RTEMS 6.1-rc1
CTRL - Control Register
#define BEE_CTRL_BEE_ENABLE_MASK   (0x1U)
#define BEE_CTRL_BEE_ENABLE_SHIFT   (0U)
#define BEE_CTRL_BEE_ENABLE(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_BEE_ENABLE_SHIFT)) & BEE_CTRL_BEE_ENABLE_MASK)
#define BEE_CTRL_CTRL_CLK_EN_MASK   (0x2U)
#define BEE_CTRL_CTRL_CLK_EN_SHIFT   (1U)
#define BEE_CTRL_CTRL_CLK_EN(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_CLK_EN_SHIFT)) & BEE_CTRL_CTRL_CLK_EN_MASK)
#define BEE_CTRL_CTRL_SFTRST_N_MASK   (0x4U)
#define BEE_CTRL_CTRL_SFTRST_N_SHIFT   (2U)
#define BEE_CTRL_CTRL_SFTRST_N(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_SFTRST_N_SHIFT)) & BEE_CTRL_CTRL_SFTRST_N_MASK)
#define BEE_CTRL_KEY_VALID_MASK   (0x10U)
#define BEE_CTRL_KEY_VALID_SHIFT   (4U)
#define BEE_CTRL_KEY_VALID(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_KEY_VALID_SHIFT)) & BEE_CTRL_KEY_VALID_MASK)
#define BEE_CTRL_KEY_REGION_SEL_MASK   (0x20U)
#define BEE_CTRL_KEY_REGION_SEL_SHIFT   (5U)
#define BEE_CTRL_KEY_REGION_SEL(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_KEY_REGION_SEL_SHIFT)) & BEE_CTRL_KEY_REGION_SEL_MASK)
#define BEE_CTRL_AC_PROT_EN_MASK   (0x40U)
#define BEE_CTRL_AC_PROT_EN_SHIFT   (6U)
#define BEE_CTRL_AC_PROT_EN(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_AC_PROT_EN_SHIFT)) & BEE_CTRL_AC_PROT_EN_MASK)
#define BEE_CTRL_LITTLE_ENDIAN_MASK   (0x80U)
#define BEE_CTRL_LITTLE_ENDIAN_SHIFT   (7U)
#define BEE_CTRL_LITTLE_ENDIAN(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_LITTLE_ENDIAN_SHIFT)) & BEE_CTRL_LITTLE_ENDIAN_MASK)
#define BEE_CTRL_SECURITY_LEVEL_R0_MASK   (0x300U)
#define BEE_CTRL_SECURITY_LEVEL_R0_SHIFT   (8U)
#define BEE_CTRL_SECURITY_LEVEL_R0(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_SECURITY_LEVEL_R0_SHIFT)) & BEE_CTRL_SECURITY_LEVEL_R0_MASK)
#define BEE_CTRL_CTRL_AES_MODE_R0_MASK   (0x400U)
#define BEE_CTRL_CTRL_AES_MODE_R0_SHIFT   (10U)
#define BEE_CTRL_CTRL_AES_MODE_R0(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R0_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R0_MASK)
#define BEE_CTRL_SECURITY_LEVEL_R1_MASK   (0x3000U)
#define BEE_CTRL_SECURITY_LEVEL_R1_SHIFT   (12U)
#define BEE_CTRL_SECURITY_LEVEL_R1(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_SECURITY_LEVEL_R1_SHIFT)) & BEE_CTRL_SECURITY_LEVEL_R1_MASK)
#define BEE_CTRL_CTRL_AES_MODE_R1_MASK   (0x4000U)
#define BEE_CTRL_CTRL_AES_MODE_R1_SHIFT   (14U)
#define BEE_CTRL_CTRL_AES_MODE_R1(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R1_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R1_MASK)
#define BEE_CTRL_BEE_ENABLE_LOCK_MASK   (0x10000U)
#define BEE_CTRL_BEE_ENABLE_LOCK_SHIFT   (16U)
#define BEE_CTRL_BEE_ENABLE_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_BEE_ENABLE_LOCK_SHIFT)) & BEE_CTRL_BEE_ENABLE_LOCK_MASK)
#define BEE_CTRL_CTRL_CLK_EN_LOCK_MASK   (0x20000U)
#define BEE_CTRL_CTRL_CLK_EN_LOCK_SHIFT   (17U)
#define BEE_CTRL_CTRL_CLK_EN_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_CLK_EN_LOCK_SHIFT)) & BEE_CTRL_CTRL_CLK_EN_LOCK_MASK)
#define BEE_CTRL_CTRL_SFTRST_N_LOCK_MASK   (0x40000U)
#define BEE_CTRL_CTRL_SFTRST_N_LOCK_SHIFT   (18U)
#define BEE_CTRL_CTRL_SFTRST_N_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_SFTRST_N_LOCK_SHIFT)) & BEE_CTRL_CTRL_SFTRST_N_LOCK_MASK)
#define BEE_CTRL_REGION1_ADDR_LOCK_MASK   (0x80000U)
#define BEE_CTRL_REGION1_ADDR_LOCK_SHIFT   (19U)
#define BEE_CTRL_REGION1_ADDR_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_REGION1_ADDR_LOCK_SHIFT)) & BEE_CTRL_REGION1_ADDR_LOCK_MASK)
#define BEE_CTRL_KEY_VALID_LOCK_MASK   (0x100000U)
#define BEE_CTRL_KEY_VALID_LOCK_SHIFT   (20U)
#define BEE_CTRL_KEY_VALID_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_KEY_VALID_LOCK_SHIFT)) & BEE_CTRL_KEY_VALID_LOCK_MASK)
