_INV [1/2]
#define CCM_OBS_OBSERVE_STATUS0_INV (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_INV_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_INV_MASK)
INV - Polarity of the observe target 0b1..Polarity of the observe target is inverted 0b0..Polarity is not inverted
◆ CCM_OBS_OBSERVE_STATUS0_INV [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_OFF [1/2]
#define CCM_OBS_OBSERVE_STATUS0_OFF (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_OFF_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_OFF_MASK)
OFF - Turn off slice 0b0..observe slice is on 0b1..observe slice is off
◆ CCM_OBS_OBSERVE_STATUS0_OFF [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_RAW [1/2]
#define CCM_OBS_OBSERVE_STATUS0_RAW (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RAW_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RAW_MASK)
RAW - Observe raw signal 0b0..Divided signal is selected 0b1..Raw signal is selected
◆ CCM_OBS_OBSERVE_STATUS0_RAW [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_RESET [1/2]
#define CCM_OBS_OBSERVE_STATUS0_RESET (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_RESET_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_RESET_MASK)
RESET - Reset state 0b1..Observe divider is in reset state 0b0..Observe divider is not in reset state
◆ CCM_OBS_OBSERVE_STATUS0_RESET [2/2]
◆ CCM_OBS_OBSERVE_STATUS0_SELECT [1/2]
#define CCM_OBS_OBSERVE_STATUS0_SELECT (   x)    (((uint32_t)(((uint32_t)(x)) << CCM_OBS_OBSERVE_STATUS0_SELECT_SHIFT)) & CCM_OBS_OBSERVE_STATUS0_SELECT_MASK)
SELECT - Select value
◆ CCM_OBS_OBSERVE_STATUS0_SELECT [2/2]
