RTEMS 6.1-rc1
Modules | Files | Macros | Variables
spec:/testsuites/fatal-too-large-tls-size
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
 spec:/acfg/val/fatal-too-large-tls-size
 Tests a fatal error.
file  ts-fatal-too-large-tls-size.c
#define FATAL_SYSINIT_RUN   AcfgValFatalTooLargeTlsSize_Run
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE    RTEMS_TASK_STORAGE_ALIGNMENT
const char rtems_test_name [] = "TestsuitesFatalTooLargeTlsSize"
 Each test must define a test name string.