#define BEE_CTRL_KEY_REGION_SEL_LOCK_MASK   (0x200000U)
#define BEE_CTRL_KEY_REGION_SEL_LOCK_SHIFT   (21U)
#define BEE_CTRL_KEY_REGION_SEL_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_KEY_REGION_SEL_LOCK_SHIFT)) & BEE_CTRL_KEY_REGION_SEL_LOCK_MASK)
#define BEE_CTRL_AC_PROT_EN_LOCK_MASK   (0x400000U)
#define BEE_CTRL_AC_PROT_EN_LOCK_SHIFT   (22U)
#define BEE_CTRL_AC_PROT_EN_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_AC_PROT_EN_LOCK_SHIFT)) & BEE_CTRL_AC_PROT_EN_LOCK_MASK)
#define BEE_CTRL_LITTLE_ENDIAN_LOCK_MASK   (0x800000U)
#define BEE_CTRL_LITTLE_ENDIAN_LOCK_SHIFT   (23U)
#define BEE_CTRL_LITTLE_ENDIAN_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_LITTLE_ENDIAN_LOCK_SHIFT)) & BEE_CTRL_LITTLE_ENDIAN_LOCK_MASK)
#define BEE_CTRL_SECURITY_LEVEL_R0_LOCK_MASK   (0x3000000U)
#define BEE_CTRL_SECURITY_LEVEL_R0_LOCK_SHIFT   (24U)
#define BEE_CTRL_SECURITY_LEVEL_R0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_SECURITY_LEVEL_R0_LOCK_SHIFT)) & BEE_CTRL_SECURITY_LEVEL_R0_LOCK_MASK)
#define BEE_CTRL_CTRL_AES_MODE_R0_LOCK_MASK   (0x4000000U)
#define BEE_CTRL_CTRL_AES_MODE_R0_LOCK_SHIFT   (26U)
#define BEE_CTRL_CTRL_AES_MODE_R0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R0_LOCK_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R0_LOCK_MASK)
#define BEE_CTRL_REGION0_KEY_LOCK_MASK   (0x8000000U)
#define BEE_CTRL_REGION0_KEY_LOCK_SHIFT   (27U)
#define BEE_CTRL_REGION0_KEY_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_REGION0_KEY_LOCK_SHIFT)) & BEE_CTRL_REGION0_KEY_LOCK_MASK)
#define BEE_CTRL_SECURITY_LEVEL_R1_LOCK_MASK   (0x30000000U)
#define BEE_CTRL_SECURITY_LEVEL_R1_LOCK_SHIFT   (28U)
#define BEE_CTRL_SECURITY_LEVEL_R1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_SECURITY_LEVEL_R1_LOCK_SHIFT)) & BEE_CTRL_SECURITY_LEVEL_R1_LOCK_MASK)
#define BEE_CTRL_CTRL_AES_MODE_R1_LOCK_MASK   (0x40000000U)
#define BEE_CTRL_CTRL_AES_MODE_R1_LOCK_SHIFT   (30U)
#define BEE_CTRL_CTRL_AES_MODE_R1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R1_LOCK_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R1_LOCK_MASK)
#define BEE_CTRL_REGION1_KEY_LOCK_MASK   (0x80000000U)
#define BEE_CTRL_REGION1_KEY_LOCK_SHIFT   (31U)
#define BEE_CTRL_REGION1_KEY_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_REGION1_KEY_LOCK_SHIFT)) & BEE_CTRL_REGION1_KEY_LOCK_MASK)
#define ENC_CTRL_CMPIE_MASK   (0x1U)
#define ENC_CTRL_CMPIE_SHIFT   (0U)
#define ENC_CTRL_CMPIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIE_SHIFT)) & ENC_CTRL_CMPIE_MASK)
#define ENC_CTRL_CMPIRQ_MASK   (0x2U)
#define ENC_CTRL_CMPIRQ_SHIFT   (1U)
#define ENC_CTRL_CMPIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIRQ_SHIFT)) & ENC_CTRL_CMPIRQ_MASK)
#define ENC_CTRL_WDE_MASK   (0x4U)
#define ENC_CTRL_WDE_SHIFT   (2U)
#define ENC_CTRL_WDE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_WDE_SHIFT)) & ENC_CTRL_WDE_MASK)
#define ENC_CTRL_DIE_MASK   (0x8U)
#define ENC_CTRL_DIE_SHIFT   (3U)
#define ENC_CTRL_DIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIE_SHIFT)) & ENC_CTRL_DIE_MASK)
#define ENC_CTRL_DIRQ_MASK   (0x10U)
#define ENC_CTRL_DIRQ_SHIFT   (4U)
#define ENC_CTRL_DIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIRQ_SHIFT)) & ENC_CTRL_DIRQ_MASK)
#define ENC_CTRL_XNE_MASK   (0x20U)
#define ENC_CTRL_XNE_SHIFT   (5U)
#define ENC_CTRL_XNE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XNE_SHIFT)) & ENC_CTRL_XNE_MASK)
#define ENC_CTRL_XIP_MASK   (0x40U)
#define ENC_CTRL_XIP_SHIFT   (6U)
#define ENC_CTRL_XIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIP_SHIFT)) & ENC_CTRL_XIP_MASK)
#define ENC_CTRL_XIE_MASK   (0x80U)
#define ENC_CTRL_XIE_SHIFT   (7U)
#define ENC_CTRL_XIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIE_SHIFT)) & ENC_CTRL_XIE_MASK)
#define ENC_CTRL_XIRQ_MASK   (0x100U)
#define ENC_CTRL_XIRQ_SHIFT   (8U)
