#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK (0x1U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT (0U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK (0x2U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT (1U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK (0x10000U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT (16U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK (0x40000000U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT (30U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK (0x3FEU) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT (1U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK (0x1C00U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT (10U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK (0x1FE000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT (13U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK (0x400000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT (22U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK (0x800000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT (23U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK (0x1000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT (24U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK (0x2000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT (25U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK (0x4000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT (26U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK (0x1U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT (0U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK (0x2U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT (1U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK (0x4U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT (2U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK (0x8U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT (3U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK (0x10U) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT (4U) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK (0xFU) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK (0xF0U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK (0x700U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK (0x3800U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK (0xFU) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK (0xF0U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK (0x700U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK (0x3800U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK (0x1U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT (0U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_ENABLE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK (0x2U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT (1U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK (0x10000U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT (16U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_TOGGLE_MASK) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK (0x40000000U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT (30U) |
#define | ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_LDO_PLL_LDO_PLL_AI_BUSY_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK (0x3FEU) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT (1U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_MD_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK (0x1C00U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT (10U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_PWR_SW_EN_1P8_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK (0x1FE000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT (13U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_ADJ_1P8_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK (0x400000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT (22U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_SOC_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK (0x800000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT (23U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_RBB_LPSR_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK (0x1000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT (24U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_EN_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK (0x2000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT (25U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_TST_DIG_OUT_MASK) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK (0x4000000U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT (26U) |
#define | ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_SHIFT)) & ANADIG_PMU_PMU_BIAS_CTRL2_WB_OK_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK (0x1U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT (0U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_TOGGLE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK (0x2U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT (1U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_AI_BUSY_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK (0x4U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT (2U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_ENABLE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK (0x8U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT (3U) |
#define | ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_REF_CONTROL_MODE_MASK) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK (0x10U) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT (4U) |
#define | ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_SHIFT)) & ANADIG_PMU_PMU_REF_CTRL_EN_PLL_VOL_REF_BUFFER_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_PLL_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_LP_MODE_SP_LP_MODE_SETPONIT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_ANA_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP0_VOLTAGE_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP1_VOLTAGE_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP2_VOLTAGE_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK (0xFFU) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK (0xFF00U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK (0xFF0000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT (16U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK (0xFF000000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT (24U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRG_SP3_VOLTAGE_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_LP_MODE_SP_LP_MODE_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_TRACKING_EN_SP_TRACKING_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_BYPASS_EN_SP_BYPASS_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_LDO_LPSR_DIG_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_ENABLE_SP_ON_OFF_SETPOINT15_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_BANDGAP_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_PLL_LDO_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_SOC_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK (0x1U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT0_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK (0x2U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT (1U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT1_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK (0x4U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT (2U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT2_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK (0x8U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT (3U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT3_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK (0x10U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT4_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK (0x20U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT (5U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT5_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK (0x40U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT (6U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT6_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK (0x80U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT (7U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT7_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK (0x100U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT8_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK (0x200U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT (9U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT9_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK (0x400U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT (10U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT10_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK (0x800U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT11_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK (0x1000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT (12U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT12_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK (0x2000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT (13U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT13_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK (0x4000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT (14U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT14_MASK) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK (0x8000U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT (15U) |
#define | ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_SHIFT)) & ANADIG_PMU_RBB_LPSR_STBY_EN_SP_STBY_EN_SETPOINT15_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK (0xFU) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT (0U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_PW_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK (0xF0U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT (4U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_WB_CFG_NW_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK (0x700U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT (8U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_OSCILLATOR_BITS_MASK) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK (0x3800U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT (11U) |
#define | ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_LPSR_CONFIGURE_REGULATOR_STRENGTH_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK (0xFU) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT (0U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_PW_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK (0xF0U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT (4U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_WB_CFG_NW_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK (0x700U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT (8U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_OSCILLATOR_BITS_MASK) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK (0x3800U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT (11U) |
#define | ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH(x) (((uint32_t)(((uint32_t)(x)) << ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_SHIFT)) & ANADIG_PMU_RBB_SOC_CONFIGURE_REGULATOR_STRENGTH_MASK) |
