RTEMS 6.3
MM. More...
| union | tlb_context_reg |
| union | tlb_tag_read_reg |
| union | tlb_demap_addr |
| union | tlb_sfsr_reg |
| union | tte_tag |
| union | tte_data |
| #define | DCACHE_LINE_SIZE 32 |
| #define | MMU_PAGE_WIDTH MMU_FRAME_WIDTH |
| #define | MMU_PAGE_SIZE MMU_FRAME_SIZE |
| #define | PAGE_WIDTH FRAME_WIDTH |
| #define | PAGE_SIZE FRAME_SIZE |
| #define | MMU_PAGES_PER_PAGE (1 << (PAGE_WIDTH - MMU_PAGE_WIDTH)) |
| #define | MMU_FRAME_WIDTH 13 |
| #define | MMU_FRAME_SIZE (1 << MMU_FRAME_WIDTH) |
| #define | FRAME_WIDTH 14 |
| #define | FRAME_SIZE (1 << FRAME_WIDTH) |
| #define | ASI_IMMU 0x50 |
| #define | ASI_IMMU_TSB_8KB_PTR_REG 0x51 |
| #define | ASI_IMMU_TSB_64KB_PTR_REG 0x52 |
| #define | ASI_ITLB_DATA_IN_REG 0x54 |
| #define | ASI_ITLB_DATA_ACCESS_REG 0x55 |
| #define | ASI_ITLB_TAG_READ_REG 0x56 |
| #define | ASI_IMMU_DEMAP 0x57 |
| #define | VA_IMMU_TSB_TAG_TARGET 0x0 |
| #define | VA_IMMU_SFSR 0x18 |
| #define | VA_IMMU_TSB_BASE 0x28 |
| #define | VA_IMMU_TAG_ACCESS 0x30 |
| #define | ASI_DMMU 0x58 |
| #define | ASI_DMMU_TSB_8KB_PTR_REG 0x59 |
| #define | ASI_DMMU_TSB_64KB_PTR_REG 0x5a |
| #define | ASI_DMMU_TSB_DIRECT_PTR_REG 0x5b |
| #define | ASI_DTLB_DATA_IN_REG 0x5c |
| #define | ASI_DTLB_DATA_ACCESS_REG 0x5d |
| #define | ASI_DTLB_TAG_READ_REG 0x5e |
| #define | ASI_DMMU_DEMAP 0x5f |
| #define | VA_DMMU_TSB_TAG_TARGET 0x0 |
| #define | VA_PRIMARY_CONTEXT_REG 0x8 |
| #define | VA_SECONDARY_CONTEXT_REG 0x10 |
| #define | VA_DMMU_SFSR 0x18 |
| #define | VA_DMMU_SFAR 0x20 |
| #define | VA_DMMU_TSB_BASE 0x28 |
| #define | VA_DMMU_TAG_ACCESS 0x30 |
| #define | VA_DMMU_VA_WATCHPOINT_REG 0x38 |
| #define | VA_DMMU_PA_WATCHPOINT_REG 0x40 |
| #define | MEM_CONTEXT_KERNEL 0 |
| #define | MEM_CONTEXT_TEMP 1 |
| #define | PAGESIZE_8K 0 |
| #define | PAGESIZE_64K 1 |
| #define | PAGESIZE_512K 2 |
| #define | PAGESIZE_4M 3 |
| #define | KERNEL_PAGE_WIDTH 22 |
| #define | TLB_DEMAP_PAGE 0 |
| #define | TLB_DEMAP_CONTEXT 1 |
| #define | TLB_DEMAP_TYPE_SHIFT 6 |
| #define | TLB_DEMAP_PRIMARY 0 |
| #define | TLB_DEMAP_SECONDARY 1 |
| #define | TLB_DEMAP_NUCLEUS 2 |
| #define | TLB_DEMAP_CONTEXT_SHIFT 4 |
| #define | TLB_TAG_ACCESS_CONTEXT_SHIFT 0 |
| #define | TLB_TAG_ACCESS_CONTEXT_MASK ((1 << 13) - 1) |
| #define | TLB_TAG_ACCESS_VPN_SHIFT 13 |
| #define | TTE_G (1 << 0) |
| #define | TTE_W (1 << 1) |
| #define | TTE_P (1 << 2) |
| #define | TTE_E (1 << 3) |
| #define | TTE_CV (1 << 4) |
| #define | TTE_CP (1 << 5) |
| #define | TTE_L (1 << 6) |
| #define | TTE_V_SHIFT 63 |
| #define | TTE_SIZE_SHIFT 61 |
| #define | VA_TAG_PAGE_SHIFT 22 |
Typedefs | |
| typedef union tlb_context_reg | tlb_context_reg_t |
| typedef tte_data_t | tlb_data_t |
| typedef union tlb_tag_read_reg | tlb_tag_read_reg_t |
| typedef union tlb_tag_read_reg | tlb_tag_access_reg_t |
| typedef union tlb_demap_addr | tlb_demap_addr_t |
| typedef union tlb_sfsr_reg | tlb_sfsr_reg_t |
| typedef union tte_tag | tte_tag_t |
| typedef union tte_data | tte_data_t |
MM.
| #define KERNEL_PAGE_WIDTH 22 |
Bit width of the TLB-locked portion of kernel address space.
| #define MEM_CONTEXT_KERNEL 0 |
TLB_DSMALL is the only of the three DMMUs that can hold locked entries.
| #define PAGESIZE_8K 0 |
Page sizes.
| #define VA_DMMU_PA_WATCHPOINT_REG 0x40 |
DMMU PA data watchpoint register.
| #define VA_DMMU_SFAR 0x20 |
DMMU sync fault address register.
| #define VA_DMMU_SFSR 0x18 |
DMMU sync fault status register.
| #define VA_DMMU_TAG_ACCESS 0x30 |
DMMU TLB tag access register.
| #define VA_DMMU_TSB_BASE 0x28 |
DMMU TSB base register.
| #define VA_DMMU_TSB_TAG_TARGET 0x0 |
DMMU TSB tag target register.
| #define VA_DMMU_VA_WATCHPOINT_REG 0x38 |
DMMU VA data watchpoint register.
| #define VA_IMMU_SFSR 0x18 |
IMMU sync fault status register.
| #define VA_IMMU_TAG_ACCESS 0x30 |
IMMU TLB tag access register.
| #define VA_IMMU_TSB_BASE 0x28 |
IMMU TSB base register.
| #define VA_IMMU_TSB_TAG_TARGET 0x0 |
IMMU TSB tag target register.
| #define VA_PRIMARY_CONTEXT_REG 0x8 |
DMMU primary context register.
| #define VA_SECONDARY_CONTEXT_REG 0x10 |
DMMU secondary context register.
| typedef tte_data_t tlb_data_t |
I-/D-TLB Data In/Access Register type.