#define ENC_CTRL_XIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIRQ_SHIFT)) & ENC_CTRL_XIRQ_MASK)
#define ENC_CTRL_PH1_MASK   (0x200U)
#define ENC_CTRL_PH1_SHIFT   (9U)
#define ENC_CTRL_PH1(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_PH1_SHIFT)) & ENC_CTRL_PH1_MASK)
#define ENC_CTRL_REV_MASK   (0x400U)
#define ENC_CTRL_REV_SHIFT   (10U)
#define ENC_CTRL_REV(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_REV_SHIFT)) & ENC_CTRL_REV_MASK)
#define ENC_CTRL_SWIP_MASK   (0x800U)
#define ENC_CTRL_SWIP_SHIFT   (11U)
#define ENC_CTRL_SWIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_SWIP_SHIFT)) & ENC_CTRL_SWIP_MASK)
#define ENC_CTRL_HNE_MASK   (0x1000U)
#define ENC_CTRL_HNE_SHIFT   (12U)
#define ENC_CTRL_HNE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HNE_SHIFT)) & ENC_CTRL_HNE_MASK)
#define ENC_CTRL_HIP_MASK   (0x2000U)
#define ENC_CTRL_HIP_SHIFT   (13U)
#define ENC_CTRL_HIP(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIP_SHIFT)) & ENC_CTRL_HIP_MASK)
#define ENC_CTRL_HIE_MASK   (0x4000U)
#define ENC_CTRL_HIE_SHIFT   (14U)
#define ENC_CTRL_HIE(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIE_SHIFT)) & ENC_CTRL_HIE_MASK)
#define ENC_CTRL_HIRQ_MASK   (0x8000U)
#define ENC_CTRL_HIRQ_SHIFT   (15U)
#define ENC_CTRL_HIRQ(x)   (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIRQ_SHIFT)) & ENC_CTRL_HIRQ_MASK)
#define EWM_CTRL_EWMEN_MASK   (0x1U)
#define EWM_CTRL_EWMEN_SHIFT   (0U)
#define EWM_CTRL_EWMEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_EWMEN_SHIFT)) & EWM_CTRL_EWMEN_MASK)
#define EWM_CTRL_ASSIN_MASK   (0x2U)
#define EWM_CTRL_ASSIN_SHIFT   (1U)
#define EWM_CTRL_ASSIN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_ASSIN_SHIFT)) & EWM_CTRL_ASSIN_MASK)
#define EWM_CTRL_INEN_MASK   (0x4U)
#define EWM_CTRL_INEN_SHIFT   (2U)
#define EWM_CTRL_INEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INEN_SHIFT)) & EWM_CTRL_INEN_MASK)
#define EWM_CTRL_INTEN_MASK   (0x8U)
#define EWM_CTRL_INTEN_SHIFT   (3U)
#define EWM_CTRL_INTEN(x)   (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INTEN_SHIFT)) & EWM_CTRL_INTEN_MASK)
#define PWM_CTRL_DBLEN_MASK   (0x1U)
#define PWM_CTRL_DBLEN_SHIFT   (0U)
#define PWM_CTRL_DBLEN(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLEN_SHIFT)) & PWM_CTRL_DBLEN_MASK)
#define PWM_CTRL_DBLX_MASK   (0x2U)
#define PWM_CTRL_DBLX_SHIFT   (1U)
#define PWM_CTRL_DBLX(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLX_SHIFT)) & PWM_CTRL_DBLX_MASK)
#define PWM_CTRL_LDMOD_MASK   (0x4U)
#define PWM_CTRL_LDMOD_SHIFT   (2U)
#define PWM_CTRL_LDMOD(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDMOD_SHIFT)) & PWM_CTRL_LDMOD_MASK)
#define PWM_CTRL_SPLIT_MASK   (0x8U)
#define PWM_CTRL_SPLIT_SHIFT   (3U)
#define PWM_CTRL_SPLIT(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_SPLIT_SHIFT)) & PWM_CTRL_SPLIT_MASK)
#define PWM_CTRL_PRSC_MASK   (0x70U)
#define PWM_CTRL_PRSC_SHIFT   (4U)
#define PWM_CTRL_PRSC(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_PRSC_SHIFT)) & PWM_CTRL_PRSC_MASK)
#define PWM_CTRL_COMPMODE_MASK   (0x80U)
#define PWM_CTRL_COMPMODE_SHIFT   (7U)
#define PWM_CTRL_COMPMODE(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_COMPMODE_SHIFT)) & PWM_CTRL_COMPMODE_MASK)
#define PWM_CTRL_DT_MASK   (0x300U)
#define PWM_CTRL_DT_SHIFT   (8U)
#define PWM_CTRL_DT(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DT_SHIFT)) & PWM_CTRL_DT_MASK)
#define PWM_CTRL_FULL_MASK   (0x400U)
#define PWM_CTRL_FULL_SHIFT   (10U)
#define PWM_CTRL_FULL(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_FULL_SHIFT)) & PWM_CTRL_FULL_MASK)
#define PWM_CTRL_HALF_MASK   (0x800U)
#define PWM_CTRL_HALF_SHIFT   (11U)
#define PWM_CTRL_HALF(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_HALF_SHIFT)) & PWM_CTRL_HALF_MASK)
