RTEMS 6.3
t-test-rtems-objs.c File Reference
This source file contains the implementation of the RTEMS objects test support. More...
#include "t-test-rtems.h"
#include <rtems/test.h>
#include <inttypes.h>
T_thread_timer_state T_get_thread_timer_state (uint32_t id)
Objects_Maximum T_objects_count (Objects_APIs api, uint16_t cls)
void T_objects_check (Objects_APIs api, uint16_t cls, Objects_Maximum *expected, const char *name)
void T_check_rtems_barriers (T_event event, const char *name)
void T_check_rtems_extensions (T_event event, const char *name)
void T_check_rtems_message_queues (T_event event, const char *name)
void T_check_rtems_partitions (T_event event, const char *name)
void T_check_rtems_periods (T_event event, const char *name)
void T_check_rtems_regions (T_event event, const char *name)
void T_check_rtems_semaphores (T_event event, const char *name)
void T_check_rtems_tasks (T_event event, const char *name)
void T_check_rtems_timers (T_event event, const char *name)
void * T_seize_objects (rtems_status_code(*create)(void *, uint32_t *), void *arg)
void T_surrender_objects (void **objects_p, rtems_status_code(*delete)(uint32_t))
