RTEMS 6.1-rc1
confdefs Directory Reference
file  bdbuf.h [code]
 This header file evaluates configuration options related to the block device cache configuration.
file  bsp.h [code]
 This header file evaluates configuration options related to the BSP configuration.
file  clock.h [code]
 This header file evaluates configuration options related to the clock driver configuration.
file  console.h [code]
 This header file evaluates configuration options related to the console driver configuration.
file  extensions.h [code]
 This header file evaluates configuration options related to the user extensions configuration.
file  face.h [code]
 This header file evaluates configuration options related to the FACE Technical Standard.
file  inittask.h [code]
 This header file evaluates configuration options related to the Classic API initialization task configuration.
file  initthread.h [code]
 This header file evaluates configuration options related to the POSIX initialization thread configuration.
file  iodrivers.h [code]
 This header file evaluates configuration options related to the I/O driver configuration.
file  libio.h [code]
 This header file evaluates configuration options related to the I/O library configuration.
file  libpci.h [code]
 This header file evaluates configuration options related to the PCI library configuration.
file  malloc.h [code]
 This header file evaluates configuration options related to the C Program Heap configuration.
file  mpci.h [code]
 This header file evaluates configuration options related to the MPCI configuration.
file  newlib.h [code]
 This header file evaluates configuration options related to the Newlib C Library configuration.
file  objectsclassic.h [code]
 This header file evaluates configuration options related to the Classic API objects configuration.
file  objectsposix.h [code]
 This header file evaluates configuration options related to the POSIX API objects configuration.
file  obsolete.h [code]
 This header file evaluates configuration options related to obsolete configuration options.
file  percpu.h [code]
 This header file evaluates configuration options related to the per-CPU configuration.
file  scheduler.h [code]
 This header file evaluates configuration options related to the scheduler configuration.
file  threads.h [code]
 This header file evaluates configuration options related to the thread configuration.
file  unlimited.h [code]
 This header file evaluates configuration options related to the unlimited objects configuration.
file  wkspace.h [code]
 This header file evaluates configuration options related to the RTEMS Workspace configuration.
file  wkspacesupport.h [code]
 This header file provides support macros to evaluate configuration options related to the RTEMS Workspace configuration.
