RTEMS 6.1-rc1
Tests a fatal error. More...
Files | |
file | tr-fatal-sparc-leon3-cache-snooping-disabled-boot.c |
file | tr-fatal-sparc-leon3-cache-snooping-disabled-boot.h |
struct | BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context |
Test context for spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot test case. More... | |
RTEMS_SYSINIT_ITEM (DisableCacheSnooping, RTEMS_SYSINIT_BSP_EARLY, RTEMS_SYSINIT_ORDER_FIRST) | |
void | BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run (rtems_fatal_source source, rtems_fatal_code code) |
Runs the parameterized test case. More... | |
This test case performs the following actions:
void BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run | ( | rtems_fatal_source | source, |
rtems_fatal_code | code | ||
source | is fatal source. |
code | is fatal code. |
