#define | ASI_AIUP 0x10 /** Access to primary context with user privileges. */ |
#define | ASI_AIUS 0x11 /** Access to secondary context with user privileges. */ |
#define | NWINDOWS 8 /** Number of register window sets. */ |
#define | VMA 0x4000 |
#define | LMA VMA |
#define | TASKMAP_MAX_RECORDS 32 |
#define | MEMMAP_MAX_RECORDS 32 |
#define | BOOTINFO_TASK_NAME_BUFLEN 32 |
#define | PSTATE_IE_BIT (1 << 1) |
#define | PSTATE_AM_BIT (1 << 3) |
#define | PSTATE_AG_BIT (1 << 0) |
#define | PSTATE_IG_BIT (1 << 11) |
#define | PSTATE_MG_BIT (1 << 10) |
#define | PSTATE_PRIV_BIT (1 << 2) |
#define | PSTATE_PEF_BIT (1 << 4) |
#define | TSTATE_PSTATE_SHIFT 8 |
#define | TSTATE_PRIV_BIT (PSTATE_PRIV_BIT << TSTATE_PSTATE_SHIFT) |
#define | TSTATE_IE_BIT (PSTATE_IE_BIT << TSTATE_PSTATE_SHIFT) |
#define | TSTATE_PEF_BIT (PSTATE_PEF_BIT << TSTATE_PSTATE_SHIFT) |
#define | TSTATE_CWP_MASK 0x1f |
| #define | WSTATE_NORMAL(n) |
| #define | WSTATE_OTHER(n) |
#define | ICBUS_CONFIG_MID_SHIFT 17 |
#define | STACK_ITEM_SIZE 8 |
| #define | STACK_ALIGNMENT 16 |
| #define | STACK_WINDOW_SAVE_AREA_SIZE (16 * STACK_ITEM_SIZE) |
| #define | STACK_ARG_SAVE_AREA_SIZE (6 * STACK_ITEM_SIZE) |
| #define | STACK_BIAS 2047 |
#define | STACK_ARG0 0 |
#define | STACK_ARG1 8 |
#define | STACK_ARG2 16 |
#define | STACK_ARG3 24 |
#define | STACK_ARG4 32 |
#define | STACK_ARG5 40 |
#define | STACK_ARG6 48 |
#define | ASI_NUCLEUS_QUAD_LDD 0x24 /** ASI for 16-byte atomic loads. */ |
#define | ASI_DCACHE_TAG 0x47 /** ASI D-Cache Tag. */ |
#define | ASI_ICBUS_CONFIG 0x4a /** ASI of the UPA_CONFIG/FIREPLANE_CONFIG register. */ |
SPARC64 Board Support Packages.
