RTEMS 6.1-rc1
capture_support.c File Reference
RTEMS Performance Monitoring and Measurement Framework. More...
#include <ctype.h>
#include <inttypes.h>
#include <rtems/monitor.h>
#include <rtems/captureimpl.h>
struct  ctrace_per_cpu
struct  ctrace_task_name
struct  ctrace_tasks
#define CTRACE_TASK_BLOCK_SIZE   (64)
void rtems_capture_print_timestamp (uint64_t uptime)
 Capture print timestamp. More...
void rtems_capture_print_record_task (int cpu, const rtems_capture_record *rec, const rtems_capture_task_record *task_rec)
 Capture print record task. More...
void rtems_capture_print_record_capture (int cpu, const rtems_capture_record *rec, uint64_t diff, const rtems_name *name)
 Capture print capture record. More...
void rtems_capture_print_trace_records (int total, bool csv)
 Capture print trace records. More...
void rtems_capture_print_watch_list (void)
 Capture print watch list. More...
This is a set of print support routines that may be shared between the RTEMS monitor and direct callers of the capture engine.
◆ rtems_capture_print_record_capture()
void rtems_capture_print_record_capture ( int  cpu,
const rtems_capture_record rec,
uint64_t  diff,
const rtems_name name
This function prints a user extension capture record.
Parameters
[in]cpuspecifies the cpu the cpu the record was logged on.
[in]recspecifies the record.
[in]diffspecifies the time between this and the last capture record.
[in]namespecifies the name of the task, NULL if none.
[in]task_countnumber of tasks to search for.
◆ rtems_capture_print_record_task()
void rtems_capture_print_record_task ( int  cpu,
const rtems_capture_task_record task_rec
This function prints a capture record task. This record contains information to identify a task. It is refrenced in other records by the task id.
Parameters
[in]recspecifies the task record.
◆ rtems_capture_print_timestamp()
void rtems_capture_print_timestamp ( uint64_t  uptime)
This function prints uptime in a timestamp format.
Parameters
[in]uptimespecifies the timestamp to print
◆ rtems_capture_print_trace_records()
void rtems_capture_print_trace_records ( int  total,
bool  csv
This function reads, prints and releases up to total trace records in either a csv format or an ascii table format.
Parameters
[in]totalspecifies the number of records to print
[in]csvspecifies a comma seperated value format
◆ rtems_capture_print_watch_list()
void rtems_capture_print_watch_list ( void  )
This function prints a capture watch list