#define PWM_CTRL_LDFQ_MASK   (0xF000U)
#define PWM_CTRL_LDFQ_SHIFT   (12U)
#define PWM_CTRL_LDFQ(x)   (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDFQ_SHIFT)) & PWM_CTRL_LDFQ_MASK)
ADDR_OFFSET0 - Offset region 0 Register
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0_MASK   (0xFFFFU)
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0_SHIFT   (0U)
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0(x)   (((uint32_t)(((uint32_t)(x)) << BEE_ADDR_OFFSET0_ADDR_OFFSET0_SHIFT)) & BEE_ADDR_OFFSET0_ADDR_OFFSET0_MASK)
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0_LOCK_MASK   (0xFFFF0000U)
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0_LOCK_SHIFT   (16U)
#define BEE_ADDR_OFFSET0_ADDR_OFFSET0_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_ADDR_OFFSET0_ADDR_OFFSET0_LOCK_SHIFT)) & BEE_ADDR_OFFSET0_ADDR_OFFSET0_LOCK_MASK)
ADDR_OFFSET1 - Offset region 1 Register
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1_MASK   (0xFFFFU)
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1_SHIFT   (0U)
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1(x)   (((uint32_t)(((uint32_t)(x)) << BEE_ADDR_OFFSET1_ADDR_OFFSET1_SHIFT)) & BEE_ADDR_OFFSET1_ADDR_OFFSET1_MASK)
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1_LOCK_MASK   (0xFFFF0000U)
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1_LOCK_SHIFT   (16U)
#define BEE_ADDR_OFFSET1_ADDR_OFFSET1_LOCK(x)   (((uint32_t)(((uint32_t)(x)) << BEE_ADDR_OFFSET1_ADDR_OFFSET1_LOCK_SHIFT)) & BEE_ADDR_OFFSET1_ADDR_OFFSET1_LOCK_MASK)
AES_KEY0_W0 - AES Key 0 Register
#define BEE_AES_KEY0_W0_KEY0_MASK   (0xFFFFFFFFU)
#define BEE_AES_KEY0_W0_KEY0_SHIFT   (0U)
#define BEE_AES_KEY0_W0_KEY0(x)   (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W0_KEY0_SHIFT)) & BEE_AES_KEY0_W0_KEY0_MASK)
AES_KEY0_W1 - AES Key 1 Register
#define BEE_AES_KEY0_W1_KEY1_MASK   (0xFFFFFFFFU)
#define BEE_AES_KEY0_W1_KEY1_SHIFT   (0U)
#define BEE_AES_KEY0_W1_KEY1(x)   (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W1_KEY1_SHIFT)) & BEE_AES_KEY0_W1_KEY1_MASK)
AES_KEY0_W2 - AES Key 2 Register
#define BEE_AES_KEY0_W2_KEY2_MASK   (0xFFFFFFFFU)
#define BEE_AES_KEY0_W2_KEY2_SHIFT   (0U)
#define BEE_AES_KEY0_W2_KEY2(x)   (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W2_KEY2_SHIFT)) & BEE_AES_KEY0_W2_KEY2_MASK)
AES_KEY0_W3 - AES Key 3 Register
#define BEE_AES_KEY0_W3_KEY3_MASK   (0xFFFFFFFFU)
#define BEE_AES_KEY0_W3_KEY3_SHIFT   (0U)
#define BEE_AES_KEY0_W3_KEY3(x)   (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W3_KEY3_SHIFT)) & BEE_AES_KEY0_W3_KEY3_MASK)
STATUS - Status Register
#define BEE_STATUS_IRQ_VEC_MASK   (0xFFU)
#define BEE_STATUS_IRQ_VEC_SHIFT   (0U)
#define BEE_STATUS_IRQ_VEC(x)   (((uint32_t)(((uint32_t)(x)) << BEE_STATUS_IRQ_VEC_SHIFT)) & BEE_STATUS_IRQ_VEC_MASK)
#define BEE_STATUS_BEE_IDLE_MASK   (0x100U)
#define BEE_STATUS_BEE_IDLE_SHIFT   (8U)
#define BEE_STATUS_BEE_IDLE(x)   (((uint32_t)(((uint32_t)(x)) << BEE_STATUS_BEE_IDLE_SHIFT)) & BEE_STATUS_BEE_IDLE_MASK)
#define TRNG_STATUS_TF1BR0_MASK   (0x1U)
#define TRNG_STATUS_TF1BR0_SHIFT   (0U)
#define TRNG_STATUS_TF1BR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF1BR0_SHIFT)) & TRNG_STATUS_TF1BR0_MASK)
#define TRNG_STATUS_TF1BR1_MASK   (0x2U)
#define TRNG_STATUS_TF1BR1_SHIFT   (1U)
#define TRNG_STATUS_TF1BR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF1BR1_SHIFT)) & TRNG_STATUS_TF1BR1_MASK)
#define TRNG_STATUS_TF2BR0_MASK   (0x4U)
#define TRNG_STATUS_TF2BR0_SHIFT   (2U)
#define TRNG_STATUS_TF2BR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF2BR0_SHIFT)) & TRNG_STATUS_TF2BR0_MASK)
#define TRNG_STATUS_TF2BR1_MASK   (0x8U)
#define TRNG_STATUS_TF2BR1_SHIFT   (3U)
#define TRNG_STATUS_TF2BR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF2BR1_SHIFT)) & TRNG_STATUS_TF2BR1_MASK)
