RTEMS 6.1-rc1
monitor.h
2
9/*
10 * COPYRIGHT (C) 1989-1999 On-Line Applications Research Corporation (OAR).
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __MONITOR_H
35#define __MONITOR_H
36
38#include <rtems/error.h> /* rtems_error() */
39#include <rtems/config.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45/* Forward decls from symbols.h */
46typedef struct _rtems_symbol_t rtems_symbol_t;
48
49/*
50 * Monitor types are derived from rtems object classes
51 */
52
53typedef enum {
54 RTEMS_MONITOR_OBJECT_INVALID = OBJECTS_CLASSIC_NO_CLASS,
55 RTEMS_MONITOR_OBJECT_TASK = OBJECTS_RTEMS_TASKS,
56 RTEMS_MONITOR_OBJECT_EXTENSION = OBJECTS_RTEMS_EXTENSIONS,
57 RTEMS_MONITOR_OBJECT_QUEUE = OBJECTS_RTEMS_MESSAGE_QUEUES,
58 RTEMS_MONITOR_OBJECT_SEMAPHORE = OBJECTS_RTEMS_SEMAPHORES,
59 RTEMS_MONITOR_OBJECT_PARTITION = OBJECTS_RTEMS_PARTITIONS,
60 RTEMS_MONITOR_OBJECT_REGION = OBJECTS_RTEMS_REGIONS,
61 RTEMS_MONITOR_OBJECT_PORT = OBJECTS_RTEMS_PORTS,
62
63 /* following monitor objects are not known to RTEMS, but
64 * we like to have "types" for them anyway */
65
66 RTEMS_MONITOR_OBJECT_DRIVER = OBJECTS_RTEMS_CLASSES_LAST+1,
67 RTEMS_MONITOR_OBJECT_DNAME,
68 RTEMS_MONITOR_OBJECT_CONFIG,
69 RTEMS_MONITOR_OBJECT_INIT_TASK,
70 RTEMS_MONITOR_OBJECT_MPCI,
71 RTEMS_MONITOR_OBJECT_SYMBOL,
72 RTEMS_MONITOR_OBJECT_PTHREAD
73} rtems_monitor_object_type_t;
74
75/*
76 * rtems_monitor_init() flags
77 */
78
79#define RTEMS_MONITOR_SUSPEND 0x0001 /* suspend monitor on startup */
80#define RTEMS_MONITOR_GLOBAL 0x0002 /* monitor should be global */
81#define RTEMS_MONITOR_NOTASK 0x0004 /* do not start monitor task */
82#define RTEMS_MONITOR_NOSYMLOAD 0x0008 /* do not load symbols */
83#define RTEMS_MONITOR_WAITQUIT 0x0010 /* wait for monitor task to terminate */
84
85/*
86 * Public interfaces for RTEMS data structures monitor is aware of.
87 * These are only used by the monitor.
88 *
89 * NOTE:
90 * All the canonical objects that correspond to RTEMS managed "objects"
91 * must have an identical first portion with 'id' and 'name' fields.
92 *
93 * Others do not have that restriction, even tho we would like them to.
94 * This is because some of the canonical structures are almost too big
95 * for shared memory driver (eg: mpci) and we are nickel and diming it.
