RTEMS
6.1-rc1
include
confdefs
wkspacesupport.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2020 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_CONFDEFS_WKSPACESUPPORT_H
38
#define _RTEMS_CONFDEFS_WKSPACESUPPORT_H
39
40
#ifndef __CONFIGURATION_TEMPLATE_h
41
#error "Do not include this file directly, use <rtems/confdefs.h> instead"
42
#endif
43
44
#ifdef CONFIGURE_INIT
45
46
rtems/score/heap.h
47
48
#define _Configure_Zero_or_one( _number ) ( ( _number ) != 0 ? 1 : 0 )
49
50
#define _Configure_Align_up( _val, _align ) \
51
( ( ( _val ) + ( _align ) - 1) - ( ( _val ) + ( _align ) - 1 ) % ( _align ) )
52
53
#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
54
_Configure_Align_up( sizeof( Heap_Block ), CPU_HEAP_ALIGNMENT )
55
56
#define _Configure_From_workspace( _size ) \
57
( (uintptr_t) ( _Configure_Zero_or_one( _size ) \
58
* _Configure_Align_up( \
59
_size + HEAP_BLOCK_HEADER_SIZE, \
60
61
62
63
#endif
/* CONFIGURE_INIT */
64
65
#endif
/* _RTEMS_CONFDEFS_WKSPACESUPPORT_H */
heap.h
This header file provides interfaces of the Heap Handler which are used by the implementation and the...
