RTEMS 6.1-rc1
Files | Data Structures | Functions
Tests a fatal error. More...
file  tr-fatal-too-large-tls-size.c
file  tr-fatal-too-large-tls-size.h
struct  AcfgValFatalTooLargeTlsSize_Context
 Test context for spec:/acfg/val/fatal-too-large-tls-size test case. More...
void AcfgValFatalTooLargeTlsSize_Run (rtems_fatal_source source, rtems_fatal_code code)
 Runs the parameterized test case. More...
This test case performs the following actions:
◆ AcfgValFatalTooLargeTlsSize_Run()
void AcfgValFatalTooLargeTlsSize_Run ( rtems_fatal_source  source,
Parameters
sourceis fatal source.
codeis fatal code.