96 */
97
98/*
99 * Type of a pointer that may be a symbol
100 */
101
102#define MONITOR_SYMBOL_LEN 20
103typedef struct {
104 char name[MONITOR_SYMBOL_LEN];
105 uint32_t value;
106 uint32_t offset;
108
109typedef struct {
110 rtems_id id;
111 rtems_name name;
112 /* end of common portion */
114
115/*
116 * Task
117 */
118typedef struct {
119 rtems_id id;
120 rtems_name name;
121 /* end of common portion */
122 char short_name[5];
123 char long_name[16];
125 void *stack;
126 uint32_t stack_size;
127 char scheduler_name[5];
128 rtems_task_priority priority;
129 States_Control state;
130 rtems_event_set events;
131 rtems_mode modes;
132 rtems_attribute attributes;
133 char wait[17];
134 uint32_t ticks;
136
137/*
138 * Init task
139 */
140
141typedef struct {
142 rtems_id id; /* not really an id */
143 rtems_name name;
144 /* end of common portion */
146 uint32_t argument;
147 uint32_t stack_size;
148 rtems_task_priority priority;
149 rtems_mode modes;
150 rtems_attribute attributes;
152
153
154/*
155 * Message queue
156 */
157typedef struct {
158 rtems_id id;
159 rtems_name name;
160 /* end of common portion */
161 rtems_attribute attributes;
162 uint32_t number_of_pending_messages;
163 uint32_t maximum_pending_messages;
164 size_t maximum_message_size;
166
167/*
168 * Semaphore
169 */
170typedef struct {
171 rtems_id id;
172 rtems_name name;
173 /* end of common portion */
174 rtems_attribute attribute;
175 rtems_task_priority priority_ceiling;
176 uint32_t max_count;
177 uint32_t cur_count;
178 rtems_id holder_id;
180
181/*
182 * Extension
183 */
184typedef struct {
185 rtems_id id;
186 rtems_name name;
187 /* end of common portion */
188 rtems_monitor_symbol_t e_create;
190 rtems_monitor_symbol_t e_restart;
191 rtems_monitor_symbol_t e_delete;
192 rtems_monitor_symbol_t e_tswitch;
194 rtems_monitor_symbol_t e_exitted;
197
198 /*
199 * Region
200 */
201typedef struct {
202 rtems_id id;
203 rtems_name name;
204 /* end of common portion */
205 rtems_attribute attribute;
206 void * start_addr;
207 uint32_t length;
208 uint32_t page_size;
209 uint32_t max_seg_size;
210 uint32_t used_blocks;
212
213/*
214 * Partition
215 */
216typedef struct {
217 rtems_id id;
218 rtems_name name;
219 /* end of common portion */
220 rtems_attribute attribute;
221 const void * start_addr;
222 uint32_t length;
223 uint32_t buf_size;
224 uint32_t used_blocks;
226
227/*
228 * Device driver
229 */
230
231typedef struct {
232 rtems_id id; /* not really an id (should be tho) */
233 rtems_name name; /* ditto */
234 /* end of common portion */
235 rtems_monitor_symbol_t initialization; /* initialization procedure */
236 rtems_monitor_symbol_t open; /* open request procedure */
237 rtems_monitor_symbol_t close; /* close request procedure */
238 rtems_monitor_symbol_t read; /* read request procedure */
239 rtems_monitor_symbol_t write; /* write request procedure */
240 rtems_monitor_symbol_t control; /* special functions procedure */
242
243/*
244 * System config
245 */
246
247typedef struct {
248 void *work_space_start;
249 uint32_t work_space_size;
250 uint32_t maximum_tasks;
251 uint32_t maximum_timers;
252 uint32_t maximum_semaphores;
253 uint32_t maximum_message_queues;
254 uint32_t maximum_partitions;
255 uint32_t maximum_regions;
256 uint32_t maximum_ports;
257 uint32_t maximum_periods;
258 uint32_t maximum_extensions;
259 uint32_t microseconds_per_tick;
260 uint32_t ticks_per_timeslice;
261 uint32_t number_of_initialization_tasks;
263
264/*
265 * MPCI config
266 */
267
268#if defined(RTEMS_MULTIPROCESSING)
269typedef struct {
270 uint32_t node; /* local node number */
271 uint32_t maximum_nodes; /* maximum # nodes in system */
272 uint32_t maximum_global_objects; /* maximum # global objects */
273 uint32_t maximum_proxies; /* maximum # proxies */
274
275 uint32_t default_timeout; /* in ticks */
276 size_t maximum_packet_size;
277 rtems_monitor_symbol_t initialization;
278 rtems_monitor_symbol_t get_packet;