#define TRNG_STATUS_TF3BR0_MASK   (0x10U)
#define TRNG_STATUS_TF3BR0_SHIFT   (4U)
#define TRNG_STATUS_TF3BR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF3BR0_SHIFT)) & TRNG_STATUS_TF3BR0_MASK)
#define TRNG_STATUS_TF3BR1_MASK   (0x20U)
#define TRNG_STATUS_TF3BR1_SHIFT   (5U)
#define TRNG_STATUS_TF3BR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF3BR1_SHIFT)) & TRNG_STATUS_TF3BR1_MASK)
#define TRNG_STATUS_TF4BR0_MASK   (0x40U)
#define TRNG_STATUS_TF4BR0_SHIFT   (6U)
#define TRNG_STATUS_TF4BR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF4BR0_SHIFT)) & TRNG_STATUS_TF4BR0_MASK)
#define TRNG_STATUS_TF4BR1_MASK   (0x80U)
#define TRNG_STATUS_TF4BR1_SHIFT   (7U)
#define TRNG_STATUS_TF4BR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF4BR1_SHIFT)) & TRNG_STATUS_TF4BR1_MASK)
#define TRNG_STATUS_TF5BR0_MASK   (0x100U)
#define TRNG_STATUS_TF5BR0_SHIFT   (8U)
#define TRNG_STATUS_TF5BR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF5BR0_SHIFT)) & TRNG_STATUS_TF5BR0_MASK)
#define TRNG_STATUS_TF5BR1_MASK   (0x200U)
#define TRNG_STATUS_TF5BR1_SHIFT   (9U)
#define TRNG_STATUS_TF5BR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF5BR1_SHIFT)) & TRNG_STATUS_TF5BR1_MASK)
#define TRNG_STATUS_TF6PBR0_MASK   (0x400U)
#define TRNG_STATUS_TF6PBR0_SHIFT   (10U)
#define TRNG_STATUS_TF6PBR0(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF6PBR0_SHIFT)) & TRNG_STATUS_TF6PBR0_MASK)
#define TRNG_STATUS_TF6PBR1_MASK   (0x800U)
#define TRNG_STATUS_TF6PBR1_SHIFT   (11U)
#define TRNG_STATUS_TF6PBR1(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TF6PBR1_SHIFT)) & TRNG_STATUS_TF6PBR1_MASK)
#define TRNG_STATUS_TFSB_MASK   (0x1000U)
#define TRNG_STATUS_TFSB_SHIFT   (12U)
#define TRNG_STATUS_TFSB(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TFSB_SHIFT)) & TRNG_STATUS_TFSB_MASK)
#define TRNG_STATUS_TFLR_MASK   (0x2000U)
#define TRNG_STATUS_TFLR_SHIFT   (13U)
#define TRNG_STATUS_TFLR(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TFLR_SHIFT)) & TRNG_STATUS_TFLR_MASK)
#define TRNG_STATUS_TFP_MASK   (0x4000U)
#define TRNG_STATUS_TFP_SHIFT   (14U)
#define TRNG_STATUS_TFP(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TFP_SHIFT)) & TRNG_STATUS_TFP_MASK)
#define TRNG_STATUS_TFMB_MASK   (0x8000U)
#define TRNG_STATUS_TFMB_SHIFT   (15U)
#define TRNG_STATUS_TFMB(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_TFMB_SHIFT)) & TRNG_STATUS_TFMB_MASK)
#define TRNG_STATUS_RETRY_CT_MASK   (0xF0000U)
#define TRNG_STATUS_RETRY_CT_SHIFT   (16U)
#define TRNG_STATUS_RETRY_CT(x)   (((uint32_t)(((uint32_t)(x)) << TRNG_STATUS_RETRY_CT_SHIFT)) & TRNG_STATUS_RETRY_CT_MASK)
CTR_NONCE0_W0 - NONCE00 Register
#define BEE_CTR_NONCE0_W0_NONCE00_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE0_W0_NONCE00_SHIFT   (0U)
#define BEE_CTR_NONCE0_W0_NONCE00(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE0_W0_NONCE00_SHIFT)) & BEE_CTR_NONCE0_W0_NONCE00_MASK)
CTR_NONCE0_W1 - NONCE01 Register
#define BEE_CTR_NONCE0_W1_NONCE01_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE0_W1_NONCE01_SHIFT   (0U)
#define BEE_CTR_NONCE0_W1_NONCE01(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE0_W1_NONCE01_SHIFT)) & BEE_CTR_NONCE0_W1_NONCE01_MASK)
CTR_NONCE0_W2 - NONCE02 Register
#define BEE_CTR_NONCE0_W2_NONCE02_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE0_W2_NONCE02_SHIFT   (0U)
#define BEE_CTR_NONCE0_W2_NONCE02(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE0_W2_NONCE02_SHIFT)) & BEE_CTR_NONCE0_W2_NONCE02_MASK)
CTR_NONCE0_W3 - NONCE03 Register
#define BEE_CTR_NONCE0_W3_NONCE03_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE0_W3_NONCE03_SHIFT   (0U)
#define BEE_CTR_NONCE0_W3_NONCE03(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE0_W3_NONCE03_SHIFT)) & BEE_CTR_NONCE0_W3_NONCE03_MASK)
CTR_NONCE1_W0 - NONCE10 Register
