RTEMS 6.3
#include <arch/mm/tte.h>#include <arch/mm/mmu.h>#include <arch/mm/page.h>#include <arch/asm.h>#include <arch/barrier.h>#include <arch/types.h>#include <arch/register.h>#include <arch/cpu.h>Go to the source code of this file.
| union | tlb_context_reg |
| union | tlb_tag_read_reg |
| union | tlb_demap_addr |
| union | tlb_sfsr_reg |
| #define | MEM_CONTEXT_KERNEL 0 |
| #define | MEM_CONTEXT_TEMP 1 |
| #define | PAGESIZE_8K 0 |
| #define | PAGESIZE_64K 1 |
| #define | PAGESIZE_512K 2 |
| #define | PAGESIZE_4M 3 |
| #define | KERNEL_PAGE_WIDTH 22 |
| #define | TLB_DEMAP_PAGE 0 |
| #define | TLB_DEMAP_CONTEXT 1 |
| #define | TLB_DEMAP_TYPE_SHIFT 6 |
| #define | TLB_DEMAP_PRIMARY 0 |
| #define | TLB_DEMAP_SECONDARY 1 |
| #define | TLB_DEMAP_NUCLEUS 2 |
| #define | TLB_DEMAP_CONTEXT_SHIFT 4 |
| #define | TLB_TAG_ACCESS_CONTEXT_SHIFT 0 |
| #define | TLB_TAG_ACCESS_CONTEXT_MASK ((1 << 13) - 1) |
| #define | TLB_TAG_ACCESS_VPN_SHIFT 13 |
Typedefs | |
| typedef union tlb_context_reg | tlb_context_reg_t |
| typedef tte_data_t | tlb_data_t |
| typedef union tlb_tag_read_reg | tlb_tag_read_reg_t |
| typedef union tlb_tag_read_reg | tlb_tag_access_reg_t |
| typedef union tlb_demap_addr | tlb_demap_addr_t |
| typedef union tlb_sfsr_reg | tlb_sfsr_reg_t |
| unsigned | long |
| unsigned | context |
| uint64_t | vpn |
| unsigned | __pad0__ |
| unsigned | e |
| unsigned | ct |
| unsigned | pr |
| unsigned | w |
| unsigned | ow |
| unsigned | fv |
| unsigned __pad0__ |
Zero.
| unsigned context |
Context/ASID.
Context identifier.
Context register selection.
| unsigned ct |
Context Register selection.
| unsigned e |
Side-effect bit.
| unsigned fv |
Fault Valid bit.
| unsigned ow |
Overwrite bit.
| unsigned pr |
Privilege bit.
| uint64_t vpn |
Virtual Address bits 63:13.
| unsigned w |
Write bit.