279 rtems_monitor_symbol_t return_packet;
280 rtems_monitor_symbol_t send_packet;
281 rtems_monitor_symbol_t receive_packet;
282} rtems_monitor_mpci_t;
283#endif
284
285/*
286 * The generic canonical information union
287 */
288
289typedef union {
299#if defined(RTEMS_MULTIPROCESSING)
300 rtems_monitor_mpci_t mpci;
301#endif
304
305/*
306 * Support for talking to other monitors
307 */
308
309/*
310 * Names of other monitors
311 */
312
313#define RTEMS_MONITOR_NAME (rtems_build_name('R', 'M', 'O', 'N'))
314#define RTEMS_MONITOR_SERVER_NAME (rtems_build_name('R', 'M', 'S', 'V'))
315#define RTEMS_MONITOR_QUEUE_NAME (rtems_build_name('R', 'M', 'S', 'Q'))
316#define RTEMS_MONITOR_RESPONSE_QUEUE_NAME (rtems_build_name('R', 'M', 'R', 'Q'))
317
318#define RTEMS_MONITOR_SERVER_RESPONSE 0x0001
319#define RTEMS_MONITOR_SERVER_CANONICAL 0x0002
320
321typedef struct
322{
323 uint32_t command;
324 rtems_id return_id;
325 uint32_t argument0;
326 uint32_t argument1;
327 uint32_t argument2;
328 uint32_t argument3;
329 uint32_t argument4;
330 uint32_t argument5;
332
333typedef struct
334{
335 uint32_t command;
336 uint32_t result0;
337 uint32_t result1;
338 rtems_monitor_union_t payload;
340
341extern rtems_id rtems_monitor_task_id;
342
343extern uint32_t rtems_monitor_node; /* our node number */
344extern uint32_t rtems_monitor_default_node; /* current default for commands */
345
346/*
347 * Monitor command function and table entry
348 */
349
352
353typedef void (*rtems_monitor_command_function_t)(
354 int argc,
355 char **argv,
356 const rtems_monitor_command_arg_t *command_arg,
357 bool verbose
358);
359
361 rtems_monitor_object_type_t monitor_object;
362 rtems_status_code status_code;
363 rtems_symbol_table_t **symbol_table;
364 const rtems_monitor_command_entry_t *monitor_command_entry;
365};
366
368 const char *command; /* command name */
369 const char *usage; /* usage string for the command */
370 uint32_t arguments_required; /* # of required args */
371 rtems_monitor_command_function_t command_function;
372 /* Some argument for the command */
373 rtems_monitor_command_arg_t command_arg;
375};
376
377
378typedef const void *(*rtems_monitor_object_next_fn)(void *, void *, rtems_id *);
379typedef void (*rtems_monitor_object_canonical_fn)(void *, const void *);
380typedef void (*rtems_monitor_object_dump_header_fn)(bool);
381typedef void (*rtems_monitor_object_dump_fn)(void *, bool);
382
383typedef struct {
384 rtems_monitor_object_type_t type;
385 void *object_information;
386 int size; /* of canonical object */
387 rtems_monitor_object_next_fn next;
388 rtems_monitor_object_canonical_fn canonical;
389 rtems_monitor_object_dump_header_fn dump_header;
390 rtems_monitor_object_dump_fn dump;
392
393typedef bool (*rtems_monitor_per_command_routine)(const rtems_monitor_command_entry_t *, void *);
394
395/* monitor.c */
396void rtems_monitor_pause_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
397void rtems_monitor_fatal_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
398void rtems_monitor_continue_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
399void rtems_monitor_debugger_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
400void rtems_monitor_reset_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
401void rtems_monitor_node_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
402void rtems_monitor_symbols_loadup(void);
403int rtems_monitor_insert_cmd(rtems_monitor_command_entry_t *);
404void rtems_monitor_wakeup(void);
405void rtems_monitor_command_iterate(rtems_monitor_per_command_routine routine, void *arg);
406rtems_status_code rtems_monitor_suspend(rtems_interval timeout);
407
408/* editor.c */
409void rtems_monitor_kill(void);
410void rtems_monitor_init(uint32_t);
411void rtems_monitor_task(rtems_task_argument);
412
413/* server.c */
414void rtems_monitor_server_kill(void);
415rtems_status_code rtems_monitor_server_request(uint32_t , rtems_monitor_server_request_t *, rtems_monitor_server_response_t *);