#define BEE_CTR_NONCE1_W0_NONCE10_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE1_W0_NONCE10_SHIFT   (0U)
#define BEE_CTR_NONCE1_W0_NONCE10(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE1_W0_NONCE10_SHIFT)) & BEE_CTR_NONCE1_W0_NONCE10_MASK)
CTR_NONCE1_W1 - NONCE11 Register
#define BEE_CTR_NONCE1_W1_NONCE11_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE1_W1_NONCE11_SHIFT   (0U)
#define BEE_CTR_NONCE1_W1_NONCE11(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE1_W1_NONCE11_SHIFT)) & BEE_CTR_NONCE1_W1_NONCE11_MASK)
CTR_NONCE1_W2 - NONCE12 Register
#define BEE_CTR_NONCE1_W2_NONCE12_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE1_W2_NONCE12_SHIFT   (0U)
#define BEE_CTR_NONCE1_W2_NONCE12(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE1_W2_NONCE12_SHIFT)) & BEE_CTR_NONCE1_W2_NONCE12_MASK)
CTR_NONCE1_W3 - NONCE13 Register
#define BEE_CTR_NONCE1_W3_NONCE13_MASK   (0xFFFFFFFFU)
#define BEE_CTR_NONCE1_W3_NONCE13_SHIFT   (0U)
#define BEE_CTR_NONCE1_W3_NONCE13(x)   (((uint32_t)(((uint32_t)(x)) << BEE_CTR_NONCE1_W3_NONCE13_SHIFT)) & BEE_CTR_NONCE1_W3_NONCE13_MASK)
REGION1_TOP - Region1 Top Address Register
#define BEE_REGION1_TOP_REGION1_TOP_MASK   (0xFFFFFFFFU)
#define BEE_REGION1_TOP_REGION1_TOP_SHIFT   (0U)
#define BEE_REGION1_TOP_REGION1_TOP(x)   (((uint32_t)(((uint32_t)(x)) << BEE_REGION1_TOP_REGION1_TOP_SHIFT)) & BEE_REGION1_TOP_REGION1_TOP_MASK)
REGION1_BOT - Region1 Bottom Address Register
#define BEE_REGION1_BOT_REGION1_BOT_MASK   (0xFFFFFFFFU)
#define BEE_REGION1_BOT_REGION1_BOT_SHIFT   (0U)
#define BEE_REGION1_BOT_REGION1_BOT(x)   (((uint32_t)(((uint32_t)(x)) << BEE_REGION1_BOT_REGION1_BOT_SHIFT)) & BEE_REGION1_BOT_REGION1_BOT_MASK)
◆ BEE_AES_KEY0_W0_KEY0
#define BEE_AES_KEY0_W0_KEY0 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W0_KEY0_SHIFT)) & BEE_AES_KEY0_W0_KEY0_MASK)
KEY0 - AES 128 key from software
◆ BEE_AES_KEY0_W1_KEY1
#define BEE_AES_KEY0_W1_KEY1 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W1_KEY1_SHIFT)) & BEE_AES_KEY0_W1_KEY1_MASK)
KEY1 - AES 128 key from software
◆ BEE_AES_KEY0_W2_KEY2
#define BEE_AES_KEY0_W2_KEY2 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W2_KEY2_SHIFT)) & BEE_AES_KEY0_W2_KEY2_MASK)
KEY2 - AES 128 key from software
◆ BEE_AES_KEY0_W3_KEY3
#define BEE_AES_KEY0_W3_KEY3 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_AES_KEY0_W3_KEY3_SHIFT)) & BEE_AES_KEY0_W3_KEY3_MASK)
KEY3 - AES 128 key from software
◆ BEE_CTRL_BEE_ENABLE
#define BEE_CTRL_BEE_ENABLE (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_BEE_ENABLE_SHIFT)) & BEE_CTRL_BEE_ENABLE_MASK)
BEE_ENABLE 0b0..Disable BEE 0b1..Enable BEE
◆ BEE_CTRL_CTRL_AES_MODE_R0
#define BEE_CTRL_CTRL_AES_MODE_R0 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R0_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R0_MASK)
CTRL_AES_MODE_R0 0b0..ECB 0b1..CTR
◆ BEE_CTRL_CTRL_AES_MODE_R1
#define BEE_CTRL_CTRL_AES_MODE_R1 (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_CTRL_AES_MODE_R1_SHIFT)) & BEE_CTRL_CTRL_AES_MODE_R1_MASK)
CTRL_AES_MODE_R1 0b0..ECB 0b1..CTR
◆ BEE_CTRL_KEY_REGION_SEL
#define BEE_CTRL_KEY_REGION_SEL (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_KEY_REGION_SEL_SHIFT)) & BEE_CTRL_KEY_REGION_SEL_MASK)
KEY_REGION_SEL 0b0..Load AES key for region0 0b1..Load AES key for region1
◆ BEE_CTRL_LITTLE_ENDIAN
#define BEE_CTRL_LITTLE_ENDIAN (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_CTRL_LITTLE_ENDIAN_SHIFT)) & BEE_CTRL_LITTLE_ENDIAN_MASK)
LITTLE_ENDIAN 0b0..The input and output data of the AES core is swapped as below: {B15,B14,B13,B12,B11,B10,B9,B8, B7,B6,B5,B4,B3,B2,B1,B0} swap to {B0,B1,B2,B3,B4,B5,B6,B7, B8,B9,B10,B11,B12,B13,B14,B15}, where B0~B15 refers to Byte0 to Byte15. 0b1..The input and output data of AES core is not swapped.
