RTEMS 6.3
i2c_rtc_base Struct Reference
#include <i2c-rtc.h>
struct  [struct].order
rtems_mutex mutex
const char * i2c_bus_path
uint8_t i2c_addr
bool initialized
int(*) hw_init (struct i2c_rtc_base *ctx)
size_t clock_offset
struct  order
Base context for the driver.
Field Documentation
◆ clock_offset
size_t i2c_rtc_base::clock_offset
Offset of the start of the clock register block.
◆ hw_init
int(*) i2c_rtc_base::hw_init(struct i2c_rtc_base *ctx)
Hardware initialization function. Will be called once when the RTC is used for the first time. Can return 0 on success or anything else on error. In an error case, it will be called again on the next use.
◆ i2c_addr
uint8_t i2c_rtc_base::i2c_addr
I2C address.
◆ i2c_bus_path
const char* i2c_rtc_base::i2c_bus_path
The path of the I2C bus device.
◆ initialized
bool i2c_rtc_base::initialized
Whether the RTC has already been initialized. Used internally.
◆ mutex
rtems_mutex i2c_rtc_base::mutex
Just initialize with RTEMS_MUTEX_INITIALIZER('mcp7940').