416void rtems_monitor_server_task(rtems_task_argument);
417void rtems_monitor_server_init(uint32_t);
418
419/* command.c */
420int rtems_monitor_make_argv(char *, int *, char **);
421int rtems_monitor_command_read(char *, int *, char **);
422void rtems_monitor_command_usage(const rtems_monitor_command_entry_t *, const char *);
423void rtems_monitor_help_cmd(int, char **, const rtems_monitor_command_arg_t *, bool);
425
426/* prmisc.c */
427void rtems_monitor_separator(void);
428uint32_t rtems_monitor_pad(uint32_t dest_col, uint32_t curr_col);
429int rtems_monitor_dump_decimal(uint32_t num);
430int rtems_monitor_dump_hex(uint32_t num);
431int rtems_monitor_dump_addr(const void *addr);
432int rtems_monitor_dump_id(rtems_id id);
433int rtems_monitor_dump_name(rtems_id id);
434int rtems_monitor_dump_priority(rtems_task_priority priority);
435int rtems_monitor_dump_state(States_Control state);
436int rtems_monitor_dump_modes(rtems_mode modes);
437int rtems_monitor_dump_attributes(rtems_attribute attributes);
438int rtems_monitor_dump_events(rtems_event_set events);
439
440/* object.c */
441rtems_id rtems_monitor_id_fixup(rtems_id, uint32_t , rtems_monitor_object_type_t);
442const rtems_monitor_object_info_t *rtems_monitor_object_lookup(rtems_monitor_object_type_t type);
443rtems_id rtems_monitor_object_canonical_get(rtems_monitor_object_type_t, rtems_id, void *, size_t *size_p);
444rtems_id rtems_monitor_object_canonical_next(const rtems_monitor_object_info_t *, rtems_id, void *);
445const void *rtems_monitor_object_next(void *, void *, rtems_id, rtems_id *);
446rtems_id rtems_monitor_object_canonical(rtems_id, const void *);
447void rtems_monitor_object_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
448
449/* manager.c */
450const void *rtems_monitor_manager_next(void *, void *, rtems_id *);
451
452/* config.c */
453void rtems_monitor_config_canonical(rtems_monitor_config_t *, const void *);
454const void *rtems_monitor_config_next(void *, rtems_monitor_config_t *, rtems_id *);
455void rtems_monitor_config_dump_header(bool);
456int rtems_monitor_config_dump(rtems_monitor_config_t *, bool verbose);
457
458/* mpci.c */
459#if defined(RTEMS_MULTIPROCESSING)
460void rtems_monitor_mpci_canonical(rtems_monitor_mpci_t *, const void *);
461const void *rtems_monitor_mpci_next(void *, rtems_monitor_mpci_t *, rtems_id *);
462void rtems_monitor_mpci_dump_header(bool);
463void rtems_monitor_mpci_dump(rtems_monitor_mpci_t *, bool verbose);
464#endif
465
466/* itask.c */
467void rtems_monitor_init_task_canonical(rtems_monitor_init_task_t *, const void *);
468const void *rtems_monitor_init_task_next(void *, rtems_monitor_init_task_t *, rtems_id *);
469void rtems_monitor_init_task_dump_header(bool);
470void rtems_monitor_init_task_dump(rtems_monitor_init_task_t *, bool verbose);
471
472/* extension.c */
473void rtems_monitor_extension_canonical(rtems_monitor_extension_t *, const void *);
474void rtems_monitor_extension_dump_header(bool verbose);
475void rtems_monitor_extension_dump(rtems_monitor_extension_t *, bool);
476
477/* task.c */
478void rtems_monitor_task_canonical(rtems_monitor_task_t *, const void *);
479void rtems_monitor_task_dump_header(bool verbose);
480void rtems_monitor_task_dump(rtems_monitor_task_t *, bool);
481
482/* sema.c */
483void rtems_monitor_sema_canonical(rtems_monitor_sema_t *, const void *);
484void rtems_monitor_sema_dump_header(bool verbose);
485void rtems_monitor_sema_dump(rtems_monitor_sema_t *, bool);
486
487/* queue.c */
488void rtems_monitor_queue_canonical(rtems_monitor_queue_t *, const void *);
489void rtems_monitor_queue_dump_header(bool verbose);
490void rtems_monitor_queue_dump(rtems_monitor_queue_t *, bool);
491
492/* region.c */
493void rtems_monitor_region_canonical(rtems_monitor_region_t *, const void *);
494void rtems_monitor_region_dump_header(bool verbose);
495void rtems_monitor_region_dump(rtems_monitor_region_t *, bool);
496