◆ BEE_REGION1_BOT_REGION1_BOT
#define BEE_REGION1_BOT_REGION1_BOT (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_REGION1_BOT_REGION1_BOT_SHIFT)) & BEE_REGION1_BOT_REGION1_BOT_MASK)
REGION1_BOT - Address lower limit of region1
◆ BEE_REGION1_TOP_REGION1_TOP
#define BEE_REGION1_TOP_REGION1_TOP (   x)    (((uint32_t)(((uint32_t)(x)) << BEE_REGION1_TOP_REGION1_TOP_SHIFT)) & BEE_REGION1_TOP_REGION1_TOP_MASK)
REGION1_TOP - Address upper limit of region1
◆ ENC_CTRL_CMPIE
#define ENC_CTRL_CMPIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIE_SHIFT)) & ENC_CTRL_CMPIE_MASK)
CMPIE - Compare Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_CMPIRQ
#define ENC_CTRL_CMPIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_CMPIRQ_SHIFT)) & ENC_CTRL_CMPIRQ_MASK)
CMPIRQ - Compare Interrupt Request 0b0..No match has occurred (the counter does not match the COMP value) 0b1..COMP match has occurred (the counter matches the COMP value)
◆ ENC_CTRL_DIE
#define ENC_CTRL_DIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIE_SHIFT)) & ENC_CTRL_DIE_MASK)
DIE - Watchdog Timeout Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_DIRQ
#define ENC_CTRL_DIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_DIRQ_SHIFT)) & ENC_CTRL_DIRQ_MASK)
DIRQ - Watchdog Timeout Interrupt Request 0b0..No Watchdog timeout interrupt has occurred 0b1..Watchdog timeout interrupt has occurred
◆ ENC_CTRL_HIE
#define ENC_CTRL_HIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIE_SHIFT)) & ENC_CTRL_HIE_MASK)
HIE - HOME Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_HIP
#define ENC_CTRL_HIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIP_SHIFT)) & ENC_CTRL_HIP_MASK)
HIP - Enable HOME to Initialize Position Counters UPOS and LPOS 0b0..No action 0b1..HOME signal initializes the position counter
◆ ENC_CTRL_HIRQ
#define ENC_CTRL_HIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HIRQ_SHIFT)) & ENC_CTRL_HIRQ_MASK)
HIRQ - HOME Signal Transition Interrupt Request 0b0..No transition on the HOME signal has occurred 0b1..A transition on the HOME signal has occurred
◆ ENC_CTRL_HNE
#define ENC_CTRL_HNE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_HNE_SHIFT)) & ENC_CTRL_HNE_MASK)
HNE - Use Negative Edge of HOME Input 0b0..Use positive-going edge-to-trigger initialization of position counters UPOS and LPOS 0b1..Use negative-going edge-to-trigger initialization of position counters UPOS and LPOS
◆ ENC_CTRL_PH1
#define ENC_CTRL_PH1 (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_PH1_SHIFT)) & ENC_CTRL_PH1_MASK)
PH1 - Enable Signal Phase Count Mode 0b0..Use the standard quadrature decoder, where PHASEA and PHASEB represent a two-phase quadrature signal. 0b1..Bypass the quadrature decoder. A positive transition of the PHASEA input generates a count signal. The PHASEB input and the REV bit control the counter direction: If CTRL[REV] = 0, PHASEB = 0, then count up If CTRL[REV] = 1, PHASEB = 1, then count up If CTRL[REV] = 0, PHASEB = 1, then count down If CTRL[REV] = 1, PHASEB = 0, then count down
◆ ENC_CTRL_REV
#define ENC_CTRL_REV (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_REV_SHIFT)) & ENC_CTRL_REV_MASK)
REV - Enable Reverse Direction Counting 0b0..Count normally 0b1..Count in the reverse direction
◆ ENC_CTRL_SWIP
#define ENC_CTRL_SWIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_SWIP_SHIFT)) & ENC_CTRL_SWIP_MASK)
SWIP - Software-Triggered Initialization of Position Counters UPOS and LPOS 0b0..No action 0b1..Initialize position counter (using upper and lower initialization registers, UINIT and LINIT)
◆ ENC_CTRL_WDE
#define ENC_CTRL_WDE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_WDE_SHIFT)) & ENC_CTRL_WDE_MASK)
WDE - Watchdog Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_XIE
#define ENC_CTRL_XIE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIE_SHIFT)) & ENC_CTRL_XIE_MASK)
XIE - INDEX Pulse Interrupt Enable 0b0..Disabled 0b1..Enabled
◆ ENC_CTRL_XIP
#define ENC_CTRL_XIP (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIP_SHIFT)) & ENC_CTRL_XIP_MASK)
XIP - INDEX Triggered Initialization of Position Counters UPOS and LPOS 0b0..INDEX pulse does not initialize the position counter 0b1..INDEX pulse initializes the position counter
◆ ENC_CTRL_XIRQ
#define ENC_CTRL_XIRQ (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XIRQ_SHIFT)) & ENC_CTRL_XIRQ_MASK)
XIRQ - INDEX Pulse Interrupt Request 0b0..INDEX pulse has not occurred 0b1..INDEX pulse has occurred
◆ ENC_CTRL_XNE
#define ENC_CTRL_XNE (   x)    (((uint16_t)(((uint16_t)(x)) << ENC_CTRL_XNE_SHIFT)) & ENC_CTRL_XNE_MASK)
XNE - Use Negative Edge of INDEX Pulse 0b0..Use positive edge of INDEX pulse 0b1..Use negative edge of INDEX pulse
◆ EWM_CTRL_ASSIN
#define EWM_CTRL_ASSIN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_ASSIN_SHIFT)) & EWM_CTRL_ASSIN_MASK)
ASSIN - EWM_in's Assertion State Select.
