RTEMS 6.1-rc1
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot | |
Tests a fatal error. | |
Files | |
file | ts-fatal-sparc-leon3-cache-snooping-disabled-boot.c |
#define | FATAL_SYSINIT_RUN BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run |
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
const char | rtems_test_name [] = "TestsuitesBspsFatalSparcLeon3CacheSnoopingDisabledBoot" |
Each test must define a test name string. | |