497/* partition.c */
498void rtems_monitor_part_canonical(rtems_monitor_part_t *, const void *);
499void rtems_monitor_part_dump_header(bool verbose);
500void rtems_monitor_part_dump(rtems_monitor_part_t *, bool);
501
502/* driver.c */
503const void *rtems_monitor_driver_next(void *, rtems_monitor_driver_t *, rtems_id *);
504void rtems_monitor_driver_canonical(rtems_monitor_driver_t *, const void *);
505void rtems_monitor_driver_dump_header(bool);
506void rtems_monitor_driver_dump(rtems_monitor_driver_t *, bool);
507
508/* symbols.c */
509rtems_symbol_table_t *rtems_symbol_table_create(void);
510void rtems_symbol_table_destroy(rtems_symbol_table_t *table);
511
512rtems_symbol_t *rtems_symbol_create(rtems_symbol_table_t *, const char *, uint32_t);
513rtems_symbol_t *rtems_symbol_value_lookup(rtems_symbol_table_t *, uint32_t);
514const rtems_symbol_t *rtems_symbol_value_lookup_exact(rtems_symbol_table_t *, uint32_t);
515rtems_symbol_t *rtems_symbol_name_lookup(rtems_symbol_table_t *, const char *);
516const void *rtems_monitor_symbol_next(void *object_info, rtems_monitor_symbol_t *, rtems_id *);
517void rtems_monitor_symbol_canonical(rtems_monitor_symbol_t *, rtems_symbol_t *);
518void rtems_monitor_symbol_canonical_by_name(rtems_monitor_symbol_t *, const char *);
519void rtems_monitor_symbol_canonical_by_value(rtems_monitor_symbol_t *, void *);
520uint32_t rtems_monitor_symbol_dump(rtems_monitor_symbol_t *, bool);
521void rtems_monitor_symbol_cmd(int, char **, const rtems_monitor_command_arg_t*, bool);
522
523#if defined(RTEMS_NETWORKING)
524void mon_ifconfig(
525 int argc,
526 char *argv[],
527 uint32_t command_arg,
528 bool verbose
529);
530void mon_route(
531 int argc,
532 char *argv[],
533 uint32_t command_arg,
534 bool verbose
535);
536#endif
537
538/* mon-object.c */
539const rtems_monitor_object_info_t *rtems_monitor_object_lookup(
540 rtems_monitor_object_type_t type
541);
542
543/* shared data */
544extern rtems_symbol_table_t *rtems_monitor_symbols;
545
546#define MONITOR_WAKEUP_EVENT RTEMS_EVENT_0
547
548#ifdef __cplusplus
549}
550#endif
551
552#endif /* ! __MONITOR_H */
RTEMS Error Reporting.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
uint32_t rtems_event_set
This integer type represents a bit field which can hold exactly 32 individual events.
Definition: event.h:436
uint32_t rtems_mode
This type represents a Classic API task mode set.
Definition: modes.h:174
rtems_status_code
Definition: status.h:85
CPU_Uint32ptr rtems_task_argument
This integer type represents task argument values.
Definition: tasks.h:100
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
#define OBJECTS_RTEMS_CLASSES_LAST
Definition: objectimpl.h:72
uint32_t States_Control
Definition: states.h:65
ssize_t read(int fd, void *buffer, size_t count)
Definition: read.c:46
ssize_t write(int fd, const void *buffer, size_t count)
Definition: write.c:49
const rtems_monitor_command_entry_t * rtems_monitor_command_lookup(const char *name)
Looks for a command with the name name in the list of registered commands.
Definition: mon-command.c:244
Iterates through all registerd commands.
Definition: mon-monitor.c:512
int open(const char *path, int oflag,...)
Definition: open.c:171
This header file provides interfaces of the Object Handler which are only used by the implementation.
Thread entry information.
Definition: thread.h:140
Definition: symbols.h:45
Definition: symbols.h:56
Definition: deflate.c:114
Definition: intercom.c:87
Definition: mmu-config.c:53
Definition: monitor.h:367
Definition: monitor.h:247
Definition: monitor.h:231
Definition: monitor.h:184
Definition: monitor.h:109
Definition: monitor.h:141
Definition: monitor.h:383
Definition: monitor.h:216
Definition: monitor.h:157
Definition: monitor.h:201
Definition: monitor.h:170
Definition: monitor.h:322
Definition: monitor.h:334
Definition: monitor.h:103
Definition: monitor.h:118
unsigned size
Definition: tte.h:1
Definition: monitor.h:360
Definition: monitor.h:289