◆ EWM_CTRL_EWMEN
#define EWM_CTRL_EWMEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_EWMEN_SHIFT)) & EWM_CTRL_EWMEN_MASK)
EWMEN - EWM enable.
◆ EWM_CTRL_INEN
#define EWM_CTRL_INEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INEN_SHIFT)) & EWM_CTRL_INEN_MASK)
INEN - Input Enable.
◆ EWM_CTRL_INTEN
#define EWM_CTRL_INTEN (   x)    (((uint8_t)(((uint8_t)(x)) << EWM_CTRL_INTEN_SHIFT)) & EWM_CTRL_INTEN_MASK)
INTEN - Interrupt Enable.
◆ PWM_CTRL_COMPMODE
#define PWM_CTRL_COMPMODE (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_COMPMODE_SHIFT)) & PWM_CTRL_COMPMODE_MASK)
COMPMODE - Compare Mode 0b0..The VAL* registers and the PWM counter are compared using an "equal to" method. This means that PWM edges are only produced when the counter is equal to one of the VAL* register values. This implies that a PWMA output that is high at the end of a period will maintain this state until a match with VAL3 clears the output in the following period. 0b1..The VAL* registers and the PWM counter are compared using an "equal to or greater than" method. This means that PWM edges are produced when the counter is equal to or greater than one of the VAL* register values. This implies that a PWMA output that is high at the end of a period could go low at the start of the next period if the starting counter value is greater than (but not necessarily equal to) the new VAL3 value.
◆ PWM_CTRL_DBLEN
#define PWM_CTRL_DBLEN (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLEN_SHIFT)) & PWM_CTRL_DBLEN_MASK)
DBLEN - Double Switching Enable 0b0..Double switching disabled. 0b1..Double switching enabled.
◆ PWM_CTRL_DBLX
#define PWM_CTRL_DBLX (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DBLX_SHIFT)) & PWM_CTRL_DBLX_MASK)
DBLX - PWMX Double Switching Enable 0b0..PWMX double pulse disabled. 0b1..PWMX double pulse enabled.
◆ PWM_CTRL_DT
#define PWM_CTRL_DT (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_DT_SHIFT)) & PWM_CTRL_DT_MASK)
DT - Deadtime
◆ PWM_CTRL_FULL
#define PWM_CTRL_FULL (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_FULL_SHIFT)) & PWM_CTRL_FULL_MASK)
FULL - Full Cycle Reload 0b0..Full-cycle reloads disabled. 0b1..Full-cycle reloads enabled.
◆ PWM_CTRL_HALF
#define PWM_CTRL_HALF (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_HALF_SHIFT)) & PWM_CTRL_HALF_MASK)
HALF - Half Cycle Reload 0b0..Half-cycle reloads disabled. 0b1..Half-cycle reloads enabled.
◆ PWM_CTRL_LDFQ
#define PWM_CTRL_LDFQ (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDFQ_SHIFT)) & PWM_CTRL_LDFQ_MASK)
LDFQ - Load Frequency 0b0000..Every PWM opportunity 0b0001..Every 2 PWM opportunities 0b0010..Every 3 PWM opportunities 0b0011..Every 4 PWM opportunities 0b0100..Every 5 PWM opportunities 0b0101..Every 6 PWM opportunities 0b0110..Every 7 PWM opportunities 0b0111..Every 8 PWM opportunities 0b1000..Every 9 PWM opportunities 0b1001..Every 10 PWM opportunities 0b1010..Every 11 PWM opportunities 0b1011..Every 12 PWM opportunities 0b1100..Every 13 PWM opportunities 0b1101..Every 14 PWM opportunities 0b1110..Every 15 PWM opportunities 0b1111..Every 16 PWM opportunities
◆ PWM_CTRL_LDMOD
#define PWM_CTRL_LDMOD (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_LDMOD_SHIFT)) & PWM_CTRL_LDMOD_MASK)
LDMOD - Load Mode Select 0b0..Buffered registers of this submodule are loaded and take effect at the next PWM reload if MCTRL[LDOK] is set. 0b1..Buffered registers of this submodule are loaded and take effect immediately upon MCTRL[LDOK] being set. In this case it is not necessary to set CTRL[FULL] or CTRL[HALF].
◆ PWM_CTRL_PRSC
#define PWM_CTRL_PRSC (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_PRSC_SHIFT)) & PWM_CTRL_PRSC_MASK)
PRSC - Prescaler 0b000..PWM clock frequency = fclk 0b001..PWM clock frequency = fclk/2 0b010..PWM clock frequency = fclk/4 0b011..PWM clock frequency = fclk/8 0b100..PWM clock frequency = fclk/16 0b101..PWM clock frequency = fclk/32 0b110..PWM clock frequency = fclk/64 0b111..PWM clock frequency = fclk/128
◆ PWM_CTRL_SPLIT
#define PWM_CTRL_SPLIT (   x)    (((uint16_t)(((uint16_t)(x)) << PWM_CTRL_SPLIT_SHIFT)) & PWM_CTRL_SPLIT_MASK)
SPLIT - Split the DBLPWM signal to PWMA and PWMB 0b0..DBLPWM is not split. PWMA and PWMB each have double pulses. 0b1..DBLPWM is split to PWMA and PWMB.
